I-button ключи от домофона. |
May 8 2006, 17:05
Пользователь №: 15 284
Код /***************************************************** This program was produced by the CodeWizardAVR V1.24.4 Standard Automatic Program Generator © Copyright 1998-2004 Pavel Haiduc, HP InfoTech s.r.l. http://www.hpinfotech.com e-mail:office@hpinfotech.com
Project : Version : Date : 07.05.2002 Author : ps1x Company : sas Comments:
Chip type : ATtiny26L Clock frequency : 4,000000 MHz Memory model : Tiny External SRAM size : 0 Data Stack size : 32 *****************************************************/
#include <tiny26.h>
// 1 Wire Bus functions #asm .equ __w1_port=0x18;PORTB .equ __w1_bit=6 #endasm #include <1wire.h> #include <delay.h> eeprom char *temp; // External Interrupt 0 service routine interrupt [EXT_INT0] void ext_int0_isr(void) { // Place your code here
// Timer 0 overflow interrupt service routine interrupt [TIM0_OVF] void timer0_ovf_isr(void) { // Place your code here
// Declare your global variables here
void main(void) { unsigned char devices,rom[9];
// Declare your local variables here
// Input/Output Ports initialization // Port A initialization // Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out // State7=0 State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=0 PORTA=0xFF; DDRA=0xFF;
// Port B initialization // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T PORTB=0x00; DDRB=0x00;
// Timer/Counter 0 initialization // Clock source: System Clock // Clock value: 3,906 kHz TCCR0=0x00; TCNT0=0x00;
// Timer/Counter 1 initialization // Clock source: System Clock // Clock value: Timer 1 Stopped // Mode: Normal top=FFh // OC1A output: Disconnected // OC1B output: Disconnected PLLCSR=0x00; TCCR1A=0x00; TCCR1B=0x00; TCNT1=0x00; OCR1A=0x00; OCR1B=0x00; OCR1C=0x00;
// External Interrupt(s) initialization // INT0: On // INT0 Mode: Falling Edge // Interrupt on any change on pins PA3, PA6, PA7 and PB4-7: Off // Interrupt on any change on pins PB0-3: Off GIMSK=0x00; MCUCR=0x00; GIFR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization TIMSK=0x00;
// Universal Serial Interface initialization // Mode: Disabled // Clock source: Register & Counter=no clk. // USI Counter Overflow Interrupt: Off USICR=0x00;
// Analog Comparator initialization // Analog Comparator: Off ACSR=0x80;
// 1 Wire Bus initialization w1_init();
// Global enable interrupts #asm("sei")
while (1) { devices=w1_search(0x33,rom); if (devices){PORTA=0x00;delay_ms(1000);PORTA=0xFF;*temp=rom;} // Place your code here
}; } Вот накатал программку для считывания серийника из таблетки и записи его в епром. Но не работает. PORTA=0x00;delay_ms(1000);PORTA=0xFF; --- вот этот кусочек, для дебага
ps1x I-button ключи от домофона. May 3 2006, 21:31 dvm11111111 Цитата(ps1x @ May 4 2006, 00:31) Нашел в ... May 3 2006, 22:27 sseett ЦитатаКто нибудь реализовывал такое на AVR?
Реали... May 3 2006, 23:13 ps1x Цитата(sseett @ May 4 2006, 03:13) Цитата... May 4 2006, 00:27  Igor26 Цитата(ps1x @ May 4 2006, 04:27) Цитата(s... May 4 2006, 05:19 SasaVitebsk Цитата(ps1x @ May 4 2006, 03:27) Как опре... May 4 2006, 20:36 SpiritDance Коли зашла речь о ключах спрошу пока тема не ушла ... May 5 2006, 04:36 add ЦитатаОпределить, подключились ли мы к домофону, м... May 5 2006, 05:57 SpiritDance Цитата(add @ May 5 2006, 09:57) На счет п... May 6 2006, 03:59 Igor26 ЦитатаКак же так?! Ключи, не посылают импульсы... May 5 2006, 06:24 SasaVitebsk [quote name='add' date='May 5 2006, 08... May 5 2006, 14:21 ps1x У меня две "таблетки", одна от далласа, ... May 5 2006, 20:02  dvm11111111 Цитата(ps1x @ May 5 2006, 23:02) У меня д... May 5 2006, 23:30 add Таааак! Ну Вам уважаемый SasaVitebsk советую п... May 6 2006, 05:32 vvs157 Цитата(add @ May 6 2006, 09:32) А вот и и... May 6 2006, 08:54 add ЦитатаТаблетка не содержит внутри себя никаких бат... May 6 2006, 09:36 vvs157 Цитата(add @ May 6 2006, 13:36) этим я по... May 6 2006, 12:13 add ЦитатаReset - Это когда после подачи питания проис... May 6 2006, 13:00 ps1x КодThe 1 Wire Functions are:
unsigned char w1... May 8 2006, 14:01 ps1x Никто не знает??? May 8 2006, 15:45 ps1x Проблема все еще актуальна: кто делал такие вещи н... May 8 2006, 22:47 WHALE в 128 раз-куда *temp смотрит? Вы его обьявили как ... May 9 2006, 06:29 ps1x Цитата(WHALE @ May 9 2006, 10:29) в 128 р... May 9 2006, 10:30  ps1x Цитата(ps1x @ May 9 2006, 14:30) Цитата(W... May 9 2006, 18:48 ilya514 Недавно сам юзал эти таблетки....именно на си и им... May 10 2006, 05:35 ps1x Цитата(ilya514 @ May 10 2006, 09:35) Неда... May 10 2006, 16:24 Pyku_He_oTTyda VTG - вольтаге таржет ( в вашем случае напряжение ... May 11 2006, 04:41 ps1x Цитата(Pyku_He_oTTyda @ May 11 2006, 08:4... May 11 2006, 13:58 Pyku_He_oTTyda Кстати, а Протеус эмулирует DS1990? May 12 2006, 04:47 ps1x Цитата(Pyku_He_oTTyda @ May 12 2006, 08:4... May 12 2006, 18:40 oscill Proteus начиная с версии 6.8 sp4 весьма прилично р... May 12 2006, 19:36 ps1x Цитата(oscill @ May 12 2006, 23:36) Prote... May 12 2006, 21:31 sseett А вот на родном (мне) русском:
http://www.telesys.... May 13 2006, 03:47 sseett "....просто скачиваешь документ с инструкциям... May 15 2006, 00:00 sseett Цитата([banned] @ May 15 2006, 15... May 16 2006, 07:17 lech196 Есть вопрос по 1-wire, задал его в форуме по интер... Feb 20 2007, 21:26 vesago По поводу интерфейса - метров 50 - работает. Иногд... Feb 21 2007, 16:33
