BPSK матлаб модулятор демодулятор |
Mar 19 2018, 12:14
Пользователь №: 39 850
Имеется код BPSK модема, передатчик и приемник. CODE clear all; Br = 117.1875*10^3; Fd = Br*8;
Fif = 20*10^6; Fdif = 60*10^6; Fdopl = 100;
%% === TRANSMITTER === M = pngen(5); D = rand(1, 200*8) > 0.5; CRC = zeros(1, 16); for i=1:length(D), CRC(16) = xor(CRC(16), D(i)); CRC = [CRC(2:16) CRC(1)]; end; FILL = ones(1, 200)*0.5; DATA = [dec2bin(length(D)/8, 11)=='1' D CRC]; packet = [FILL M M diff_enc([0 DATA]) FILL]*2-1;
% redescr Ndkr = Fd/Br; pkt = packet(ceil(0.01:1/Ndkr:length(packet)));
hch = firls(31, [0 .24 .3 .5]*2, [1 1 0 0]); pktf = filter(hch, [1], pkt);
% upsample t1 = upsample4(pktf, 31); t2 = upsample4(t1, 31); pktfu = upsample4(t2, 31)';
% -> IF l = length(pktfu); s = sin(2*pi*(Fif+Fdopl)*(0:1/Fdif:l/Fdif)); c = cos(2*pi*(Fif+Fdopl)*(0:1/Fdif:l/Fdif)); pkts = pktfu.*s(1:l); pktc = pktfu.*c(1:l);
%% === TRANSMIT LINE === Ir = awgn(awgn(pkts, 0.05), 0.01); Qr = awgn(awgn(pktc, 0.05), 0.01);
%% === RECEIVER === % -> 0 l = length(Ir); s = sin(2*pi*Fif*(0:1/Fdif:l/Fdif)); c = cos(2*pi*Fif*(0:1/Fdif:l/Fdif));
Rreu = Ir.*s(1:l) + Qr.*c(1:l); Rimu = Qr.*s(1:l) - Ir.*c(1:l);
tr00 = downsample4(Rreu); tr01 = downsample4(tr00); Rre_ = downsample4(tr01); Rre = filter(hch, [1], Rre_);
tr10 = downsample4(Rimu); tr11 = downsample4(tr10); Rim_ = downsample4(tr11); Rim = filter(hch, [1], Rim_);
%figure; hold on; plot(Rre); plot(Rim, 'r');
% detection Ms = M(ceil(0.01:1/Ndkr:length(M))); cfh = Ms(length(Ms):-1:1); cre = filter(cfh, [1], Rre)/length(cfh); cim = filter(cfh, [1], Rim)/length(cfh); %cr = sqrt(cre.^2 + cim.^2); cr = (7/8)*max(abs(cre), abs(cim)) + (1/8)*min(abs(cre), abs(cim));
%figure; hold on; plot(cre); plot(cim); plot(cr, 'r');
env(length(cr)) = 0; for j=1:length(cr), f = max(1, j-Ndkr*length(M)+2*Ndkr); t = min(length(cr), max(2, j-Ndkr)); env(j) = sum(cr(f:t))/(t-f); end;
%figure; hold on; plot(cr, 'r'); plot(env, 'g'); plot(env*5);
% for i=length(M)*Ndkr+1:length(cr)-1, c1 = cr(i) > env(i)*5; % c2 = (cr(i) > cr(i-1)) && (cr(i) > cr(i+1)); c2 = (cr(i-1) > cr(i-2)) && (cr(i-1) > cr(i)); c3 = abs(cr(i)-cr(i-length(M)*Ndkr)) < 4*env(i); c4 = cr(i-length(M)*Ndkr) > env(i-length(M)*Ndkr)*5;
if c1 && c2 && c3 && c4, break; end; end; i re = Rre(i:length(Rre)); im = Rim(i:length(Rim));
%figure; hold on; plot(re); plot(im, 'r'); figure; hold on; plot(cr, 'r'); plot(env, 'g'); plot(env*5); plot((c1&c2&c3&c4)*1.3, 'k');
% l = length(re); lb = length(packet); Yre(lb) = 0; Yim(lb) = 0; fre(lb) = 0; fim(lb) = 0; are(lb) = 0; aim(lb) = 0; mark(l) = 0; bit(lb) = 0;
k = 1; gamma = 0.1; Yre(1) = re(1); Yim(1) = im(1);
for i = 8:8:length(re)-10, mark(i) = 1; are(k) = sum(re(i-6:i-1)); aim(k) = sum(im(i-6:i-1));
% okre(k) = are(k)*Yim(k) - aim(k)*Yre(k); okim(k) = aim(k)*Yim(k) + are(k)*Yre(k);
bit(k) = sign(okim(k));
fre(k) = are(k)*bit(k); fim(k) = aim(k)*bit(k);
Yre(k+1) = (1-gamma)*Yre(k) + gamma*fre(k); Yim(k+1) = (1-gamma)*Yim(k) + gamma*fim(k);
k = k + 1; end;
bit_dec = diff_dec(sign(bit+1)); bits = bit_dec(2:length(bit_dec));
%figure; hold on; plot(okim); plot(okre, 'r'); %figure; hold on; plot(re); plot(Yre(ceil(0.01:1/Ndkr:length(bit))), 'r'); %figure; hold on; plot(im); plot(Yim(ceil(0.01:1/Ndkr:length(bit))), 'r');
figure; hold on; plot(im); plot(mark, 'k');
% len = bin2dec(int2str(bits(1:11))); data = bits(12:12+len*8-1); rcrc = bits(12+len*8:12+len*8+15); crc = zeros(1, 16); for i=1:length(D), crc(16) = xor(crc(16), data(i)); crc = [crc(2:16) crc(1)]; end;
disp('---'); disp(sprintf('Received packet length: %d bytes', len)); disp(sprintf('Data ok: %d', sum(abs(data-D))==0)); disp(sprintf('CRC ok: %d', sum(abs(crc-rcrc))==0)); При компиляции возникает ошибка: Undefined function 'pngen' for input arguments of type 'double'. Error in Modem (line 10) M = pngen(5); Я так понимаю, что функция pngen должна быть где-то описана. Или такая функция уже встроена в Матлаб последних версий. Использую R2014a. Подскажите пожалуйста в чем проблема. Если кто сталкивался, подсобите пожалуйста простейшим рабочим кодом BPSK модема (передатчик + приемник).
Mar 26 2018, 08:08
Цитата(ataradov @ Mar 26 2018, 08:09)  Костас только убирает несовпадение частот и допплер (они не различимы на приемнике). Костас ничего не делает для символьной синхронизации. Для этого в данные вставляют синхропоследовательности для начальной синхронизации и дальнейшая синхронизация осуществляется по смене фаз дынных. И чтобы этих смен было достаточно используют скремблеры. Спасибо. Понятно. Стало более понятно значение нескольких байт преамбулы обычно используемой в пакете данных. Попытаюсь встроить петлю Костаса в код
На демодулятор поступает rx (смесь модулированного сигнала с аддит. гаусовым шумом) которую далее необходимо умножать на sin и cos поступающие с выхода VCO Очевидно что в демодуляторе необходимо будет организовать 1. Управляемый генератор sin cos (VCO). 2. Два одинаковых ФНЧ 3. Фазовый дискриминатор 4. Еще фильтр перед управляемым генератором Какова роль фильтра (loopfilter) после фазового дискриминатора?
Mar 26 2018, 08:32
Из: Balakhna
Пользователь №: 937
Цитата(Acvarif @ Mar 26 2018, 11:08)  Попытаюсь встроить петлю Костаса в код В коде сложнее что-либо разглядеть, чем в симулинк модели. Цитата(Acvarif @ Mar 26 2018, 11:08)  2. Два одинаковых ФНЧ Согласованный фильтр лучше поставить до петли, иначе задержка фильтра будет входить в петлю ФАПЧ, с соответствующим увеличением времени настройки, для обеспечения устойчивасти. Цитата(Acvarif @ Mar 26 2018, 11:08)  4. Еще фильтр перед управляемым генератором Какова роль фильтра (loopfilter) после фазового дискриминатора? Пропорционально интегрирующее звено ФАПЧ. Ещё что-то надо делать с амплитудой сигнала, которую надо учитывать при рассчёте коэффициентов передачи ФАПЧ.
Mar 26 2018, 10:45
Цитата(petrov @ Mar 26 2018, 11:32)  Согласованный фильтр лучше поставить до петли, иначе задержка фильтра будет входить в петлю ФАПЧ, с соответствующим увеличением времени настройки, для обеспечения устойчивасти. До петли это как? На схеме разве не так? Фильтры стоят сразу после I Q умножителей. Разве можно как-то иначе поставить фильтры и так чтобы не учитывалась их задерка в петле ФАПЧ? Хотя Ваша схема ФАПЧ не похожа на привычную петлю Костаса
Если не сложно, поясните пожалуйста в нескольких фразах как она работает. Цитата Ещё что-то надо делать с амплитудой сигнала, которую надо учитывать при рассчёте коэффициентов передачи ФАПЧ. С этим я вообще пока не знаю что делать... В свое время когда петля ФАПЧ делалась в бинарном виде этот вопрос вообще не стоял.
Сообщение отредактировал Acvarif - Mar 26 2018, 11:20
Mar 26 2018, 11:47
Из: Balakhna
Пользователь №: 937
Цитата(Acvarif @ Mar 26 2018, 13:45)  До петли это как? На схеме разве не так? Фильтры стоят сразу после I Q умножителей. Уже выше обсуждали, что комплексный сигнал у вас будет на нулевой частоте, сначала фильтр согласованный, а потом уже ФАПЧ - умножение на управляемую комплексную экспоненту, поворачиваем вращающееся созвездие в обратную сторону, чтобы оно стояло неподвижно. Цитата(Acvarif @ Mar 26 2018, 13:45)  Хотя Ваша схема ФАПЧ не похожа на привычную петлю Костаса Если не сложно, поясните пожалуйста в нескольких фразах как она работает. Это и не петля Костаса, в оригинальной статье петля работает без символьной синхронизации, здесь же она работает после символьной синхронизации в домене одного отсчёта на символ. Согласованный фильтр здесь как раз включён в петлю. Цитата(Acvarif @ Mar 26 2018, 13:45)  С этим я вообще пока не знаю что делать... В свое время когда петля ФАПЧ делалась в бинарном виде этот вопрос вообще не стоял. Моделировать, моделировать. У вас же в общем случае короткие пакеты будут приходить минимального и максимального уровня друг за другом.
Mar 26 2018, 13:10
Цитата(petrov @ Mar 26 2018, 14:47)  Уже выше обсуждали, что комплексный сигнал у вас будет на нулевой частоте, сначала фильтр согласованный, а потом уже ФАПЧ - умножение на управляемую комплексную экспоненту, поворачиваем вращающееся созвездие в обратную сторону, чтобы оно стояло неподвижно. Запутался. Вот петля Костаса
Входной сигнал m(t) sin(ωt) Далее он сразу умножается в одном плече на sin(ωt) в другом на cos(ωt) Как результат - на выходе верхнего плеча компонента I, нижнего Q. Произошел снос на нулевую частоту. Что понимается под согласованным фильтром? У нас, например, под согласованным фильтром понимается коррелятор при работе со сложным сигналом.
Сообщение отредактировал Acvarif - Mar 26 2018, 13:10
Mar 26 2018, 15:26
Из: Balakhna
Пользователь №: 937
Цитата(Acvarif @ Mar 26 2018, 16:10)  Запутался. Вот петля Костаса Входной сигнал m(t) sin(ωt) Далее он сразу умножается в одном плече на sin(ωt) в другом на cos(ωt) Как результат - на выходе верхнего плеча компонента I, нижнего Q. Произошел снос на нулевую частоту. Что понимается под согласованным фильтром? У нас, например, под согласованным фильтром понимается коррелятор при работе со сложным сигналом. Статья Костаса древняя, эту петлю в аналоге делали, не нужно её тупо переносить в цифру. Разобрались, что мы можем перенести сигнал на нулевую частоту. Далее фильтруем его согласованным фильтром, согласованным с формой видео импульсов, которые мы передаём. Коррелятор фильтром не является, он не инвариантен ко времени прихода. Далее петлёй Костаса на нулевой частоте разворачиваем созвездие BPSK, чтобы оно стояло. Filter1,3 не нужны, 2 - ПИ звено. VCO - NCO, комплексная экспонента управляемая, умножается на комплексный сигнал с выхода согласованного фильтра. Детектор ошибки - произведение реальной и мнимой частей после умножителя.
Mar 26 2018, 18:10
Спасибо что Вы мне подсказываете. Общее понимание почти сложилось. Но непонятые детали не дают покоя. Цитата(petrov @ Mar 26 2018, 18:26)  Статья Костаса древняя, эту петлю в аналоге делали, не нужно её тупо переносить в цифру. Да. Картинка немного не та. Вот та картинка
Но суть вроде не меняется. Цитата Разобрались, что мы можем перенести сигнал на нулевую частоту. Железно. Перенос на нулевую частоту это умножения входного сигнала на комплексную экспоненту. Цитата Далее фильтруем его согласованным фильтром, согласованным с формой видео импульсов, которые мы передаём. В цифровом варианте это будет FIR (LPF) Это понимается под согласованным фильтром? Цитата Filter1,3 не нужны Если по цифровой схеме Костаса то не нужны. Там стоят LPF. Цитата VCO - NCO, комплексная экспонента управляемая, умножается на комплексный сигнал с выхода согласованного фильтра. Тут опять тупик. Получается что согласованный фильтр должен стоять до умножителей. Может в качестве согласованного фильтра имеется ввиду это?
Сообщение отредактировал Acvarif - Mar 26 2018, 19:11
Acvarif BPSK матлаб модулятор демодулятор Mar 19 2018, 12:14 Grizzzly Нет, это не встроенная функция. Ее написал автор э... Mar 19 2018, 12:18 Acvarif Цитата(Grizzzly @ Mar 19 2018, 16:18) Нет... Mar 19 2018, 13:00 ataradov Ух ты. Я написал этот код много лет назад и все эт... Mar 19 2018, 16:59 ataradov Вот исходник этой pngen():
CODEfunction x=pngen... Mar 20 2018, 00:45 Acvarif Цитата(ataradov @ Mar 20 2018, 03:45) Есл... Mar 20 2018, 05:59 ataradov Какая-то из версий этой модели была на Verilog-е р... Mar 20 2018, 06:34 Acvarif Цитата(ataradov @ Mar 20 2018, 09:34) Как... Mar 20 2018, 07:10  ataradov QUOTE (Acvarif @ Mar 20 2018, 00:10) Похо... Mar 20 2018, 07:12   Acvarif Цитата(ataradov @ Mar 20 2018, 10:12) Это... Mar 20 2018, 07:28    ataradov QUOTE (Acvarif @ Mar 20 2018, 00:28) Похо... Mar 20 2018, 07:36     Acvarif ЦитатаЛучше сразу смотреть в строну симулинка, обл... Mar 20 2018, 07:51      ataradov QUOTE (Acvarif @ Mar 20 2018, 00:51) Да. ... Mar 20 2018, 07:55       Acvarif Цитата(ataradov @ Mar 20 2018, 10:55) Мож... Mar 20 2018, 08:06      petrov Цитата(Acvarif @ Mar 20 2018, 10:51) Да. ... Mar 20 2018, 08:07       Acvarif Цитата(petrov @ Mar 20 2018, 11:07) Получ... Mar 20 2018, 08:14        petrov Цитата(Acvarif @ Mar 20 2018, 11:14) Кста... Mar 20 2018, 08:29         Acvarif Цитата(petrov @ Mar 20 2018, 12:29) Возмо... Mar 22 2018, 06:26          ataradov QUOTE (Acvarif @ Mar 21 2018, 23:26) Посм... Mar 22 2018, 06:32           Acvarif Цитата(ataradov @ Mar 22 2018, 10:32) Нуж... Mar 22 2018, 07:21            ataradov QUOTE (Acvarif @ Mar 22 2018, 00:21) Спас... Mar 22 2018, 07:27             Acvarif Цитата(ataradov @ Mar 22 2018, 11:27) Это... Mar 22 2018, 08:09              petrov Цитата(Acvarif @ Mar 22 2018, 11:09) Толь... Mar 22 2018, 09:05               Acvarif Цитата(petrov @ Mar 22 2018, 13:05) Читай... Mar 22 2018, 11:11                petrov Цитата(Acvarif @ Mar 22 2018, 14:11) Проб... Mar 22 2018, 11:22                 Acvarif Цитата(petrov @ Mar 22 2018, 15:22) Никак... Mar 22 2018, 11:46                  petrov Цитата(Acvarif @ Mar 22 2018, 14:46) Поня... Mar 22 2018, 12:52                   Acvarif Цитата(petrov @ Mar 22 2018, 16:52) Нет н... Mar 23 2018, 06:12                    petrov RE: BPSK матлаб модулятор демодулятор Mar 23 2018, 06:49                     Acvarif Цитата(petrov @ Mar 23 2018, 10:49)
Пока... Mar 23 2018, 07:22                      petrov При умножении на комплексную экспоненту ничего не ... Mar 23 2018, 07:37                       Acvarif Цитата(petrov @ Mar 23 2018, 11:37) При у... Mar 23 2018, 08:10                        petrov Цитата(Acvarif @ Mar 23 2018, 11:10) Но в... Mar 23 2018, 08:17                         Acvarif Цитата(petrov @ Mar 23 2018, 12:17) Вы ви... Mar 23 2018, 08:51                          Acvarif Для большего понимания для себя происходящего в BP... Mar 26 2018, 05:01  petrov Цитата(Acvarif @ Mar 20 2018, 10:10) Для ... Mar 20 2018, 07:30        petrov Цитата(Acvarif @ Mar 26 2018, 21:10) Чем ... Mar 26 2018, 19:15         Acvarif Цитата(petrov @ Mar 26 2018, 22:15) Далее... Mar 26 2018, 19:54          petrov Цитата(Acvarif @ Mar 26 2018, 22:54) Как-... Mar 27 2018, 06:54          Acvarif Если посчитать за какое время сработает петля Кост... Mar 27 2018, 07:41           petrov Цитата(Acvarif @ Mar 27 2018, 10:41) Уже ... Mar 27 2018, 08:21            Acvarif Цитата(petrov @ Mar 27 2018, 11:21) Это е... Mar 27 2018, 12:03             petrov Цитата(Acvarif @ Mar 27 2018, 15:03) Ok. ... Mar 27 2018, 12:19              Acvarif Цитата(petrov @ Mar 27 2018, 15:19) Не ну... Mar 28 2018, 05:33 ataradov VCO получает сигал ошибки в качестве контрольного,... Mar 27 2018, 07:43 Acvarif Цитата(ataradov @ Mar 27 2018, 10:43) VCO... Mar 27 2018, 07:47  ataradov QUOTE (Acvarif @ Mar 27 2018, 00:47) Что ... Mar 27 2018, 07:51 ataradov Нужно взять исходный бинарный сигнал, умножить его... Mar 28 2018, 06:47 Acvarif Цитата(ataradov @ Mar 28 2018, 09:47) Нуж... Mar 28 2018, 07:09  Acvarif Не получается.
Пытаюсь сформировать синфазную и кв... Mar 30 2018, 05:13 ataradov Для отладки синхронизации не нужна несущая, ее мож... Mar 30 2018, 05:28 Acvarif Цитата(ataradov @ Mar 30 2018, 08:28) Для... Mar 30 2018, 06:51  Acvarif Сворганил BPSK приемо-передатчик с петлей Костаса ... Apr 12 2018, 10:44   Acvarif RE: BPSK матлаб модулятор демодулятор Apr 16 2018, 07:54
