> STM32F3xx, USB, “1 x 16 bits/word” access scheme, Что это, и где определено?
ViKo
сообщение Jun 17 2015, 20:15
Универсальный солдатик
Пользователь №: 10 362
Читаю RM0316, раздел USB, 32.6.3 Buffer descriptor table:
In the following pages, two address locations are reported for devices with “1 x 16 bits/word”
access scheme: the one to be used by application software while accessing the packet
memory, and the local one relative to USB peripheral access. To obtain the correct memory
address value to be used in the application software while accessing the packet memory,
the actual memory location address must be multiplied by two.
On devices with “2 x 16 bits/word” access scheme, the address location to be used by
application software is the same as the local one relative to USB peripheral access. The
packet memory on these devices should be accessed only by byte (8-bit) or half-word (16-
bit) accesses. Word (32-bit) accesses are not allowed.
Допустим, понять еще... ладно, и понять не могу biggrin.gif И узнать, какому MCU какая схема соответствует.
Кубописатели в stm32f3xx_hal_pcd_ex.h предлагают такое решение:
CODE
* @brief Gets address in an endpoint register.
* @param USBx: USB peripheral instance register address.
* @param bEpNum: Endpoint Number.
* @retval None
#if defined(STM32F302xC) || defined(STM32F303xC) || \
defined(STM32F373xC)
#define PCD_EP_TX_ADDRESS(USBx, bEpNum) ((uint32_t *)((USBx->BTABLE+bEpNum*8)*2+ ((uint32_t)USBx + 0x400)))
#define PCD_EP_TX_CNT(USBx, bEpNum) ((uint32_t *)((USBx->BTABLE+bEpNum*8+2)*2+ ((uint32_t)USBx + 0x400)))
#define PCD_EP_RX_ADDRESS(USBx, bEpNum) ((uint32_t *)((USBx->BTABLE+bEpNum*8+4)*2+ ((uint32_t)USBx + 0x400)))
#define PCD_EP_RX_CNT(USBx, bEpNum) ((uint32_t *)((USBx->BTABLE+bEpNum*8+6)*2+ ((uint32_t)USBx + 0x400)))
#define PCD_SET_EP_RX_CNT(USBx, bEpNum,wCount) {\
uint32_t *pdwReg = PCD_EP_RX_CNT(USBx, bEpNum); \
PCD_SET_EP_CNT_RX_REG(pdwReg, wCount);\
#endif /* STM32F302xC || STM32F303xC || */
/* STM32F373xC */
#if defined(STM32F302xE) || defined(STM32F303xE) || \
defined(STM32F302x8)
#define PCD_EP_TX_ADDRESS(USBx, bEpNum) ((uint16_t *)((USBx->BTABLE+bEpNum*8)+ ((uint32_t)USBx + 0x400)))
#define PCD_EP_TX_CNT(USBx, bEpNum) ((uint16_t *)((USBx->BTABLE+bEpNum*8+2)+ ((uint32_t)USBx + 0x400)))
#define PCD_EP_RX_ADDRESS(USBx, bEpNum) ((uint16_t *)((USBx->BTABLE+bEpNum*8+4)+ ((uint32_t)USBx + 0x400)))
#define PCD_EP_RX_CNT(USBx, bEpNum) ((uint16_t *)((USBx->BTABLE+bEpNum*8+6)+ ((uint32_t)USBx + 0x400)))
uint16_t *pdwReg = PCD_EP_RX_CNT(USBx, bEpNum); \
Но откуда они узнали? Где написано?
Что-то я впадаю в депрессию при попытках разобраться с USB в STM32...
SSerge
сообщение Jun 18 2015, 10:29
Из: Novosibirsk
Пользователь №: 8 528
Откуда они узнали не знаю, а Вы можете это посмотреть в разделе 32.3 Table 176.
Все эти странности по одной простой причине: буферная память у них 16-разрядная и её по-разному отображают в адресное пространство процессора.
512-байтный буфер виден кусочками по 16 бит в каждом 32-битном слове, а в девайсах с буфером 1024 байта эти 16-битные слова упакованы по две штуки в слово. Но читать их по-прежнему можно только полусловами, по 16 бит за раз.
Russia est omnis divisa in partes octo.
RSS Текстовая версия Сейчас: 3rd August 2025 - 21:16
Страница сгенерированна за 0.01353 секунд с 7
