У перспективных STM32H7 в корпусах TQFP100 и TQFP144 нету USB2.0 HS !, Вот это залет!! |
Jun 17 2017, 20:15
Пользователь №: 284
нашел вот такой текст в UM2217 User Manual Description of STM32H7 HAL driversQUOTE HAL_SYSCFG_AnalogSwitchConfig Function name void HAL_SYSCFG_AnalogSwitchConfig (uint32_t SYSCFG_AnalogSwitch, uint32_t SYSCFG_SwitchState) Function description Analog Switch control for dual analog pads. Parameters SYSCFG_AnalogSwitch: Selects the analog pad This parameter can be one or a combination of the following values: SYSCFG_SWITCH_PA0 : Select PA0 analog switch SYSCFG_SWITCH_PA1: Select PA1 analog switch SYSCFG_SWITCH_PC2 : Select PC2 analog switch SYSCFG_SWITCH_PC3: Select PC3 analog switch SYSCFG_SwitchState: Open or Close the analog switch between dual pads (PXn and PXn_C) This parameter can be one or a combination of the following values: SYSCFG_SWITCH_PA0_OPEN SYSCFG_SWITCH_PA0_CLOSE SYSCFG_SWITCH_PA1_OPEN SYSCFG_SWITCH_PA1_CLOSE SYSCFG_SWITCH_PC2_OPEN SYSCFG_SWITCH_PC2_CLOSE SYSCFG_SWITCH_PC3_OPEN SYSCFG_SWITCH_PC3_CLOSE Return values None то есть ноги можно переключать типа аналоговая pc2_c и нормальная pc2 в stm32h7xx_hal.c нашел QUOTE /** * @brief Analog Switch control for dual analog pads. * @param SYSCFG_AnalogSwitch: Selects the analog pad * This parameter can be one or a combination of the following values: * @arg SYSCFG_SWITCH_PA0 : Select PA0 analog switch * @arg SYSCFG_SWITCH_PA1: Select PA1 analog switch * @arg SYSCFG_SWITCH_PC2 : Select PC2 analog switch * @arg SYSCFG_SWITCH_PC3: Select PC3 analog switch * @param SYSCFG_SwitchState: Open or Close the analog switch between dual pads (PXn and PXn_C) * This parameter can be one or a combination of the following values: * @arg SYSCFG_SWITCH_PA0_OPEN * @arg SYSCFG_SWITCH_PA0_CLOSE * @arg SYSCFG_SWITCH_PA1_OPEN * @arg SYSCFG_SWITCH_PA1_CLOSE * @arg SYSCFG_SWITCH_PC2_OPEN * @arg SYSCFG_SWITCH_PC2_CLOSE * @arg SYSCFG_SWITCH_PC3_OPEN * @arg SYSCFG_SWITCH_PC3_CLOSE * @retval None */
void HAL_SYSCFG_AnalogSwitchConfig(uint32_t SYSCFG_AnalogSwitch , uint32_t SYSCFG_SwitchState ) { /* Check the parameter */ assert_param(IS_SYSCFG_ANALOG_SWITCH(SYSCFG_AnalogSwitch)); assert_param(IS_SYSCFG_SWITCH_STATE(SYSCFG_SwitchState)); MODIFY_REG(SYSCFG->PMCR, (uint32_t) SYSCFG_AnalogSwitch, (uint32_t)(SYSCFG_SwitchState)); } мануала нормального по stm32h7 нету пока... может заработает usb 2.0 все таки...
Jun 18 2017, 12:08
Пользователь №: 284
QUOTE (AlexandrY @ Jun 18 2017, 00:51)  Если бы они рассчитывали сделать встроенный физический драйвер для скорости 480 Mbit они бы не делали интерфейс ULPI, а оформили бы еррату по поводу что дескать физика HS будет исправлена в будущем. Кстати и ULPI у них как-то криво раскидан по периметру всего корпуса. Страссировать его грамотно будет тяжковато в бюджетных вариантах. в том то и дело что в корпусах tqfp100 и tqfp144 ulpi тоже раскидан... только двух ног не хватает... какой смысл было его раскидывать если им пользоваться невозможно... надеюсь что это особенность предварительных образцов.. и серии будет исправлено...
Jun 19 2017, 03:08
Пользователь №: 284
QUOTE (rloc @ Jun 19 2017, 00:13)  Что за сигналы OTG_HS_DM и OTG_HS_DP на ногах 53,54 STM32H7 LQFP100? это внутренний phy... он на HS не работает...
dachny У перспективных STM32H7 в корпусах TQFP100 и TQFP144 нету USB2.0 HS ! Jun 16 2017, 12:18 mantech Цитата(dachny @ Jun 16 2017, 15:18) То ес... Jun 16 2017, 19:34 AlexandrY Цитата(dachny @ Jun 16 2017, 15:18) может... Jun 16 2017, 21:02 skripach LPC, Kinetis, Atmel'ы имеют HS встроенный. Бер... Jun 16 2017, 21:28 a123-flex Цитата(AlexandrY @ Jun 17 2017, 01:02) От... Jun 17 2017, 19:33 rloc Цитата(AlexandrY @ Jun 17 2017, 00:02) Ст... Jul 6 2017, 05:38  Allregia Цитата(rloc @ Jul 6 2017, 06:38) Какую св... Jul 8 2017, 11:09   rloc Цитата(Allregia @ Jul 8 2017, 14:09) 27мб... Jul 8 2017, 14:26 AVI-crak Цитата(dachny @ Jun 16 2017, 18:18) То ес... Jun 17 2017, 02:48 Шаманъ Цитата(AVI-crak @ Jun 17 2017, 05:48... Jun 17 2017, 06:17   Forger Цитата(dachny @ Jun 18 2017, 15:08) надею... Jun 18 2017, 12:53 dachny в новом даташите en.DM00387108.pdf от 22-Jun-2017 ... Jun 27 2017, 16:39 dachny QUOTE (dachny @ Jun 27 2017, 20:39) то ес... Jul 16 2017, 19:22  AlexandrY Цитата(dachny @ Jul 16 2017, 22:22) новый... Jul 16 2017, 20:32  Vakhtang Цитата(dachny @ Jul 16 2017, 22:22) новый... Jan 6 2018, 12:19
