> вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 008
rom67
сообщение Nov 2 2016, 21:05
Пользователь №: 88 095
DATE: 10-29-2016   HOTFIX VERSION: 008
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
1644406 ALLEGRO_EDITOR SHAPE            Alternate symbol placement results in illegal parent identifier error
1647098 SIP_LAYOUT     OTHER            SiP crashes on symbol copy and rotate
1647154 APD            OTHER            Disconnected Clines not working
1648817 GRE            IFP_INTERACTIVE  Allegro PCB Editor stops responding on adding netgroups to a nested netgroup
1649829 CONCEPT_HDL    CORE             Project Manager: A delay is observed before the sub menus of the File and Tools menus appear
1652930 ALLEGRO_EDITOR OTHER            Command-line version of switchversion not working
1653109 ASDA           DESIGN_CORRUPTIO SDA not pulling latest library information for part
1655377 FLOWS          PROJMGR          Project Manager crashes on Windows 10
rom67
сообщение Jan 9 2017, 13:17
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 010
DATE: 01-6-2017    HOTFIX VERSION: 010
1524700 F2B            DESIGNVARI       Variant file cannot be loaded
1597787 CONCEPT_HDL    MARKERS          Save As in Marker dialog causes DE-HDL to crash
1599843 CONCEPT_HDL    INTERFACE_DESIGN Moving NG causes extra elements or moving
1620017 F2B            PACKAGERXL       Packager Fails with ERROR(SPCOPK-1053) when $PART_NUMBER property for components has a value
1632977 CONCEPT_HDL    INTERFACE_DESIGN Connectivity error when moving NG members
1635941 ALLEGRO_EDITOR INTERFACES       Shape created by IPC 2581 for negative film is not same as the shape on board
1656357 CONCEPT_HDL    CORE             Pasting a signal name across pages causes the name to overlap with the wire segment
1657346 CONCEPT_HDL    PDF              Wire Pattern set to two-dot chain line in a schematic appears as a solid line in the PDF output
1658048 ALLEGRO_EDITOR COLOR            color_lastgroup is not working in SPB 17.2
1658874 CONCEPT_HDL    CORE             'Insert (n) Pages' command does not work when the CONFIRM_WRITE directive is ON
1659030 RF_PCB         LIBRARY          Offset is not calculated from the center if using negative values for input pins when placing MSOP symbols
1659097 CONCEPT_HDL    CORE             mouse stroke fails to be enabled on startup with left moust button (LMB)
1659532 CONCEPT_HDL    CORE             About Import Design command with the CONFIRM_WRITE directive
1659929 CONSTRAINT_MGR UI_FORMS         Using wildcards in filename for Import Constraints does not work in 17.2
1660200 ALLEGRO_EDITOR UI_GENERAL       Move by Sym Pin # edit box is obfuscated
1662821 ALLEGRO_EDITOR OTHER            Cross section chart does not show stack vias in 17.2
1663641 CONCEPT_HDL    COPY_PROJECT     File - Copy Project in Project Manager creates two designs if there are dashes in the design name
1665652 ALLEGRO_EDITOR SHAPE            Critical fillet and shape issues in 17.2
1665918 CONCEPT_HDL    CHECKPLUS        Error (100) Program Internal Error "Create_flat_node" with checkplus run
1667056 ASI_PI         GUI              Power Feasibility Editor does not list capacitors connected to selected nets/parts
1668137 ALLEGRO_EDITOR SCRIPTS          PCB Editor crashing when running Script Replay
1669651 CONCEPT_HDL    CREFER           CreferHDL values are invisible
1669707 CONCEPT_HDL    CORE             Pin numbers not visible on the canvas after replacing a part with the same symbol but a different part property
1670339 ALLEGRO_EDITOR OTHER            Small shapes define on the mechanical symbol Board Geometry – Outline are not converted to the Cutout subclass.
1670564 ALLEGRO_EDITOR MANUFACT         exported gerber file can't import in brd
1670687 ALLEGRO_EDITOR NC               nclegend.log reports missing columns which are present in the NC Legend
1670811 PSPICE         AA_MC            AA MC Plot settings options
1671428 ALLEGRO_EDITOR UI_FORMS         Display origin checkbox position changes in Step Mapping dialog
1671728 CONCEPT_HDL    CORE             Option requested to reload preferred_projects.txt without re-opening DE-HDL
1671901 ALLEGRO_EDITOR UI_GENERAL       Toolbar and menus are locked or greyed out
1672477 ALLEGRO_EDITOR DRC_CONSTR       DRC generated by Dynamic fillets
1673499 ALLEGRO_EDITOR DATABASE         Would you please check on the drill table title issue of backdrill design in v172.
1673681 ALLEGRO_EDITOR UI_GENERAL       F1 for Help not working in PCB Editor 17.2
1675499 ALLEGRO_EDITOR DATABASE         Running the Gloss command causes PCB Editor to crash...
1676480 ALLEGRO_EDITOR MANUFACT         Creating Variant Assy_Bot Drawing showing Variant Assy Top Drawing
1677431 ALLEGRO_EDITOR DATABASE         Get ERROR(SPMHA1-141): Invalid sector row. Contact cadence customer support when opening DRA File
1677651 CONSTRAINT_MGR CONCEPT_HDL      DE-HDL crash on design after successful packaging
1677672 CONCEPT_HDL    CORE             Whitespaces in URL links are not resolved correctly on Linux with Firefox
1680837 ALLEGRO_EDITOR SHAPE            Updating the shape makes the shape disconnect from Thru pins of same net
1681059 ALLEGRO_EDITOR SHAPE            Shape Voiding using DV_SQUARECORNERS environmental variable does not always produce voids with square corners.
1682312 SIG_INTEGRITY  LICENSING        Allegro Sigrity SI/PI Product Choices window is blank after installing 17.2-s009 hotfix
- rom67   вышел хотфикс OrCAD/Allegro 17.2   Nov 2 2016, 21:05
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Dec 13 2016, 20:18
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Jan 23 2017, 17:27
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Feb 13 2017, 18:33
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Feb 19 2017, 18:31
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Mar 5 2017, 19:29
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Mar 27 2017, 18:54
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Apr 10 2017, 19:03
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Apr 12 2017, 21:29
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   May 9 2017, 00:32
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   May 14 2017, 15:16
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   May 22 2017, 21:40
- - rom67   .   May 22 2017, 21:40
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Jun 6 2017, 17:04
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Jun 19 2017, 15:37
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Aug 11 2017, 22:41
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Aug 28 2017, 17:39
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Sep 20 2017, 18:53
|- - alver   Кто-нибудь знает, что за новая опция появилась в A...   Sep 26 2017, 12:41
- - Карлсон   Может что-то тут есть?   Sep 26 2017, 17:09
|- - alver   нет, и официальные партнеры затрудняются сказать.   Sep 26 2017, 17:26
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Oct 9 2017, 17:30
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Oct 16 2017, 20:36
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Nov 8 2017, 17:41
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Nov 20 2017, 18:30
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Dec 11 2017, 15:35
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Jan 15 2018, 20:45
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Jan 30 2018, 17:53
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Feb 14 2018, 19:02
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Mar 5 2018, 19:55
- - rom67   КодFixed CCRs: SPB 17.2 HF035 02-30-2018 =====...   Mar 7 2018, 17:11
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Mar 19 2018, 17:17
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Apr 3 2018, 14:46
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   May 3 2018, 12:23
- - copov   Очень мощное обновление Cadence Allegro Editor и ...   May 7 2018, 10:51
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   May 15 2018, 15:36
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   May 29 2018, 21:01
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Jun 19 2018, 07:33
- - copov   Подскажите пожалуйста. После установки OrCAD/Alleg...   Jun 22 2018, 08:08
- - copov   Спасибо, сам отвечу. Косяки в символьном редактор...   Jun 26 2018, 06:03
|- - PCBtech   Цитата(copov @ Jun 26 2018, 09:03) Спасиб...   Jul 18 2018, 19:59
- - copov   del   Jun 27 2018, 09:23
- - En_Serg   А в известном месте можно взять Hotfix 42. Такая ж...   Jul 18 2018, 07:54
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Jul 18 2018, 21:40
|- - rloc   Sigrity 2018 Whats New https://www.cadence.com/co...   Jul 26 2018, 09:01
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Aug 3 2018, 16:27
- - kudor   ВРоде много пишут о фиксах Symbol Editor, а как на...   Aug 6 2018, 22:22
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Aug 11 2018, 22:51
- - Flood   Пекут как горячие пирожки Спасибо!   Aug 13 2018, 16:09
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Aug 26 2018, 16:24
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Sep 13 2018, 19:54
- - copov   Есть ли смысл выкладывать на FTP? Hotfix_SPB16.60....   Sep 20 2018, 07:25
|- - Aner   QUOTE (copov @ Sep 20 2018, 10:25) Есть л...   Sep 20 2018, 07:33
- - copov   Hotfix_SPB16.60.112_wint upload\PCB\_Cad...   Sep 20 2018, 12:01
RSS Текстовая версия Сейчас: 29th July 2025 - 08:05
Страница сгенерированна за 0.01444 секунд с 7
