> Сборка КФС для arm 920t через biuldroot 2009.08
kvazar2
сообщение Jun 27 2014, 09:39
Пользователь №: 82 085
Пытаюсь собрать КФС используя buildroot-2009.08 Использую ubuntu 12.04 x32
При сборке получаю вот такую ошибку
#error It appears you have defined _FILE_OFFSET_BITS=64. Unfortunately, uClibc was built without large file support enabled.
Вывод консоли
make[1]: Вход в каталог `/home/v4x32/buildroot-2009.08/build_arm/logrotate-3.7.7'
/home/v4x32/buildroot-2009.08/build_arm/staging_dir/usr/bin/arm-linux-uclibcgnueabi-gcc -Os -pipe -Os -I/home/v4x32/buildroot-2009.08/build_arm/staging_dir/usr/include -I/home/v4x32/buildroot-2009.08/build_arm/staging_dir/include --sysroot=/home/v4x32/buildroot-2009.08/build_arm/staging_dir/ -isysroot /home/v4x32/buildroot-2009.08/build_arm/staging_dir -mtune=arm920t -march=armv4t -mabi=aapcs-linux -msoft-float -Wall -D_GNU_SOURCE -DLinux -DVERSION=\"3.7.7\" -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -g -c -o logrotate.o logrotate.c
In file included from /home/v4x32/buildroot-2009.08/build_arm/staging_dir/usr/include/sys/cdefs.h:25,
from /home/v4x32/buildroot-2009.08/build_arm/staging_dir/usr/include/sys/queue.h:36,
from logrotate.c:1:
/home/v4x32/buildroot-2009.08/build_arm/staging_dir/usr/include/features.h:416:4: error: #error It appears you have defined _FILE_OFFSET_BITS=64. Unfortunately, uClibc was built without large file support enabled.
In file included from /home/v4x32/buildroot-2009.08/build_arm/staging_dir/usr/include/stdio.h:72,
from /home/v4x32/buildroot-2009.08/build_arm/staging_dir/usr/include/popt.h:12,
from logrotate.c:7:
/home/v4x32/buildroot-2009.08/build_arm/staging_dir/usr/include/bits/uClibc_stdio.h:61:2: error: #error Sorry... uClibc was built without large file support!
In file included from /home/v4x32/buildroot-2009.08/build_arm/staging_dir/usr/include/popt.h:12,
from logrotate.c:7:
/home/v4x32/buildroot-2009.08/build_arm/staging_dir/usr/include/stdio.h:83: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'fpos_t'
/home/v4x32/buildroot-2009.08/build_arm/staging_dir/usr/include/stdio.h:87: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'fpos64_t'
from logrotate.c:7:
/home/v4x32/buildroot-2009.08/build_arm/staging_dir/usr/include/stdio.h:714: error: expected declaration specifiers or '...' before 'fpos_t'
/home/v4x32/buildroot-2009.08/build_arm/staging_dir/usr/include/stdio.h:716: error: expected ';', ',' or ')' before '*' token
/home/v4x32/buildroot-2009.08/build_arm/staging_dir/usr/include/stdio.h:728: error: expected declaration specifiers or '...' before 'fpos64_t'
/home/v4x32/buildroot-2009.08/build_arm/staging_dir/usr/include/stdio.h:729: error: expected ';', ',' or ')' before '*' token
make[1]: *** [logrotate.o] Ошибка 1
make[1]: Выход из каталога `/home/v4x32/buildroot-2009.08/build_arm/logrotate-3.7.7'
make: *** [/home/v4x32/buildroot-2009.08/build_arm/logrotate-3.7.7/logrotate] Ошибка 2
v4x32@x32:~/buildroot-2009.08$
Я в использовании линукса совсем зелёный, поэтому не имею ни малейшего представления как заставить его работать.
Сразу скажу, что поддержка 64 битной архитектуры меня не интересует. Помогите пожалуйста разобраться
RSS Текстовая версия Сейчас: 2nd August 2025 - 00:04
Страница сгенерированна за 0.01338 секунд с 7
