> Spartan6 не дает развести DCM
ovs_pavel
сообщение Sep 14 2012, 09:31
Пользователь №: 17 249
Вываливает такую ошибку:
Phase 4.2 Initial Placement for Architecture Specific Features ERROR:Place:1238 - Component "U9/DCM_SP_Clk_25_MHz" does not have a feasible site.
There are 12 potential locations for the component:
Location "DCM_X0Y1" cannot be used to place the component due to following error condition(s):
ERROR:Place:1201 - Component <U9/DCM_SP_Clk_25_MHz> of type DCM is not placeable because it has locked loads placed in regions: CLOCKREGION_X1Y7.
There is a restriction that the clock loads of a DCM must be in a horizontally adjacent clock region to the DCM. It is recommended that a BUFG
be used for this clock signal so that the clock loads can be placed anywhere on the device. If the clock driver or clock loads are locked or area grouped,
please ensure that they are constrained to horizontally adjacent clock regions.
Location "DCM_X0Y3" cannot be used to place the component due to following error condition(s):
И т.д. вывалил все DCM-ы, т.е. вроде как использовать их не могу.
Привожу часть проекта как подцепил DCM.
BUFG BUFG_Clk_125_MHz (
.I (Clk_125_MHz),
.O (w_Clk_125_MHz) - это тактовая частота. Она разводится внутри кристалла. От нее же тактируется и DCM следующим образом:
DCM_SP #(
.CLKDV_DIVIDE (2.0),
.CLKFX_DIVIDE (10),
.CLKFX_MULTIPLY (2),
.CLKIN_DIVIDE_BY_2 ("FALSE"),
.CLKIN_PERIOD (8),
.CLKOUT_PHASE_SHIFT ("NONE"),
.CLK_FEEDBACK ("1X"),
.DESKEW_ADJUST ("SYSTEM_SYNCHRONOUS"),
.DLL_FREQUENCY_MODE ("LOW"),
.DUTY_CYCLE_CORRECTION ("TRUE"),
.PHASE_SHIFT (0),
.STARTUP_WAIT ("FALSE")
) DCM_SP_Clk_25_MHz (
.CLK0 (w_CLK0),
.CLK180 (),
.CLK270 (),
.CLK2X (),
.CLK2X180 (),
.CLK90 (),
.CLKDV (),
.CLKFX (w_Phy_25MHz),
.CLKFX180 (),
.LOCKED (w_Lock_25MHz),
.PSDONE (),
.STATUS (),
.CLKFB (w_CLK0),
.CLKIN (Clk_125_MHz),
.PSCLK (),
.PSEN (1'b0),
.PSINCDEC (),
.RST (1'b0)
assign Phy_25MHz = w_Phy_25MHz;
assign Phy_GTXClk = w_CLK0;
Эти два сигнала (Phy_GTXClk и Phy_25MHz) не тактируют внутри кристалла ничего, просто выдаются наружу.
В usf-файле прописал ограничение на
PIN "Phy_GTXClk_BUFG.O" CLOCK_DEDICATED_ROUTE = FALSE;
но не помогает.
Как можно тактовую развести на DCM, чтобы не ругался разводчик??
troiden
сообщение Sep 14 2012, 13:28
Пользователь №: 45 069
Вот например что-то именно про ODDR2 для вывода клока наружу:
http://www.xilinx.com/support/answers/35032.htm
Что значит "Все-таки DCM - надежнее."? Вы в любом случае к нему привязаны.
Сообщение отредактировал troiden - Sep 14 2012, 13:32
Timmy
сообщение Sep 14 2012, 16:35
Пользователь №: 39 515
А по-моему разводчик прямо говорит, что нужно делать:"It is recommended that a BUFG
please ensure that they are constrained to horizontally adjacent clock regions"
. То есть поместить BUFG между выходом DCM и пинами, куда выводится клок. При генерации DCM визардом BUFG к его выходам цепляются по умолчанию, насколько я помню.
ovs_pavel
сообщение Sep 14 2012, 18:28
Если сигнал с выхода DCM через BUFG попытаться вывести на пин, то произойдет ошибка mapper'а. Не разводится тактовый сигнал на выходной пин.
Добавляется дополнительный блок между в тактовый сигнал, имхо. Хотя в цифре стабильность определяется задатчиком, ну не знаю... Не делал просто так раньше, а тут приходиться писать проект под чужую плату. Вообщем я бы так не делал (поставил бы разветвитель частоты и раздал бы тактовую).
troiden
сообщение Sep 14 2012, 19:03
А у вас к этой частоте еще какие-нибудь входы-выходы привязаны? Или же от нее работает какая-то не связанная с ПЛИСом микросхема?
Одна из причин выводить тактовый сигнал через ODDR в том, чтобы обеспечить ему минимальную задержку относительно других пинов. Вам этот параметр важен?
RSS Текстовая версия Сейчас: 26th July 2025 - 08:11
Страница сгенерированна за 0.01394 секунд с 7
