> ошибка в stm32f4xx_conf.h с assert_param
Tapochka
сообщение Jul 2 2013, 07:40
Пользователь №: 75 799
Решил разобраться с таймерами в stm32. В итоге прога компилится, однако линкер в Keil выдает timer.axf: Error: L6218E: Undefined symbol assert_param (reffered from stm32f4xx_gpio.o). ну естественно разобрался откуда берется эта assert_param - из stm32f4xx_conf.h(код приведен ниже):
CODE
* @file USART/HyperTerminal_Interrupt/stm32f4xx_conf.h
* @author MCD Application Team
* @version V1.0.1
* @date 13-April-2012
* @brief Library configuration file.
* @attention
* <h2><center>&copy; COPYRIGHT 2012 STMicroelectronics</center></h2>
* Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
* You may not use this file except in compliance with the License.
* You may obtain a copy of the License at:
* http://www.st.com/software_license_agreement_liberty_v2
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __STM32F4xx_CONF_H
#define __STM32F4xx_CONF_H
#if defined (HSE_VALUE)
/* Redefine the HSE value; it's equal to 8 MHz on the STM32F4-DISCOVERY Kit */
#undef HSE_VALUE
#define HSE_VALUE ((uint32_t)8000000)
#endif /* HSE_VALUE */
/* Includes ------------------------------------------------------------------*/
/* Uncomment the line below to enable peripheral header file inclusion */
/*#include "stm32f4xx_adc.h"
#include "stm32f4xx_can.h"
#include "stm32f4xx_crc.h"
#include "stm32f4xx_cryp.h"
#include "stm32f4xx_dac.h"
#include "stm32f4xx_dbgmcu.h"
#include "stm32f4xx_dcmi.h"
#include "stm32f4xx_dma.h"
#include "stm32f4xx_exti.h"
#include "stm32f4xx_flash.h"
#include "stm32f4xx_fsmc.h"
#include "stm32f4xx_hash.h" */
#include "stm32f4xx_gpio.h"
/* #include "stm32f4xx_i2c.h"
#include "stm32f4xx_iwdg.h"
#include "stm32f4xx_pwr.h" */
#include "stm32f4xx_rcc.h"
/* #include "stm32f4xx_rng.h"
#include "stm32f4xx_rtc.h"
#include "stm32f4xx_sdio.h"
#include "stm32f4xx_spi.h"
#include "stm32f4xx_syscfg.h"*/
#include "stm32f4xx_tim.h"
/*#include "stm32f4xx_usart.h"
#include "stm32f4xx_wwdg.h"
#include "misc.h" *//* High level functions for NVIC and SysTick (add-on to CMSIS functions) */
/* Exported types ------------------------------------------------------------*/
/* Exported constants --------------------------------------------------------*/
/* If an external clock source is used, then the value of the following define
should be set to the value of the external clock source, else, if no external
clock is used, keep this define commented */
/*#define I2S_EXTERNAL_CLOCK_VAL 12288000 */ /* Value of the external clock in Hz */
/* Uncomment the line below to expanse the "assert_param" macro in the
Standard Peripheral Library drivers code */
/* #define USE_FULL_ASSERT 1 */
/* Exported macro ------------------------------------------------------------*/
#ifdef USE_FULL_ASSERT
* @brief The assert_param macro is used for function's parameters check.
* @param expr: If expr is false, it calls assert_failed function
* which reports the name of the source file and the source
* line number of the call that failed.
* If expr is true, it returns no value.
* @retval None
#define assert_param(expr) ((expr) ? (void)0 : assert_failed((uint8_t *)__FILE__, __LINE__))
/* Exported functions ------------------------------------------------------- */
void assert_failed(uint8_t* file, uint32_t line);
#else
#define assert_param(expr) ((void)0)
#endif /*USE_FULL_ASSERT */
#endif /*__STM32F4xx_CONF_H */
/************************ © COPYRIGHT STMicroelectronics *****END OF FILE****/
Сказано, что нужно раскомментить #define USE_FULL_ASSERT - я раскомментил, так же раскомментил необходимые файлы сверху, однако проблема не решается, выдает все тоже самое. Помогите, у кого было подобное
Сообщение отредактировал IgorKossak - Jul 2 2013, 09:08
Причина редактирования: [codebox] для длинного кода, [code] - для короткого!!!
Porolon
сообщение May 15 2015, 08:24
Из: Зеленоград
Пользователь №: 7 014
столкнулся с такой же проблемой на STM32F103 При использовании драйверов. Необходимо в настройках проекта определить Define : USE_STDPERIPH_DRIVER
RSS Текстовая версия Сейчас: 29th July 2025 - 18:05
