Для чего стоит использовать функцию __low_level_init? В EW430_CompilerReference.pdf я нашел такое: Customizing system initialization It is likely that you need to customize the code for system initialization. For example, your application might need to initialize memory-mapped peripheral units, or omit the default initialization of data segments performed by cstartup. You can do this by providing a customized version of the routine __low_level_init, which is called from cmain before the data segments are initialized. Avoid modifying the cstartup file directly.
Судя из этого, всю периферию надо инициализировать в __low_level_init. Объясните, плз, правильно ли я понял?
