> Вопрос про phy ethernet, stm32f407 + KSZ8873
Granadoespada
сообщение Sep 5 2016, 12:49
Пользователь №: 89 981
Здравствуйте! Есть микроконтроллер и phy KSZ8873 делаю инициализацию пинов
CODE
void eth_gpio_config()
GPIO_InitTypeDef GPIO_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB |
RCC_AHB1Periph_GPIOC, ENABLE);
/* Configure PA2 as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
//GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_ETH);
/* Configure PC1, PC2 and PC3 as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource1, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource2, GPIO_AF_ETH);
/* Configure PB5, PB8, PB11, PB12 and PB13 as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_11 |
GPIO_Pin_12 | GPIO_Pin_13;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource11, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource12, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_ETH);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_3;
// GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_PinAFConfig(GPIOA, GPIO_PinSource0, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource1, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_ETH);
/* Configure PB10 as input */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
// GPIO_ResetBits(GPIOB, GPIO_Pin_10); /* FIXME: fucking workaround */
GPIO_PinAFConfig(GPIOB, GPIO_PinSource10, GPIO_AF_ETH);
/* Configure PC3 as input */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
GPIO_PinAFConfig(GPIOC, GPIO_PinSource3, GPIO_AF_ETH);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_ETH);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
GPIO_PinAFConfig(GPIOC, GPIO_PinSource4, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource5, GPIO_AF_ETH);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
GPIO_PinAFConfig(GPIOB, GPIO_PinSource0, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource1, GPIO_AF_ETH);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_PinAFConfig(GPIOA, GPIO_PinSource8, GPIO_AF_MCO);
дальше идет конфигурация MAC_DMA
CODE
void eth_mac_dma_config()
ETH_InitTypeDef ETH_InitStructure;
/* Enable SYSCFG clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
/* Включение частот ETHERNET */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_ETH_MAC | RCC_AHB1Periph_ETH_MAC_Tx |
RCC_AHB1Periph_ETH_MAC_Rx, ENABLE);
/* MII/RMII Media interface selection --------------------------------------*/
SYSCFG_ETH_MediaInterfaceConfig(SYSCFG_ETH_MediaInterface_MII);
RCC_MCO1Config(RCC_MCO1Source_HSE, RCC_MCO1Div_1);
SYSCFG_CompensationCellCmd(ENABLE);
/* Перзагрузка ETHERNET на шине AHB */
ETH_DeInit();
/* Программная перезагрузка */
ETH_SoftwareReset();
/* Ожидание программной перезагрузки */
while(ETH_GetSoftwareResetStatus() == SET);
/* Настройка ETHERNET */
ETH_StructInit(&ETH_InitStructure);
/* Настройка параметров MAC */
ETH_InitStructure.ETH_AutoNegotiation = ETH_AutoNegotiation_Enable;
ETH_InitStructure.ETH_LoopbackMode = ETH_LoopbackMode_Disable;
ETH_InitStructure.ETH_RetryTransmission = ETH_RetryTransmission_Disable;
ETH_InitStructure.ETH_AutomaticPadCRCStrip = ETH_AutomaticPadCRCStrip_Disable;
ETH_InitStructure.ETH_ReceiveAll = ETH_ReceiveAll_Disable;
ETH_InitStructure.ETH_BroadcastFramesReception = ETH_BroadcastFramesReception_Enable;
ETH_InitStructure.ETH_PromiscuousMode = ETH_PromiscuousMode_Disable;
ETH_InitStructure.ETH_MulticastFramesFilter = ETH_MulticastFramesFilter_Perfect;
ETH_InitStructure.ETH_UnicastFramesFilter = ETH_UnicastFramesFilter_Perfect;
ETH_InitStructure.ETH_ChecksumOffload = ETH_ChecksumOffload_Enable;
/* Настройка параметров DMA */
ETH_InitStructure.ETH_DropTCPIPChecksumErrorFrame = ETH_DropTCPIPChecksumErrorFrame_Enable;
ETH_InitStructure.ETH_ReceiveStoreForward = ETH_ReceiveStoreForward_Enable;
ETH_InitStructure.ETH_TransmitStoreForward = ETH_TransmitStoreForward_Enable;
ETH_InitStructure.ETH_Speed = ETH_Speed_100M;
ETH_InitStructure.ETH_ForwardErrorFrames = ETH_ForwardErrorFrames_Disable;
ETH_InitStructure.ETH_ForwardUndersizedGoodFrames = ETH_ForwardUndersizedGoodFrames_Disable;
ETH_InitStructure.ETH_SecondFrameOperate = ETH_SecondFrameOperate_Enable;
ETH_InitStructure.ETH_AddressAlignedBeats = ETH_AddressAlignedBeats_Enable;
ETH_InitStructure.ETH_FixedBurst = ETH_FixedBurst_Enable;
ETH_InitStructure.ETH_RxDMABurstLength = ETH_RxDMABurstLength_32Beat;
ETH_InitStructure.ETH_TxDMABurstLength = ETH_TxDMABurstLength_32Beat;
ETH_InitStructure.ETH_DMAArbitration = ETH_DMAArbitration_RoundRobin_RxTx_2_1;
/* Применение настроек Ethernet */
ETH_Init(&ETH_InitStructure, PHY_ADDRESS);
/* Включение прерываний Ethernet Rx */
ETH_DMAITConfig(ETH_DMA_IT_NIS | ETH_DMA_IT_R, ENABLE);
Почему то не может выйти из функции ожидания программной перезагрузки while(ETH_GetSoftwareResetStatus() == SET).
Может кто сможет подсказать что делаю не так?
За ранее спасибо.
Сообщение отредактировал IgorKossak - Sep 5 2016, 15:13
Причина редактирования: [codebox] для длинного кода. [code]-для короткого!!!
scifi
сообщение Sep 5 2016, 13:15
Пользователь №: 25 136
Было такое, когда из PHY в МК не приходил тактирующий сигнал.
Granadoespada
сообщение Sep 5 2016, 13:21
А тактирующий сигнал должен по MCO приходит?
просто я смотрю с помощью осциллографа и 25 МГц вро де как приходит на физику.
scifi
сообщение Sep 5 2016, 14:08
Тактирующий сигнал из PHY в МК. А не наоборот. У меня RMII, там он называется REF_CLK и имеет частоту 50 МГц.
- Granadoespada   Вопрос про phy ethernet   Sep 5 2016, 12:49
|- - Granadoespada   Цитата(scifi @ Sep 5 2016, 14:08) Тактиру...   Sep 5 2016, 14:29
|- - scifi   Цитата(Granadoespada @ Sep 5 2016, 17:29)...   Sep 5 2016, 14:33
- - jcxz   А что значит "нерестится"? Икру мечет?   Sep 5 2016, 13:59
|- - Granadoespada   Цитата(jcxz @ Sep 5 2016, 13:59) А что зн...   Sep 5 2016, 14:04
- - Obam   Из жизни эмбеддера рыбака: мечет икру (нерестится)...   Sep 5 2016, 14:02
- - x893   Путина началась ? Тогда отнерестится.   Sep 5 2016, 14:05
|- - Granadoespada   Цитата(x893 @ Sep 5 2016, 14:05) Путина н...   Sep 5 2016, 14:08
- - Jury093   Цитата(Granadoespada @ Sep 5 2016, 15:49)...   Sep 5 2016, 15:51
|- - Granadoespada   Цитата(Jury093 @ Sep 5 2016, 15:51) почит...   Sep 6 2016, 08:48
|- - Jury093   Цитата(Granadoespada @ Sep 6 2016, 11:48)...   Sep 6 2016, 08:56
|- - Granadoespada   Цитата(Jury093 @ Sep 6 2016, 08:56) как г...   Sep 6 2016, 09:14
|- - iosifk   Цитата(Granadoespada @ Sep 6 2016, 12:14)...   Sep 6 2016, 09:23
|- - Granadoespada   Цитата(iosifk @ Sep 6 2016, 09:23) Как гд...   Sep 6 2016, 09:35
|- - iosifk   Цитата(Granadoespada @ Sep 6 2016, 12:35)...   Sep 6 2016, 09:47
|- - Granadoespada   Цитата(iosifk @ Sep 6 2016, 10:47) Есть и...   Sep 6 2016, 10:04
|- - iosifk   Цитата(Granadoespada @ Sep 6 2016, 13:04)...   Sep 6 2016, 10:41
||- - Granadoespada   Цитата(iosifk @ Sep 6 2016, 11:41) Ну мне...   Sep 6 2016, 10:46
||- - scifi   Цитата(iosifk @ Sep 6 2016, 13:41) Ну мне...   Sep 6 2016, 13:23
||- - Granadoespada   Цитата(scifi @ Sep 6 2016, 14:23) Путаете...   Sep 6 2016, 13:29
||- - scifi   Цитата(Granadoespada @ Sep 6 2016, 16:29)...   Sep 6 2016, 13:35
|- - Jury093   Цитата(Granadoespada @ Sep 6 2016, 13:04)...   Sep 6 2016, 11:13
|- - Granadoespada   Цитата(Jury093 @ Sep 6 2016, 12:13) я пло...   Sep 6 2016, 12:29
|- - Integro   Цитата(Granadoespada @ Sep 6 2016, 15:29)...   Sep 6 2016, 12:42
|- - Granadoespada   Цитата(Integro @ Sep 6 2016, 13:42) Схему...   Sep 6 2016, 13:22
|- - Integro   Цитата(Granadoespada @ Sep 6 2016, 16:22)...   Sep 6 2016, 13:33
|- - Granadoespada   Цитата(Integro @ Sep 6 2016, 14:33) Как б...   Sep 6 2016, 13:35
|- - Integro   Цитата(Granadoespada @ Sep 6 2016, 16:35)...   Sep 6 2016, 13:43
|- - Granadoespada   Цитата(Integro @ Sep 6 2016, 14:43) Тепер...   Sep 6 2016, 13:50
||- - Integro   Цитата(Granadoespada @ Sep 6 2016, 16:50)...   Sep 6 2016, 14:07
||- - Granadoespada   Цитата(Integro @ Sep 6 2016, 15:07) и...?...   Sep 6 2016, 14:11
||- - scifi   Цитата(Granadoespada @ Sep 6 2016, 17:11)...   Sep 6 2016, 14:17
||- - Granadoespada   Цитата(scifi @ Sep 6 2016, 15:17) Кстати,...   Sep 7 2016, 05:26
||- - Integro   Если схема включения уже отлажена, я бы порекоменд...   Sep 7 2016, 07:05
||- - Granadoespada   Цитата(Integro @ Sep 7 2016, 08:05) Если ...   Sep 7 2016, 09:57
||- - iosifk   Цитата(Granadoespada @ Sep 7 2016, 12:57)...   Sep 7 2016, 10:06
||- - Granadoespada   Цитата(iosifk @ Sep 7 2016, 11:06) И в че...   Sep 7 2016, 10:20
|- - scifi   Цитата(Integro @ Sep 6 2016, 16:43) Тепер...   Sep 6 2016, 14:07
- - IgorKossak   Granadoespada , соблаговолите оформлять код как по...   Sep 6 2016, 12:18
RSS Текстовая версия Сейчас: 6th August 2025 - 20:56
Страница сгенерированна за 0.01506 секунд с 7
