> Внешние прерывания, STM32F103VB
Jenya7
сообщение Jul 27 2014, 06:35
Пользователь №: 71 075
Я пытаюсь включить внешние прерывания в свою программу на STM32F103VB.
CODE
void ExtIntInit(void)
// enable clock for Alternate Function
RCC->APB2ENR |= RCC_APB2ENR_AFIOEN;
//BUT - PE0
GPIOE->CRL &= ~GPIO_CRL_MODE0; //Configure as input
GPIOE->CRL &= ~GPIO_CRL_CNF0;
GPIOE->CRL |= GPIO_CRL_CNF0_1; //input with pull-up/pull-down resistor
GPIOE->BSRR |= GPIO_BSRR_BS0; //set pull-up
//ENC1 - PE1
GPIOE->CRL &= ~GPIO_CRL_MODE1; //Configure as input
GPIOE->CRL &= ~GPIO_CRL_CNF1;
GPIOE->CRL |= GPIO_CRL_CNF1_1; //input with pull-up/pull-down resistor
GPIOE->BSRR |= GPIO_BSRR_BS1; //set pull-up
//ENC2 - PE2
GPIOE->CRL &= ~GPIO_CRL_MODE2; //Configure as input
GPIOE->CRL &= ~GPIO_CRL_CNF2;
GPIOE->CRL |= GPIO_CRL_CNF2_1; //input with pull-up/pull-down resistor
GPIOE->BSRR |= GPIO_BSRR_BS2; //set pull-up
//interrupt source PE
AFIO->EXTICR[0] |= AFIO_EXTICR1_EXTI0_PE; //PE0 - BUT
AFIO->EXTICR[0] |= AFIO_EXTICR1_EXTI1_PE; //PE1 - ENC1
AFIO->EXTICR[0] |= AFIO_EXTICR1_EXTI2_PE; //PE2 - ENC2
AFIO->EXTICR[0] |= AFIO_EXTICR1_EXTI3_PE; //PE3 - ENC3
//interrupt edge
EXTI->RTSR |= 0; //EXTI_RTSR_TR0; //rising
EXTI->FTSR |= EXTI_FTSR_TR0; //falling
EXTI->FTSR |= EXTI_FTSR_TR1; //falling
EXTI->FTSR |= EXTI_FTSR_TR2; //falling
EXTI->FTSR |= EXTI_FTSR_TR3; //falling
//enable ext interrupt
EXTI->IMR |= EXTI_IMR_MR0;
EXTI->IMR |= EXTI_IMR_MR1;
EXTI->IMR |= EXTI_IMR_MR2;
EXTI->IMR |= EXTI_IMR_MR3;
NVIC_EnableIRQ(EXTI0_IRQn);
NVIC_EnableIRQ(EXTI1_IRQn);
NVIC_EnableIRQ(EXTI2_IRQn);
NVIC_EnableIRQ(EXTI3_IRQn);
И обработчик
CODE
void EXTI0_IRQHandler(void) //button pressed
EXTI->PR = EXTI_PR_PR0; //clear flag???
TIM4->CNT = 0;
TIM4->CR1 |= TIM_CR1_CEN;
//but_int = true;
//NVIC_EnableIRQ(TIM7_IRQn);
void EXTI1_IRQHandler(void) //encoder1
EXTI->PR = EXTI_PR_PR1; //clear flag???
enc1_int = 1;
if(DIR1)
{ mot1_position++; }
else
if(mot1_position > 0)
{ mot1_position--; }
void EXTI2_IRQHandler(void) //encoder2
EXTI->PR = EXTI_PR_PR2; //clear flag???
if(DIR2)
{ mot2_position++; }
else
if(mot2_position > 0)
{ mot2_position--; }
void EXTI3_IRQHandler(void) //encoder3
EXTI->PR = EXTI_PR_PR3; //clear flag???
if(DIR3)
{ mot3_position++; }
else
if(mot3_position > 0)
{ mot3_position--; }
До этого кода все работает нормально. После включения этого куска кода камень умирает и не реагирует ни на что. Я уже пару дней бьюсь над проблемой. Читаю документацию вдоль и поперек не могу понять где проблема.
Jenya7
сообщение Jul 28 2014, 14:12
Я тут посмотрел...возможно я таки найду свободные пины для таймера.
А насчет чистки битов, может как в AVR?
#define SETBIT(ADDRESS,BIT) (ADDRESS |= (1<<BIT))
#define CLEARBIT(ADDRESS,BIT) (ADDRESS &= ~(1<<BIT))
Кстати я не вижу большого криминала обрабатывать энкодер на прерываниях. На AVR прекрасно работало, а STM32 все таки в 5 раз быстрее.
Сообщение отредактировал Jenya7 - Jul 28 2014, 14:08
adnega
сообщение Jul 28 2014, 16:27
Из: Ярославль, Россия
Пользователь №: 27 702
Вы же сами жаловались, что ничего не работает! Когда CPU постоянно сидит в обработчиках прерываний mainloop не крутится и не работают менее приоритетные (и этого же уровня) прерывания - что есть зло. С учетом того, что в энкодере будет дребезг - в это время ничего работать не будет.
А начнет пользователь крутить быстро - так вообще много чудес можно словить в устройстве, с таким количеством "важной" периферии, что не остается
свободных ног таймера.
Jenya7
сообщение Jul 29 2014, 06:15
Golikov A.
Спасибо за подробное объяснение.
Тут конечно все дело в частоте прерываний. У иеня максимальная 200 Герц значит 5 ms. Дьюти 50% - 2.5 ms между перепадами. Это достаточно большое время как мне кажется.
adnega
сообщение Jul 29 2014, 08:30
Да уж - ни туда, ни сюда.
Возможно, в этом случае опрос может проиграть EXTI.
Я бы все равно постарался подключить к таймеру.
Может, МК другой посмотреть: в F100 таймеров обычно больше (правда частота CPU до 24МГц).
Jenya7
сообщение Jul 29 2014, 10:29
Даже на этом, я думаю, умудрюсь заремапить три пина на свободный таймер.
Но я не могу посчитать три канала на одном таймере.
- Jenya7   Внешние прерывания   Jul 27 2014, 06:35
- - AHTOXA   GPIO затактировать забыли?   Jul 27 2014, 06:55
|- - Jenya7   Цитата(AHTOXA @ Jul 27 2014, 11:55) GPIO ...   Jul 27 2014, 07:25
- - Genadi Zawidowski   выясните для начала, нет ли ситуации что "кам...   Jul 27 2014, 10:02
|- - Jenya7   Цитата(Genadi Zawidowski @ Jul 27 2014, 16...   Jul 27 2014, 10:16
|- - smk   Цитата(Jenya7 @ Jul 27 2014, 13:16) Я так...   Jul 27 2014, 12:33
|- - adnega   Цитата(smk @ Jul 27 2014, 16:33) EXTI-...   Jul 27 2014, 12:46
|- - smk   Цитата(adnega @ Jul 27 2014, 15:46) Так т...   Jul 27 2014, 14:04
|- - adnega   Цитата(smk @ Jul 27 2014, 18:04) Но ведь ...   Jul 27 2014, 14:09
|- - smk   Цитата(adnega @ Jul 27 2014, 17:09) Может...   Jul 27 2014, 14:39
|- - Jenya7   Цитата(smk @ Jul 27 2014, 20:39) Код#defi...   Jul 27 2014, 16:00
- - adnega   Цитатачто так что так В таком случае предлагаю по...   Jul 27 2014, 16:45
|- - Сергей Борщ   Цитата(adnega @ Jul 27 2014, 19:45) Напри...   Jul 27 2014, 19:20
- - Golikov A.   ЦитатаPS. В cortex-m хорошо, что прерывания защелк...   Jul 27 2014, 19:22
- - adnega   Если использовать EXTI не самоцель, то для получен...   Jul 27 2014, 20:18
|- - Jenya7   Цитата(adnega @ Jul 28 2014, 02:18) Если ...   Jul 28 2014, 09:36
- - Jenya7   Проблема закралась с неожиданной стороны. На плате...   Jul 28 2014, 05:50
|- - KnightIgor   Цитата(Jenya7 @ Jul 28 2014, 07:50) Но вс...   Jul 28 2014, 13:54
- - hd44780   Jenya7, посмотрите, может ремап Вам поможет. Мне н...   Jul 28 2014, 10:07
|- - Jenya7   Цитата(hd44780 @ Jul 28 2014, 16:07) Jeny...   Jul 28 2014, 10:16
|- - adnega   Цитата(Jenya7 @ Jul 28 2014, 14:16) Я смо...   Jul 28 2014, 13:13
|- - adnega   Цитата(Jenya7 @ Jul 29 2014, 14:29) Но я ...   Jul 29 2014, 12:46
|- - Jenya7   Цитата(adnega @ Jul 29 2014, 18:46) А дву...   Jul 29 2014, 13:13
- - Golikov A.   Опять нужна лекция... попробуем укороченный вариан...   Jul 28 2014, 15:52
- - Golikov A.   ПЛИС надо ставить...   Jul 29 2014, 13:41
|- - Jenya7   Цитата(Golikov A. @ Jul 29 2014, 19:41) П...   Jul 29 2014, 13:52
- - Golikov A.   ага, где то полдня работы... у нас 5 моторами рули...   Jul 29 2014, 19:02
|- - Jenya7   Цитата(Golikov A. @ Jul 30 2014, 01:02) а...   Jul 30 2014, 05:20
|- - adnega   Цитата(Jenya7 @ Jul 30 2014, 09:20) Это к...   Jul 30 2014, 06:35
|- - Jenya7   Цитата(adnega @ Jul 30 2014, 12:35) STM32...   Jul 30 2014, 07:07
- - adnega   А если вместо ПЛИС поставить мелкоту, типа STM32F0...   Jul 29 2014, 19:23
- - Golikov A.   ЦитатаМожет подгоните имплементацию парсера комман...   Jul 30 2014, 06:19
|- - Jenya7   Цитата(Golikov A. @ Jul 30 2014, 12:19) Е...   Jul 30 2014, 06:27
- - Golikov A.   RE: Внешние прерывания   Jul 30 2014, 07:03
- - Golikov A.   RE: Внешние прерывания   Jul 30 2014, 07:14
- - Jenya7   Перед тем как начать програмироать на ПЛИС я читал...   Jul 30 2014, 07:30
|- - DmitryM   Цитата(Jenya7 @ Jul 30 2014, 11:30) Перед...   Jul 30 2014, 07:59
- - Golikov A.   Поскольку мне надо делать дело, а не быть в тренде...   Jul 30 2014, 09:23
RSS Текстовая версия Сейчас: 21st August 2025 - 00:23
Страница сгенерированна за 0.01468 секунд с 7
