> STM32F429 + SDRAM
Atlantis-
сообщение Aug 7 2014, 11:43
Пользователь №: 65 102
Здравствуйте!
Отказывается работать SDRAM на плате Discovery, выдает статус ОК, но читаются одни нули.
Инициализирую так:
CODE
void MX_FMC_Init(void)
FMC_SDRAM_TimingTypeDef SdramTiming;
/** Perform the SDRAM1 memory initialization sequence
hsdram1.Instance = FMC_SDRAM_DEVICE;
/* hsdram1.Init */
hsdram1.Init.SDBank = FMC_SDRAM_BANK2;//FMC_SDRAM_BANK2
hsdram1.Init.ColumnBitsNumber = FMC_SDRAM_COLUMN_BITS_NUM_8;
hsdram1.Init.RowBitsNumber = FMC_SDRAM_ROW_BITS_NUM_12;//11
hsdram1.Init.MemoryDataWidth = FMC_SDRAM_MEM_BUS_WIDTH_16;
hsdram1.Init.InternalBankNumber = FMC_SDRAM_INTERN_BANKS_NUM_4;
hsdram1.Init.CASLatency = FMC_SDRAM_CAS_LATENCY_3;//1
hsdram1.Init.WriteProtection = FMC_SDRAM_WRITE_PROTECTION_DISABLE;
hsdram1.Init.SDClockPeriod = FMC_SDRAM_CLOCK_PERIOD_2;//FMC_SDRAM_CLOCK_DISABLE
hsdram1.Init.ReadBurst = FMC_SDRAM_RBURST_DISABLE;
hsdram1.Init.ReadPipeDelay = FMC_SDRAM_RPIPE_DELAY_1;//FMC_SDRAM_RPIPE_DELAY_0
/* SdramTiming */
/* Timing configuration for 84 Mhz of SD clock frequency (168Mhz/2) */
/* TMRD: 2 Clock cycles */
SdramTiming.LoadToActiveDelay = 2;
/* TXSR: min=70ns (7x11.9ns) */
SdramTiming.ExitSelfRefreshDelay = 7;
/* TRAS: min=42ns (4x11.9ns) max=120k (ns) */
SdramTiming.SelfRefreshTime = 4;
/* TRC: min=70 (7x11.9ns) */
SdramTiming.RowCycleDelay = 7;
/* TWR: min=1+ 7ns (1+1x11.9ns) */
SdramTiming.WriteRecoveryTime = 2;
/* TRP: 20ns => 2x11.11ns */
SdramTiming.RPDelay = 2;
/* TRCD: 20ns => 2x11.11ns */
SdramTiming.RCDDelay = 2;
HAL_SDRAM_Init(&hsdram1, &SdramTiming);
проверяю так:
CODE
uint8_t Array1[5] = {1,2,3,4,5};
uint8_t Array2[5] = {0,0,0,0,0};
#define BUFFER_SIZE ((uint32_t)0x0005)
#define WRITE_READ_ADDR ((uint32_t)0x0800)
#define SDRAM_BANK_ADDR ((uint32_t)0xD0000000)
/* Counter index */
volatile uint32_t uwIndex = 0x0000;
/* Write data to the SDRAM memory */
for (uwIndex = 0; uwIndex < BUFFER_SIZE; uwIndex++)
*(__IO uint8_t*) (SDRAM_BANK_ADDR + uwIndex) = Array1[uwIndex];
/* Read back data from the SDRAM memory */
Array2[uwIndex] = *(__IO uint8_t*) (SDRAM_BANK_ADDR + uwIndex);
настойки тайминга брал из примеров для данной платы (пример работает!). единственное глобальное отличие - в примере 180 МГц, а у меня 168
Atlantis-
сообщение Aug 12 2014, 13:29
локализовал проблему: в ходе инициализации SDRAM вызывался SysTick_Handler далее xPortSysTickHandler(), в дебрях которого намертво зависал
RSS Текстовая версия Сейчас: 20th August 2025 - 22:00
Страница сгенерированна за 0.01442 секунд с 7
