> Вентильное моделирование в Modelsim 10., Не находится SDF-файл
b-volkov
сообщение Nov 23 2017, 11:13
Из: г. Троицк
Пользователь №: 26 907
Почему-то Modelsim не хочет находить сгенерированный квартусом SDF-файл.
В закладке "SDF" окна "Start Simulation" выбираю файл (от реально там есть)
При старте симуляции получаю следующее:
vsim -L {D:/WORK/Altera/ModelSim Lib/verilog_libs/maxii_ver} -sdftyp tb/s1=D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3_v.sdo -novopt tb
# vsim -L {D:/WORK/Altera/ModelSim Lib/verilog_libs/maxii_ver} -sdftyp tb/s1=D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3_v.sdo -novopt tb
# Loading work.tb
# Loading work.Main
# Loading D:/WORK/Altera/ModelSim Lib/verilog_libs/maxii_ver.maxii_lcell
# Loading D:/WORK/Altera/ModelSim Lib/verilog_libs/maxii_ver.maxii_asynch_lcell
# Loading D:/WORK/Altera/ModelSim Lib/verilog_libs/maxii_ver.maxii_lcell_register
# Loading D:/WORK/Altera/ModelSim Lib/verilog_libs/maxii_ver.maxii_io
# Loading work.FTDIAsincModel
# ** INTERNAL ERROR: mtiarOpen(): Unrecognized file path (Keratom3_v.sdo)
[b]# ** Error: (vsim-SDF-3894) Keratom3_v.sdo: Compiled SDF file was not found.[/b]
# Loading instances from D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3_v.sdo
# ** Warning: (vsim-3017) D:/WORK/Altera/Keratom3_main/testbench_FIFO.v(93): [TFMPC] - Too few port connections. Expected 26, found 22.
#         Region: /tb/s1
# ** Warning: (vsim-3722) D:/WORK/Altera/Keratom3_main/testbench_FIFO.v(93): [TFMPC] - Missing connection for port 'SPICS'.
# ** Warning: (vsim-3722) D:/WORK/Altera/Keratom3_main/testbench_FIFO.v(93): [TFMPC] - Missing connection for port 'SPIClk'.
# ** Warning: (vsim-3722) D:/WORK/Altera/Keratom3_main/testbench_FIFO.v(93): [TFMPC] - Missing connection for port 'SPIIn'.
# ** Warning: (vsim-3722) D:/WORK/Altera/Keratom3_main/testbench_FIFO.v(93): [TFMPC] - Missing connection for port 'SPIOut'.
# Loading timing data from D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3_v.sdo
[b]# ** Error: (vsim-7) Failed to open SDF file "Keratom3_v.sdo" in read mode.
# No such file or directory. (errno = ENOENT)[/b]
# ** Error: (vsim-SDF-3445) Failed to parse SDF file "Keratom3_v.sdo".
#    Time: 0 ps  Iteration: 0  Instance: /tb File: D:/WORK/Altera/Keratom3_main/testbench_FIFO.v
# Error loading design
# Load canceled
Кстати, есть еще одна непонятка: Modelsim не видит альтеровские библиотеки, которые прописаны в окне Library.
vsim -sdftyp tb/s1=D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3_v.sdo -novopt tb
# vsim -sdftyp tb/s1=D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3_v.sdo -novopt tb
# Loading work.tb
# Loading work.Main
# ** Error: (vsim-3033) D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3.vo(1015): Instantiation of 'maxii_lcell' failed. The design unit was not found.
#         Region: /tb/s1
#         Searched libraries:
#             D:\WORK\Altera\Keratom3_main\work
# ** Error: (vsim-3033) D:/WORK/Altera/Keratom3_main/simulation/modelsim/Keratom3.vo(1055): Instantiation of 'maxii_lcell' failed. The design unit was not found.
#         Region: /tb/s1
... и так таких сообщений несколько десятков
Но если прописать тот же самый путь в закладке Libraries окна "Start Simulation", то эти сообщения исчезают.
RSS Текстовая версия Сейчас: 29th July 2025 - 15:11
Страница сгенерированна за 0.01356 секунд с 7
