> запись во флеш/чтение на atxmega32d4, +IAR
addi
сообщение Oct 20 2012, 13:36
Пользователь №: 19 422
Здравствуйте
Пытаюсь использовать код от Атмела под ИАР для записи/чения флеш памяти
К сожалению чтото не выходит на этапе загрузчи буфера все виснет
Вот мой код
#include "sp_driver.h"
/* Temporary storage used for NVM-workaround. */
uint8_t sleepCtr;
uint8_t statusStore;
uint8_t pmicStore;
uint8_t globalInt;
uint8_t spmintStore;
unsigned short y;
#pragma vector =  NVM_SPM_vect
__interrupt void NVM_SPM_vectint(void)
    /* Disable the SPM interrupt */
    NVM.INTCTRL = (NVM.INTCTRL & ~NVM_SPMLVL_gm);
    /* Restore sleep settings */
    SLEEP.CTRL = sleepCtr;
    /* Restore PMIC status and control registers */
    PMIC.STATUS = statusStore;
    PMIC.CTRL = pmicStore;
    /* Restore SPM interruptsettings */
    NVM.INTCTRL = spmintStore;
    /* Restore global interrupt settings */
    SREG = globalInt;
    return;
/* Set interrupt vector location to boot section of flash */
void PMIC_SetVectorLocationToBoot( void )
    uint8_t temp = PMIC.CTRL | PMIC_IVSEL_bm;
    CCP = CCP_IOREG_gc;
    PMIC.CTRL = temp;
/*Set interrupt vector location to application section of flash */
void PMIC_SetVectorLocationToApplication( void )
    uint8_t temp = PMIC.CTRL & ~PMIC_IVSEL_bm;
    CCP = CCP_IOREG_gc;
    PMIC.CTRL = temp;
/* Save register settings before entering sleep mode */
void Prepare_to_Sleep( void )
    sleepCtr = SLEEP.CTRL;
    /* Set sleep mode to IDLE */
    SLEEP.CTRL =  0x00;
    /* Save the PMIC Status and control registers */
    statusStore = PMIC.STATUS;
    pmicStore = PMIC.CTRL;
    /* Enable only the highest level of interrupts */
    PMIC.CTRL = (PMIC.CTRL & ~(PMIC_MEDLVLEN_bm | PMIC_LOLVLEN_bm)) | PMIC_HILVLEN_bm;
    /* Save SREG for later use */
    globalInt = SREG;
    /* Enable global interrupts */
    sei();
    /* Save SPM interrupt settings for later */
    spmintStore = NVM.INTCTRL;
/* New function declarations used for the NVM-workaround */
void EraseApplicationPage(uint32_t address)
    /*Set the correct settings and store critical registers before NVM-workaround*/
    Prepare_to_Sleep();
    /*Assembly "function" to preform page erase*/
    SP_EraseApplicationPage(address);
void EraseWriteApplicationPage(uint32_t address)
    Prepare_to_Sleep();
    /*Assembly "function" to preform page erase-write*/
    SP_EraseWriteApplicationPage(address);
void ClearFlashBuffer(void)
    Prepare_to_Sleep();
    /*Assembly "function" to erase flash buffer*/
    SP_EraseFlashBuffer();
void LoadFlashWord(uint32_t address, uint16_t word)
    Prepare_to_Sleep();
    /*Assembly "function" to load flash buffer*/
       SP_LoadFlashWord(address, word);
void main()
  __enable_interrupt();
  PMIC_SetVectorLocationToBoot();
ClearFlashBuffer();
for(y=0;y<(128);y+=2)
  LoadFlashWord(y,0xAAAA);
  SP_WaitForSPM();
EraseWriteApplicationPage(16000);
if(SP_ReadByte(0x3E00)==0x55)
PORTD_OUT |= 0x40;
for(;;)
Прошу подсказать что не так кто уже пользовал иаровский код
Заранее благодарен
_Артём_
сообщение Oct 20 2012, 14:16
Пользователь №: 17 322
  SP_WaitForSPM();
PORTD_OUT |= 0x40;
for(;;)
Что-то не понял смысла вашего кода...
Вы пишете во flash начиная с адреса 16000(0x3E80) числа 0xAAAA и потом надеетесь прочитать из 0x3E00 0x55?
addi
сообщение Oct 20 2012, 14:45
спасибо за поддержку
Это результат постоянного корректирования кода, но к сожелению чтение флеш не дает ни AA ни 55, пробовал и так и так, все FF.
попробовал на отладчике посмотреть где я останавливаюсь, оказаолось после кодманды SLEEP, т.е получается что я невыходу из слипа вследствии того что почемуто нет SP прерывания.
В инииализации микроконтролера ставлю PMIC.CNTRL = 0x04 - приоритет только hi как требуется
Не могу найти в мануале где влючаются непосредственно SP прерывания...
addi
сообщение Oct 20 2012, 15:00
NVM.INTCTRL = (NVM.INTCTRL | NVM_SPMLVL_gm); в инициализации микроконтроллера тоже не выводит из сна (((
моя инициализация микроконтроллера
    unsigned h,n; //g=0;
  unsigned char k=0;
  OSC.XOSCCTRL=0x8b;
  OSC.CTRL =OSC_XOSCEN_bm;
  while (!(OSC.STATUS & OSC_XOSCRDY_bm) );
  OSC.PLLCTRL = 0xC4;                // Fcpu = 29.4912 Mhz
  OSC.CTRL = OSC.CTRL|0x10;       // enable
  while((OSC.STATUS & 0x10) ==0);
  CCP = CCP_IOREG_gc;
  //CLK.CTRL =CLK_SCLKSEL_XOSC_gc;
  CLK.CTRL =CLK_SCLKSEL_PLL_gc;
  OSC.CTRL = OSC.CTRL & 0xFE;
  init_timer1();
   PORTD_OUT &= ~0x40;
  PMIC.CTRL = 0x04;
   PORTD_OUT &= ~0x40;
  PORTE.DIR=0xff;
  PORTE_OUT = 0xff;
  PORTD_DIR |= 0xC0;
  PORTD_DIR |= 0x08;
  PORTD_OUT |= 0x80;
  PWM_init2();
_Артём_
сообщение Oct 20 2012, 15:02
Странно...попробуйте запустить какую-нибудь другую команды при настроенном прерывании NVM.
Прерывания разрешены?
Может проблемы с расположением бута? Там ли таблица векторов находится?
Проект выложте - гадать можно долго.
addi
сообщение Oct 20 2012, 15:15
спасибо за поддержку, наверна все так как Вы говорите, потому как я ничего ни делал с бутом, тем более нигде никакие операции по его расположению не делал, потому что думал что стандартного xcl хватит
Высылаю проект
Сообщение отредактировал addi - Oct 20 2012, 15:15
Прикрепленный файл  nodefulliar_19_10_12s.rar ( 189.72 килобайт ) Кол-во скачиваний: 13
_Артём_
сообщение Oct 20 2012, 15:30
Но где-то должны быть настройки линкера для бута: стандарный xcl расположит код от 0.
Посмотрите в отладчике по каким адресам таблица векторов и программа.
Высылаю проект
Открыть не получается - мои версии ИАРа видимо устарели (6.10).
RSS Текстовая версия Сейчас: 25th August 2025 - 10:26
Страница сгенерированна за 0.01905 секунд с 7
