> как отловить в каком месте ставится latch?
GAYVER
сообщение Apr 3 2013, 11:04
Пользователь №: 76 333
суммари:
Device Utilization Summary:
Number of Slice Registers - 4,631
Number used as Flip Flops - 4,630
Number used as Latches - 1
синтез репорт:
CODE
Device utilization summary:
Selected Device : 6vlx195tff1156-1
Slice Logic Utilization:
Number of Slice Registers: 4816 out of 249600 1%
Number of Slice LUTs: 4488 out of 124800 3%
Number used as Logic: 3500 out of 124800 2%
Number used as Memory: 988 out of 48640 2%
Number used as SRL: 988
Slice Logic Distribution:
Number of LUT Flip Flop pairs used: 6227
Number with an unused Flip Flop: 1411 out of 6227 22%
Number with an unused LUT: 1739 out of 6227 27%
Number of fully used LUT-FF pairs: 3077 out of 6227 49%
Number of unique control sets: 181
IO Utilization:
Number of IOs: 440
Number of bonded IOBs: 344 out of 600 57%
Specific Feature Utilization:
Number of Block RAM/FIFO: 3 out of 344 0%
Number using Block RAM only: 3
Number of BUFG/BUFGCTRLs: 4 out of 32 12%
мап репорт:
CODE
Design Summary
Number of errors: 0
Number of warnings: 358
Number of Slice Registers: 4,631 out of 249,600 1%
Number used as Flip Flops: 4,630
Number used as Latches: 1
Number used as Latch-thrus: 0
Number used as AND/OR logics: 0
Number of Slice LUTs: 3,955 out of 124,800 3%
Number used as logic: 2,931 out of 124,800 2%
Number using O6 output only: 2,255
Number using O5 output only: 33
Number using O5 and O6: 643
Number used as ROM: 0
Number used as Memory: 984 out of 48,640 2%
Number used as Dual Port RAM: 0
Number used as Single Port RAM: 0
Number used as Shift Register: 984
Number using O6 output only: 984
Number using O5 output only: 0
Number using O5 and O6: 0
Number used exclusively as route-thrus: 40
Number with same-slice register load: 39
Number with same-slice carry load: 1
Number with other load: 0
Number of occupied Slices: 1,781 out of 31,200 5%
Number of LUT Flip Flop pairs used: 5,224
Number with an unused Flip Flop: 898 out of 5,224 17%
Number with an unused LUT: 1,269 out of 5,224 24%
Number of fully used LUT-FF pairs: 3,057 out of 5,224 58%
Number of unique control sets: 183
Number of slice register sites lost
to control set restrictions: 705 out of 249,600 1%
IO Utilization:
Number of bonded IOBs: 440 out of 600 73%
Number of LOCed IOBs: 440 out of 440 100%
IOB Flip Flops: 164
IOB Master Pads: 12
IOB Slave Pads: 12
Number of RAMB36E1/FIFO36E1s: 3 out of 344 1%
Number using RAMB36E1 only: 3
Number using FIFO36E1 only: 0
Number of RAMB18E1/FIFO18E1s: 0 out of 688 0%
Number used as BUFGs: 4
Number used as BUFGCTRLs: 0
Number of ILOGICE1/ISERDESE1s: 64 out of 600 10%
Number used as ILOGICE1s: 0
Number used as ISERDESE1s: 64
Number of OLOGICE1/OSERDESE1s: 166 out of 600 27%
Number used as OLOGICE1s: 166
Number used as OSERDESE1s: 0
Number of BSCANs: 0 out of 4 0%
Number of BUFHCEs: 0 out of 120 0%
Number of BUFIODQSs: 8 out of 60 13%
Number of BUFRs: 0 out of 30 0%
Number of CAPTUREs: 0 out of 1 0%
Number of DSP48E1s: 0 out of 640 0%
Number of EFUSE_USRs: 0 out of 1 0%
Number of FRAME_ECCs: 0 out of 1 0%
Number of GTXE1s: 0 out of 20 0%
Number of IBUFDS_GTXE1s: 0 out of 10 0%
Number of ICAPs: 0 out of 2 0%
Number of IDELAYCTRLs: 12 out of 15 80%
Number of IODELAYE1s: 236 out of 600 39%
Number of MMCM_ADVs: 1 out of 10 10%
Number of PCIE_2_0s: 0 out of 2 0%
Number of STARTUPs: 1 out of 1 100%
Number of SYSMONs: 0 out of 1 0%
Number of TEMAC_SINGLEs: 0 out of 4 0%
вопрос - как выловить эту защелку???
Сообщение отредактировал GAYVER - Apr 3 2013, 11:08
GAYVER
сообщение Apr 3 2013, 13:06
проект - скелет вычислителя в котором на данный момент собраны только устройства, отвечающие за "перегонку" данных. однако в уцф-нике описаны все пины, которые будут и, соответственно на топ-лвл-е все эти пины присутствуют. половина из них висит в воздухе. так же некоторые порты уже собранных устройств повешены на землю ввиду отсутствия источников сигналов. из-за этого много сообщений типа - такой то сигнал - нулевая константа, итд.
да, я собираю проект из чужих блоков, поэтому не знаю всех тонкостей каждого отдельно взятого элемента..
CODE
Reading design: SNK_OU.prj
TABLE OF CONTENTS
1) Synthesis Options Summary
2) HDL Parsing
3) HDL Elaboration
4) HDL Synthesis
4.1) HDL Synthesis Report
5) Advanced HDL Synthesis
5.1) Advanced HDL Synthesis Report
6) Low Level Synthesis
7) Partition Report
8) Design Summary
8.1) Primitive and Black Box Usage
8.2) Device utilization summary
8.3) Partition Resource Summary
8.4) Timing Report
8.4.1) Clock Information
8.4.2) Asynchronous Control Signals Information
8.4.3) Timing Summary
8.4.4) Timing Details
8.4.5) Cross Clock Domains Report
* Synthesis Options Summary *
---- Source Parameters
Input File Name : "SNK_OU.prj"
Ignore Synthesis Constraint File : NO
---- Target Parameters
Output File Name : "SNK_OU"
Output Format : NGC
Target Device : xc6vlx195t-1-ff1156
---- Source Options
Top Module Name : SNK_OU
Automatic FSM Extraction : YES
FSM Encoding Algorithm : Auto
Safe Implementation : No
FSM Style : LUT
RAM Extraction : Yes
RAM Style : Auto
ROM Extraction : Yes
Shift Register Extraction : YES
ROM Style : Auto
Resource Sharing : YES
Asynchronous To Synchronous : NO
Shift Register Minimum Size : 2
Use DSP Block : Auto
Automatic Register Balancing : No
---- Target Options
LUT Combining : Auto
Reduce Control Sets : Auto
Add IO Buffers : YES
Global Maximum Fanout : 100000
Add Generic Clock Buffer(BUFG) : 32
Register Duplication : NO
Optimize Instantiated Primitives : NO
Use Clock Enable : Auto
Use Synchronous Set : Auto
Use Synchronous Reset : Auto
Pack IO Registers into IOBs : Auto
Equivalent register Removal : NO
---- General Options
Optimization Goal : Speed
Optimization Effort : 1
Power Reduction : NO
Keep Hierarchy : No
Netlist Hierarchy : As_Optimized
RTL Output : Yes
Global Optimization : AllClockNets
Read Cores : YES
Write Timing Constraints : NO
Cross Clock Analysis : NO
Hierarchy Separator : /
Bus Delimiter : <>
Case Specifier : Maintain
Slice Utilization Ratio : 100
BRAM Utilization Ratio : 100
DSP48 Utilization Ratio : 100
Auto BRAM Packing : NO
Slice Utilization Ratio Delta : 5
INFO:Xst - Part-select index evaluated to out of bound value may lead to incorrect synthesis results; it is recommended not to use them in RTL
* HDL Parsing *
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/write_channel.vhd" into library work
Parsing entity <write_channel>.
Parsing architecture <Behavioral> of entity <write_channel>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/SPI/Block_SPI_2LINE.vhd" into library work
Parsing entity <Block_SPI_2LINE>.
Parsing architecture <Behavioral> of entity <block_spi_2line>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/SPI/Block_AMBA_slave.vhd" into library work
Parsing entity <Block_AMBA_AXI_slave>.
Parsing architecture <Behavioral> of entity <block_amba_axi_slave>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/read_chennal.vhd" into library work
Parsing entity <read_channel>.
Parsing architecture <Behavioral> of entity <read_channel>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/shifter_i.vhd" into library work
Parsing entity <shifter_i>.
Parsing architecture <Behavioral> of entity <shifter_i>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/RG_D2.vhd" into library work
Parsing entity <RG_D2>.
Parsing architecture <Behavioral> of entity <rg_d2>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/RG_D1.vhd" into library work
Parsing entity <RG_D1>.
Parsing architecture <Behavioral> of entity <rg_d1>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/RAMB_1Kx64.vhd" into library work
Parsing entity <RAMB_1Kx64>.
Parsing architecture <Behavioral> of entity <ramb_1kx64>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/RAMB_1Kx32.vhd" into library work
Parsing entity <RAMB_1Kx32>.
Parsing architecture <Behavioral> of entity <ramb_1kx32>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/PPK.vhd" into library work
Parsing entity <PPK>.
Parsing architecture <Behavioral> of entity <ppk>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/ct_n.vhd" into library work
Parsing entity <ct_n>.
Parsing architecture <Behavioral> of entity <ct_n>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/CT_AK.vhd" into library work
Parsing entity <CT_AK>.
Parsing architecture <Behavioral> of entity <ct_ak>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/comp_0.vhd" into library work
Parsing entity <comp_0>.
Parsing architecture <Behavioral> of entity <comp_0>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/CC22CLED.vhd" into library work
Parsing entity <CC22CLED>.
Parsing architecture <Behavioral> of entity <cc22cled>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/CC10CLED.vhd" into library work
Parsing entity <CC10CLED>.
Parsing architecture <Behavioral> of entity <cc10cled>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/BU_BUSok.vhd" into library work
Parsing entity <BU_BUSok>.
Parsing architecture <Behavioral> of entity <bu_busok>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/ALU_I_v6.vhf" into library work
Parsing entity <M2_1_HXILINX_ALU_I_v6>.
Parsing architecture <M2_1_HXILINX_ALU_I_v6_V> of entity <m2_1_hxilinx_alu_i_v6>.
Parsing entity <ALU_I_v6>.
Parsing architecture <BEHAVIORAL> of entity <alu_i_v6>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/AXI_SPI_2_LINE.vhf" into library work
Parsing entity <AXI_SPI_2_LINE>.
Parsing architecture <BEHAVIORAL> of entity <axi_spi_2_line>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/SLAVE_K.vhd" into library work
Parsing entity <SLAVE_K>.
Parsing architecture <Behavioral> of entity <slave_k>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/RESET_block.vhd" into library work
Parsing entity <RESET_block>.
Parsing architecture <Behavioral> of entity <reset_block>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/LVDS_block.vhd" into library work
Parsing entity <LVDS_block>.
Parsing architecture <Behavioral> of entity <lvds_block>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/Kontr_QDR_OU_AXI.vhd" into library work
Parsing entity <Kontr_QDR_OU_AXI>.
Parsing architecture <Behavioral> of entity <kontr_qdr_ou_axi>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/interconnect.vhd" into library work
Parsing entity <interconnect>.
Parsing architecture <Behavioral> of entity <interconnect>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/ETH_WRITE.vhd" into library work
Parsing entity <ETH_WRITE>.
Parsing architecture <Behavioral> of entity <eth_write>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/BUSok.vhf" into library work
Parsing entity <M2_1_HXILINX_BUSok>.
Parsing architecture <M2_1_HXILINX_BUSok_V> of entity <m2_1_hxilinx_busok>.
Parsing entity <ALU_I_v6_MUSER_BUSok>.
Parsing architecture <BEHAVIORAL> of entity <alu_i_v6_muser_busok>.
Parsing entity <BUSok>.
Parsing architecture <BEHAVIORAL> of entity <busok>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/BUF_block.vhd" into library work
Parsing entity <BUF_block>.
Parsing architecture <Behavioral> of entity <buf_block>.
Parsing VHDL file "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" into library work
Parsing entity <SNK_OU>.
Parsing architecture <BEHAVIORAL> of entity <snk_ou>.
CODE
* HDL Elaboration *
Elaborating entity <SNK_OU> (architecture <BEHAVIORAL>) from library <work>.
Elaborating entity <BUF_block> (architecture <Behavioral>) from library <work>.
Elaborating entity <LVDS_block> (architecture <Behavioral>) from library <work>.
Elaborating entity <RESET_block> (architecture <Behavioral>) from library <work>.
Elaborating entity <interconnect> (architecture <Behavioral>) from library <work>.
Elaborating entity <write_channel> (architecture <Behavioral>) from library <work>.
WARNING:HDLCompiler:1127 - "/home/gayver/Project Xilinx/Project/SNK_OU/write_channel.vhd" Line 180: Assignment to end_transfer_d ignored, since the identifier is never used
WARNING:HDLCompiler:1127 - "/home/gayver/Project Xilinx/Project/SNK_OU/write_channel.vhd" Line 275: Assignment to awready_2d ignored, since the identifier is never used
Elaborating entity <read_channel> (architecture <Behavioral>) from library <work>.
WARNING:HDLCompiler:1127 - "/home/gayver/Project Xilinx/Project/SNK_OU/read_chennal.vhd" Line 115: Assignment to end_transferm1_r ignored, since the identifier is never used
WARNING:HDLCompiler:1127 - "/home/gayver/Project Xilinx/Project/SNK_OU/read_chennal.vhd" Line 116: Assignment to end_transferm2_r ignored, since the identifier is never used
WARNING:HDLCompiler:1127 - "/home/gayver/Project Xilinx/Project/SNK_OU/read_chennal.vhd" Line 117: Assignment to end_transferm3_r ignored, since the identifier is never used
WARNING:HDLCompiler:1127 - "/home/gayver/Project Xilinx/Project/SNK_OU/read_chennal.vhd" Line 153: Assignment to bl_arvalid_d ignored, since the identifier is never used
WARNING:HDLCompiler:1127 - "/home/gayver/Project Xilinx/Project/SNK_OU/read_chennal.vhd" Line 388: Assignment to rid_3d ignored, since the identifier is never used
Elaborating entity <Kontr_QDR_OU_AXI> (architecture <Behavioral>) with generics from library <work>.
WARNING:HDLCompiler:1127 - "/home/gayver/Project Xilinx/Project/SNK_OU/Kontr_QDR_OU_AXI.vhd" Line 127: Assignment to arvalid_2d ignored, since the identifier is never used
Elaborating entity <AXI_SPI_2_LINE> (architecture <BEHAVIORAL>) from library <work>.
Elaborating entity <Block_AMBA_AXI_slave> (architecture <Behavioral>) from library <work>.
Elaborating entity <Block_SPI_2LINE> (architecture <Behavioral>) from library <work>.
WARNING:HDLCompiler:1127 - "/home/gayver/Project Xilinx/Project/SNK_OU/SPI/Block_SPI_2LINE.vhd" Line 156: Assignment to kd_0_d1 ignored, since the identifier is never used
WARNING:HDLCompiler:1127 - "/home/gayver/Project Xilinx/Project/SNK_OU/SPI/Block_SPI_2LINE.vhd" Line 797: Assignment to pch1_d1_p ignored, since the identifier is never used
Elaborating entity <BUSok> (architecture <BEHAVIORAL>) from library <work>.
Elaborating entity <CT_AK> (architecture <Behavioral>) from library <work>.
Elaborating entity <ALU_I_v6_MUSER_BUSok> (architecture <BEHAVIORAL>) from library <work>.
Elaborating entity <M2_1_HXILINX_BUSok> (architecture <M2_1_HXILINX_BUSok_V>) from library <work>.
INFO:HDLCompiler:679 - "/home/gayver/Project Xilinx/Project/SNK_OU/BUSok.vhf" Line 44. Case statement is complete. others clause is never selected
Elaborating entity <BU_BUSok> (architecture <Behavioral>) from library <work>.
Elaborating entity <comp_0> (architecture <Behavioral>) from library <work>.
Elaborating entity <CC22CLED> (architecture <Behavioral>) with generics from library <work>.
Elaborating entity <CC10CLED> (architecture <Behavioral>) with generics from library <work>.
Elaborating entity <ct_n> (architecture <Behavioral>) from library <work>.
Elaborating entity <RAMB_1Kx32> (architecture <Behavioral>) with generics from library <work>.
Elaborating entity <RAMB_1Kx64> (architecture <Behavioral>) with generics from library <work>.
Elaborating entity <PPK> (architecture <Behavioral>) from library <work>.
Elaborating entity <RG_D1> (architecture <Behavioral>) from library <work>.
Elaborating entity <RG_D2> (architecture <Behavioral>) from library <work>.
Elaborating entity <shifter_i> (architecture <Behavioral>) from library <work>.
Elaborating entity <ETH_WRITE> (architecture <Behavioral>) from library <work>.
Elaborating entity <SLAVE_K> (architecture <Behavioral>) from library <work>.
WARNING:HDLCompiler:634 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" Line 288: Net <RREADY_m1> does not have a driver.
* HDL Synthesis *
Synthesizing Unit <SNK_OU>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf".
Set property "BANDWIDTH = OPTIMIZED" for instance <XLXI_38>.
Set property "CLKFBOUT_MULT_F = 24.0" for instance <XLXI_38>.
Set property "CLKFBOUT_PHASE = 0.000" for instance <XLXI_38>.
Set property "CLKIN1_PERIOD = 20.0" for instance <XLXI_38>.
Set property "CLKOUT0_DIVIDE_F = 6.0" for instance <XLXI_38>.
Set property "CLKOUT0_DUTY_CYCLE = 0.500" for instance <XLXI_38>.
Set property "CLKOUT0_PHASE = 0.000" for instance <XLXI_38>.
Set property "CLKOUT1_DIVIDE = 6" for instance <XLXI_38>.
Set property "CLKOUT1_DUTY_CYCLE = 0.500" for instance <XLXI_38>.
Set property "CLKOUT1_PHASE = 270.0" for instance <XLXI_38>.
Set property "CLKOUT2_DIVIDE = 1" for instance <XLXI_38>.
Set property "CLKOUT2_DUTY_CYCLE = 0.500" for instance <XLXI_38>.
Set property "CLKOUT2_PHASE = 0.000" for instance <XLXI_38>.
Set property "CLKOUT3_DIVIDE = 8" for instance <XLXI_38>.
Set property "CLKOUT3_DUTY_CYCLE = 0.500" for instance <XLXI_38>.
Set property "CLKOUT3_PHASE = 0.000" for instance <XLXI_38>.
Set property "CLKOUT4_CASCADE = FALSE" for instance <XLXI_38>.
Set property "CLKOUT4_DIVIDE = 1" for instance <XLXI_38>.
Set property "CLKOUT4_DUTY_CYCLE = 0.500" for instance <XLXI_38>.
Set property "CLKOUT4_PHASE = 0.000" for instance <XLXI_38>.
Set property "CLKOUT5_DIVIDE = 1" for instance <XLXI_38>.
Set property "CLKOUT5_DUTY_CYCLE = 0.500" for instance <XLXI_38>.
Set property "CLKOUT5_PHASE = 0.000" for instance <XLXI_38>.
Set property "CLKOUT6_DIVIDE = 1" for instance <XLXI_38>.
Set property "CLKOUT6_DUTY_CYCLE = 0.500" for instance <XLXI_38>.
Set property "CLKOUT6_PHASE = 0.000" for instance <XLXI_38>.
Set property "CLOCK_HOLD = FALSE" for instance <XLXI_38>.
Set property "DIVCLK_DIVIDE = 1" for instance <XLXI_38>.
Set property "REF_JITTER1 = 0.010" for instance <XLXI_38>.
Set property "STARTUP_WAIT = FALSE" for instance <XLXI_38>.
WARNING:Xst:647 - Input <AP> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <BP> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <BUS_PDCL> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <CD_0> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <CD_1> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <CSMCU> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <CTS_0> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <CTS_1> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <DSR_0> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <DSR_1> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <F_ADC> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <OCHM_ETH> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <OCHM_USB> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <PPDS_ETH> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <PVDS_ETH> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <RI_0> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <RI_1> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <RP> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <RXD_0> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <RXD_1> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <RXFM_USB> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <RXFS_USB> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <SCLKMCU> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <SDIMCU> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <SYNC_CLK> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <TXEM_USB> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <TXES_USB> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <U0_OCHS_ETH> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <U0_OCHS_USB> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <Z_OCHS_ETH> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <Z_OCHS_USB> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 795: Output port <d_out_usbm> of the instance <B_BUF> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 795: Output port <d_out_usbs> of the instance <B_BUF> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 795: Output port <d_out_eths> of the instance <B_BUF> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 795: Output port <d_out_izp> of the instance <B_BUF> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 876: Output port <AWID> of the instance <inter_slave0> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 876: Output port <RDATAm3> of the instance <inter_slave0> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 876: Output port <ARREADYm3> of the instance <inter_slave0> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 876: Output port <RVALIDm3> of the instance <inter_slave0> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 876: Output port <AWREADYm3> of the instance <inter_slave0> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 876: Output port <WREADYm3> of the instance <inter_slave0> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 937: Output port <AWID> of the instance <inter_slave1> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 937: Output port <RDATAm3> of the instance <inter_slave1> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 937: Output port <ARREADYm3> of the instance <inter_slave1> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 937: Output port <RVALIDm3> of the instance <inter_slave1> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 937: Output port <AWREADYm3> of the instance <inter_slave1> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 937: Output port <WREADYm3> of the instance <inter_slave1> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 998: Output port <AWID> of the instance <inter_slave7> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 998: Output port <RDATAm3> of the instance <inter_slave7> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 998: Output port <ARREADYm3> of the instance <inter_slave7> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 998: Output port <RVALIDm3> of the instance <inter_slave7> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 998: Output port <AWREADYm3> of the instance <inter_slave7> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 998: Output port <WREADYm3> of the instance <inter_slave7> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1059: Output port <AWID> of the instance <inter_slave8> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1059: Output port <RDATAm3> of the instance <inter_slave8> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1059: Output port <ARREADYm3> of the instance <inter_slave8> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1059: Output port <RVALIDm3> of the instance <inter_slave8> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1059: Output port <AWREADYm3> of the instance <inter_slave8> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1059: Output port <WREADYm3> of the instance <inter_slave8> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1120: Output port <AWID> of the instance <inter_slave41> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1120: Output port <RDATAm3> of the instance <inter_slave41> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1120: Output port <ARREADYm3> of the instance <inter_slave41> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1120: Output port <RVALIDm3> of the instance <inter_slave41> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1120: Output port <AWREADYm3> of the instance <inter_slave41> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1120: Output port <WREADYm3> of the instance <inter_slave41> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1181: Output port <DATA_BVV> of the instance <K_QDR_RAM1> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1181: Output port <OCH_WR> of the instance <K_QDR_RAM1> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1181: Output port <OCH_RD> of the instance <K_QDR_RAM1> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1181: Output port <STROB_BVV> of the instance <K_QDR_RAM1> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1223: Output port <DATA_BVV> of the instance <K_QDR_RAM2> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1223: Output port <OCH_WR> of the instance <K_QDR_RAM2> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1223: Output port <OCH_RD> of the instance <K_QDR_RAM2> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1223: Output port <STROB_BVV> of the instance <K_QDR_RAM2> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1265: Output port <DATA_BVV> of the instance <K_QDR_RAM3> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1265: Output port <OCH_WR> of the instance <K_QDR_RAM3> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1265: Output port <OCH_RD> of the instance <K_QDR_RAM3> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1265: Output port <STROB_BVV> of the instance <K_QDR_RAM3> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1307: Output port <DATA_BVV> of the instance <K_QDR_RAM4> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1307: Output port <OCH_WR> of the instance <K_QDR_RAM4> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1307: Output port <OCH_RD> of the instance <K_QDR_RAM4> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1307: Output port <STROB_BVV> of the instance <K_QDR_RAM4> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1349: Output port <BRESP> of the instance <K_SPI_OU1> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1349: Output port <RRESP> of the instance <K_SPI_OU1> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1349: Output port <BVALID> of the instance <K_SPI_OU1> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1374: Output port <WSTRB> of the instance <M1_BUS> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1374: Output port <BREADY> of the instance <M1_BUS> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1374: Output port <RREADY> of the instance <M1_BUS> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1397: Output port <AWPROT> of the instance <M2_ETH> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1397: Output port <WSTRB> of the instance <M2_ETH> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1397: Output port <BREADY> of the instance <M2_ETH> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1397: Output port <ARPROT> of the instance <M2_ETH> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1594: Output port <CLKFBOUTB> of the instance <XLXI_38> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1594: Output port <CLKOUT0B> of the instance <XLXI_38> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1594: Output port <CLKOUT1B> of the instance <XLXI_38> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1594: Output port <CLKOUT2> of the instance <XLXI_38> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1594: Output port <CLKOUT2B> of the instance <XLXI_38> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1594: Output port <CLKOUT3B> of the instance <XLXI_38> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1594: Output port <CLKOUT4> of the instance <XLXI_38> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1594: Output port <CLKOUT5> of the instance <XLXI_38> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1594: Output port <CLKOUT6> of the instance <XLXI_38> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/SNK_OU.vhf" line 1594: Output port <LOCKED> of the instance <XLXI_38> is unconnected or connected to loadless signal.
WARNING:Xst:653 - Signal <RREADY_m1> is used but never assigned. This sourceless signal will be automatically connected to value GND.
Summary:
no macro.
Unit <SNK_OU> synthesized.
CODE
Synthesizing Unit <BUF_block>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/BUF_block.vhd".
WARNING:Xst:647 - Input <d_in_eths<7:0>> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
Summary:
no macro.
Unit <BUF_block> synthesized.
Synthesizing Unit <LVDS_block>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/LVDS_block.vhd".
Summary:
no macro.
Unit <LVDS_block> synthesized.
Synthesizing Unit <RESET_block>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/RESET_block.vhd".
Summary:
no macro.
Unit <RESET_block> synthesized.
Synthesizing Unit <interconnect>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/interconnect.vhd".
Summary:
no macro.
Unit <interconnect> synthesized.
Synthesizing Unit <write_channel>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/write_channel.vhd".
Found 1-bit register for signal <bl_wreadym1>.
Found 1-bit register for signal <bl_awreadym2>.
Found 1-bit register for signal <bl_wreadym2>.
Found 1-bit register for signal <bl_awreadym3>.
Found 1-bit register for signal <bl_wreadym3>.
Found 1-bit register for signal <bl_awready>.
Found 1-bit register for signal <bl_wready>.
Found 1-bit register for signal <hold_channel>.
Found 1-bit register for signal <bl_wready_d>.
Found 1-bit register for signal <awvalidm1_d>.
Found 1-bit register for signal <awvalidm1_2d>.
Found 1-bit register for signal <awvalidm2_d>.
Found 1-bit register for signal <awvalidm2_2d>.
Found 1-bit register for signal <awvalidm3_d>.
Found 1-bit register for signal <awvalidm3_2d>.
Found 1-bit register for signal <awvalidm1_2d_dt>.
Found 1-bit register for signal <awvalidm2_2d_dt>.
Found 1-bit register for signal <awvalidm3_2d_dt>.
Found 26-bit register for signal <awaddrm1_d>.
Found 26-bit register for signal <awaddrm1_2d>.
Found 26-bit register for signal <awaddrm2_d>.
Found 26-bit register for signal <awaddrm2_2d>.
Found 26-bit register for signal <awaddrm3_d>.
Found 26-bit register for signal <awaddrm3_2d>.
Found 3-bit register for signal <n_channel_w>.
Found 3-bit register for signal <n_channel_data>.
Found 1-bit register for signal <awready_d>.
Found 1-bit register for signal <falling_awready>.
Found 1-bit register for signal <rising_awready_d>.
Found 26-bit register for signal <awaddrs_m2d>.
Found 1-bit register for signal <awvalids_m2d>.
Found 26-bit register for signal <awaddrs_md>.
Found 1-bit register for signal <awvalids_md>.
Found 3-bit register for signal <n_channel_wn_d>.
Found 3-bit register for signal <n_channel_datan_d>.
Found 1-bit register for signal <new_ch_adr_d>.
Found 1-bit register for signal <new_ch_adr_2d>.
Found 1-bit register for signal <new_ch_adr_3d>.
Found 1-bit register for signal <new_ch_adr_4d>.
Found 1-bit register for signal <new_ch_adr_5d>.
Found 1-bit register for signal <new_ch_data_d>.
Found 1-bit register for signal <new_ch_data_2d>.
Found 1-bit register for signal <new_ch_data_3d>.
Found 1-bit register for signal <new_ch_data_4d>.
Found 1-bit register for signal <new_ch_data_5d>.
Found 1-bit register for signal <wvalidm1_d>.
Found 1-bit register for signal <wvalidm1_2d>.
Found 1-bit register for signal <wvalidm2_d>.
Found 1-bit register for signal <wvalidm2_2d>.
Found 1-bit register for signal <wvalidm3_d>.
Found 1-bit register for signal <wvalidm3_2d>.
Found 32-bit register for signal <wdatam1_d>.
Found 32-bit register for signal <wdatam1_2d>.
Found 32-bit register for signal <wdatam2_d>.
Found 32-bit register for signal <wdatam2_2d>.
Found 32-bit register for signal <wdatam3_d>.
Found 32-bit register for signal <wdatam3_2d>.
Found 1-bit register for signal <wready_d>.
Found 1-bit register for signal <falling_wready>.
Found 1-bit register for signal <rising_wready_d>.
Found 32-bit register for signal <wdatas_m2d>.
Found 1-bit register for signal <wvalids_m2d>.
Found 32-bit register for signal <wdatas_md>.
Found 1-bit register for signal <wvalids_md>.
Found 1-bit register for signal <och1w>.
Found 1-bit register for signal <och2w>.
Found 1-bit register for signal <flag1w>.
Found 1-bit register for signal <flag2w>.
Found 1-bit register for signal <awready_internal>.
Found 1-bit register for signal <wready_internal>.
Found 1-bit register for signal <awvalids_tmp>.
Found 1-bit register for signal <wvalids_tmp>.
Found 1-bit register for signal <awvalids_tmp_d>.
Found 1-bit register for signal <wvalids_tmp_d>.
Found 26-bit register for signal <awaddrs_tmp>.
Found 32-bit register for signal <wdatas_tmp>.
Found 1-bit register for signal <AWREADYm1>.
Found 1-bit register for signal <WREADYm1>.
Found 1-bit register for signal <AWREADYm2>.
Found 1-bit register for signal <WREADYm2>.
Found 1-bit register for signal <AWREADYm3>.
Found 1-bit register for signal <WREADYm3>.
Found 4-bit register for signal <AWID>.
Found 1-bit register for signal <awreadym1_internal>.
Found 1-bit register for signal <wreadym1_internal>.
Found 1-bit register for signal <awreadym2_internal>.
Found 1-bit register for signal <wreadym2_internal>.
Found 1-bit register for signal <awreadym3_internal>.
Found 1-bit register for signal <wreadym3_internal>.
Found 1-bit register for signal <bl_awreadym1>.
Found 6-bit comparator equal for signal <cmp_ustr_w_m1> created at line 176
Found 6-bit comparator equal for signal <cmp_ustr_w_m2> created at line 177
Found 6-bit comparator equal for signal <cmp_ustr_w_m3> created at line 178
Summary:
inferred 605 D-type flip-flop(s).
inferred 3 Comparator(s).
inferred 48 Multiplexer(s).
Unit <write_channel> synthesized.
Synthesizing Unit <read_channel>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/read_chennal.vhd".
Found 1-bit register for signal <bl_arreadym2>.
Found 1-bit register for signal <bl_arreadym3>.
Found 1-bit register for signal <bl_arready>.
Found 1-bit register for signal <ust_rready>.
Found 1-bit register for signal <bl_rvalids>.
Found 1-bit register for signal <rvalids_dt>.
Found 1-bit register for signal <bl_arready_d>.
Found 1-bit register for signal <arvalidm1_d>.
Found 1-bit register for signal <arvalidm1_2d>.
Found 1-bit register for signal <arvalidm2_d>.
Found 1-bit register for signal <arvalidm2_2d>.
Found 1-bit register for signal <arvalidm3_d>.
Found 1-bit register for signal <arvalidm3_2d>.
Found 1-bit register for signal <arvalidm1_2d_dt>.
Found 1-bit register for signal <arvalidm2_2d_dt>.
Found 1-bit register for signal <arvalidm3_2d_dt>.
Found 26-bit register for signal <araddrm1_d>.
Found 26-bit register for signal <araddrm1_2d>.
Found 26-bit register for signal <araddrm2_d>.
Found 26-bit register for signal <araddrm2_2d>.
Found 26-bit register for signal <araddrm3_d>.
Found 26-bit register for signal <araddrm3_2d>.
Found 1-bit register for signal <arready_d>.
Found 1-bit register for signal <falling_arready>.
Found 1-bit register for signal <rising_arready_d>.
Found 26-bit register for signal <araddrs_m2d>.
Found 1-bit register for signal <arvalids_m2d>.
Found 26-bit register for signal <araddrs_md>.
Found 1-bit register for signal <arvalids_md>.
Found 3-bit register for signal <n_channel_rn_d>.
Found 1-bit register for signal <new_ch_r_d>.
Found 1-bit register for signal <new_ch_r_2d>.
Found 1-bit register for signal <new_ch_r_3d>.
Found 1-bit register for signal <new_ch_r_4d>.
Found 1-bit register for signal <new_ch_r_5d>.
Found 1-bit register for signal <start_rvalidm3_d>.
Found 1-bit register for signal <start_rvalidm2_d>.
Found 1-bit register for signal <start_rvalidm1_d>.
Found 1-bit register for signal <och1r>.
Found 1-bit register for signal <och2r>.
Found 1-bit register for signal <flag1r>.
Found 1-bit register for signal <flag2r>.
Found 3-bit register for signal <n_channel_r>.
Found 1-bit register for signal <arready_internal>.
Found 32-bit register for signal <rdatas_d>.
Found 32-bit register for signal <rdatas_2d>.
Found 32-bit register for signal <rdatas_3d>.
Found 32-bit register for signal <rdatas_4d>.
Found 1-bit register for signal <rvalids_d>.
Found 1-bit register for signal <rvalids_2d>.
Found 1-bit register for signal <rvalids_3d>.
Found 1-bit register for signal <rvalids_4d>.
Found 1-bit register for signal <rreadym1_d>.
Found 1-bit register for signal <rreadym2_d>.
Found 1-bit register for signal <rreadym3_d>.
Found 1-bit register for signal <start_d>.
Found 1-bit register for signal <rising_rreadym1_d>.
Found 1-bit register for signal <rising_rreadym2_d>.
Found 1-bit register for signal <rising_rreadym3_d>.
Found 1-bit register for signal <falling_rreadym1>.
Found 1-bit register for signal <falling_rreadym2>.
Found 1-bit register for signal <falling_rreadym3>.
Found 1-bit register for signal <arvalids_tmp>.
Found 1-bit register for signal <arvalids_tmp_d>.
Found 26-bit register for signal <araddrs_tmp>.
Found 1-bit register for signal <ARREADYm1>.
Found 1-bit register for signal <ARREADYm2>.
Found 1-bit register for signal <ARREADYm3>.
Found 4-bit register for signal <ARID>.
Found 1-bit register for signal <arreadym1_internal>.
Found 1-bit register for signal <arreadym2_internal>.
Found 1-bit register for signal <arreadym3_internal>.
Found 3-bit register for signal <rid_tmp>.
Found 32-bit register for signal <RDATAm1>.
Found 1-bit register for signal <rvalidm1_tmp>.
Found 32-bit register for signal <RDATAm2>.
Found 1-bit register for signal <rvalidm2_tmp>.
Found 32-bit register for signal <RDATAm3>.
Found 1-bit register for signal <rvalidm3_tmp>.
Found 1-bit register for signal <rreadys_tmp>.
Found 1-bit register for signal <rreadys_internal>.
Found 1-bit register for signal <rvalidm1_tmp_d>.
Found 1-bit register for signal <rvalidm2_tmp_d>.
Found 1-bit register for signal <rvalidm3_tmp_d>.
Found 1-bit register for signal <bl_arreadym1>.
Found 6-bit comparator equal for signal <cmp_ustr_r_m1> created at line 141
Found 6-bit comparator equal for signal <cmp_ustr_r_m2> created at line 142
Found 6-bit comparator equal for signal <cmp_ustr_r_m3> created at line 143
Summary:
inferred 536 D-type flip-flop(s).
inferred 49 Multiplexer(s).
Unit <read_channel> synthesized.
Synthesizing Unit <Kontr_QDR_OU_AXI>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/Kontr_QDR_OU_AXI.vhd".
depth = 5
depth_zap = 5
depth_op = 7
depth2 = 6
WARNING:Xst:647 - Input <AWADDR<31:23>> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <AWADDR<1:0>> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <ARADDR<31:23>> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <ARADDR<1:0>> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
Found 1-bit register for signal <bl_awvalid>.
Found 1-bit register for signal <wready_tmp>.
Found 1-bit register for signal <bl_wvalid>.
Found 1-bit register for signal <zapros_och_wr_d>.
Found 1-bit register for signal <zapros_och_wr_2d>.
Found 1-bit register for signal <zapros_och_wr_3d>.
Found 1-bit register for signal <zapros_och_rd_d>.
Found 1-bit register for signal <zapros_och_rd_2d>.
Found 1-bit register for signal <zapros_och_rd_3d>.
Found 1-bit register for signal <awvalid_d>.
Found 1-bit register for signal <awvalid_2d>.
Found 1-bit register for signal <awready_2d>.
Found 1-bit register for signal <STROB_BVV>.
Found 32-bit register for signal <DATA_BVV>.
Found 1-bit register for signal <end_op>.
Found 1-bit register for signal <och_rd_tmp>.
Found 1-bit register for signal <och_wr_tmp>.
Found 21-bit register for signal <write_addr>.
Found 21-bit register for signal <read_addr>.
Found 32-bit register for signal <data_wr>.
Found 1-bit register for signal <wr_qdr>.
Found 1-bit register for signal <rd_qdr>.
Found 1-bit register for signal <rd_ram>.
Found 1-bit register for signal <rvalid_tmp>.
Found 1-bit register for signal <arready_tmp>.
Found 1-bit register for signal <rising_arvalid_sh_d>.
Found 6-bit register for signal <rising_arvalid_sh>.
Found 6-bit register for signal <falling_arvalid_sh>.
Found 6-bit register for signal <t_zap_conv>.
Found 32-bit register for signal <conv_data<6>>.
Found 32-bit register for signal <conv_data<5>>.
Found 32-bit register for signal <conv_data<4>>.
Found 32-bit register for signal <conv_data<3>>.
Found 32-bit register for signal <conv_data<2>>.
Found 32-bit register for signal <conv_data<1>>.
Found 32-bit register for signal <conv_data<0>>.
Found 7-bit register for signal <falling_arvalid_sh_ce>.
Found 8-bit register for signal <t_op_conv>.
Found 32-bit register for signal <RDATA>.
Found 1-bit register for signal <conv>.
Found 1-bit register for signal <zap_conv>.
Found 1-bit register for signal <op_conv>.
Found 4-bit register for signal <id_in>.
Found 4-bit register for signal <RID>.
Found 1-bit register for signal <arvalid_d>.
Found 1-bit register for signal <awready_tmp>.
Summary:
inferred 432 D-type flip-flop(s).
inferred 12 Multiplexer(s).
Unit <Kontr_QDR_OU_AXI> synthesized.
Synthesizing Unit <AXI_SPI_2_LINE>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/AXI_SPI_2_LINE.vhf".
Summary:
no macro.
Unit <AXI_SPI_2_LINE> synthesized.
Synthesizing Unit <Block_AMBA_AXI_slave>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/SPI/Block_AMBA_slave.vhd".
WARNING:Xst:647 - Input <AWADDR<31:24>> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <AWADDR<22:6>> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <ARADDR<31:24>> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <ARADDR<22:6>> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
Found 4-bit register for signal <ARID_s>.
Found 2-bit register for signal <RRESP>.
Found 1-bit register for signal <BVALID>.
Found 1-bit register for signal <datazap>.
Found 1-bit register for signal <RD>.
Found 1-bit register for signal <WR_s>.
Found 1-bit register for signal <PROC_stop_d>.
Found 1-bit register for signal <PROC_stop_d1>.
Found 1-bit register for signal <PROC_stop_d2>.
Found 5-bit register for signal <s_SHADR_R>.
Found 1-bit register for signal <ARREADY_s>.
Found 1-bit register for signal <adr_l>.
Found 5-bit register for signal <s_SHADR>.
Found 1-bit register for signal <data_l>.
Found 32-bit register for signal <SHD_TO_OUT>.
Found 1-bit register for signal <AWREADY_s>.
Found 1-bit register for signal <WREADY_s>.
Found 1-bit register for signal <RVALID_s>.
Found 2-bit register for signal <BRESP>.
Summary:
inferred 67 D-type flip-flop(s).
inferred 2 Multiplexer(s).
Unit <Block_AMBA_AXI_slave> synthesized.
CODE
Synthesizing Unit <Block_SPI_2LINE>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/SPI/Block_SPI_2LINE.vhd".
WARNING:Xst:647 - Input <CLR> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
Found 16-bit register for signal <RG_KD>.
Found 5-bit register for signal <RG_Kbit>.
Found 5-bit register for signal <RG_Kbit_symbol>.
Found 32-bit register for signal <RGD_out>.
Found 32-bit register for signal <RGS_out>.
Found 4-bit register for signal <count_t>.
Found 5-bit register for signal <COUNT_Kbit>.
Found 5-bit register for signal <COUNT_Kbit_symbol>.
Found 16-bit register for signal <COUNT_KD>.
Found 1-bit register for signal <start_sclk>.
Found 1-bit register for signal <OD>.
Found 8-bit register for signal <RG_com>.
Found 8-bit register for signal <RG_com_isp>.
Found 1-bit register for signal <data_got_s>.
Found 1-bit register for signal <KD_0>.
Found 1-bit register for signal <KD_0_data>.
Found 1-bit register for signal <s_P_in>.
Found 1-bit register for signal <s_P_out>.
Found 1-bit register for signal <P_in>.
Found 1-bit register for signal <P_out>.
Found 1-bit register for signal <s_RGD_out_busy>.
Found 1-bit register for signal <s_RG_com_busy>.
Found 1-bit register for signal <s_RGD_in_ready_d0>.
Found 1-bit register for signal <RGD_in_zap>.
Found 8-bit register for signal <status>.
Found 1-bit register for signal <sclk_tmp>.
Found 1-bit register for signal <perepol>.
Found 1-bit register for signal <P_in_d1>.
Found 1-bit register for signal <s_RG_loaded>.
Found 32-bit register for signal <SHD_TO_IN>.
Found 1-bit register for signal <s_RGD_in_ready>.
Found 1-bit register for signal <data_delay>.
Found 1-bit register for signal <process_stoped>.
Found 1-bit register for signal <com_in>.
Found 1-bit register for signal <com_out>.
Found 1-bit register for signal <Pch0>.
Found 1-bit register for signal <Pch1>.
Found 1-bit register for signal <T0>.
Found 1-bit register for signal <T0_in>.
Found 1-bit register for signal <T_in>.
Found 1-bit register for signal <T>.
Found 32-bit register for signal <RGS_in>.
Found 1-bit register for signal <read_enable>.
Found 32-bit register for signal <RGD_in>.
Found 5-bit register for signal <RG_tp_kc>.
Found 4-bit adder for signal <count_t[3]_GND_813_o_add_0_OUT> created at line 196.
Found 5-bit subtractor for signal <GND_813_o_GND_813_o_sub_66_OUT<4:0>> created at line 300.
Found 5-bit subtractor for signal <GND_813_o_GND_813_o_sub_123_OUT<4:0>> created at line 418.
Found 16-bit subtractor for signal <GND_813_o_GND_813_o_sub_176_OUT<15:0>> created at line 550.
Found 1-bit 4-to-1 multiplexer for signal <GND_813_o_count_t[0]_MUX_654_o> created at line 806.
Summary:
inferred 4 Adder/Subtractor(s).
inferred 274 D-type flip-flop(s).
inferred 1220 Multiplexer(s).
Unit <Block_SPI_2LINE> synthesized.
Synthesizing Unit <BUSok>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/BUSok.vhf".
Set property "HU_SET = XLXI_11_0_191" for instance <XLXI_11_0>.
Set property "HU_SET = XLXI_11_1_190" for instance <XLXI_11_1>.
Set property "HU_SET = XLXI_11_2_189" for instance <XLXI_11_2>.
Set property "HU_SET = XLXI_11_3_188" for instance <XLXI_11_3>.
Set property "HU_SET = XLXI_11_4_187" for instance <XLXI_11_4>.
Set property "HU_SET = XLXI_11_5_186" for instance <XLXI_11_5>.
Set property "HU_SET = XLXI_11_6_185" for instance <XLXI_11_6>.
Set property "HU_SET = XLXI_11_7_184" for instance <XLXI_11_7>.
Set property "HU_SET = XLXI_11_8_183" for instance <XLXI_11_8>.
Set property "HU_SET = XLXI_11_9_182" for instance <XLXI_11_9>.
Set property "HU_SET = XLXI_11_10_181" for instance <XLXI_11_10>.
Set property "HU_SET = XLXI_11_11_180" for instance <XLXI_11_11>.
Set property "HU_SET = XLXI_11_12_179" for instance <XLXI_11_12>.
Set property "HU_SET = XLXI_11_13_178" for instance <XLXI_11_13>.
Set property "HU_SET = XLXI_11_14_177" for instance <XLXI_11_14>.
Set property "HU_SET = XLXI_11_15_176" for instance <XLXI_11_15>.
Set property "HU_SET = XLXI_11_16_175" for instance <XLXI_11_16>.
Set property "HU_SET = XLXI_11_17_174" for instance <XLXI_11_17>.
Set property "HU_SET = XLXI_11_18_173" for instance <XLXI_11_18>.
Set property "HU_SET = XLXI_11_19_172" for instance <XLXI_11_19>.
Set property "HU_SET = XLXI_11_20_171" for instance <XLXI_11_20>.
Set property "HU_SET = XLXI_11_21_170" for instance <XLXI_11_21>.
Set property "HU_SET = XLXI_11_22_169" for instance <XLXI_11_22>.
Set property "HU_SET = XLXI_11_23_168" for instance <XLXI_11_23>.
Set property "HU_SET = XLXI_11_24_167" for instance <XLXI_11_24>.
Set property "HU_SET = XLXI_11_25_166" for instance <XLXI_11_25>.
Set property "HU_SET = XLXI_11_26_165" for instance <XLXI_11_26>.
Set property "HU_SET = XLXI_11_27_164" for instance <XLXI_11_27>.
Set property "HU_SET = XLXI_11_28_163" for instance <XLXI_11_28>.
Set property "HU_SET = XLXI_11_29_162" for instance <XLXI_11_29>.
Set property "HU_SET = XLXI_11_30_161" for instance <XLXI_11_30>.
Set property "HU_SET = XLXI_11_31_160" for instance <XLXI_11_31>.
Set property "HU_SET = XLXI_11_32_159" for instance <XLXI_11_32>.
Set property "HU_SET = XLXI_11_33_158" for instance <XLXI_11_33>.
Set property "HU_SET = XLXI_11_34_157" for instance <XLXI_11_34>.
Set property "HU_SET = XLXI_11_35_156" for instance <XLXI_11_35>.
Set property "HU_SET = XLXI_11_36_155" for instance <XLXI_11_36>.
Set property "HU_SET = XLXI_11_37_154" for instance <XLXI_11_37>.
Set property "HU_SET = XLXI_11_38_153" for instance <XLXI_11_38>.
Set property "HU_SET = XLXI_11_39_152" for instance <XLXI_11_39>.
Set property "HU_SET = XLXI_11_40_151" for instance <XLXI_11_40>.
Set property "HU_SET = XLXI_11_41_150" for instance <XLXI_11_41>.
Set property "HU_SET = XLXI_11_42_149" for instance <XLXI_11_42>.
Set property "HU_SET = XLXI_11_43_148" for instance <XLXI_11_43>.
Set property "HU_SET = XLXI_11_44_147" for instance <XLXI_11_44>.
Set property "HU_SET = XLXI_11_45_146" for instance <XLXI_11_45>.
Set property "HU_SET = XLXI_11_46_145" for instance <XLXI_11_46>.
Set property "HU_SET = XLXI_11_47_144" for instance <XLXI_11_47>.
Set property "HU_SET = XLXI_11_48_143" for instance <XLXI_11_48>.
Set property "HU_SET = XLXI_11_49_142" for instance <XLXI_11_49>.
Set property "HU_SET = XLXI_11_50_141" for instance <XLXI_11_50>.
Set property "HU_SET = XLXI_11_51_140" for instance <XLXI_11_51>.
Set property "HU_SET = XLXI_11_52_139" for instance <XLXI_11_52>.
Set property "HU_SET = XLXI_11_53_138" for instance <XLXI_11_53>.
Set property "HU_SET = XLXI_11_54_137" for instance <XLXI_11_54>.
Set property "HU_SET = XLXI_11_55_136" for instance <XLXI_11_55>.
Set property "HU_SET = XLXI_11_56_135" for instance <XLXI_11_56>.
Set property "HU_SET = XLXI_11_57_134" for instance <XLXI_11_57>.
Set property "HU_SET = XLXI_11_58_133" for instance <XLXI_11_58>.
Set property "HU_SET = XLXI_11_59_132" for instance <XLXI_11_59>.
Set property "HU_SET = XLXI_11_60_131" for instance <XLXI_11_60>.
Set property "HU_SET = XLXI_11_61_130" for instance <XLXI_11_61>.
Set property "HU_SET = XLXI_11_62_129" for instance <XLXI_11_62>.
Set property "HU_SET = XLXI_11_63_128" for instance <XLXI_11_63>.
Set property "HU_SET = XLXI_654_0_201" for instance <XLXI_654_0>.
Set property "HU_SET = XLXI_654_1_200" for instance <XLXI_654_1>.
Set property "HU_SET = XLXI_654_2_199" for instance <XLXI_654_2>.
Set property "HU_SET = XLXI_654_3_198" for instance <XLXI_654_3>.
Set property "HU_SET = XLXI_654_4_197" for instance <XLXI_654_4>.
Set property "HU_SET = XLXI_654_5_196" for instance <XLXI_654_5>.
Set property "HU_SET = XLXI_654_6_195" for instance <XLXI_654_6>.
Set property "HU_SET = XLXI_654_7_194" for instance <XLXI_654_7>.
Set property "HU_SET = XLXI_654_8_193" for instance <XLXI_654_8>.
Set property "HU_SET = XLXI_654_9_192" for instance <XLXI_654_9>.
Set property "HU_SET = XLXI_655_0_211" for instance <XLXI_655_0>.
Set property "HU_SET = XLXI_655_1_210" for instance <XLXI_655_1>.
Set property "HU_SET = XLXI_655_2_209" for instance <XLXI_655_2>.
Set property "HU_SET = XLXI_655_3_208" for instance <XLXI_655_3>.
Set property "HU_SET = XLXI_655_4_207" for instance <XLXI_655_4>.
Set property "HU_SET = XLXI_655_5_206" for instance <XLXI_655_5>.
Set property "HU_SET = XLXI_655_6_205" for instance <XLXI_655_6>.
Set property "HU_SET = XLXI_655_7_204" for instance <XLXI_655_7>.
Set property "HU_SET = XLXI_655_8_203" for instance <XLXI_655_8>.
Set property "HU_SET = XLXI_655_9_202" for instance <XLXI_655_9>.
Set property "HU_SET = XLXI_658_0_221" for instance <XLXI_658_0>.
Set property "HU_SET = XLXI_658_1_220" for instance <XLXI_658_1>.
Set property "HU_SET = XLXI_658_2_219" for instance <XLXI_658_2>.
Set property "HU_SET = XLXI_658_3_218" for instance <XLXI_658_3>.
Set property "HU_SET = XLXI_658_4_217" for instance <XLXI_658_4>.
Set property "HU_SET = XLXI_658_5_216" for instance <XLXI_658_5>.
Set property "HU_SET = XLXI_658_6_215" for instance <XLXI_658_6>.
Set property "HU_SET = XLXI_658_7_214" for instance <XLXI_658_7>.
Set property "HU_SET = XLXI_658_8_213" for instance <XLXI_658_8>.
Set property "HU_SET = XLXI_658_9_212" for instance <XLXI_658_9>.
Set property "HU_SET = XLXI_741_0_253" for instance <XLXI_741_0>.
Set property "HU_SET = XLXI_741_1_252" for instance <XLXI_741_1>.
Set property "HU_SET = XLXI_741_2_251" for instance <XLXI_741_2>.
Set property "HU_SET = XLXI_741_3_250" for instance <XLXI_741_3>.
Set property "HU_SET = XLXI_741_4_249" for instance <XLXI_741_4>.
Set property "HU_SET = XLXI_741_5_248" for instance <XLXI_741_5>.
Set property "HU_SET = XLXI_741_6_247" for instance <XLXI_741_6>.
Set property "HU_SET = XLXI_741_7_246" for instance <XLXI_741_7>.
Set property "HU_SET = XLXI_741_8_245" for instance <XLXI_741_8>.
Set property "HU_SET = XLXI_741_9_244" for instance <XLXI_741_9>.
Set property "HU_SET = XLXI_741_10_243" for instance <XLXI_741_10>.
Set property "HU_SET = XLXI_741_11_242" for instance <XLXI_741_11>.
Set property "HU_SET = XLXI_741_12_241" for instance <XLXI_741_12>.
Set property "HU_SET = XLXI_741_13_240" for instance <XLXI_741_13>.
Set property "HU_SET = XLXI_741_14_239" for instance <XLXI_741_14>.
Set property "HU_SET = XLXI_741_15_238" for instance <XLXI_741_15>.
Set property "HU_SET = XLXI_741_16_237" for instance <XLXI_741_16>.
Set property "HU_SET = XLXI_741_17_236" for instance <XLXI_741_17>.
Set property "HU_SET = XLXI_741_18_235" for instance <XLXI_741_18>.
Set property "HU_SET = XLXI_741_19_234" for instance <XLXI_741_19>.
Set property "HU_SET = XLXI_741_20_233" for instance <XLXI_741_20>.
Set property "HU_SET = XLXI_741_21_232" for instance <XLXI_741_21>.
Set property "HU_SET = XLXI_741_22_231" for instance <XLXI_741_22>.
Set property "HU_SET = XLXI_741_23_230" for instance <XLXI_741_23>.
Set property "HU_SET = XLXI_741_24_229" for instance <XLXI_741_24>.
Set property "HU_SET = XLXI_741_25_228" for instance <XLXI_741_25>.
Set property "HU_SET = XLXI_741_26_227" for instance <XLXI_741_26>.
Set property "HU_SET = XLXI_741_27_226" for instance <XLXI_741_27>.
Set property "HU_SET = XLXI_741_28_225" for instance <XLXI_741_28>.
Set property "HU_SET = XLXI_741_29_224" for instance <XLXI_741_29>.
Set property "HU_SET = XLXI_741_30_223" for instance <XLXI_741_30>.
Set property "HU_SET = XLXI_741_31_222" for instance <XLXI_741_31>.
Set property "HU_SET = XLXI_742_0_285" for instance <XLXI_742_0>.
Set property "HU_SET = XLXI_742_1_284" for instance <XLXI_742_1>.
Set property "HU_SET = XLXI_742_2_283" for instance <XLXI_742_2>.
Set property "HU_SET = XLXI_742_3_282" for instance <XLXI_742_3>.
Set property "HU_SET = XLXI_742_4_281" for instance <XLXI_742_4>.
Set property "HU_SET = XLXI_742_5_280" for instance <XLXI_742_5>.
Set property "HU_SET = XLXI_742_6_279" for instance <XLXI_742_6>.
Set property "HU_SET = XLXI_742_7_278" for instance <XLXI_742_7>.
Set property "HU_SET = XLXI_742_8_277" for instance <XLXI_742_8>.
Set property "HU_SET = XLXI_742_9_276" for instance <XLXI_742_9>.
Set property "HU_SET = XLXI_742_10_275" for instance <XLXI_742_10>.
Set property "HU_SET = XLXI_742_11_274" for instance <XLXI_742_11>.
Set property "HU_SET = XLXI_742_12_273" for instance <XLXI_742_12>.
Set property "HU_SET = XLXI_742_13_272" for instance <XLXI_742_13>.
Set property "HU_SET = XLXI_742_14_271" for instance <XLXI_742_14>.
Set property "HU_SET = XLXI_742_15_270" for instance <XLXI_742_15>.
Set property "HU_SET = XLXI_742_16_269" for instance <XLXI_742_16>.
Set property "HU_SET = XLXI_742_17_268" for instance <XLXI_742_17>.
Set property "HU_SET = XLXI_742_18_267" for instance <XLXI_742_18>.
Set property "HU_SET = XLXI_742_19_266" for instance <XLXI_742_19>.
Set property "HU_SET = XLXI_742_20_265" for instance <XLXI_742_20>.
Set property "HU_SET = XLXI_742_21_264" for instance <XLXI_742_21>.
Set property "HU_SET = XLXI_742_22_263" for instance <XLXI_742_22>.
Set property "HU_SET = XLXI_742_23_262" for instance <XLXI_742_23>.
Set property "HU_SET = XLXI_742_24_261" for instance <XLXI_742_24>.
Set property "HU_SET = XLXI_742_25_260" for instance <XLXI_742_25>.
Set property "HU_SET = XLXI_742_26_259" for instance <XLXI_742_26>.
Set property "HU_SET = XLXI_742_27_258" for instance <XLXI_742_27>.
Set property "HU_SET = XLXI_742_28_257" for instance <XLXI_742_28>.
Set property "HU_SET = XLXI_742_29_256" for instance <XLXI_742_29>.
Set property "HU_SET = XLXI_742_30_255" for instance <XLXI_742_30>.
Set property "HU_SET = XLXI_742_31_254" for instance <XLXI_742_31>.
Set property "HU_SET = XLXI_744_0_317" for instance <XLXI_744_0>.
Set property "HU_SET = XLXI_744_1_316" for instance <XLXI_744_1>.
Set property "HU_SET = XLXI_744_2_315" for instance <XLXI_744_2>.
Set property "HU_SET = XLXI_744_3_314" for instance <XLXI_744_3>.
Set property "HU_SET = XLXI_744_4_313" for instance <XLXI_744_4>.
Set property "HU_SET = XLXI_744_5_312" for instance <XLXI_744_5>.
Set property "HU_SET = XLXI_744_6_311" for instance <XLXI_744_6>.
Set property "HU_SET = XLXI_744_7_310" for instance <XLXI_744_7>.
Set property "HU_SET = XLXI_744_8_309" for instance <XLXI_744_8>.
Set property "HU_SET = XLXI_744_9_308" for instance <XLXI_744_9>.
Set property "HU_SET = XLXI_744_10_307" for instance <XLXI_744_10>.
Set property "HU_SET = XLXI_744_11_306" for instance <XLXI_744_11>.
Set property "HU_SET = XLXI_744_12_305" for instance <XLXI_744_12>.
Set property "HU_SET = XLXI_744_13_304" for instance <XLXI_744_13>.
Set property "HU_SET = XLXI_744_14_303" for instance <XLXI_744_14>.
Set property "HU_SET = XLXI_744_15_302" for instance <XLXI_744_15>.
Set property "HU_SET = XLXI_744_16_301" for instance <XLXI_744_16>.
Set property "HU_SET = XLXI_744_17_300" for instance <XLXI_744_17>.
Set property "HU_SET = XLXI_744_18_299" for instance <XLXI_744_18>.
Set property "HU_SET = XLXI_744_19_298" for instance <XLXI_744_19>.
Set property "HU_SET = XLXI_744_20_297" for instance <XLXI_744_20>.
Set property "HU_SET = XLXI_744_21_296" for instance <XLXI_744_21>.
Set property "HU_SET = XLXI_744_22_295" for instance <XLXI_744_22>.
Set property "HU_SET = XLXI_744_23_294" for instance <XLXI_744_23>.
Set property "HU_SET = XLXI_744_24_293" for instance <XLXI_744_24>.
Set property "HU_SET = XLXI_744_25_292" for instance <XLXI_744_25>.
Set property "HU_SET = XLXI_744_26_291" for instance <XLXI_744_26>.
Set property "HU_SET = XLXI_744_27_290" for instance <XLXI_744_27>.
Set property "HU_SET = XLXI_744_28_289" for instance <XLXI_744_28>.
Set property "HU_SET = XLXI_744_29_288" for instance <XLXI_744_29>.
Set property "HU_SET = XLXI_744_30_287" for instance <XLXI_744_30>.
Set property "HU_SET = XLXI_744_31_286" for instance <XLXI_744_31>.
Set property "HU_SET = XLXI_751_0_323" for instance <XLXI_751_0>.
Set property "HU_SET = XLXI_751_1_322" for instance <XLXI_751_1>.
Set property "HU_SET = XLXI_751_2_321" for instance <XLXI_751_2>.
Set property "HU_SET = XLXI_751_3_320" for instance <XLXI_751_3>.
Set property "HU_SET = XLXI_751_4_319" for instance <XLXI_751_4>.
Set property "HU_SET = XLXI_751_5_318" for instance <XLXI_751_5>.
Set property "HU_SET = XLXI_758_0_355" for instance <XLXI_758_0>.
Set property "HU_SET = XLXI_758_1_354" for instance <XLXI_758_1>.
Set property "HU_SET = XLXI_758_2_353" for instance <XLXI_758_2>.
Set property "HU_SET = XLXI_758_3_352" for instance <XLXI_758_3>.
Set property "HU_SET = XLXI_758_4_351" for instance <XLXI_758_4>.
Set property "HU_SET = XLXI_758_5_350" for instance <XLXI_758_5>.
Set property "HU_SET = XLXI_758_6_349" for instance <XLXI_758_6>.
Set property "HU_SET = XLXI_758_7_348" for instance <XLXI_758_7>.
Set property "HU_SET = XLXI_758_8_347" for instance <XLXI_758_8>.
Set property "HU_SET = XLXI_758_9_346" for instance <XLXI_758_9>.
Set property "HU_SET = XLXI_758_10_345" for instance <XLXI_758_10>.
Set property "HU_SET = XLXI_758_11_344" for instance <XLXI_758_11>.
Set property "HU_SET = XLXI_758_12_343" for instance <XLXI_758_12>.
Set property "HU_SET = XLXI_758_13_342" for instance <XLXI_758_13>.
Set property "HU_SET = XLXI_758_14_341" for instance <XLXI_758_14>.
Set property "HU_SET = XLXI_758_15_340" for instance <XLXI_758_15>.
Set property "HU_SET = XLXI_758_16_339" for instance <XLXI_758_16>.
Set property "HU_SET = XLXI_758_17_338" for instance <XLXI_758_17>.
Set property "HU_SET = XLXI_758_18_337" for instance <XLXI_758_18>.
Set property "HU_SET = XLXI_758_19_336" for instance <XLXI_758_19>.
Set property "HU_SET = XLXI_758_20_335" for instance <XLXI_758_20>.
Set property "HU_SET = XLXI_758_21_334" for instance <XLXI_758_21>.
Set property "HU_SET = XLXI_758_22_333" for instance <XLXI_758_22>.
Set property "HU_SET = XLXI_758_23_332" for instance <XLXI_758_23>.
Set property "HU_SET = XLXI_758_24_331" for instance <XLXI_758_24>.
Set property "HU_SET = XLXI_758_25_330" for instance <XLXI_758_25>.
Set property "HU_SET = XLXI_758_26_329" for instance <XLXI_758_26>.
Set property "HU_SET = XLXI_758_27_328" for instance <XLXI_758_27>.
Set property "HU_SET = XLXI_758_28_327" for instance <XLXI_758_28>.
Set property "HU_SET = XLXI_758_29_326" for instance <XLXI_758_29>.
Set property "HU_SET = XLXI_758_30_325" for instance <XLXI_758_30>.
Set property "HU_SET = XLXI_758_31_324" for instance <XLXI_758_31>.
Set property "HU_SET = XLXI_762_0_377" for instance <XLXI_762_0>.
Set property "HU_SET = XLXI_762_1_376" for instance <XLXI_762_1>.
Set property "HU_SET = XLXI_762_2_375" for instance <XLXI_762_2>.
Set property "HU_SET = XLXI_762_3_374" for instance <XLXI_762_3>.
Set property "HU_SET = XLXI_762_4_373" for instance <XLXI_762_4>.
Set property "HU_SET = XLXI_762_5_372" for instance <XLXI_762_5>.
Set property "HU_SET = XLXI_762_6_371" for instance <XLXI_762_6>.
Set property "HU_SET = XLXI_762_7_370" for instance <XLXI_762_7>.
Set property "HU_SET = XLXI_762_8_369" for instance <XLXI_762_8>.
Set property "HU_SET = XLXI_762_9_368" for instance <XLXI_762_9>.
Set property "HU_SET = XLXI_762_10_367" for instance <XLXI_762_10>.
Set property "HU_SET = XLXI_762_11_366" for instance <XLXI_762_11>.
Set property "HU_SET = XLXI_762_12_365" for instance <XLXI_762_12>.
Set property "HU_SET = XLXI_762_13_364" for instance <XLXI_762_13>.
Set property "HU_SET = XLXI_762_14_363" for instance <XLXI_762_14>.
Set property "HU_SET = XLXI_762_15_362" for instance <XLXI_762_15>.
Set property "HU_SET = XLXI_762_16_361" for instance <XLXI_762_16>.
Set property "HU_SET = XLXI_762_17_360" for instance <XLXI_762_17>.
Set property "HU_SET = XLXI_762_18_359" for instance <XLXI_762_18>.
Set property "HU_SET = XLXI_762_19_358" for instance <XLXI_762_19>.
Set property "HU_SET = XLXI_762_20_357" for instance <XLXI_762_20>.
Set property "HU_SET = XLXI_762_21_356" for instance <XLXI_762_21>.
WARNING:Xst:647 - Input <BRESP<1:0>> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <RRESP<1:0>> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <BVALID> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <PR> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/BUSok.vhf" line 1858: Output port <TC> of the instance <CT_A> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/BUSok.vhf" line 1868: Output port <TC> of the instance <CT_A1> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/BUSok.vhf" line 1878: Output port <TC> of the instance <CT_A2> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/BUSok.vhf" line 4316: Output port <Q> of the instance <XLXI_740_22> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/BUSok.vhf" line 4321: Output port <Q> of the instance <XLXI_740_23> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/BUSok.vhf" line 4326: Output port <Q> of the instance <XLXI_740_24> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/BUSok.vhf" line 4331: Output port <Q> of the instance <XLXI_740_25> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/BUSok.vhf" line 4336: Output port <Q> of the instance <XLXI_740_26> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/BUSok.vhf" line 4341: Output port <Q> of the instance <XLXI_740_27> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/BUSok.vhf" line 4346: Output port <Q> of the instance <XLXI_740_28> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/BUSok.vhf" line 4351: Output port <Q> of the instance <XLXI_740_29> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/BUSok.vhf" line 4356: Output port <Q> of the instance <XLXI_740_30> is unconnected or connected to loadless signal.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/BUSok.vhf" line 4361: Output port <Q> of the instance <XLXI_740_31> is unconnected or connected to loadless signal.
Summary:
no macro.
Unit <BUSok> synthesized.
CODE
Synthesizing Unit <CT_AK>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/CT_AK.vhd".
Found 10-bit register for signal <tmp>.
Found 1-bit register for signal <q_tmp<10>>.
Found 10-bit adder for signal <tmp[9]_GND_815_o_add_2_OUT> created at line 74.
Summary:
inferred 1 Adder/Subtractor(s).
inferred 11 D-type flip-flop(s).
Unit <CT_AK> synthesized.
Synthesizing Unit <ALU_I_v6_MUSER_BUSok>.
Set property "HU_SET = XLXI_872_0_95" for instance <XLXI_872_0>.
Set property "HU_SET = XLXI_872_1_94" for instance <XLXI_872_1>.
Set property "HU_SET = XLXI_872_2_93" for instance <XLXI_872_2>.
Set property "HU_SET = XLXI_872_3_92" for instance <XLXI_872_3>.
Set property "HU_SET = XLXI_872_4_91" for instance <XLXI_872_4>.
Set property "HU_SET = XLXI_872_5_90" for instance <XLXI_872_5>.
Set property "HU_SET = XLXI_872_6_89" for instance <XLXI_872_6>.
Set property "HU_SET = XLXI_872_7_88" for instance <XLXI_872_7>.
Set property "HU_SET = XLXI_872_8_87" for instance <XLXI_872_8>.
Set property "HU_SET = XLXI_872_9_86" for instance <XLXI_872_9>.
Set property "HU_SET = XLXI_872_10_85" for instance <XLXI_872_10>.
Set property "HU_SET = XLXI_872_11_84" for instance <XLXI_872_11>.
Set property "HU_SET = XLXI_872_12_83" for instance <XLXI_872_12>.
Set property "HU_SET = XLXI_872_13_82" for instance <XLXI_872_13>.
Set property "HU_SET = XLXI_872_14_81" for instance <XLXI_872_14>.
Set property "HU_SET = XLXI_872_15_80" for instance <XLXI_872_15>.
Set property "HU_SET = XLXI_872_16_79" for instance <XLXI_872_16>.
Set property "HU_SET = XLXI_872_17_78" for instance <XLXI_872_17>.
Set property "HU_SET = XLXI_872_18_77" for instance <XLXI_872_18>.
Set property "HU_SET = XLXI_872_19_76" for instance <XLXI_872_19>.
Set property "HU_SET = XLXI_872_20_75" for instance <XLXI_872_20>.
Set property "HU_SET = XLXI_872_21_74" for instance <XLXI_872_21>.
Set property "HU_SET = XLXI_872_22_73" for instance <XLXI_872_22>.
Set property "HU_SET = XLXI_872_23_72" for instance <XLXI_872_23>.
Set property "HU_SET = XLXI_872_24_71" for instance <XLXI_872_24>.
Set property "HU_SET = XLXI_872_25_70" for instance <XLXI_872_25>.
Set property "HU_SET = XLXI_872_26_69" for instance <XLXI_872_26>.
Set property "HU_SET = XLXI_872_27_68" for instance <XLXI_872_27>.
Set property "HU_SET = XLXI_872_28_67" for instance <XLXI_872_28>.
Set property "HU_SET = XLXI_872_29_66" for instance <XLXI_872_29>.
Set property "HU_SET = XLXI_872_30_65" for instance <XLXI_872_30>.
Set property "HU_SET = XLXI_872_31_64" for instance <XLXI_872_31>.
Set property "INIT = 6A66CC00EAEE8866" for instance <XLXI_893_0>.
Set property "INIT = 6A66CC00EAEE8866" for instance <XLXI_893_1>.
Set property "INIT = 6A66CC00EAEE8866" for instance <XLXI_893_2>.
Set property "INIT = 6A66CC00EAEE8866" for instance <XLXI_893_3>.
Set property "INIT = 6A66CC00EAEE8866" for instance <XLXI_896_0>.
Set property "INIT = 6A66CC00EAEE8866" for instance <XLXI_896_1>.
Set property "INIT = 6A66CC00EAEE8866" for instance <XLXI_896_2>.
Set property "INIT = 6A66CC00EAEE8866" for instance <XLXI_896_3>.
Set property "INIT = 6A66CC00EAEE8866" for instance <XLXI_898_0>.
Set property "INIT = 6A66CC00EAEE8866" for instance <XLXI_898_1>.
Set property "INIT = 6A66CC00EAEE8866" for instance <XLXI_898_2>.
Set property "INIT = 6A66CC00EAEE8866" for instance <XLXI_898_3>.
Set property "INIT = 6A66CC00EAEE8866" for instance <XLXI_900_0>.
Set property "INIT = 6A66CC00EAEE8866" for instance <XLXI_900_1>.
Set property "INIT = 6A66CC00EAEE8866" for instance <XLXI_900_2>.
Set property "INIT = 6A66CC00EAEE8866" for instance <XLXI_900_3>.
Set property "INIT = 6A66AA00EAEE8866" for instance <XLXI_906_0>.
Set property "INIT = 6A66AA00EAEE8866" for instance <XLXI_906_1>.
Set property "INIT = 6A66AA00EAEE8866" for instance <XLXI_906_2>.
Set property "INIT = 6A66AA00EAEE8866" for instance <XLXI_906_3>.
Set property "INIT = 6A66AA00EAEE8866" for instance <XLXI_912_0>.
Set property "INIT = 6A66AA00EAEE8866" for instance <XLXI_912_1>.
Set property "INIT = 6A66AA00EAEE8866" for instance <XLXI_912_2>.
Set property "INIT = 6A66AA00EAEE8866" for instance <XLXI_912_3>.
Set property "INIT = 6A66AA00EAEE8866" for instance <XLXI_916_0>.
Set property "INIT = 6A66AA00EAEE8866" for instance <XLXI_916_1>.
Set property "INIT = 6A66AA00EAEE8866" for instance <XLXI_916_2>.
Set property "INIT = 6A66AA00EAEE8866" for instance <XLXI_916_3>.
Set property "INIT = 6A66AA00EAEE8866" for instance <XLXI_918_0>.
Set property "INIT = 6A66AA00EAEE8866" for instance <XLXI_918_1>.
Set property "INIT = 6A66AA00EAEE8866" for instance <XLXI_918_2>.
Set property "INIT = 6A66AA00EAEE8866" for instance <XLXI_918_3>.
Set property "INIT = 6A66AA00EAEE8866" for instance <XLXI_928>.
Set property "HU_SET = XLXI_932_0_127" for instance <XLXI_932_0>.
Set property "HU_SET = XLXI_932_1_126" for instance <XLXI_932_1>.
Set property "HU_SET = XLXI_932_2_125" for instance <XLXI_932_2>.
Set property "HU_SET = XLXI_932_3_124" for instance <XLXI_932_3>.
Set property "HU_SET = XLXI_932_4_123" for instance <XLXI_932_4>.
Set property "HU_SET = XLXI_932_5_122" for instance <XLXI_932_5>.
Set property "HU_SET = XLXI_932_6_121" for instance <XLXI_932_6>.
Set property "HU_SET = XLXI_932_7_120" for instance <XLXI_932_7>.
Set property "HU_SET = XLXI_932_8_119" for instance <XLXI_932_8>.
Set property "HU_SET = XLXI_932_9_118" for instance <XLXI_932_9>.
Set property "HU_SET = XLXI_932_10_117" for instance <XLXI_932_10>.
Set property "HU_SET = XLXI_932_11_116" for instance <XLXI_932_11>.
Set property "HU_SET = XLXI_932_12_115" for instance <XLXI_932_12>.
Set property "HU_SET = XLXI_932_13_114" for instance <XLXI_932_13>.
Set property "HU_SET = XLXI_932_14_113" for instance <XLXI_932_14>.
Set property "HU_SET = XLXI_932_15_112" for instance <XLXI_932_15>.
Set property "HU_SET = XLXI_932_16_111" for instance <XLXI_932_16>.
Set property "HU_SET = XLXI_932_17_110" for instance <XLXI_932_17>.
Set property "HU_SET = XLXI_932_18_109" for instance <XLXI_932_18>.
Set property "HU_SET = XLXI_932_19_108" for instance <XLXI_932_19>.
Set property "HU_SET = XLXI_932_20_107" for instance <XLXI_932_20>.
Set property "HU_SET = XLXI_932_21_106" for instance <XLXI_932_21>.
Set property "HU_SET = XLXI_932_22_105" for instance <XLXI_932_22>.
Set property "HU_SET = XLXI_932_23_104" for instance <XLXI_932_23>.
Set property "HU_SET = XLXI_932_24_103" for instance <XLXI_932_24>.
Set property "HU_SET = XLXI_932_25_102" for instance <XLXI_932_25>.
Set property "HU_SET = XLXI_932_26_101" for instance <XLXI_932_26>.
Set property "HU_SET = XLXI_932_27_100" for instance <XLXI_932_27>.
Set property "HU_SET = XLXI_932_28_99" for instance <XLXI_932_28>.
Set property "HU_SET = XLXI_932_29_98" for instance <XLXI_932_29>.
Set property "HU_SET = XLXI_932_30_97" for instance <XLXI_932_30>.
Set property "HU_SET = XLXI_932_31_96" for instance <XLXI_932_31>.
INFO:Xst:3210 - "/home/gayver/Project Xilinx/Project/SNK_OU/BUSok.vhf" line 947: Output port <O> of the instance <XLXI_927> is unconnected or connected to loadless signal.
Summary:
no macro.
Unit <ALU_I_v6_MUSER_BUSok> synthesized.
Synthesizing Unit <M2_1_HXILINX_BUSok>.
Summary:
inferred 1 Multiplexer(s).
Unit <M2_1_HXILINX_BUSok> synthesized.
Synthesizing Unit <BU_BUSok>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/BU_BUSok.vhd".
WARNING:Xst:647 - Input <KOP<57:28>> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <KOP<21:11>> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:647 - Input <KOP<9:0>> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
Found 1-bit register for signal <reset_2d>.
Found 1-bit register for signal <zp_rg_k_tmp>.
Found 1-bit register for signal <t1>.
Found 1-bit register for signal <t2>.
Found 1-bit register for signal <t3>.
Found 6-bit register for signal <rg_kop>.
Found 1-bit register for signal <zagr>.
Found 1-bit register for signal <zagr_c>.
Found 1-bit register for signal <vygr>.
Found 1-bit register for signal <vygr_c>.
Found 1-bit register for signal <uost>.
Found 1-bit register for signal <alk>.
Found 1-bit register for signal <vygr_pk>.
Found 1-bit register for signal <massiv>.
Found 1-bit register for signal <bit_27>.
Found 1-bit register for signal <bit_10>.
Found 3-bit register for signal <alk_op>.
Found 1-bit register for signal <tct>.
Found 1-bit register for signal <vo_3d>.
Found 1-bit register for signal <vo_4d>.
Found 1-bit register for signal <vo_5d>.
Found 1-bit register for signal <vo>.
Found 1-bit register for signal <vo_d>.
Found 1-bit register for signal <vo_2d>.
Found 1-bit register for signal <vod>.
Found 1-bit register for signal <vod_d>.
Found 1-bit register for signal <vod_2d>.
Found 1-bit register for signal <vod_3d>.
Found 1-bit register for signal <rg_fi>.
Found 1-bit register for signal <rg_zn>.
Found 1-bit register for signal <rg_zero>.
Found 2-bit register for signal <n_usl>.
Found 1-bit register for signal <delta1>.
Found 1-bit register for signal <delta2>.
Found 1-bit register for signal <delta3>.
Found 1-bit register for signal <delta4>.
Found 1-bit register for signal <delta5>.
Found 1-bit register for signal <x1>.
Found 1-bit register for signal <x2>.
Found 1-bit register for signal <x3>.
Found 1-bit register for signal <ci>.
Found 1-bit register for signal <nakop>.
Found 1-bit register for signal <inv_rg_d2>.
Found 1-bit register for signal <alk_d>.
Found 1-bit register for signal <nop>.
Found 1-bit register for signal <up_d>.
Found 1-bit register for signal <arvalid_tmp>.
Found 1-bit register for signal <rready_tmp>.
Found 1-bit register for signal <awvalid_tmp>.
Found 1-bit register for signal <wvalid_tmp>.
Found 1-bit register for signal <bready_tmp>.
Found 1-bit register for signal <reset_d>.
Summary:
inferred 60 D-type flip-flop(s).
inferred 85 Multiplexer(s).
Unit <BU_BUSok> synthesized.
Synthesizing Unit <comp_0>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/comp_0.vhd".
Summary:
no macro.
Unit <comp_0> synthesized.
Synthesizing Unit <CC22CLED>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/CC22CLED.vhd".
width = 22
Found 22-bit register for signal <COUNT>.
Found 22-bit adder for signal <COUNT[21]_GND_820_o_add_0_OUT> created at line 59.
Found 22-bit subtractor for signal <GND_820_o_GND_820_o_sub_2_OUT<21:0>> created at line 61.
Summary:
inferred 22 D-type flip-flop(s).
Unit <CC22CLED> synthesized.
Synthesizing Unit <CC10CLED>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/CC10CLED.vhd".
width = 10
Found 10-bit register for signal <COUNT>.
Found 10-bit adder for signal <COUNT[9]_GND_821_o_add_0_OUT> created at line 59.
Found 10-bit subtractor for signal <GND_821_o_GND_821_o_sub_2_OUT<9:0>> created at line 61.
Summary:
inferred 10 D-type flip-flop(s).
Unit <CC10CLED> synthesized.
Synthesizing Unit <ct_n>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/ct_n.vhd".
Found 10-bit register for signal <q_count>.
Found 11-bit subtractor for signal <tmp> created at line 36.
Summary:
Unit <ct_n> synthesized.
Synthesizing Unit <RAMB_1Kx32>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/RAMB_1Kx32.vhd".
size = 1024
addr_width = 10
di_width = 32
Found 1024x32-bit dual-port RAM <Mram_RAM> for signal <RAM>.
Found 32-bit register for signal <DOB>.
Found 32-bit register for signal <DOA>.
Summary:
inferred 1 RAM(s).
inferred 64 D-type flip-flop(s).
Unit <RAMB_1Kx32> synthesized.
Synthesizing Unit <RAMB_1Kx64>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/RAMB_1Kx64.vhd".
size = 1024
addr_width = 10
di_width = 64
Found 1024x64-bit dual-port RAM <Mram_RAM> for signal <RAM>.
Found 64-bit register for signal <DOB>.
Found 64-bit register for signal <DOA>.
Summary:
inferred 1 RAM(s).
inferred 128 D-type flip-flop(s).
Unit <RAMB_1Kx64> synthesized.
Synthesizing Unit <PPK>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/PPK.vhd".
Found 64-bit register for signal <Q>.
Found 16x64-bit Read Only RAM for signal <tmp>
Summary:
inferred 1 RAM(s).
Unit <PPK> synthesized.
Synthesizing Unit <RG_D1>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/RG_D1.vhd".
Found 32-bit register for signal <q_tmp>.
Summary:
inferred 32 D-type flip-flop(s).
Unit <RG_D1> synthesized.
Synthesizing Unit <RG_D2>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/RG_D2.vhd".
Summary:
Unit <RG_D2> synthesized.
Synthesizing Unit <shifter_i>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/BUSoK/shifter_i.vhd".
Found 35-bit 4-to-1 multiplexer for signal <shift_3> created at line 27.
Found 47-bit 4-to-1 multiplexer for signal <shift_12> created at line 28.
Found 32-bit 32-to-1 multiplexer for signal <dc_const> created at line 25.
Summary:
inferred 8 Multiplexer(s).
Unit <shifter_i> synthesized.
CODE
Synthesizing Unit <ETH_WRITE>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/ETH_WRITE.vhd".
WARNING:Xst:653 - Signal <WSTRB> is used but never assigned. This sourceless signal will be automatically connected to value GND.
WARNING:Xst:653 - Signal <BREADY> is used but never assigned. This sourceless signal will be automatically connected to value GND.
WARNING:Xst:653 - Signal <ARPROT> is used but never assigned. This sourceless signal will be automatically connected to value GND.
Found 1-bit register for signal <kvd2d>.
Found 1-bit register for signal <kpdd>.
Found 1-bit register for signal <kpd2d>.
Found 1-bit register for signal <PPD>.
Found 1-bit register for signal <pvd_tmp>.
Found 1-bit register for signal <shift_stack_out>.
Found 1-bit register for signal <wr_stack_in>.
Found 1-bit register for signal <wr_stack_in_d>.
Found 8-bit register for signal <rg1d>.
Found 8-bit register for signal <rg2d>.
Found 8-bit register for signal <rg3d>.
Found 8-bit register for signal <rg4d>.
Found 8-bit register for signal <rg5d>.
Found 8-bit register for signal <rg6d>.
Found 8-bit register for signal <rg7d>.
Found 8-bit register for signal <rg8d>.
Found 1-bit register for signal <flag_data>.
Found 4-bit register for signal <ct_stack>.
Found 8-bit register for signal <rg_com>.
Found 24-bit register for signal <ct_col_a>.
Found 32-bit register for signal <ct_addr>.
Found 24-bit register for signal <ct_col_d>.
Found 32-bit register for signal <rg_WDATA>.
Found 1-bit register for signal <WVALID_tmp>.
Found 1-bit register for signal <Flag_AWVALID>.
Found 1-bit register for signal <AWVALID>.
Found 1-bit register for signal <ARVALID>.
Found 8-bit register for signal <rg4d_out>.
Found 8-bit register for signal <rg3d_out>.
Found 8-bit register for signal <rg2d_out>.
Found 8-bit register for signal <rg1d_out>.
Found 32-bit register for signal <Rg_RDATA>.
Found 1-bit register for signal <wr_stack_out>.
Found 1-bit register for signal <RREADY_tmp>.
Found 1-bit register for signal <kvdd>.
Found 4-bit adder for signal <ct_stack[3]_GND_831_o_add_23_OUT> created at line 133.
Found 32-bit adder for signal <ct_addr[31]_GND_831_o_add_31_OUT> created at line 155.
Found 24-bit subtractor for signal <GND_831_o_GND_831_o_sub_31_OUT<23:0>> created at line 154.
Found 24-bit subtractor for signal <GND_831_o_GND_831_o_sub_42_OUT<23:0>> created at line 165.
Summary:
inferred 268 D-type flip-flop(s).
inferred 9 Multiplexer(s).
Unit <ETH_WRITE> synthesized.
Synthesizing Unit <SLAVE_K>.
Related source file is "/home/gayver/Project Xilinx/Project/SNK_OU/SLAVE_K.vhd".
Summary:
no macro.
Unit <SLAVE_K> synthesized.
HDL Synthesis Report
Macro Statistics
# RAMs : 3
1024x32-bit dual-port RAM : 1
1024x64-bit dual-port RAM : 1
16x64-bit single-port Read Only RAM : 1
# Adders/Subtractors : 14
10-bit adder : 1
10-bit addsub : 3
11-bit subtractor : 1
16-bit subtractor : 1
22-bit addsub : 1
24-bit subtractor : 2
32-bit adder : 1
4-bit adder : 2
5-bit subtractor : 2
# Registers : 1228
1-bit register : 884
10-bit register : 5
16-bit register : 2
2-bit register : 3
21-bit register : 8
22-bit register : 1
24-bit register : 3
26-bit register : 90
3-bit register : 36
32-bit register : 134
4-bit register : 22
5-bit register : 7
6-bit register : 13
64-bit register : 3
7-bit register : 4
8-bit register : 13
# Comparators : 30
6-bit comparator equal : 30
# Multiplexers : 2183
1-bit 2-to-1 multiplexer : 825
1-bit 4-to-1 multiplexer : 1
10-bit 2-to-1 multiplexer : 6
16-bit 2-to-1 multiplexer : 6
2-bit 2-to-1 multiplexer : 1
21-bit 2-to-1 multiplexer : 8
22-bit 2-to-1 multiplexer : 1
24-bit 2-to-1 multiplexer : 4
26-bit 2-to-1 multiplexer : 60
3-bit 2-to-1 multiplexer : 45
32-bit 2-to-1 multiplexer : 131
32-bit 32-to-1 multiplexer : 1
35-bit 4-to-1 multiplexer : 1
47-bit 4-to-1 multiplexer : 1
5-bit 2-to-1 multiplexer : 1079
64-bit 2-to-1 multiplexer : 2
7-bit 2-to-1 multiplexer : 8
8-bit 2-to-1 multiplexer : 3
# Xors : 45
1-bit xor2 : 45
CODE
* Advanced HDL Synthesis *
WARNING:Xst:1710 - FF/Latch <rvalidm1_tmp> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <awaddrm2_d_0> (without init value) has a constant value of 0 in block <write_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <awaddrm2_d_1> (without init value) has a constant value of 0 in block <write_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <rreadym1_d> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <bl_arreadym2> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <ust_rready> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <rising_rreadym1_d> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <araddrm2_d_0> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <araddrm2_d_1> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <ARID_3> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_0> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_1> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_2> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_3> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_4> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_5> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_6> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_7> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_8> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_9> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_10> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_11> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_12> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_13> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_14> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_15> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_16> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_17> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_18> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_19> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_20> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_21> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_22> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_23> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_24> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_25> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_26> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_27> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_28> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_29> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_30> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RDATAm1_31> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <ARID_s_3> (without init value) has a constant value of 0 in block <KSPI_AXI>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1293 - FF/Latch <status_1> has a constant value of 0 in block <KSPI_SPI>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1293 - FF/Latch <status_7> has a constant value of 0 in block <KSPI_SPI>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <id_in_3> (without init value) has a constant value of 0 in block <K_QDR_RAM1>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <id_in_3> (without init value) has a constant value of 0 in block <K_QDR_RAM2>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <id_in_3> (without init value) has a constant value of 0 in block <K_QDR_RAM3>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <id_in_3> (without init value) has a constant value of 0 in block <K_QDR_RAM4>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <araddrm2_2d_0> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <RID_3> (without init value) has a constant value of 0 in block <K_QDR_RAM2>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <RID_3> (without init value) has a constant value of 0 in block <K_QDR_RAM4>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <rvalidm1_tmp_d> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <araddrm2_2d_1> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <awaddrm2_2d_0> (without init value) has a constant value of 0 in block <write_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <awaddrm2_2d_1> (without init value) has a constant value of 0 in block <write_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <RID_3> (without init value) has a constant value of 0 in block <K_QDR_RAM3>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1896 - Due to other FF/Latch trimming, FF/Latch <RID_3> has a constant value of 0 in block <KSPI_AXI>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <RID_3> (without init value) has a constant value of 0 in block <K_QDR_RAM1>. This FF/Latch will be trimmed during the optimization process.
CODE
WARNING:Xst:2677 - Node <rg8d_0> of sequential type is unconnected in block <M2_ETH>.
WARNING:Xst:2677 - Node <rg8d_1> of sequential type is unconnected in block <M2_ETH>.
WARNING:Xst:2677 - Node <rg8d_2> of sequential type is unconnected in block <M2_ETH>.
WARNING:Xst:2677 - Node <rg8d_3> of sequential type is unconnected in block <M2_ETH>.
WARNING:Xst:2677 - Node <rg8d_4> of sequential type is unconnected in block <M2_ETH>.
WARNING:Xst:2677 - Node <rg8d_5> of sequential type is unconnected in block <M2_ETH>.
WARNING:Xst:2677 - Node <rg8d_6> of sequential type is unconnected in block <M2_ETH>.
WARNING:Xst:2677 - Node <rg_com_0> of sequential type is unconnected in block <M2_ETH>.
WARNING:Xst:2677 - Node <rg_com_1> of sequential type is unconnected in block <M2_ETH>.
WARNING:Xst:2677 - Node <rg_com_2> of sequential type is unconnected in block <M2_ETH>.
WARNING:Xst:2677 - Node <rg_com_3> of sequential type is unconnected in block <M2_ETH>.
WARNING:Xst:2677 - Node <rg_com_4> of sequential type is unconnected in block <M2_ETH>.
WARNING:Xst:2677 - Node <rg_com_5> of sequential type is unconnected in block <M2_ETH>.
WARNING:Xst:2677 - Node <rg_com_6> of sequential type is unconnected in block <M2_ETH>.
WARNING:Xst:2677 - Node <awaddrs_tmp_0> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_1> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_23> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_24> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_25> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_0> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_1> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_23> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_24> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_25> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_6> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_7> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_8> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_9> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_10> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_11> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_12> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_13> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_14> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_15> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_16> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_17> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_18> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_19> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_20> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_21> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <awaddrs_tmp_22> of sequential type is unconnected in block <write_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_6> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_7> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_8> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_9> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_10> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_11> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_12> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_13> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_14> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_15> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_16> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_17> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_18> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_19> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_20> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_21> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <araddrs_tmp_22> of sequential type is unconnected in block <read_ch>.
WARNING:Xst:2677 - Node <RG_com_isp_0> of sequential type is unconnected in block <KSPI_SPI>.
WARNING:Xst:2677 - Node <RG_com_isp_1> of sequential type is unconnected in block <KSPI_SPI>.
WARNING:Xst:2677 - Node <RG_com_isp_2> of sequential type is unconnected in block <KSPI_SPI>.
WARNING:Xst:1710 - FF/Latch <rvalidm1_tmp_d> (without init value) has a constant value of 0 in block <read_ch>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:2677 - Node <rready_tmp> of sequential type is unconnected in block <BU_BUS>.
WARNING:Xst:2404 - FFs/Latches <AWID<3:3>> (without init value) have a constant value of 0 in block <write_channel>.
WARNING:Xst:2404 - FFs/Latches <ARID<3:3>> (without init value) have a constant value of 0 in block <read_channel>.
Synthesizing (advanced) Unit <Block_SPI_2LINE>.
The following registers are absorbed into counter <count_t>: 1 register on signal <count_t>.
Unit <Block_SPI_2LINE> synthesized (advanced).
Synthesizing (advanced) Unit <CC10CLED>.
The following registers are absorbed into counter <COUNT>: 1 register on signal <COUNT>.
Unit <CC10CLED> synthesized (advanced).
Synthesizing (advanced) Unit <CC22CLED>.
Unit <CC22CLED> synthesized (advanced).
Synthesizing (advanced) Unit <CT_AK>.
The following registers are absorbed into counter <tmp>: 1 register on signal <tmp>.
Unit <CT_AK> synthesized (advanced).
Synthesizing (advanced) Unit <ETH_WRITE>.
The following registers are absorbed into counter <ct_stack>: 1 register on signal <ct_stack>.
Unit <ETH_WRITE> synthesized (advanced).
Synthesizing (advanced) Unit <PPK>.
INFO:Xst:3231 - The small RAM <Mram_tmp> will be implemented on LUTs in order to maximize performance and save block RAM resources. If you want to force its implementation on block, use option/constraint ram_style.
| ram_type | Distributed | |
| Port A |
| aspect ratio | 16-word x 64-bit | |
| weA | connected to signal <GND> | high |
| addrA | connected to signal <A> | |
| diA | connected to signal <GND> | |
| doA | connected to signal <tmp> | |
Unit <PPK> synthesized (advanced).
Synthesizing (advanced) Unit <RAMB_1Kx32>.
INFO:Xst:3226 - The RAM <Mram_RAM> will be implemented as a BLOCK RAM, absorbing the following register(s): <DOA> <DOB>
| ram_type | Block | |
| Port A |
| aspect ratio | 1024-word x 32-bit | |
| mode | write-first | |
| clkA | connected to signal <CLKA> | rise |
| enA | connected to signal <ENA> | high |
| weA | connected to signal <WEA> | high |
| addrA | connected to signal <ADDRA> | |
| diA | connected to signal <DIA> | |
| doA | connected to signal <DOA> | |
| optimization | speed | |
| Port B |
| clkB | connected to signal <CLKB> | rise |
| enB | connected to signal <ENB> | high |
| weB | connected to signal <WEB> | high |
| addrB | connected to signal <ADDRB> | |
| diB | connected to signal <DIB> | |
| doB | connected to signal <DOB> | |
Unit <RAMB_1Kx32> synthesized (advanced).
Synthesizing (advanced) Unit <RAMB_1Kx64>.
| Port A |
| aspect ratio | 1024-word x 64-bit | |
| Port B |
CODE
Unit <RAMB_1Kx64> synthesized (advanced).
WARNING:Xst:2677 - Node <rg8d_0> of sequential type is unconnected in block <ETH_WRITE>.
WARNING:Xst:2677 - Node <rg8d_1> of sequential type is unconnected in block <ETH_WRITE>.
WARNING:Xst:2677 - Node <rg8d_2> of sequential type is unconnected in block <ETH_WRITE>.
WARNING:Xst:2677 - Node <rg8d_3> of sequential type is unconnected in block <ETH_WRITE>.
WARNING:Xst:2677 - Node <rg8d_4> of sequential type is unconnected in block <ETH_WRITE>.
WARNING:Xst:2677 - Node <rg8d_5> of sequential type is unconnected in block <ETH_WRITE>.
WARNING:Xst:2677 - Node <rg8d_6> of sequential type is unconnected in block <ETH_WRITE>.
WARNING:Xst:2677 - Node <rg_com_0> of sequential type is unconnected in block <ETH_WRITE>.
WARNING:Xst:2677 - Node <rg_com_1> of sequential type is unconnected in block <ETH_WRITE>.
WARNING:Xst:2677 - Node <rg_com_2> of sequential type is unconnected in block <ETH_WRITE>.
WARNING:Xst:2677 - Node <rg_com_3> of sequential type is unconnected in block <ETH_WRITE>.
WARNING:Xst:2677 - Node <rg_com_4> of sequential type is unconnected in block <ETH_WRITE>.
WARNING:Xst:2677 - Node <rg_com_5> of sequential type is unconnected in block <ETH_WRITE>.
WARNING:Xst:2677 - Node <rg_com_6> of sequential type is unconnected in block <ETH_WRITE>.
WARNING:Xst:2677 - Node <RG_com_isp_0> of sequential type is unconnected in block <Block_SPI_2LINE>.
WARNING:Xst:2677 - Node <RG_com_isp_1> of sequential type is unconnected in block <Block_SPI_2LINE>.
WARNING:Xst:2677 - Node <RG_com_isp_2> of sequential type is unconnected in block <Block_SPI_2LINE>.
Advanced HDL Synthesis Report
Macro Statistics
# RAMs : 3
1024x32-bit dual-port block RAM : 1
1024x64-bit dual-port block RAM : 1
16x64-bit single-port distributed Read Only RAM : 1
# Adders/Subtractors : 7
32-bit adder : 1
# Counters : 7
10-bit up counter : 1
10-bit updown counter : 3
22-bit updown counter : 1
4-bit up counter : 2
# Registers : 8524
Flip-Flops : 8524
# Comparators : 30
# Multiplexers : 2794
1-bit 2-to-1 multiplexer : 1479
10-bit 2-to-1 multiplexer : 2
26-bit 2-to-1 multiplexer : 40
32-bit 2-to-1 multiplexer : 115
# Xors : 45
1-bit xor2 : 45
* Low Level Synthesis *
WARNING:Xst:1710 - FF/Latch <bl_arreadym2> (without init value) has a constant value of 0 in block <read_channel>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <bl_arreadym3> (without init value) has a constant value of 0 in block <read_channel>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <ust_rready> (without init value) has a constant value of 0 in block <read_channel>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <RRESP_0> (without init value) has a constant value of 0 in block <Block_AMBA_AXI_slave>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <BRESP_0> (without init value) has a constant value of 0 in block <Block_AMBA_AXI_slave>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1293 - FF/Latch <status_1> has a constant value of 0 in block <Block_SPI_2LINE>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1896 - Due to other FF/Latch trimming, FF/Latch <status_7> has a constant value of 0 in block <Block_SPI_2LINE>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <Q_34> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_35> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_36> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_37> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_38> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_39> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_40> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_41> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_42> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_43> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_44> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_45> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_46> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_47> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_48> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_49> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_50> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_51> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_52> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_53> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_54> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_55> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_56> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_57> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_58> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_59> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_60> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_61> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_62> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_63> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_0> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_1> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_2> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_3> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_4> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_5> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_6> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_7> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_8> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_9> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_10> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_11> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_12> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_13> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_14> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_15> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_16> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_17> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_18> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_19> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_20> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_21> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_22> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_23> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_27> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_28> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_29> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_30> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_31> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_32> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Q_33> (without init value) has a constant value of 0 in block <PPK>. This FF/Latch will be trimmed during the optimization process.
INFO:Xst:1901 - Instance buf_cq in unit Kontr_QDR_OU_AXI of type BUFIO has been replaced by BUFIODQS
INFO:Xst:1901 - Instance buf_cq_inv in unit Kontr_QDR_OU_AXI of type BUFIO has been replaced by BUFIODQS
INFO:Xst:1901 - Instance XLXI_38 in unit SNK_OU of type MMCM_BASE has been replaced by MMCM_ADV
Optimizing unit <RG_D1> ...
Optimizing unit <ALU_I_v6_MUSER_BUSok> ...
Optimizing unit <SNK_OU> ...
Optimizing unit <LVDS_block> ...
Optimizing unit <Kontr_QDR_OU_AXI> ...
Optimizing unit <ETH_WRITE> ...
Optimizing unit <BUF_block> ...
Optimizing unit <write_channel> ...
Optimizing unit <read_channel> ...
Optimizing unit <Block_AMBA_AXI_slave> ...
Optimizing unit <Block_SPI_2LINE> ...
Optimizing unit <BUSok> ...
Optimizing unit <BU_BUSok> ...
Optimizing unit <ct_n> ...
Optimizing unit <RG_D2> ...
Optimizing unit <M2_1_HXILINX_BUSok> ...
Optimizing unit <shifter_i> ...
Сообщение отредактировал GAYVER - Apr 3 2013, 13:07
Maverick
сообщение Apr 3 2013, 13:11
я только учусь...
Из: Украина
Пользователь №: 24 839
там приведены названия сигналов, для которых синтезатор делает латчи. Проверьте условие if else, везде ли есть else
Например
WARNING:Xst:1710 - FF/Latch <inter_slave41/read_ch/RDATAm1_23> (without init value) has a constant value of 0 in block <SNK_OU>. This FF/Latch will be trimmed during the optimization process.
кажется у Вас есть сигнал inter_slave41 в модуле read_ch или наоборот...
If it doesn't work in simulation, it won't work on the board.
"Ты живешь в своих поступках, а не в теле. Ты — это твои действия, и нет другого тебя" Антуан де Сент-Экзюпери повесть "Маленький принц"
- GAYVER   как отловить в каком месте ставится latch?   Apr 3 2013, 11:04
- - andrew_b   Логи синтезатора читать, а не только финальный отч...   Apr 3 2013, 11:31
- - iosifk   Цитата(GAYVER @ Apr 3 2013, 15:04) вопрос...   Apr 3 2013, 11:36
- - GAYVER   второй день курю логи. в отчете просматривал все п...   Apr 3 2013, 11:42
|- - alexadmin   Цитата(GAYVER @ Apr 3 2013, 15:42) второй...   Apr 3 2013, 11:43
||- - GAYVER   Цитата(alexadmin @ Apr 3 2013, 15:43) Про...   Apr 3 2013, 11:46
||- - Maverick   Цитата(GAYVER @ Apr 3 2013, 14:46) в прое...   Apr 3 2013, 12:01
||- - alexadmin   Цитата(GAYVER @ Apr 3 2013, 15:46) в прое...   Apr 3 2013, 13:07
||- - GAYVER   Цитата(alexadmin @ Apr 3 2013, 17:07) А, ...   Apr 3 2013, 13:14
||- - Maverick   Цитата(GAYVER @ Apr 3 2013, 16:14) и куск...   Apr 3 2013, 13:26
|||- - GAYVER   Цитата(Maverick @ Apr 3 2013, 17:26) попр...   Apr 3 2013, 13:41
||- - yes   Цитата(GAYVER @ Apr 3 2013, 17:14) после ...   Apr 3 2013, 14:27
||- - GAYVER   Цитата(yes @ Apr 3 2013, 18:27) ну это вр...   Apr 4 2013, 07:50
|- - iosifk   Цитата(GAYVER @ Apr 3 2013, 15:42) . прос...   Apr 3 2013, 11:58
- - GAYVER   WARNING:Xst:1710 - FF/Latch <inter_slave0/read...   Apr 3 2013, 13:08
- - XVR   Судя по логам latch'а там нет. Посмотрите в ga...   Apr 4 2013, 07:40
- - GAYVER   пардоньте, не дцм. The outputs from the MMCM are ...   Apr 4 2013, 09:59
RSS Текстовая версия Сейчас: 21st July 2025 - 15:45
Страница сгенерированна за 0.01726 секунд с 7
