> вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 008
rom67
сообщение Nov 2 2016, 21:05
Пользователь №: 88 095
DATE: 10-29-2016   HOTFIX VERSION: 008
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
1644406 ALLEGRO_EDITOR SHAPE            Alternate symbol placement results in illegal parent identifier error
1647098 SIP_LAYOUT     OTHER            SiP crashes on symbol copy and rotate
1647154 APD            OTHER            Disconnected Clines not working
1648817 GRE            IFP_INTERACTIVE  Allegro PCB Editor stops responding on adding netgroups to a nested netgroup
1649829 CONCEPT_HDL    CORE             Project Manager: A delay is observed before the sub menus of the File and Tools menus appear
1652930 ALLEGRO_EDITOR OTHER            Command-line version of switchversion not working
1653109 ASDA           DESIGN_CORRUPTIO SDA not pulling latest library information for part
1655377 FLOWS          PROJMGR          Project Manager crashes on Windows 10
rom67
сообщение May 9 2017, 00:32
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 018
Fixed CCRs: SPB 17.2 HF018
04-23-2017
CCRID   Product            ProductLevel2 Title
1721773 ADW                ADW_UPREV     adw_uprev updates all versions in history log to the new version. Should only insert note about uprev.
1684346 ADW                LIBDISTRIBUTI lib_dist_client fails for new release 17.2-2016 design server
1696632 ADW                LIBDISTRIBUTI lib_dist_client fails on release 17.2 Designer Server having release 16.6 Master Server
1705224 ADW                LIBDISTRIBUTI Cannot migrate Library Footprint Models having subdirectory to release 17.2-2016
1721017 ADW                LIBDISTRIBUTI adwserver -install fails intermittently during Master Library Server or MLR distribution
1711373 ALLEGRO_EDITOR     COLOR         Cannot interact with Allegro PCB Editor when Color dialog is open
1710772 ALLEGRO_EDITOR     DATABASE      Mirror command not working on zones
1725621 ALLEGRO_EDITOR     DATABASE      PCB Editor crashes when moving a group of components or clines
1699796 ALLEGRO_EDITOR     EDIT_ETCH     AiDT fails and reports there are no timing constraints even when propagation delay is set
1726483 ALLEGRO_EDITOR     EDIT_ETCH     PCB Editor crashing when converting corners to arcs
1726678 ALLEGRO_EDITOR     INTERFACES    IDX copper layer export does not export all pin pads
1691036 ALLEGRO_EDITOR     MANUFACT      Fillet not centered on trace
1732304 ALLEGRO_EDITOR     MANUFACT      Countersink does not have drill figure on NCCOUNTERDRILL-1 subclass
1719564 ALLEGRO_EDITOR     OTHER         Cannot open PDF published in release 17.2-2016 in third-party software
1723065 ALLEGRO_EDITOR     OTHER         PDF out does not print the outline correctly
1729247 ALLEGRO_EDITOR     OTHER         Cannot delete shape on Route Keepout layer
1722747 ALLEGRO_EDITOR     PAD_EDITOR    Option to enable 'Connect by Touch' in Pad Editor
1731643 ALLEGRO_EDITOR     PAD_EDITOR    Changes to secondary drill are not saved on padstack update
1727303 ALLEGRO_EDITOR     REPORTS       The 'Shape Dynamic State' report has changed to 'Shape Dynamic Status' in release 17.2-2016
1695879 ALLEGRO_EDITOR     SHAPE         Dynamic shape priority error creates shorts.
1713014 ALLEGRO_EDITOR     SHAPE         Incorrect behavior of donut shaped pads at certain rotations
1588769 ALLEGRO_EDITOR     UI_GENERAL    Alt+key shortcuts are not available in release 17.2
1602563 ALLEGRO_EDITOR     UI_GENERAL    Shortcuts to menu items not working in release 17.2
1603776 ALLEGRO_EDITOR     UI_GENERAL    Alt key not working with menu commands
1611516 ALLEGRO_EDITOR     UI_GENERAL    Keyboard shortcuts have no response
1647271 ALLEGRO_EDITOR     UI_GENERAL    Preselection is not working for docked Find window
1650044 ALLEGRO_EDITOR     UI_GENERAL    Keyboard shortcuts are not working properly in release 17.2
1651912 ALLEGRO_EDITOR     UI_GENERAL    Inconsistent response when using the Alt key
1679964 ALLEGRO_EDITOR     UI_GENERAL    Many dialog boxes are blurred in Allegro PCB Editor
1692416 ALLEGRO_EDITOR     UI_GENERAL    Underscores in menu commands denoting shortcuts are missing in release 17.2
1693055 ALLEGRO_EDITOR     UI_GENERAL    Reports with html links end with an extra > at the end
1693968 ALLEGRO_EDITOR     UI_GENERAL    Batch process that uses SKILL is taking too long to process files and generate reports
1698840 ALLEGRO_EDITOR     UI_GENERAL    In release 17.2-2016 Waive DRC report, selected coordinates of a Waived DRC remain blue
1703065 ALLEGRO_EDITOR     UI_GENERAL    Menu shortcuts do not work as expected
1707547 ALLEGRO_EDITOR     UI_GENERAL    Release 17.2: The Alt key function is not working in PCB Editor
1709280 ALLEGRO_EDITOR     UI_GENERAL    Alt+Function key not working in release 17.2.
1711203 ALLEGRO_EDITOR     UI_GENERAL    Color does not change for selected coordinates in reports and Show Element
1711724 ALLEGRO_EDITOR     UI_GENERAL    In release 17.2-2016, custom interactive menus stop responding when invoking another custom command
1715613 ALLEGRO_EDITOR     UI_GENERAL    With undocked Options window there is a mix up of entered text and funckey
1719301 ALLEGRO_EDITOR     UI_GENERAL    Selected coordinates do not change color in reports and Show Element
1724197 ALLEGRO_EDITOR     UI_GENERAL    Short cuts and hot keys not working in PCB Editor in release 17.2-2016
1728724 ALLEGRO_EDITOR     UI_GENERAL    Funckey is not working in release 17.2-2016
1673703 ALLEGRO_PROD_TOOLB OTHERS        Design compare not reporting the Top and Bottom layer differences
1704474 ALLEGRO_PROD_TOOLB OTHERS        When using Productivity Toolkit - PCB Design Compare, 'Override undefined width' is incorrectly applied
1571035 ALTM_TRANSLATOR    CAPTURE       Circles in third-party schematics not getting translated into Capture
1588911 ALTM_TRANSLATOR    CAPTURE       Capture crashes when translating, project and libraries are empty
1589394 ALTM_TRANSLATOR    CAPTURE       Schematic getting shifted off the page after translation
1631294 ALTM_TRANSLATOR    CAPTURE       Errors while translating third-party design when original design is in metric units
1663176 ALTM_TRANSLATOR    CAPTURE       Only first sheet of design getting translated from third-party schematic into Capture
1694363 ALTM_TRANSLATOR    CAPTURE       Capture is unable to translate third-party designs
1539739 ALTM_TRANSLATOR    CORE          Capture crashes on importing a third-party project
1542860 ALTM_TRANSLATOR    CORE          Capture crashes on clicking Translate after selecting a third-party design
1551642 ALTM_TRANSLATOR    CORE          Unable to import third-party schematics into Capture
1572929 ALTM_TRANSLATOR    CORE          Footprint names getting altered during translation
1568436 ALTM_TRANSLATOR    PCB_EDITOR    Unable to translate third-party layout data into PCB Editor
1629256 ALTM_TRANSLATOR    PCB_EDITOR    Getting empty symbol and devices folders when importing into PCB Editor
1664120 ALTM_TRANSLATOR    PCB_EDITOR    Import from third-party to PCB Editor is not translating data correctly
1701537 ALTM_TRANSLATOR    PCB_EDITOR    Import does not complete and reports errors
1698706 APD                DIE_GENERATOR When using Compose Symbol from Geometry, circle from DXF cannot generate to pin
1714528 APD                DIE_GENERATOR Getting 'illegal pad pointer' warning when creating die from geometry
1714532 APD                DIE_GENERATOR Compose Die from Geometry creates incorrect pad shapes
1734310 APD                MULTI_USER    Symphony server mode malfunctions when die layer present.
1725506 APD                SHAPE         In release 17.2-2016 Hotfix 015, void is not generated in Artwork for BC7 layer causing short
1724395 APD                WIREBOND      Running axlBondWireDelete returns error message
1726609 ASDA               CANVAS_EDIT   Paste should not be allowed in the Current Refdes column of the Change Refdes form
1719754 CONCEPT_HDL        ARCHIVER      Path stored in the compressed file starts from /home instead of the current working directory
1726570 CONCEPT_HDL        CHECKPLUS     Checkplus crashes on Windows 10
1697977 CONCEPT_HDL        CONSTRAINT_MG Differential pair disappears when it is packaged
1679575 CONCEPT_HDL        CORE          Page numbers are duplicated in Hierarchy Viewer when editing page names
1697732 CONCEPT_HDL        CORE          Pasting a signal name results in warning (SPCOCN-922) if the wire is too close to the edge of the page border
1711564 CONCEPT_HDL        CREFER        CRefer crashes while processing a hierarchical design containing subdesigns
1730736 CONCEPT_HDL        OTHER         Crash on generating BOM from design
1608350 CONSTRAINT_MGR     CONCEPT_HDL   Name of buffer model is not passed from Constraint Manager of DE-HDL to SigXplorer
1715803 CONSTRAINT_MGR     CONCEPT_HDL   Extract a net from constraint manager to SigXplorer, the models assigned are not displayed in SigXplorer
1718073 CONSTRAINT_MGR     CONCEPT_HDL   ECSet mapping errors on an upreved design in release 17.2: Pins in XNet and CSet do not match
1720886 CONSTRAINT_MGR     CONCEPT_HDL   SigXplorer does not extract assigned model from the schematic
1718514 CONSTRAINT_MGR     ECS_APPLY     Extracted topology does not use the PINUSE overrides specified on the canvas
1722306 GRE                CORE          Boards with Total Etch Length constraint only should not include z-axis when budgeting pin pairs
1710049 PSPICE             SIMULATOR     Functions are not taking parameters in correct order
1693021 SIG_INTEGRITY      OTHER         PINUSE is not updated correctly at model assignment with specific steps
1730854 SIP_LAYOUT         SYMB_EDIT_APP Cannot delete all the die pin from a symbol using the Symbol Edit application mode
- rom67   вышел хотфикс OrCAD/Allegro 17.2   Nov 2 2016, 21:05
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Dec 13 2016, 20:18
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Jan 9 2017, 13:17
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Jan 23 2017, 17:27
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Feb 13 2017, 18:33
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Feb 19 2017, 18:31
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Mar 5 2017, 19:29
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Mar 27 2017, 18:54
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Apr 10 2017, 19:03
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Apr 12 2017, 21:29
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   May 14 2017, 15:16
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   May 22 2017, 21:40
- - rom67   .   May 22 2017, 21:40
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Jun 6 2017, 17:04
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Jun 19 2017, 15:37
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Aug 11 2017, 22:41
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Aug 28 2017, 17:39
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Sep 20 2017, 18:53
|- - alver   Кто-нибудь знает, что за новая опция появилась в A...   Sep 26 2017, 12:41
- - Карлсон   Может что-то тут есть?   Sep 26 2017, 17:09
|- - alver   нет, и официальные партнеры затрудняются сказать.   Sep 26 2017, 17:26
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Oct 9 2017, 17:30
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Oct 16 2017, 20:36
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Nov 8 2017, 17:41
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Nov 20 2017, 18:30
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Dec 11 2017, 15:35
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Jan 15 2018, 20:45
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Jan 30 2018, 17:53
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Feb 14 2018, 19:02
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Mar 5 2018, 19:55
- - rom67   КодFixed CCRs: SPB 17.2 HF035 02-30-2018 =====...   Mar 7 2018, 17:11
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Mar 19 2018, 17:17
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Apr 3 2018, 14:46
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   May 3 2018, 12:23
- - copov   Очень мощное обновление Cadence Allegro Editor и ...   May 7 2018, 10:51
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   May 15 2018, 15:36
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   May 29 2018, 21:01
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Jun 19 2018, 07:33
- - copov   Подскажите пожалуйста. После установки OrCAD/Alleg...   Jun 22 2018, 08:08
- - copov   Спасибо, сам отвечу. Косяки в символьном редактор...   Jun 26 2018, 06:03
|- - PCBtech   Цитата(copov @ Jun 26 2018, 09:03) Спасиб...   Jul 18 2018, 19:59
- - copov   del   Jun 27 2018, 09:23
- - En_Serg   А в известном месте можно взять Hotfix 42. Такая ж...   Jul 18 2018, 07:54
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Jul 18 2018, 21:40
|- - rloc   Sigrity 2018 Whats New https://www.cadence.com/co...   Jul 26 2018, 09:01
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Aug 3 2018, 16:27
- - kudor   ВРоде много пишут о фиксах Symbol Editor, а как на...   Aug 6 2018, 22:22
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Aug 11 2018, 22:51
- - Flood   Пекут как горячие пирожки Спасибо!   Aug 13 2018, 16:09
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Aug 26 2018, 16:24
- - rom67   вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ...   Sep 13 2018, 19:54
- - copov   Есть ли смысл выкладывать на FTP? Hotfix_SPB16.60....   Sep 20 2018, 07:25
|- - Aner   QUOTE (copov @ Sep 20 2018, 10:25) Есть л...   Sep 20 2018, 07:33
- - copov   Hotfix_SPB16.60.112_wint upload\PCB\_Cad...   Sep 20 2018, 12:01
RSS Текстовая версия Сейчас: 20th July 2025 - 20:16
Страница сгенерированна за 0.01434 секунд с 7
