Цитата(Сергей Борщ @ Nov 9 2016, 11:19)
Где-то путаницы (unsigned char *) <->(int *) не может быть? 32 / sizeof(int) = 8. Попробуйте записать, скажем, 28 байт.
Писал разное количество, и 31 и 26, и т.д.
Код функций на инициализацию, чтение, запись, и прочее:
Файл memory.c
CODE
#ifndef AT91RM9200_H
#include <AT91RM9200.H>
#endif
#include "memory.h"
#define PAGE_SIZE 2112
extern unsigned char data[PAGE_SIZE];
extern int statusReadPageNand;
extern unsigned char writeData[30];
void delayNand(int a)
while(a!=0)
a--;
void BOARD_ConfigureNandFlash(void)
// Configure EBI
AT91C_BASE_EBI->EBI_CSA |= AT91C_EBI_CS3A_SMC_SmartMedia;
// Setup Flash
// WSEN = 1 (Wait states are enabled)
// NWS = 1 (Number of Wait States) (1 * 16,7 nS)
// DBW = 2 (Data Bus Width - 8-bit)
AT91C_BASE_SMC2->SMC2_CSR[3] = (AT91C_SMC2_NWS & 1) | AT91C_SMC2_WSEN | AT91C_SMC2_DBW_8;
void PIO_Configure_CE_RB(void)
//PC14=SMCE - output
AT91C_BASE_PIOC->PIO_IDR = AT91C_PIO_PC14; //Disable interrupts
AT91C_BASE_PIOC->PIO_PPUDR = AT91C_PIO_PC14;
AT91C_BASE_PIOC->PIO_MDDR = AT91C_PIO_PC14;
AT91C_BASE_PIOC->PIO_SODR = AT91C_PIO_PC14; //1
AT91C_BASE_PIOC->PIO_OER = AT91C_PIO_PC14;
AT91C_BASE_PIOC->PIO_PER = AT91C_PIO_PC14;
//SMWE - output
AT91C_BASE_PIOC->PIO_MDDR = AT91C_PIO_PC3;
AT91C_BASE_PIOC->PIO_PDR = AT91C_PIO_PC3;
AT91C_BASE_PIOC->PIO_ASR = AT91C_PIO_PC3;
//SMOE - output
AT91C_BASE_PIOC->PIO_MDDR = AT91C_PIO_PC1;
AT91C_BASE_PIOC->PIO_PDR = AT91C_PIO_PC1;
AT91C_BASE_PIOC->PIO_ASR = AT91C_PIO_PC1;
//PC15=SMRB - input
AT91C_BASE_PMC->PMC_PCER = 1 << AT91C_ID_PIOC;
AT91C_BASE_PIOC->PIO_IDR = AT91C_PIO_PC15; //Disable interrupts
AT91C_BASE_PIOC->PIO_PPUDR = AT91C_PIO_PC15;
AT91C_BASE_PIOC->PIO_IFDR = AT91C_PIO_PC15;
AT91C_BASE_PIOC->PIO_ODR = AT91C_PIO_PC15;
AT91C_BASE_PIOC->PIO_PER = AT91C_PIO_PC15;
unsigned char Get_SMRB(void)
unsigned int reg = AT91C_BASE_PIOC->PIO_PDSR;
if ((reg & AT91C_PIO_PC15) == 0) {
return 0;
else {
return 1;
void WaitReady(void)
while (!Get_SMRB());
void NandFlash_Reset(void)
// PC14 #CE=0
AT91C_BASE_PIOC->PIO_CODR = AT91C_PIO_PC14; //0
WRITE_COMMAND(COMMAND_RESET);
WaitReady();
// PC14 #CE=1
int NandFlash_ReadId(void)
unsigned int chipId;
unsigned char chipId2;
// PC14 #CE=0
WRITE_COMMAND(COMMAND_READID);
WRITE_ADDRESS(0);
chipId = READ_DATA8;
if (chipId == 0x2C)
return 1;
chipId |= READ_DATA8 << 8;
chipId |= READ_DATA8 << 16;
chipId |= READ_DATA8 << 24;
chipId2 = READ_DATA8;
// PC14 #CE=1
if(chipId==0)
chipId=10;
if(chipId2==0)
chipId2=10;
return chipId;
void NandFlash_Read(int column, int row, int page, int LUN, int plane)
int column1,column2,row1,row2,row3;
int i = 0;
int cycle1,cycle2,cycle3,cycle4,cycle5;
cycle1 = column%65536;
cycle2 = column>>16;
cycle3 = page;
cycle3 |= plane<<7;
cycle4 = row%65536;
cycle5 = row>>9;
cycle5 |= LUN<<10;
// PC14 #CE=0
WRITE_COMMAND(COMMAND_READ_1);
WRITE_ADDRESS(cycle1);
WRITE_ADDRESS(cycle2);
WRITE_ADDRESS(cycle3);
WRITE_ADDRESS(cycle4);
WRITE_ADDRESS(cycle5);
WRITE_COMMAND(COMMAND_READ_2);
WaitReady();
for(i = 0; i<PAGE_SIZE; i++)
data[i] = READ_DATA8;
delayNand(1);
data[i] |= READ_DATA8 << 8;
delayNand(1);
data[i] |= READ_DATA8 << 16;
delayNand(1);
data[i] |= READ_DATA8 << 24;
delayNand(1);
// PC14 #CE=1
void NandFlash_Write(int column, int row, int page, int LUN, int plane)
// PC14 #CE=0
int column1,column2,row1,row2,row3,i;
unsigned char * Write;
Write = (unsigned char *) writeData;
cycle3 = page;
cycle3 |= plane<<7;
cycle4 = row%65536;
cycle5 = row>>9;
cycle5 |= LUN<<10;
WRITE_COMMAND(COMMAND_WRITE_1);
for(i = 10;i>0;i--)
WRITE_DATA8(Write[i]);
delayNand(1);
WRITE_COMMAND(COMMAND_WRITE_2);
WaitReady();
// PC14 #CE=1
unsigned char NandFlash_ReadStatus()
int status;
WRITE_COMMAND(COMMAND_READ_STATUS);
status = READ_DATA8;
WaitReady();
return status;
void NandFlash_EraseBlock(int column, int page, int plane)
unsigned char status;
int cycle1,cycle2,cycle3;
cycle3 = page;
cycle3 |= plane<<7;
WRITE_COMMAND(COMMAND_ERASE_1);
WRITE_COMMAND(COMMAND_ERASE_2);
WaitReady();
status = NandFlash_ReadStatus();
void NandFlash_WriteFF(int column,int row, int page, int LUN, int plane)
// PC14 #CE=0
cycle3 = page;
cycle3 |= plane<<7;
cycle4 = row%65536;
cycle5 = row>>9;
cycle5 |= LUN<<10;
for(i = 2112;i>0;i--)
WRITE_DATA8(0xFF);
delayNand(1);
WaitReady();
// PC14 #CE=1
Файл memory.h
CODE
#ifndef MEMORY_H
#define MEMORY_H
#endif
#define COMMAND_RESET 0xFF
#define COMMAND_READID 0x90
#define COMMAND_READ_1 0x00
#define COMMAND_READ_2 0x30
#define COMMAND_WRITE_1 0x80
#define COMMAND_WRITE_2 0x10
#define COMMAND_ERASE_1 0x60
#define COMMAND_ERASE_2 0xD0
#define COMMAND_READ_STATUS 0x70
/// Address for transferring command bytes to the nandflash.
#define BOARD_NF_COMMAND_ADDR 0x40200000
/// Address for transferring address bytes to the nandflash.
#define BOARD_NF_ADDRESS_ADDR 0x40400000
/// Address for transferring data bytes to the nandflash.
#define BOARD_NF_DATA_ADDR 0x40000000
#define WRITE_COMMAND(command) \
{*((volatile unsigned char *) BOARD_NF_COMMAND_ADDR) = (unsigned char) command;}
#define WRITE_ADDRESS(address) \
{*((volatile unsigned char *) BOARD_NF_ADDRESS_ADDR) = (unsigned char) address;}
#define WRITE_DATA8(data) \
{*((volatile unsigned char *) BOARD_NF_DATA_ADDR) = (unsigned char) data;}
#define READ_DATA8 \
(*((volatile unsigned char *) BOARD_NF_DATA_ADDR))
void BOARD_ConfigureNandFlash(void);
void PIO_Configure_CE_RB(void);
unsigned char Get_SMRB(void);
void WaitReady(void);
void NandFlash_Reset(void);
int NandFlash_ReadId(void);
void NandFlash_Write(int column,int row, int page, int LUN, int plane);
void NandFlash_Read(int column,int row, int page, int LUN, int plane);
unsigned char NandFlash_ReadStatus();
void NandFlash_EraseBlock(int column, int page, int plane);
void NandFlash_WriteFF(int column,int row, int page, int LUN, int plane);
Сообщение отредактировал Akscan - Nov 9 2016, 08:30
