QUOTE (редактор @ Sep 6 2012, 09:44)
для получения 32-битного указателя требовалось ключевое сово far (расширение компилятора а не стандарт).
Но от этого он не переставал быть указателем.
Да и что спорить? Стандарт говорит:
QUOTE
6.3.2.3 Pointers
3 An integer constant expression with the value 0, or such an expression cast to type
void *, is called a null pointer constant.
5 An integer may be converted to any pointer type. Except as previously specified, the
result is implementation-defined, might not be correctly aligned, might not point to an
entity of the referenced type, and might be a trap representation.
6 Any pointer type may be converted to an integer type. Except as previously specified, the
result is implementation-defined. If the result cannot be represented in the integer type,
the behavior is undefined. The result need not be in the range of values of any integer
type.
