> Вышел PADS9.5
fill
сообщение Oct 19 2012, 08:21
Из: КП Две Поляны
Пользователь №: 512
[attachment=72114:PADS_rh.pdf]
[attachment=72115:PADS_rn.pdf]
www.megratec.ru
sh007
сообщение Jul 5 2013, 08:35
Живой
Пользователь №: 560
Вопросы наверное к fill
1. Сообщалось, что вышел PADS 9.5 update 1. Интересно, что в нём?
2. Когда планируют выход долгожданного PADS 9.6?
Kompot
сообщение Jul 5 2013, 09:13
Из: Хочу в пампасы...
Пользователь №: 38 192
Вышел он еще в мае 2013.
http://supportnet.mentor.com/docs/20130100...9.5_Upd1_rn.pdf
но пускает только избранных. Вот что нового:
Fixed in PADS 9.5 Update 1
DxDesigner
 DR 941866 - Customer observes that when fonts are exported to hpgl file the text is not WYSIWYG
 DR 941870 - HPGL data exported from a DxDesigner sheet is not the correct size
 DR 941875 - Mapped fonts don't zoom properly
 DR 941879 - The translator simultaneously migrates schematic symbols locally in the design and into the Central Library
 DR 941881 - Text origin is not changed when Scout is run
 DR 941882 - Need to increment the DxD application version string
 DR 941883 - Symbol_Swap Groups data is incorrect in created PDB
 DR 941884 - Translated design is losing global net name when pins are on top of one another
 DR 941885 - Schematic instances have pin number duplication; Packager failed
HyperLynx Analog
 DR 941871 - Update Simulation Model does not support symbol version properly
 DR 941873 - Ability to associate a local model to several components at a time
iCDB
 DR 926341 - Error while creating new project using RSCM server
 DR 926705 - Scout removes nets and components in PADS 9.5
PADS Layout
 DR 924209 - Changing ref des font on Chinese install of PADS 9.5 results in a crash
ODB++
 DR 916783 - ODB++ export is combining different sized slots.
 DR 922608 - ODB++ output is combining slotted drill sizes with regular, circular drill sizes in the drill chart
 DR 916779 - ODB++ export isn't creating the 'THRU/PRTL' column in the drill table
 DR 916785 - ODB++ export puts a drill marker (symbol) at the center of a slot but Gerber places 2 markers, one at each end.
 DR 918290 - ODB++ shows trace passing through annular ring pad creating short
 DR 932145 - vSure Main Application has stopped working when component on the bottom side has 151 or more pins associated with copper
sh007
сообщение Jul 10 2013, 09:10
Живой
Пользователь №: 560
Спасибо, Kompot
А вот по поводу выхода PADS 9.6 появились сомнения.
Раньше обещали выпустить его летом 2013.
А теперь, в PCB Planned Releases (http://supportnet.mentor.com/news/bsd_planned_releases.cfm)
сообщили о изменении порядка нумерации версий, и ближайшая версия PADSVX.1 намечена на декабрь 2013.
Значит ли это то, что вместо PADS 9.6 летом 2013, обещают PADSVX.1 в конце 2013 года.
Прикрепленный файл  Final_bsd_release_content_7_1_2013.pdf ( 129.52 килобайт ) Кол-во скачиваний: 806
Lexa-E
сообщение Jul 18 2013, 06:58
Пользователь №: 32 121
Уже в мае у Megratec была новая версия PADS на тестировании!
Как она называется и что конкретно изменилось не знаю, но были обнаружены изменения менюшек.
etoja
сообщение Aug 20 2013, 12:29
Пользователь №: 1 952
Это сильно.
PS: Маниакальное ожидание центральной библиотеки мне непонятно.
Работаю и в PADS и в Expedition.
Инженерам-одиночкам удобнее работать в PADS Sch-Layout.
DxDesigner и центральная библиотека - очень неудобно. Это для желающих таскать пианино на пятый этаж.
- fill   Вышел PADS9.5   Oct 19 2012, 08:21
- - sh007   Интересно, а ЦБ отдали народу или по прежнему, для...   Oct 19 2012, 09:12
|- - fill   Цитата(sh007 @ Oct 19 2012, 13:12) Интере...   Oct 19 2012, 09:47
- - ClayMan   виртуальные пины добавили - полезное улучшение, жа...   Oct 22 2012, 08:46
|- - fill   Цитата(ClayMan @ Oct 22 2012, 12:46) вирт...   Oct 22 2012, 11:07
|- - ClayMan   Цитата(fill @ Oct 22 2012, 14:07) спасиб...   Oct 25 2012, 11:22
|- - fill   Цитата(ClayMan @ Oct 25 2012, 15:22) спас...   Nov 28 2012, 08:14
- - Nixon   Ну такое наблюдается с 2008 года Могу покопаться ...   Oct 22 2012, 13:41
- - ClayMan   Я не совсем понял...вы про общедоступный 9.5 говор...   Nov 28 2012, 12:23
|- - fill   Цитата(ClayMan @ Nov 28 2012, 16:23) Я не...   Nov 28 2012, 13:51
- - ClayMan   хм, вобщем-то нет. у меня в DXD, кот идет в компле...   Nov 28 2012, 14:22
- - ClayMan   ЦБ - отличный инструмент, очень удобный. Его появл...   Aug 20 2013, 13:55
|- - sh007   Уточните, пожалуйста. Коснётся ли предполагаемое п...   Aug 21 2013, 03:19
- - ClayMan   Учитвая, что ментор упорно отказывается поддержива...   Aug 21 2013, 09:17
RSS Текстовая версия Сейчас: 24th August 2025 - 09:22
