> Модель фазового шума
Grizzzly
сообщение Jun 10 2015, 15:39
Пользователь №: 75 748
Тут коллеги моделируют фазовый шум. Разбирают код, взятый с MATLAB File Exchange: http://www.mathworks.com/matlabcentral/fil...844-phase-noise
Сам код:
CODE
function Sout = add_phase_noise( Sin, Fs, phase_noise_freq, phase_noise_power, VALIDATION_ON )
% function Sout = add_phase_noise( Sin, Fs, phase_noise_freq, phase_noise_power, VALIDATION_ON )
% Oscillator Phase Noise Model
% INPUT:
% Sin - input COMPLEX signal
% Fs - sampling frequency ( in Hz ) of Sin
% phase_noise_freq - frequencies at which SSB Phase Noise is defined (offset from carrier in Hz)
% phase_noise_power - SSB Phase Noise power ( in dBc/Hz )
% VALIDATION_ON - 1 - perform validation, 0 - don't perfrom validation
% OUTPUT:
% Sout - output COMPLEX phase noised signal
% NOTE:
% Input signal should be complex
% EXAMPLE ( How to use add_phase_noise ):
% Assume SSB Phase Noise is specified as follows:
% | Offset From Carrier | Phase Noise |
% | 1 kHz | -84 dBc/Hz |
% | 10 kHz | -100 dBc/Hz |
% | 100 kHz | -96 dBc/Hz |
% | 1 MHz | -109 dBc/Hz |
% | 10 MHz | -122 dBc/Hz |
% Assume that we have 10000 samples of complex sinusoid of frequency 3 KHz
% sampled at frequency 40MHz:
% Fc = 3e3; % carrier frequency
% Fs = 40e6; % sampling frequency
% t = 0:9999;
% S = exp(j*2*pi*Fc/Fs*t); % complex sinusoid
% Then, to produce phase noised signal S1 from the original signal S run follows:
% Fs = 40e6;
% phase_noise_freq = [ 1e3, 10e3, 100e3, 1e6, 10e6 ]; % Offset From Carrier
% phase_noise_power = [ -84, -100, -96, -109, -122 ]; % Phase Noise power
% S1 = add_phase_noise( S, Fs, phase_noise_freq, phase_noise_power );
% Version 1.0
% Alex Bur-Guy, October 2005
% alex@wavion.co.il
% Revisions:
% Version 1.5 - Comments. Validation.
% Version 1.0 - initial version
% NOTES:
% 1) The presented model is a simple VCO phase noise model based on the following consideration:
% If the output of an oscillator is given as V(t) = V0 * cos( w0*t + phi(t) ),
% then phi(t) is defined as the phase noise. In cases of small noise
% sources (a valid assumption in any usable system), a narrowband modulation approximation can
% be used to express the oscillator output as:
% V(t) = V0 * cos( w0*t + phi(t) )
% = V0 * [cos(w0*t)*cos(phi(t)) - sin(w0*t)*sin(phi(t)) ]
% ~ V0 * [cos(w0*t) - sin(w0*t)*phi(t)]
% This shows that phase noise will be mixed with the carrier to produce sidebands around the carrier.
% 2) In other words, exp(j*x) ~ (1+j*x) for small x
% 3) Phase noise = 0 dBc/Hz at freq. offset of 0 Hz
% 4) The lowest phase noise level is defined by the input SSB phase noise power at the maximal
% freq. offset from DC. (IT DOES NOT BECOME EQUAL TO ZERO )
% The generation process is as follows:
% First of all we interpolate (in log-scale) SSB phase noise power spectrum in M
% equally spaced points (on the interval [0 Fs/2] including bounds ).
% After that we calculate required frequency shape of the phase noise by X(m) = sqrt(P(m)*dF(m))
% and after that complement it by the symmetrical negative part of the spectrum.
% After that we generate AWGN of power 1 in the freq domain and multiply it sample-by-sample to
% the calculated shape
% Finally we perform 2*M-2 points IFFT to such generated noise
% ( See comments inside the code )
% 0 dBc/Hz
% \P dBc/Hz /
% . \____________________________________________/ /_ This level is defined by the phase_noise_power at the maximal freq. offset from DC defined in phase_noise_freq
% |__| _|__|__|__|__|__|__|__|__|__|__|__|__|__|__|__|__|__|__|__ (N points)
% 0 dF Fs/2 Fs
% DC
% For some basics about Oscillator phase noise see:
% http://www.circuitsage.com/pll/plldynamics.pdf
% http://www.wj.com/pdf/technotes/LO_phase_noise.pdf
if nargin < 5
VALIDATION_ON = 0;
end
% Check Input
error( nargchk(4,5,nargin) );
if ~any( imag(Sin(:)) )
error( 'Input signal should be complex signal' );
end
if max(phase_noise_freq) >= Fs/2
error( 'Maximal frequency offset should be less than Fs/2');
end
% Make sure phase_noise_freq and phase_noise_power are the row vectors
phase_noise_freq = phase_noise_freq(:).';
phase_noise_power = phase_noise_power(:).';
if length( phase_noise_freq ) ~= length( phase_noise_power )
error('phase_noise_freq and phase_noise_power should be of the same length');
end
% Sort phase_noise_freq and phase_noise_power
[phase_noise_freq, indx] = sort( phase_noise_freq );
phase_noise_power = phase_noise_power( indx );
% Add 0 dBc/Hz @ DC
if ~any(phase_noise_freq == 0)
phase_noise_power = [ 0, phase_noise_power ];
phase_noise_freq = [0, phase_noise_freq];
end
% Calculate input length
N = prod( size( Sin ) );
% Define M number of points (frequency resolution) in the positive spectrum
% (M equally spaced points on the interval [0 Fs/2] including bounds),
% then the number of points in the negative spectrum will be M-2
% ( interval (Fs/2, Fs) not including bounds )
% The total number of points in the frequency domain will be 2*M-2, and if we want
% to get the same length as the input signal, then
% 2*M-2 = N
% M-1 = N/2
% M = N/2 + 1
% So, if N is even then M = N/2 + 1, and if N is odd we will take M = (N+1)/2 + 1
if rem(N,2), % N odd
M = (N+1)/2 + 1;
else
M = N/2 + 1;
end
% Equally spaced partitioning of the half spectrum
F = linspace( 0, Fs/2, M ); % Freq. Grid
dF = [diff(F) F(end)-F(end-1)]; % Delta F
% Perform interpolation of phase_noise_power in log-scale
intrvlNum = length( phase_noise_freq );
logP = zeros( 1, M );
for intrvlIndex = 1 : intrvlNum,
leftBound = phase_noise_freq(intrvlIndex);
t1 = phase_noise_power(intrvlIndex);
if intrvlIndex == intrvlNum
rightBound = Fs/2;
t2 = phase_noise_power(end);
inside = find( F>=leftBound & F<=rightBound );
else
rightBound = phase_noise_freq(intrvlIndex+1);
t2 = phase_noise_power(intrvlIndex+1);
inside = find( F>=leftBound & F<rightBound );
end
logP( inside ) = ...
t1 + ( log10( F(inside) + realmin) - log10(leftBound+ realmin) ) / ( log10( rightBound + realmin) - log10( leftBound + realmin) ) * (t2-t1);
end
P = 10.^(real(logP)/10); % Interpolated P ( half spectrum [0 Fs/2] ) [ dBc/Hz ]
% Now we will generate AWGN of power 1 in frequency domain and shape it by the desired shape
% as follows:
% At the frequency offset F(m) from DC we want to get power Ptag(m) such that P(m) = Ptag/dF(m),
% that is we have to choose X(m) = sqrt( P(m)*dF(m) );
% Due to the normalization factors of FFT and IFFT defined as follows:
% For length K input vector x, the DFT is a length K vector X,
% with elements
% K
% X(k) = sum x(n)*exp(-j*2*pi*(k-1)*(n-1)/K), 1 <= k <= K.
% n=1
% The inverse DFT (computed by IFFT) is given by
% K
% x(n) = (1/K) sum X(k)*exp( j*2*pi*(k-1)*(n-1)/K), 1 <= n <= K.
% k=1
% we have to compensate normalization factor (1/K) multiplying X(k) by K.
% In our case K = 2*M-2.
% Generate AWGN of power 1
if ~VALIDATION_ON
awgn_P1 = ( sqrt(0.5)*(randn(1, M) +1j*randn(1, M)) );
else
awgn_P1 = ( sqrt(0.5)*(ones(1, M) +1j*ones(1, M)) );
end
% Shape the noise on the positive spectrum [0, Fs/2] including bounds ( M points )
X = (2*M-2) * sqrt( dF .* P ) .* awgn_P1;
% Complete symmetrical negative spectrum (Fs/2, Fs) not including bounds (M-2 points)
X( M + (1:M-2) ) = fliplr( conj(X(2:end-1)) );
% Remove DC
X(1) = 0;
% Perform IFFT
x = ifft( X );
% Calculate phase noise
phase_noise = exp( j * real(x(1:N)) );
% Add phase noise
if ~VALIDATION_ON
Sout = Sin .* reshape( phase_noise, size(Sin) );
else
Sout = 'VALIDATION IS ON';
end
if VALIDATION_ON
figure;
plot( phase_noise_freq, phase_noise_power, 'o-' ); % Input SSB phase noise power
hold on;
grid on;
plot( F, 10*log10(P),'r*-'); % Input SSB phase noise power
X1 = fft( phase_noise );
plot( F, 10*log10( ( (abs(X1(1:M))/max(abs(X1(1:M)))).^2 ) ./ dF(1) ), 'ks-' );% generated phase noise exp(j*x)
X2 = fft( 1 + j*real(x(1:N)) );
plot( F, 10*log10( ( (abs(X2(1:M))/max(abs(X2(1:M)))).^2 ) ./ dF(1) ), 'm>-' ); % approximation ( 1+j*x )
xlabel('Frequency [Hz]');
ylabel('dBc/Hz');
legend( ...
'Input SSB phase noise power', ...
'Interpolated SSB phase noise power', ...
'Positive spectrum of the generated phase noise exp(j*x)', ...
'Positive spectrum of the approximation ( 1+j*x )' ...
end
У них возник вопрос по строчке:
Почему мы формируем спектр требуемого фазового шума, умножая awgn_P1, а не fft(awgn_P1)?
Сейчас задумался, вроде бы действительно надо перейти в частотную область, чтобы получить равномерный спектр, затем его умножить на характеристику генератора, а потом сделать ifft. Или же можно считать, что awgn_P1 уже в частотной области, поскольку ограничения на вид распределения у нас нет?
Нашел статейку. Там как раз к отсчетам АБГШ применяется fft. Как всё-таки правильно?
Сообщение отредактировал Grizzzly - Jun 10 2015, 15:40
serjj
сообщение Jun 23 2016, 17:04
Пользователь №: 81 866
Имеется в виду ширина спектра генератора по уровню -3 дБ. Видимо подразумевают, что маска спектра генератора описывается строгой математической формулой независимо от отстройки, по которой, зная ширину по -3 дБ можно посчитать уровень ФШ при произвольной отстройке, т.е. получить профиль ФШ.
Но ИМХО лучше глянуть статьи по-свежее, у analog devices например спектр ФШ разбивают на зоны, в каждой из которых спектральная плотность описывается своим законом. Я к тому, что реальный спектр генератора не всегда подходит под математическую абстракцию.
Для OFDM кстати полезно получить значения профиля ФШ на отстройках кратных расстоянию между поднесущими. Эти значения можно пересчитать в деградацию ФШ. Возможно это более информативно чем ширина по -3 дБ.
Ivan55
сообщение Jul 22 2016, 12:01
Пользователь №: 69 640
Добрый день всем!
Взял я вот такой генератор TX5-504HL5
Профиль фазового шума у него вот такой:
-80 дБн/Гц на 10 Гц
-125 дБн/Гц на 100 Гц
-145 дБн/Гц на 1 кГц
-148 дБн/Гц на 10 кГц
-150 дБн/Гц на 100 кГц
замоделил OFDM КАМ-16 при ОСШ = 20 дБ и получилось что фазовые шумы снизили ОСШ приблизительно всего на 5*10-5 дБ
получается что проблемы у OFDM с фазовыми шумами нет? иначе это должен быть ну ооочень плохой генератор чтоб они возникли
проверил на модели результат такойже
des00
сообщение Jul 23 2016, 05:44
Вечный ламер
Из: Томск
Пользователь №: 3 453
Цитата(Ivan55 @ Jul 22 2016, 19:01) *
1. Как понимаю, вы взяли опорный генератор, дюже хорошего качества. Про свч синтезаторы, приемный и передающий, с параметрами -85дб на отстройке 100КГц вы случайно не забыли?
2. Влияние фш зависит от полосы сигнала. -85 на 100, могут быть не заметны для полосы 100МГц, но чувствительны для полосы 450КГц
Ivan55
сообщение Jul 26 2016, 06:26
Я моделил для полосы 15 кГц частота дискретизации 48 кГц, разнос поднесущих приблизительно 46 Гц диапазон КВ. Моделил следующим образом:
1. Генерировал OFDM на нулевой частоте, никуда не переносил
2. Задавал белый шум, мерил ОСШ
3. Моделил фазу по маске, и умножал Ofdm на экспоненту в степени фазы
4. Мерил ОСШ, брал разность с ОСШ до добавления фазы
методика измерений верна? или может я не правильно измеряю?
И вообще есть какие то требования к ухудшению ОСШ из за фазовых шумов? какие то ГОСТЫ... на скока допустимо ухудшение ОСШ?
Сообщение отредактировал Ivan55 - Jul 26 2016, 06:31
des00
сообщение Jul 26 2016, 06:49
Вечный ламер
Из: Томск
ИМХО не верно
Фазу по маске? Это как это? Вы должны были задать профиль ФШ в частотной области, затем его синтезировать, затем перейти от частоты ко времени, и только потом моделировать фазу (это фазовая компонента фазового шума). При этом, по хорошему, нужно брать 2 источника ФШ, с разной инициализацией и добавить еще между ними рассинхронизацию по частоте
Если ОСШ вы измеряете через энергии то не увидите вы его. Либо измеряйте RxMER либо чутье.
Требования - коэффициент системы связи/чувствительность приемника. А уж какими методами и на каких генераторах вы этого добились, будет определять цену вашего изделия.
- Grizzzly   Модель фазового шума   Jun 10 2015, 15:39
- - des00   Цитата(Grizzzly @ Jun 10 2015, 22:39) Поч...   Jun 10 2015, 17:12
|- - Grizzzly   Цитата(des00 @ Jun 10 2015, 20:12) Потому...   Jun 10 2015, 17:21
|- - des00   Цитата(Grizzzly @ Jun 11 2015, 00:21) А н...   Jun 10 2015, 17:26
|- - Grizzzly   Цитата(des00 @ Jun 10 2015, 20:26) Уже то...   Jun 10 2015, 17:28
- - serjj   ЦитатаУвидите непосредственно ФШ. Затем сгенерируй...   Jun 10 2015, 17:35
|- - des00   Цитата(serjj @ Jun 11 2015, 01:35) Ну ФШ ...   Jun 10 2015, 17:40
- - des00   Немного интересных документов. Есть еще, но весят ...   Jun 11 2015, 04:26
|- - Кнкн   Цитата(des00 @ Jun 11 2015, 07:26) Немног...   Jun 11 2015, 06:12
|- - des00   Цитата(Кнкн @ Jun 11 2015, 14:12) Тема ин...   Jun 11 2015, 06:54
||- - andyp   Цитата(des00 @ Jun 11 2015, 09:54) Не зна...   Jun 11 2015, 07:00
||- - des00   Цитата(andyp @ Jun 11 2015, 15:00) А нель...   Jun 11 2015, 07:16
||- - des00   Цитата(des00 @ Jun 11 2015, 15:16) ок, ча...   Jun 11 2015, 17:49
||- - andyp   Цитата(des00 @ Jun 11 2015, 20:49) http:/...   Jun 11 2015, 18:28
||- - Grizzzly   Цитата(des00 @ Jun 11 2015, 20:49) http:/...   Jun 11 2015, 18:33
|- - des00   Цитата(Кнкн @ Jun 11 2015, 14:12) Может б...   Jun 12 2015, 03:22
|- - Кнкн   Цитата(des00 @ Jun 12 2015, 06:22) положи...   Jun 15 2015, 07:08
|- - Ivan55   Всем добрый день! Заинтересовался данной темой...   Feb 11 2016, 10:02
- - andyp   Цитата(Grizzzly @ Jun 10 2015, 18:39) У н...   Jun 12 2015, 19:50
|- - Grizzzly   Цитата(andyp @ Jun 12 2015, 22:50) Подума...   Jun 14 2015, 10:10
- - des00   Фазовый шум - вариация фазы генератора, причем тут...   Feb 11 2016, 11:11
|- - Ivan55   Цитата(des00 @ Feb 11 2016, 14:11) Фазовы...   Feb 11 2016, 11:32
|- - des00   Цитата(Ivan55 @ Feb 11 2016, 18:32) В так...   Feb 11 2016, 12:08
|- - Ivan55   Цитата(des00 @ Feb 11 2016, 15:08) Наверн...   Feb 11 2016, 12:20
|- - des00   Цитата(Ivan55 @ Feb 11 2016, 20:20) точне...   Feb 11 2016, 15:27
|- - Ivan55   Цитата(des00 @ Feb 11 2016, 18:27) это-то...   Feb 11 2016, 17:12
|- - des00   Цитата(Ivan55 @ Feb 12 2016, 01:12) Было ...   Feb 16 2016, 05:59
|- - Fat Robot   Очень впечатляет. Вы могли бы объяснить природу эт...   Feb 16 2016, 08:04
|- - des00   Цитата(Fat Robot @ Feb 16 2016, 16:04) Вы...   Feb 16 2016, 08:23
|- - Ivan55   фазовый шум описывается Винеровским процессом: ph(...   Apr 19 2016, 08:08
- - KalashKS   Похоже на правду. По дному символу такое созвездие...   Apr 19 2016, 08:37
|- - Ivan55   Цитата(KalashKS @ Apr 19 2016, 12:37) По ...   Apr 19 2016, 08:45
- - KalashKS   Да, правильно.   Apr 19 2016, 08:46
|- - Ivan55   Цитата(KalashKS @ Apr 19 2016, 12:46) Да,...   Apr 19 2016, 08:48
- - serjj   О влиянии фазового шума в OFDM модеме мне понравил...   Apr 25 2016, 06:34
|- - des00   Цитата(serjj @ Apr 25 2016, 14:34) при ус...   Apr 25 2016, 08:36
- - serjj   Цитатавот сделать это на разных, дешевых, шумящих ...   Apr 27 2016, 21:02
|- - des00   Цитата(serjj @ Apr 28 2016, 04:02) Ну есл...   Apr 28 2016, 01:32
- - serjj   Можно проделать мысленный эксперимент. Допустим ес...   Apr 28 2016, 13:29
|- - des00   Цитата(serjj @ Apr 28 2016, 21:29) Можно ...   Apr 28 2016, 13:45
- - serjj   Цитатаа еще если pRX11 == pRx22, т.е. двухканальны...   Apr 28 2016, 14:00
|- - des00   Цитата(serjj @ Apr 28 2016, 21:00) Спорти...   Apr 29 2016, 02:38
|- - Ivan55   Добрый день! возвращаясь к данной теме возник...   Jun 22 2016, 08:54
||- - Ivan55   Цитата(des00 @ Jul 26 2016, 10:49) Фазу п...   Jul 26 2016, 07:22
||- - des00   Цитата(Ivan55 @ Jul 26 2016, 14:22) да та...   Jul 26 2016, 07:27
|- - Ivan55   Цитата(des00 @ Jul 23 2016, 08:44) вы взя...   Jul 28 2016, 06:14
|- - des00   Цитата(Ivan55 @ Jul 28 2016, 13:14) Не по...   Jul 28 2016, 09:15
|- - Ivan55   Цитата(des00 @ Jul 28 2016, 12:15) [-30 -...   Jul 28 2016, 09:33
|- - des00   Цитата(Ivan55 @ Jul 28 2016, 16:33) Это ч...   Jul 28 2016, 09:40
|- - Ivan55   Цитата(des00 @ Jul 28 2016, 12:40) это кл...   Jul 28 2016, 09:48
|- - des00   Цитата(Ivan55 @ Jul 28 2016, 16:48) У мен...   Jul 28 2016, 10:08
|- - Ivan55   Цитата(des00 @ Jul 28 2016, 13:08) и еще,...   Jul 28 2016, 10:46
|- - des00   Цитата(Ivan55 @ Jul 28 2016, 17:46) А меж...   Jul 28 2016, 10:53
|- - Ivan55   RE: Модель фазового шума   Aug 2 2016, 06:35
- - KalashKS   Похоже на правду. Но поворот созвездия нужно скомп...   Aug 2 2016, 08:40
- - Ivan55   Доброго дня всем! Возможно щас глупость спрош...   Aug 16 2016, 08:45
- - Ivan55   Можно еще так вопрос задать есть структурная схем...   Aug 17 2016, 08:13
- - Ivan55   Цитата(Ivan55 @ Aug 17 2016, 12:13) Можно...   Aug 22 2016, 05:07
- - Ivan55   И снова здравствуйте!) есть такой вопрос в ...   Jan 24 2017, 11:51
RSS Текстовая версия Сейчас: 31st July 2025 - 16:37
Страница сгенерированна за 0.01547 секунд с 7
