как отловить в каком месте ставится latch? |
Apr 3 2013, 11:04
Пользователь №: 76 333
суммари: Device Utilization Summary: Number of Slice Registers - 4,631 Number used as Flip Flops - 4,630 Number used as Latches - 1 ..... синтез репорт: CODE Device utilization summary: --------------------------- Selected Device : 6vlx195tff1156-1
Slice Logic Utilization: Number of Slice Registers: 4816 out of 249600 1% Number of Slice LUTs: 4488 out of 124800 3% Number used as Logic: 3500 out of 124800 2% Number used as Memory: 988 out of 48640 2% Number used as SRL: 988
Slice Logic Distribution: Number of LUT Flip Flop pairs used: 6227 Number with an unused Flip Flop: 1411 out of 6227 22% Number with an unused LUT: 1739 out of 6227 27% Number of fully used LUT-FF pairs: 3077 out of 6227 49% Number of unique control sets: 181
IO Utilization: Number of IOs: 440 Number of bonded IOBs: 344 out of 600 57%
Specific Feature Utilization: Number of Block RAM/FIFO: 3 out of 344 0% Number using Block RAM only: 3 Number of BUFG/BUFGCTRLs: 4 out of 32 12% мап репорт: CODE Design Summary -------------- Number of errors: 0 Number of warnings: 358 Slice Logic Utilization: Number of Slice Registers: 4,631 out of 249,600 1% Number used as Flip Flops: 4,630 Number used as Latches: 1 Number used as Latch-thrus: 0 Number used as AND/OR logics: 0 Number of Slice LUTs: 3,955 out of 124,800 3% Number used as logic: 2,931 out of 124,800 2% Number using O6 output only: 2,255 Number using O5 output only: 33 Number using O5 and O6: 643 Number used as ROM: 0 Number used as Memory: 984 out of 48,640 2% Number used as Dual Port RAM: 0 Number used as Single Port RAM: 0 Number used as Shift Register: 984 Number using O6 output only: 984 Number using O5 output only: 0 Number using O5 and O6: 0 Number used exclusively as route-thrus: 40 Number with same-slice register load: 39 Number with same-slice carry load: 1 Number with other load: 0
Slice Logic Distribution: Number of occupied Slices: 1,781 out of 31,200 5% Number of LUT Flip Flop pairs used: 5,224 Number with an unused Flip Flop: 898 out of 5,224 17% Number with an unused LUT: 1,269 out of 5,224 24% Number of fully used LUT-FF pairs: 3,057 out of 5,224 58% Number of unique control sets: 183 Number of slice register sites lost to control set restrictions: 705 out of 249,600 1%
IO Utilization: Number of bonded IOBs: 440 out of 600 73% Number of LOCed IOBs: 440 out of 440 100% IOB Flip Flops: 164 IOB Master Pads: 12 IOB Slave Pads: 12
Specific Feature Utilization: Number of RAMB36E1/FIFO36E1s: 3 out of 344 1% Number using RAMB36E1 only: 3 Number using FIFO36E1 only: 0 Number of RAMB18E1/FIFO18E1s: 0 out of 688 0% Number of BUFG/BUFGCTRLs: 4 out of 32 12% Number used as BUFGs: 4 Number used as BUFGCTRLs: 0 Number of ILOGICE1/ISERDESE1s: 64 out of 600 10% Number used as ILOGICE1s: 0 Number used as ISERDESE1s: 64 Number of OLOGICE1/OSERDESE1s: 166 out of 600 27% Number used as OLOGICE1s: 166 Number used as OSERDESE1s: 0 Number of BSCANs: 0 out of 4 0% Number of BUFHCEs: 0 out of 120 0% Number of BUFIODQSs: 8 out of 60 13% Number of BUFRs: 0 out of 30 0% Number of CAPTUREs: 0 out of 1 0% Number of DSP48E1s: 0 out of 640 0% Number of EFUSE_USRs: 0 out of 1 0% Number of FRAME_ECCs: 0 out of 1 0% Number of GTXE1s: 0 out of 20 0% Number of IBUFDS_GTXE1s: 0 out of 10 0% Number of ICAPs: 0 out of 2 0% Number of IDELAYCTRLs: 12 out of 15 80% Number of IODELAYE1s: 236 out of 600 39% Number of MMCM_ADVs: 1 out of 10 10% Number of PCIE_2_0s: 0 out of 2 0% Number of STARTUPs: 1 out of 1 100% Number of SYSMONs: 0 out of 1 0% Number of TEMAC_SINGLEs: 0 out of 4 0%
вопрос - как выловить эту защелку???
Сообщение отредактировал GAYVER - Apr 3 2013, 11:08
Apr 3 2013, 11:46
Цитата(alexadmin @ Apr 3 2013, 15:43)  Проходите по отчету синтезатора ища "latch". Обычно он выводит предупреждение, какое место кода его создало. в проекте 4к с хреном триггеров, в отчетах каждый триггер описывается типа "FF/Latch <bl_arreadym2>...."
Apr 3 2013, 13:14
Цитата(alexadmin @ Apr 3 2013, 17:07)  А, это хилинкс. Тогда не знаю. У альтеры явный варнинг на это есть. Синтезируйте кусками, методом дихотомии, другой идеи нет. В репорте у вас явного сообщения на эту тему нет. GREP гарантирует. и кусками уже делал )). защелка появляется при разводке топ-лвл-а... Цитата(Maverick @ Apr 3 2013, 17:11)  там приведены названия сигналов, для которых синтезатор делает латчи. Проверьте условие if else, везде ли есть else после синтеза защелки нет. она появляется на мапе...
Apr 3 2013, 13:41
Цитата(Maverick @ Apr 3 2013, 17:26)  попробуйте отключить в настройках синтезатора объединение блоков при синтезе... (Keep hierarchy) и тоже самое с Netlist проделать объединение никогда и не включалось ))
GAYVER как отловить в каком месте ставится latch? Apr 3 2013, 11:04 andrew_b Логи синтезатора читать, а не только финальный отч... Apr 3 2013, 11:31 iosifk Цитата(GAYVER @ Apr 3 2013, 15:04) вопрос... Apr 3 2013, 11:36   Maverick Цитата(GAYVER @ Apr 3 2013, 14:46) в прое... Apr 3 2013, 12:01     yes Цитата(GAYVER @ Apr 3 2013, 17:14) после ... Apr 3 2013, 14:27      GAYVER Цитата(yes @ Apr 3 2013, 18:27) ну это вр... Apr 4 2013, 07:50 iosifk Цитата(GAYVER @ Apr 3 2013, 15:42) . прос... Apr 3 2013, 11:58 GAYVER RE: как отловить в каком месте ставится latch? Apr 3 2013, 13:06 Maverick там приведены названия сигналов, для которых синте... Apr 3 2013, 13:11 GAYVER
WARNING:Xst:1710 - FF/Latch <inter_slave0/read... Apr 3 2013, 13:08 XVR Судя по логам latch'а там нет. Посмотрите в ga... Apr 4 2013, 07:40 GAYVER пардоньте, не дцм.
The outputs from the MMCM are ... Apr 4 2013, 09:59
