вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 008 |
Aug 11 2017, 22:41
Пользователь №: 88 095
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 024 Код Fixed CCRs: SPB 17.2 HF024 07-28-2017 ================================================================================ ======================================================================== CCRID Product ProductLevel2 Title ================================================================================ ======================================================================== 1762143 ADW COMPONENT_BRO Part placed using the 'Add' button does not populate 'PART_NAME' property 1765790 ADW PART_BROWSER Fail to extract component part number and footprint information 1757719 ADW TDA TDO and Windchilll Work Group Manager out of sync at times 1760607 ALLEGRO_EDITOR DATABASE Value for number of decimal places changes in Pad Designer in release 17.2-2016 1775160 ALLEGRO_EDITOR DFA Loading DFA spreadsheet crashes PCB Editor in release 17.2-2016 1765984 ALLEGRO_EDITOR OTHER Cannot view System Info 1729350 ALLEGRO_EDITOR REPORTS Net loop is not listed in report 1725242 ALLEGRO_EDITOR SHAPE 'Same net shape to hole spacing' is only detecting the DRC and not voiding the shape 1754402 ALLEGRO_EDITOR SHAPE Illegal arc radius error (SPMHA1-85) 1762888 ALLEGRO_EDITOR SHAPE Border line missing for some crosshatch (xhatch) shape voids 1769188 ALLEGRO_EDITOR SHOW_ELEM 'Show Element' with the 'Groups' option used on certain modules crashes PCB Editor 1767690 ALLEGRO_EDITOR TESTPREP PCB Editor crashes when running automatic Testprep 1737337 ALLEGRO_EDITOR UI_FORMS Pinned Show Element window closes when opening new design in release 17.2-2016 1736642 ALLEGRO_PROD_TOOLB INTEGRATION Cannot change accuracy to 4 for 'Change Width' in Productivity Toolbox 1685216 ALTM_TRANSLATOR CAPTURE Third-party translator placing symbols off grid 1738679 ALTM_TRANSLATOR CAPTURE Connectivity loss in imported schematic 1738705 ALTM_TRANSLATOR CAPTURE Connectivity loss in imported schematic 1748583 ALTM_TRANSLATOR CAPTURE Crash on importing design using third-party translator 1679310 ALTM_TRANSLATOR PCB_EDITOR Third-party translator should fix off-centered connections 1686845 ALTM_TRANSLATOR PCB_EDITOR Third-party translator does not place parts after successful translation 1723141 ALTM_TRANSLATOR PCB_EDITOR Placement outlines are rotated in third-party translator 1723164 ALTM_TRANSLATOR PCB_EDITOR Third-party translator creates board with missing data: vias, traces, and so on 1723190 ALTM_TRANSLATOR PCB_EDITOR Third-party translator changes design origin 1750496 ALTM_TRANSLATOR PCB_EDITOR Third-party board with arc tracks not correctly converted to arc clines 1769624 APD DATABASE Attempted symbol delete crashes APD 1727206 APD SHAPE Merging two shapes results in an incorrect shape 1707756 ASDA VARIANT_MANAG Scrolling in Create Variant closes tool 1753699 CM RELEASE installDebugger() does not work in release 17.2-2016 as SKILL kit is not installed 1741534 CONCEPT_HDL CORE DE-HDL freezes when selecting a net that contains many connections 1752687 CONCEPT_HDL CORE The move command changes the connectivity of the schematic 1763525 CONCEPT_HDL CORE Genview crashes when generating split symbols 1766797 CONCEPT_HDL CORE Schematic not refreshed after using the clear xnet overrides feature 1770852 F2B PACKAGERXL ERROR(SPCOPK-1138): A hard location was found on instances of different physical part types 1754473 FSP DE-HDL_SCHEMA Provide an option to generate symbols with custom attributes 1748106 FSP OTHER Create protocol from existing protocol error message needs clarity 1724201 FSP SYMBOL_EDITOR Unable to change 'Pin Direction' in symbol editor 1772429 ORBITIO ALLEGRO_SIP_I Import - OrbitIO: Translator cannot create bundle in PCB Editor 1725759 SIG_INTEGRITY OTHER PCB shape/plane capacitance 1760924 SIP_LAYOUT DIE_STACK_EDI Package height of die .dra file reset to 110um when placed 1764385 SIP_LAYOUT MODULES Embedded components are unplaced in created modules (.mdd) 1733679 SIP_LAYOUT OTHER 'metal density scan' does not use select window 1763707 SIP_LAYOUT OTHER SiP Layout exits with error message in release 17.2-2016 1763515 SIP_RF DIEEXPORT Virtuoso writes incorrect width for 45 degree path segments in XDA file 1772397 TDA DEHDL DE-HDL crashes if license is not available for team design
rom67 вышел хотфикс OrCAD/Allegro 17.2 Nov 2 2016, 21:05 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Dec 13 2016, 20:18 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Jan 9 2017, 13:17 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Jan 23 2017, 17:27 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Feb 13 2017, 18:33 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Feb 19 2017, 18:31 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Mar 5 2017, 19:29 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Mar 27 2017, 18:54 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Apr 10 2017, 19:03 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Apr 12 2017, 21:29 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... May 9 2017, 00:32 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... May 14 2017, 15:16 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... May 22 2017, 21:40 rom67 . May 22 2017, 21:40 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Jun 6 2017, 17:04 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Jun 19 2017, 15:37 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Aug 28 2017, 17:39 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Sep 20 2017, 18:53 alver Кто-нибудь знает, что за новая опция появилась в A... Sep 26 2017, 12:41 Карлсон Может что-то тут есть?
Sep 26 2017, 17:09 alver нет, и официальные партнеры затрудняются сказать. Sep 26 2017, 17:26 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Oct 9 2017, 17:30 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Oct 16 2017, 20:36 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Nov 8 2017, 17:41 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Nov 20 2017, 18:30 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Dec 11 2017, 15:35 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Jan 15 2018, 20:45 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Jan 30 2018, 17:53 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Feb 14 2018, 19:02 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Mar 5 2018, 19:55 rom67 КодFixed CCRs: SPB 17.2 HF035
02-30-2018
=====... Mar 7 2018, 17:11 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Mar 19 2018, 17:17 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Apr 3 2018, 14:46 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... May 3 2018, 12:23 copov Очень мощное обновление Cadence Allegro Editor и ... May 7 2018, 10:51 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... May 15 2018, 15:36 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... May 29 2018, 21:01 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Jun 19 2018, 07:33 copov Подскажите пожалуйста. После установки OrCAD/Alleg... Jun 22 2018, 08:08 copov Спасибо, сам отвечу. Косяки в символьном редактор... Jun 26 2018, 06:03 PCBtech Цитата(copov @ Jun 26 2018, 09:03) Спасиб... Jul 18 2018, 19:59 copov del Jun 27 2018, 09:23 En_Serg А в известном месте можно взять Hotfix 42.
Такая ж... Jul 18 2018, 07:54 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Jul 18 2018, 21:40 rloc Sigrity 2018 Whats New
https://www.cadence.com/co... Jul 26 2018, 09:01 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Aug 3 2018, 16:27 kudor ВРоде много пишут о фиксах Symbol Editor, а как на... Aug 6 2018, 22:22 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Aug 11 2018, 22:51 Flood Пекут как горячие пирожки
Спасибо! Aug 13 2018, 16:09 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Aug 26 2018, 16:24 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Sep 13 2018, 19:54 copov Есть ли смысл выкладывать на FTP?
Hotfix_SPB16.60.... Sep 20 2018, 07:25 Aner QUOTE (copov @ Sep 20 2018, 10:25) Есть л... Sep 20 2018, 07:33 copov Hotfix_SPB16.60.112_wint
upload\PCB\_Cad... Sep 20 2018, 12:01
