GPS/ГЛОНАСС модуль SL869 от Телита, есть ли управление частотой выдачи посылок? |
Dec 14 2012, 08:00
Пользователь №: 29 216
А что с 3.1.5 версией? Там, по моему, ничего особо нового не появилось... GNSS Library Fixed PPS 1ms offset after more than 24 days running Fixed PPS functionality when GPS satellites are not present in GNSS mode (NOTE: some optimizations and improvements are still on going on timing functionality. This SW is released as evaluation for timing applications) Improved tracking performances during flash erase Introduced support for 2.5ppm TCXO (this feature needs to be enabled – see firmware configuration). SBAS Library Fixed SBAS auto-search timeout management Fixed default SBAS satellite restoring during suspend/restart STAGPS Library Fixed a potential issue in the STAGPS real ephemeris database initialization Application Added checksum to all $PSTMVER NMEA messages Added NMEA message to report raw noise floor estimation Fixed mixing GPS and GLONASS satellites ids in the $PSTMAGPS message Enabled by default the predicted ephemeris age report on the $PSTMAGPS message Reduced current consumption in GPS only mode (implemented GLONASS HW power OFF when GLONASS is not enabled) Fixed a regression on the USB driver which was causing high CPU load in USB mode.
Я тебе говорю - звони, дам эту версию, она у меня уже почти месяц лежит... Я твой телефон потерял.
Да, кстати, 3.2.2 поинтереснее будет...
Сообщение отредактировал Владимир О. - Dec 14 2012, 08:36
---------------- С уважением Владимир
Dec 14 2012, 09:52
Из: ukraine
Пользователь №: 28 658
Цитата(Владимир О. @ Dec 14 2012, 10:00)  А что с 3.1.5 версией? Там, по моему, ничего особо нового не появилось... GNSS Library Fixed PPS 1ms offset after more than 24 days running Fixed PPS functionality when GPS satellites are not present in GNSS mode (NOTE: some optimizations and improvements are still on going on timing functionality. This SW is released as evaluation for timing applications) Improved tracking performances during flash erase Introduced support for 2.5ppm TCXO (this feature needs to be enabled – see firmware configuration). SBAS Library Fixed SBAS auto-search timeout management Fixed default SBAS satellite restoring during suspend/restart STAGPS Library Fixed a potential issue in the STAGPS real ephemeris database initialization Application Added checksum to all $PSTMVER NMEA messages Added NMEA message to report raw noise floor estimation Fixed mixing GPS and GLONASS satellites ids in the $PSTMAGPS message Enabled by default the predicted ephemeris age report on the $PSTMAGPS message Reduced current consumption in GPS only mode (implemented GLONASS HW power OFF when GLONASS is not enabled) Fixed a regression on the USB driver which was causing high CPU load in USB mode.
Да, кстати, 3.2.2 поинтереснее будет... хорошо, вопрос был пока о телитах, но у меня есть еще модули от навиа, для них я могу получить версию ПО ?
Dec 14 2012, 11:10
Из: СПБ
Пользователь №: 60 836
Цитата(~phase @ Dec 14 2012, 13:52)  хорошо, вопрос был пока о телитах, но у меня есть еще модули от навиа, для них я могу получить версию ПО ? в личку киньте мне мыло, я пришлю новую прошивку и лоадер Цитата(Владимир О. @ Dec 14 2012, 12:00)  Да, кстати, 3.2.2 поинтереснее будет... конечно поинтересней обещают потребление на 30..40% ниже сделать. и цена ниже насколько я понимаю!
_Ivana GPS/ГЛОНАСС модуль SL869 от Телита Nov 8 2012, 10:45 mempfis_ Цитата(_Ivana @ Nov 8 2012, 14:45) Добрый... Nov 8 2012, 11:08 CADiLO Копать в сторону Set Message Rate: Message ID 112 ... Nov 8 2012, 11:49 _Ivana Спасибо, попробую. Но насколько я понял, формат ко... Nov 8 2012, 12:23 mempfis_ ЦитатаСпасибо, попробую. Но насколько я понял, фор... Nov 8 2012, 14:02 _Ivana Максимум что я нашел по этому чипу - это http://ww... Nov 8 2012, 14:30 CADiLO И так и все же немного не так - протокол NMEA изна... Nov 8 2012, 15:37 _Ivana CADiLO, очередное спасибо, узнал много нового, но ... Nov 8 2012, 17:15 CADiLO Доки на Wenku открываются в читалке прямо на их са... Nov 9 2012, 06:08 krdmitry Парни, а если не секрет - в каких приложениях испо... Nov 9 2012, 06:17 Telit Цитата(_Ivana @ Nov 8 2012, 14:45) Добрый... Nov 9 2012, 06:21 _Ivana Спасибо. Даже имея в распоряжении все вышеприведен... Nov 9 2012, 10:14 ~phase Может не совсем в тему, к причудам заказчика, есть... Nov 12 2012, 09:54  molecul Цитата(~phase @ Nov 12 2012, 13:54) Может... Nov 12 2012, 11:42   ~phase модуль: SL869
прошивка:
$PSTMVER,GNSSLIB_7.3.... Nov 12 2012, 12:17    molecul Цитата(~phase @ Nov 12 2012, 16:17) модул... Nov 14 2012, 08:25     ~phase Цитата(molecul @ Nov 14 2012, 10:25) Вот ... Nov 14 2012, 14:26      ~phase Проверили работу в дифф режиме.
1. После подачи ко... Nov 16 2012, 12:41       Telit Цитата(~phase @ Nov 16 2012, 16:41) Прове... Nov 19 2012, 13:19    ~phase Цитата(~phase @ Nov 12 2012, 14:17) ... Nov 20 2012, 14:30     Telit вот что пишут.
Can you have them send a reset com... Nov 22 2012, 10:12      ~phase Цитата(Telit @ Nov 22 2012, 12:12) вот чт... Nov 22 2012, 11:09 Alechek у ST c дифпоправками вообще туго как я понял.
они ... Nov 14 2012, 07:30 x893 Если не секрет - RTCM как формируется ? Программно... Nov 23 2012, 02:18 ~phase Цитата(x893 @ Nov 23 2012, 04:18) Если не... Nov 23 2012, 14:49 alfff Кажется мне, новинки от Simcom составят серьезную... Nov 23 2012, 13:09 CADiLO Давайте не будем в этой теме сравнениями заниматьс... Nov 23 2012, 13:39 x893 А что то подобное rtcm-ntrip.org существует для Ро... Nov 26 2012, 22:24 ~phase Вобщем проверил, все осталось как и было.
0х11E798... Dec 7 2012, 15:53  Alechek Цитата(~phase @ Dec 7 2012, 21:53) PS Хот... Dec 10 2012, 06:23 CADiLO Может пригодится - http://microchip.ua/simcom/GPS/... Dec 8 2012, 08:57 Telit Цитата(CADiLO @ Dec 8 2012, 12:57) Может ... Dec 9 2012, 08:51 ~phase Цитата(CADiLO @ Dec 8 2012, 10:57) Может ... Dec 10 2012, 06:44  Telit Цитата(~phase @ Dec 10 2012, 10:44) Спаси... Dec 11 2012, 09:21   ~phase Цитата(Telit @ Dec 11 2012, 11:21) говоря... Dec 12 2012, 08:59    Telit Цитата(~phase @ Dec 12 2012, 12:59) PS Ст... Dec 12 2012, 19:12     Alechek Цитата(Telit @ Dec 13 2012, 01:12) Debug ... Dec 13 2012, 05:59 Владимир О. Всем добрый день!
10Гц еще нужно? Работает но... Dec 13 2012, 08:07 Telit Цитата(Владимир О. @ Dec 13 2012, 12:07) ... Dec 13 2012, 09:00 Владимир О. Саша, получу приемник, генерирующий 1001 и 1009 со... Dec 13 2012, 09:39 ~phase Где взять не "летний релиз" прошивки ? И... Dec 13 2012, 13:31  Telit Цитата(~phase @ Dec 13 2012, 17:31) Где в... Dec 13 2012, 14:58   ~phase Цитата(Telit @ Dec 13 2012, 16:58) По ход... Dec 13 2012, 15:10    Telit Цитата(~phase @ Dec 13 2012, 19:10) Это х... Dec 13 2012, 15:38  Alechek Цитата(~phase @ Dec 13 2012, 19:31) @Alec... Dec 14 2012, 06:25 Владимир О. Только что появилась 3.1.6 Dec 24 2012, 04:52 Telit Цитата(Владимир О. @ Dec 24 2012, 08:52) ... Dec 24 2012, 06:33 Владимир О. А кто говорит, что новой ревизии нету?
Я уже тести... Dec 24 2012, 06:48 Telit Цитата(Владимир О. @ Dec 24 2012, 10:48) ... Dec 24 2012, 08:02 Владимир О. А ничего не выходит...
Разница не более 10мА на ст... Dec 24 2012, 13:09 Telit Цитата(Владимир О. @ Dec 24 2012, 17:09) ... Dec 24 2012, 13:21  ~phase По поводу дифф режима, запутался я, вся наша апара... Dec 24 2012, 14:25 Benon Добрый день!
Есть модуль EB-600, сконфигуриров... Oct 31 2013, 07:27 vlx Цитата(Benon @ Oct 31 2013, 10:27) ... мо... Dec 24 2013, 09:49 Владимир О. Мои установки для 10 Гц:
103 -> 01
121 -> 02... Dec 25 2013, 06:04 vlx Спасибо, Владимир. Как я понял, основная настройка... Dec 25 2013, 08:38 Владимир О. Не совсем так.
Модуль выдает навигационное решение... Dec 26 2013, 05:13 vlx Еще раз большое спасибо!
Запустил RMC через вт... Dec 26 2013, 09:16 Владимир О. Пишите в личку свой электронный адрес Dec 26 2013, 09:51 vlx Цитата(Владимир О. @ Dec 26 2013, 12:51) ... Dec 26 2013, 10:18 Владимир О. Давайте тогда на
vo(собака)naviaglonass.ru Dec 26 2013, 12:09
