> Матлаб/симулинк - не загружается модель, не находит компоненты
_Ivana
сообщение Sep 1 2013, 21:06
Из: Воронеж
Пользователь №: 66 710
Мне прислали модель для симулинка, открывал в релизе 2012а - сообщал что файл был создан в релизе 2013а и далее кучу ошибок. Скачал с ФТП и поставил 2013а,ошибки те же:
Warning: Cube (blockdiagram.xml, line 640): This model contains objects of class
"SSC.SimscapeCC" that can not be instantiated. If you save this model, the
information associated with these objects will be lost.
In general\private\openmdl at 13
In general\private\openslx at 9
In open at 159
In uiopen at 196
Warning: Cube (blockdiagram.xml, line 643): This model contains objects of class
"MECH.SimMechanicsCC" that can not be instantiated. If you save this model, the
In open at 159
In uiopen at 196
Warning: Cube (blockdiagram.xml, line 674): This model contains objects of class
"simmechanics.ConfigurationSet" that can not be instantiated. If you save this
model, the information associated with these objects will be lost.
In open at 159
In uiopen at 196
Warning: Cube (blockdiagram.xml, line 677): This model contains objects of class
"simmechanics.DiagnosticsConfigSet" that can not be instantiated. If you save this
In open at 159
In uiopen at 196
Warning: Cube (blockdiagram.xml, line 689): This model contains objects of class
"simmechanics.ExplorerConfigSet" that can not be instantiated. If you save this
In open at 159
In uiopen at 196
Warning: Unable to load block diagram 'mblibv1'
In open at 159
In uiopen at 196
Warning: Viewer 'Cube/Floating Scope1' was previously observing the signal
originating from block 'Энкодер', output port 1. That signal is no longer valid
and will be removed from the viewer's signal list
In open at 159
In uiopen at 196
но окно симуляции открывается. хотя на почти всех блоках написано "Bad link" и при попытке запустить выдается
Failed to load library 'mblibv1' referenced by 'Cube/Joint Initial Condition'
Caused by:
Что может быть причиной? С симулинком встречаюсь впервые )
RSS Текстовая версия Сейчас: 21st July 2025 - 22:33
Страница сгенерированна за 0.0137 секунд с 7
