Обработка математических ошибок в ARM |
Jan 14 2015, 14:36
Пользователь №: 84 046
Здравствуйте! Я использую IAR EWARM 6.40 и STM32F407 (с FPU). Нужно останавливать контроллер при возникновении математических ошибок, например, при log(-1). В этом случае я получаю NaN в качестве результата, но по умолчанию никакого вызова функции или exception не происходит. Нету ли для ARM функции, аналогичной стандартной _matherr (math.h)? На других архитектурах она вызывается при следующих ошибках: Код DOMAIN = 1, /* argument domain error -- log (-1) */ SING, /* argument singularity -- pow (0,-2)) */ OVERFLOW, /* overflow range error -- exp (1000) */ UNDERFLOW, /* underflow range error -- exp (-1000) */ TLOSS, /* total loss of significance -- sin(10e70) */ PLOSS, /* partial loss of signif. -- not used */ STACKFAULT /* floating point unit stack overflow */ Через FPU все эти ошибки, как я понял, тоже нельзя определить, например, регистр FPSCR Cortex-M4 среди битов исключений domain error не имеет: Bit 7 IDC: Input denormal cumulative exception bit. Cumulative exception bit for floating-point exception. 1: Indicates that the corresponding exception occurred since 0 was last written to it. Bit 6:5 Reserved Bit 4 IXC: Inexact cumulative exception bit. Cumulative exception bit for floating-point exception. 1: Indicates that the corresponding exception occurred since 0 was last written to it. Bit 3 UFC: Underflow cumulative exception bit. Cumulative exception bit for floating-point exception. 1: Indicates that the corresponding exception occurred since 0 was last written to it. Bit 2 OFC: Overflow cumulative exception bit. Cumulative exception bit for floating-point exception. 1: Indicates that the corresponding exception occurred since 0 was last written to it. Bit 1 DZC: Division by zero cumulative exception bit. Cumulative exception bit for floating-point exception. 1: Indicates that the corresponding exception occurred since 0 was last written to it. Bit 0 IOC: Invalid operation cumulative exception bit. Cumulative exception bit for floating-point exception. 1: Indicates that the corresponding exception occurred since 0 was last written to it.Мне даже переполнение при результате операции 0.Infinite не удалось зафиксировать в этих флагах. Может, что-то не так сделал, но вроде бы в любом случае ситуацию log(-1) ни один из этих флагов не должен определять? Заранее спасибо.
Jan 14 2015, 19:43
Цитата Насколько я помню, Вам нужно переопределить хандлер matherr() который должен отвечать за обработку ошибки. Хотелось бы, только в моей среде в math.h эта функция не описана, как и ее аргумент exception, поэтому переопределять нечего  . Цитата Так что да, делайте проверку после и/или перед каждой операцией. На самом деле это совсем не сложно. Если бы этот вариант подходил, я бы здесь не писал.
Сообщение отредактировал cyrax0 - Jan 14 2015, 19:45
cyrax0 Обработка математических ошибок в ARM Jan 14 2015, 14:36 scifi Цитата(cyrax0 @ Jan 14 2015, 17:36) Я исп... Jan 14 2015, 14:55 cyrax0 А можно поподробнее, что за errno? Отмечу еще раз,... Jan 14 2015, 17:02 scifi Цитата(cyrax0 @ Jan 14 2015, 20:02) А мож... Jan 14 2015, 19:17  jcxz Цитата(cyrax0 @ Jan 15 2015, 01:43) Если ... Jan 15 2015, 05:26   scifi Цитата(jcxz @ Jan 15 2015, 08:26) Через M... Jan 15 2015, 06:57 Xenia Цитата(cyrax0 @ Jan 14 2015, 20:02) А мож... Jan 14 2015, 22:42 cyrax0 Цитата(Xenia @ Jan 15 2015, 02:42) А чем ... Jan 15 2015, 07:59  jcxz Цитата(cyrax0 @ Jan 15 2015, 13:59) Прико... Jan 15 2015, 08:20 _Pasha Собственно можно пойти далеко в обход: написать ну... Jan 15 2015, 04:32 cyrax0 Не очень понимаю, с какой стати errno может быть в... Jan 15 2015, 08:35 jcxz Цитата(cyrax0 @ Jan 15 2015, 14:35) Не оч... Jan 15 2015, 10:14 scifi Цитата(cyrax0 @ Jan 15 2015, 10:59) У нас... Jan 15 2015, 09:08 jcxz Цитата(scifi @ Jan 15 2015, 15:08) Не фак... Jan 15 2015, 10:27 cyrax0 ЦитатаА если привлечь Си++, то можно и операторы п... Jan 15 2015, 09:25 scifi Цитата(cyrax0 @ Jan 15 2015, 12:25) В ито... Jan 15 2015, 10:22 klen здравствуйте.
вставлю свои 5 копеек.
1. FPU вычисл... Jan 16 2015, 07:25 Xenia Господа! Вы что, с ума сошли? Переменную errn... Jan 15 2015, 12:28 scifi Цитата(Xenia @ Jan 15 2015, 15:28) Одного... Jan 15 2015, 13:01  Xenia Цитата(scifi @ Jan 15 2015, 16:01) Конечн... Jan 15 2015, 13:29   scifi Цитата(Xenia @ Jan 15 2015, 16:29) Тогда ... Jan 15 2015, 13:47    cyrax0 Цитата(scifi @ Jan 15 2015, 17:47) Подозр... Jan 15 2015, 13:53     scifi Цитата(cyrax0 @ Jan 15 2015, 16:53) Делен... Jan 15 2015, 14:51 jcxz Цитата(Xenia @ Jan 15 2015, 18:28) Господ... Jan 15 2015, 17:08 cyrax0 Цитата(scifi @ Jan 15 2015, 14:22) Там ес... Jan 15 2015, 13:46 cyrax0 Цитата(jcxz @ Jan 15 2015, 21:08) Так пом... Jan 16 2015, 06:09 jcxz Цитата(cyrax0 @ Jan 16 2015, 12:09) Я поп... Jan 16 2015, 17:55 WitFed Ещё 1 коп: обычно можно переопределить "систе... Jan 16 2015, 09:19
