Вопросы по Agilent ADS |
Mar 12 2013, 00:07
Пользователь №: 75 645
ads_2012_08_hf2 (General Hotfix)
Installation Instructions (.pdf) Download 945,574 bytes (923,4 kB) Linux (.zip) Download 560,753,901 bytes (534,8 MB) Release Notes (pdf) Download 56,950 bytes (55,6 kB) Windows (.zip) Download 182,218,281 bytes (173,8 MB)
Issues addressed in this hotfix:
Selecting/deselecting objects in ADS2011.05 layout Shift select should unselect a previously selected vertex Version Control function update_all_files_in_path() is not refreshing open views. Version Control: Delete Workspace menu needs to inform SOS that a workspace is being deleted so that SOS can check for checked out items within the workspace Version Control: Need new interface function so ADS can tell SOS when a workspace is opened and closed Layer Preferences empty Layers in the Layers Window and Layers Preferences window are not shown Agilent Survey Link is broken on WinXP 32-bit Gerber Import: drill files do not properly handle decimals IFF export is truncating most angles to an integer number of degrees IFF import is ignoring library resolution setting and using default resolution IFF import creates layout views without support for rotation, even if instances are rotated CouplerDual has bad noise behavior at some coupling values Design Kit part fails to tune when series component is added. S4P_Eqn does not work in S-parameters noise simulation when it is terminated withTerm in all ports of the S4P_Eqn Circuit converges easily on 2011, fails totally on 2012 Allow ADS_Diode data file to be stored at other than workspace ./data location (e.g., with the Design Kits). Dynamic tuning is not working with subcircuit parameters when linear collapse is enabled ADS hicum model with NQS turned on is slow and difficult to converge in HB simulation Tuning produces incorrect results for S-parameter analysis with mixer SI/PI analyzer does not label nodes correctly yielding to failure of inclusion of parts Momentum versus FEM different treatment for the via Momentum Virtuoso cannot invoke the Cadence Distributed Process window in IC615 ISR12 and later Replace EM_Class_wrk in next ADS hotfix Disappearing tabs in mailLVS Results Viewer LVS Results viewing window: tabs for Component mismatches, Nodal mismatches, and Parameter mismatches are lost on repeated viewing Replace modify "Sample Board setting using Strips" option in ADFI EESOF Export set up
vIgort Вопросы по Agilent ADS Apr 18 2012, 10:45 ser_aleksey_p Цитата(vIgort @ Apr 18 2012, 14:45) Добры... Apr 20 2012, 16:01 vIgort Цитата(ser_aleksey_p @ Apr 20 2012, 19:01... Apr 21 2012, 14:20  ser_aleksey_p Цитата(vIgort @ Apr 21 2012, 18:20) Сейча... Apr 21 2012, 18:23 vIgort А еще не подскажете такой момент:
Практически во в... Apr 25 2012, 08:57 Filippov Цитата(vIgort @ Apr 25 2012, 11:57) А еще... Apr 25 2012, 10:41  vIgort Цитата(Filippov @ Apr 25 2012, 13:41) Мод... Apr 25 2012, 13:07 ser_aleksey_p Цитата(vIgort @ Apr 25 2012, 12:57) А еще... Apr 25 2012, 15:09 Pir0texnik Цитата(vIgort @ Apr 25 2012, 11:57) А еще... Apr 25 2012, 21:00 MPAK123 Здравствуйте. Подскажите пожалуйста каким образом ... Apr 25 2012, 17:15 ser_aleksey_p Цитата(MPAK123 @ Apr 25 2012, 21:15) Здра... Apr 25 2012, 18:13 MPAK123 Те. Если символу соответсвует макет(Layout) то рас... Apr 25 2012, 18:27 ser_aleksey_p Цитата(MPAK123 @ Apr 25 2012, 22:27) Те. ... Apr 25 2012, 19:36 MPAK123 Большое вам спасибо. Все встало на свои места. Apr 25 2012, 20:15 vIgort Цитата(ser_aleksey_p @ Apr 25 2012, 18:09... Apr 26 2012, 06:54 Filippov Цитата(vIgort @ Apr 26 2012, 09:54) Ну на... Apr 26 2012, 08:02 Pir0texnik Цитата(vIgort @ Apr 26 2012, 09:54) Я зна... Apr 27 2012, 13:13 ser_aleksey_p Цитата(vIgort @ Apr 26 2012, 10:54) Я зна... Apr 27 2012, 17:23 vIgort Цитата(Pir0texnik @ Apr 27 2012, 16:13) т... Apr 28 2012, 07:03 ser_aleksey_p Цитата(vIgort @ Apr 28 2012, 11:03) Так в... Apr 28 2012, 14:29 Pir0texnik Цитата(vIgort @ Apr 28 2012, 10:03) Так в... Apr 28 2012, 18:28 vIgort Спасибо. Теперь буду знать в случае чего искать эл... May 2 2012, 09:14 ser_aleksey_p Цитата(vIgort @ May 2 2012, 13:14) (это к... May 3 2012, 17:27 Pir0texnik Гуру, подскажите, чего за фигня у меня с объединен... May 10 2012, 22:55 vIgort В даташите на транзистор приведены входное и выход... May 22 2012, 14:07  ser_aleksey_p Цитата(vIgort @ May 22 2012, 18:07) В дат... May 22 2012, 15:03   vIgort Цитата(ser_aleksey_p @ May 22 2012, 18:03... May 23 2012, 05:29    EVS Цитата(vIgort).. как задать в Терминаторе: для 1 Г... May 23 2012, 11:24     vIgort Цитата(EVS @ May 23 2012, 14:24) Вероятно... May 23 2012, 13:04      EVS Цитата(vIgort)Я еще в хелпе нашел способ через..
Д... May 23 2012, 14:19      EVS Да ладно.. Даже извратщенцы извратщаются с фантаз... May 23 2012, 21:27    nik_us Цитата(vIgort @ May 23 2012, 08:29) Так ж... May 23 2012, 14:53 Pir0texnik по-моему немного извратно... для этого там есть сп... May 23 2012, 19:45 vIgort Цитата(Pir0texnik @ May 23 2012, 22:45) п... May 24 2012, 05:41 Pir0texnik ЦитатаFailed to create netlist:
Failed to find the... May 24 2012, 12:29 vIgort Цитата(Pir0texnik @ May 24 2012, 15:29) т... May 24 2012, 13:53  Pir0texnik вот так May 24 2012, 15:26   vIgort Цитата(Pir0texnik @ May 24 2012, 18:26) в... May 25 2012, 05:42 Pir0texnik Пожалуйста!
Народ, а давайте прилепим темку ... May 25 2012, 14:06 1lliivv1 Цитата(Pir0texnik @ May 25 2012, 18:06) Н... May 30 2012, 06:32 EUrry Почему нет, за! Вот только MWO почему-то не пр... May 25 2012, 18:34 Pir0texnik так тож микровейв офис какой-то, мелко.
а тут цел... May 25 2012, 20:06 l1l1l1 ADS - система замечательная, тема интересная, хоро... May 30 2012, 12:22 vIgort Опять обращаюсь к Гуру ADS: подскажите, пожалуйста... Jun 6 2012, 13:28 Pir0texnik ну так взять и перенести её на схематик )
в буквал... Jun 6 2012, 23:24 vIgort Цитата(Pir0texnik @ Jun 7 2012, 02:24) ну... Jun 7 2012, 06:34  Pir0texnik Цитата(vIgort @ Jun 7 2012, 09:34) Э... Н... Jun 7 2012, 12:50 BlackOps Agilent ADS + Cadence Virtuozo 6.14, как организуе... Jul 12 2012, 06:17 Predat0r Цитата(BlackOps @ Jul 12 2012, 09:17) Agi... Jul 26 2012, 20:18 BlackOps не заметил ответа в этой ветке. спасибо.
такой во... Aug 14 2012, 03:28 Predat0r Цитата(BlackOps @ Aug 14 2012, 06:28) и е... Aug 14 2012, 15:04 BlackOps Так я в Layout и смотрю, и стоит там мм, но все ра... Aug 14 2012, 18:56 N1cR Такой вопрос. В окне Shcematic можно задавать вид ... Aug 23 2012, 11:09 ser_aleksey_p Цитата(N1cR @ Aug 23 2012, 15:09) Такой в... Aug 24 2012, 16:47  N1cR Цитата(ser_aleksey_p @ Aug 24 2012, 19:47... Aug 27 2012, 06:56   ser_aleksey_p Цитата(N1cR @ Aug 27 2012, 10:56) Выходит... Aug 28 2012, 18:44    N1cR И вот Вам два графика КО: ЕМ и схемный расчет. В К... Aug 29 2012, 06:30     vIgort Цитата(N1cR @ Aug 29 2012, 09:30) Во-перв... Aug 29 2012, 08:08     ser_aleksey_p Цитата(N1cR @ Aug 29 2012, 10:30) Про пор... Aug 30 2012, 18:54 N1cR И еще, какую калибровку портов при симуляции в Lay... Aug 24 2012, 06:38 EUrry Что-то Вам никто не отвечает пока, то ли из-за пер... Aug 24 2012, 07:53 Pir0texnik И как пользоваться портом типа СМД ?? Картинка та ... Sep 3 2012, 04:40 ser_aleksey_p Цитата(Pir0texnik @ Sep 3 2012, 08:40) И ... Sep 3 2012, 18:21 Pir0texnik Ух, спасибо за хелпы, теперь-то хоть понятно как с... Sep 4 2012, 05:30 maxim26 Помогите разобраться с моментумом в Ads. Не возмож... Oct 16 2012, 17:14 ser_aleksey_p Цитата(maxim26 @ Oct 16 2012, 21:14) Помо... Oct 17 2012, 16:12 ser_aleksey_p Наверное, нет смысла создавать отдельную тему по E... Oct 30 2012, 15:46 Predat0r Цитата(ser_aleksey_p @ Oct 30 2012, 18:46... Oct 30 2012, 20:36 DesNer Спасайте, уже на грани нервного срыва. На схеме ес... Nov 1 2012, 11:13 EVS Не надо нервного срыва Лучше вместо блока Var ис... Nov 1 2012, 11:28  DesNer Цитата(EVS @ Nov 1 2012, 15:28) Не надо н... Nov 1 2012, 11:38 1lliivv1 Заметил неприятную особенность при создании нового... Nov 9 2012, 06:23 Pavlova4ever Добрый день!
Пожалуйста, кто-нибудь помогите п... Jan 24 2013, 12:28 ulia Подскажите в таком вопросе.
Пассивный микрополоско... Jan 25 2013, 07:46 ser_aleksey_p Цитата(ulia @ Jan 25 2013, 11:46) Подскаж... Jan 27 2013, 07:35 nadie ЦитатаПассивный микрополосковый делитель\сумм... Jan 26 2013, 12:22 microwave Добрый день!
Подскажите в таком вопросе. Есть ... Jan 31 2013, 08:27 Shadowboxer Доброе время суток.
При моделировании 3-децибельно... Jan 31 2013, 09:24 l1l1l1 вопрос, поднятый участником ASDFG123 по поводу реа... Jan 31 2013, 22:04 ser_aleksey_p Кто-нибудь разбирался в ADS с каскадным кодом RS-с... Feb 1 2013, 17:31 telix Разочаровался я в ADS. Пакет хорош для моделирован... Feb 16 2013, 14:15 l1l1l1 Цитата(telix @ Feb 16 2013, 18:15) Разоча... Feb 16 2013, 17:52 ser_aleksey_p Цитата(telix @ Feb 16 2013, 18:15) ...Но ... Feb 19 2013, 16:39  telix Цитата(ser_aleksey_p @ Feb 19 2013, 20:39... Feb 19 2013, 19:01   ser_aleksey_p Цитата(telix @ Feb 19 2013, 23:01) Тут я ... Feb 19 2013, 19:42 nadie Из-за известных ограничений Momentum Agilent и пыт... Feb 17 2013, 21:30 telix Еще вопрос, по поводу утилиты Filter Design. Синте... Feb 18 2013, 04:56 ser_aleksey_p Цитата(telix @ Feb 18 2013, 08:56) Может ... Feb 18 2013, 17:42 Pir0texnik да чудненький оптимизатор в адс, куча методов, опт... Feb 18 2013, 07:04 nadie ЦитатаЧтобы какой-нибудь САПР в мгновение ока опти... Feb 19 2013, 12:04 1lliivv1 А реально ли сделать в Schematic систему для оформ... Apr 4 2013, 10:59 ser_aleksey_p Цитата(1lliivv1 @ Apr 4 2013, 14:59) А ре... May 16 2013, 16:12 angslv Довольно часто в теме звучит вопрос "с чего н... May 13 2013, 11:00 Виталий_ Можно ли ADS прочитать формат s2p? Если можно, то ... May 18 2013, 20:24 1lliivv1 Виталий
Да, можно. Нужно использовать элемент S2P... May 19 2013, 04:26 Artemij14 Привет всем!
Моделирую линию задержки, котора... May 26 2013, 12:12 Pir0texnik Терзают меня смутные сомнения, что моментум позвол... May 27 2013, 02:29 Artemij14 Цитата(Pir0texnik @ May 27 2013, 06:29) Т... May 27 2013, 04:57
