> Li-ion на морозе, Что делать когда нельзя, но надо.
ArtemKAD
сообщение Nov 26 2017, 14:51
Пользователь №: 18 364
Ни кто не подскажет причину запрета заряда литиевых АКБ при отрицательных температурах? Интересует физика(химия) этих ограничений.
Itch
сообщение Nov 29 2017, 05:32
Из: Новосибирск
Пользователь №: 18 410
Li ion can be fast charged from 5°C to 45°C (41 to 113°F). Below 5°C, the charge current should be reduced, and no charging is permitted at freezing temperatures because of the reduced diffusion rates on the anode. During charge, the internal cell resistance causes a slight temperature rise that compensates for some of the cold. The internal resistance of all batteries rises when cold, prolonging charge times noticeably.
Many battery users are unaware that consumer-grade lithium-ion batteries cannot be charged below 0°C (32°F). Although the pack appears to be charging normally, plating of metallic lithium can occur on the anode during a sub-freezing charge. This is permanent and cannot be removed with cycling. Batteries with lithium plating are more vulnerable to failure if exposed to vibration or other stressful conditions. Advanced chargers (Cadex) prevent charging Li-ion below freezing.
Advancements are being made to charge Li-ion below freezing temperatures. Charging is indeed possible with most lithium-ion cells but only at very low currents. According to research papers, the allowable charge rate at –30°C (–22°F) is 0.02C. At this low current, the charge time would stretch to over 50 hours, a time that is deemed impractical. There are, however, specialty Li-ions that can charge down to –10°C (14°F) at a reduced rate.
http://batteryuniversity.com/learn/article...ow_temperatures
https://batteryworkshop.msfc.nasa.gov/prese..._AZimmerman.pdf
Т.е. заряжать лучше малым током, чтобы скорость образования лития была меньше скорости его растворения в электролите.
Со временем он может уйти, или остаться на сепараторе. Тогда вероятно КЗ элемента и общая деградация.
- ArtemKAD   Li-ion на морозе   Nov 26 2017, 14:51
- - GefarD   А видеорегистраторы с акб зачем тогда разрабатыва...   Nov 26 2017, 19:04
- - Огурцов   Цитата(ArtemKAD @ Nov 26 2017, 14:51) Инт...   Nov 26 2017, 22:10
|- - ArtemKAD   Цитата(Огурцов @ Nov 27 2017, 00:10) вся ...   Nov 26 2017, 22:54
|- - Myron   Цитата(ArtemKAD @ Nov 26 2017, 16:54) Сни...   Nov 27 2017, 00:29
- - Ydaloj   ЦитатаЧто делать когда нельзя, но надо.Заменить АК...   Nov 27 2017, 10:46
- - ArtemKAD   Литий-титанатные не подходят по критериям габарито...   Nov 27 2017, 21:25
|- - Myron   Цитата(ArtemKAD @ Nov 27 2017, 15:25) Ну,...   Nov 27 2017, 21:33
|- - Огурцов   Цитата(ArtemKAD @ Nov 27 2017, 21:25) Лит...   Nov 28 2017, 00:12
- - yuri.job   Стандартная li-ion батарея(аккум) включает в сбя т...   Nov 28 2017, 09:41
|- - ArtemKAD   Цитата(yuri.job @ Nov 28 2017, 11:41) Ста...   Nov 28 2017, 20:22
- - GefarD   А обычный свинцовый( например стартерный) акк можн...   Nov 28 2017, 16:24
|- - Herz   Цитата(GefarD @ Nov 28 2017, 18:24) А обы...   Nov 28 2017, 19:30
|- - MikeSchir   Цитата(Herz @ Nov 28 2017, 23:30) А когда...   Apr 19 2018, 10:32
- - GefarD   Как то не особо. Подкапотное пространство в принци...   Nov 28 2017, 20:22
- - V_G   Не знаю, кто такой ДЭС, но литиевый акк Ниссана Ли...   Nov 28 2017, 23:59
|- - ArtemKAD   Цитата(Itch @ Nov 29 2017, 07:32) http://...   Nov 29 2017, 08:03
- - VCO   А может проще подогревать аккумулятор на минусах, ...   Dec 17 2017, 14:35
- - vladec   ЦитатаА может проще подогревать аккумулятор на мин...   Dec 18 2017, 09:14
- - kolhoz   Посмотрите это: http://www.eemb.com/battery/rechar...   Apr 19 2018, 08:01
- - one_eight_seven   ЦитатаМожно заряжать и при -20 Чукча - не читатель...   Apr 19 2018, 08:11
- - kolhoz   ЦитатаЧукча - не читатель, чукча - писатель? Пардо...   Apr 19 2018, 21:15
RSS Текстовая версия Сейчас: 30th July 2025 - 17:04
