> Alwinner A13 не стартует с SD-карты, Отладочная плата A13-olinuxino
__inline__
сообщение Mar 30 2018, 13:15
Пользователь №: 99 126
Здравствуйте!
Начал осваивать Allwinner A13 и пока безуспешно. Использую отладочную плату "A13-olinuxino", загрузиться хочу с SD карты (4 ГБ класс скорости 4).
Компилятор arm-none-eabi , исходник программы ниже, мигает светодиодом на порте G 9 (штатный порт на отладочной плате со светодиодом):
CODE
#define uint32_t unsigned long int
#define CCMBase 0x01C20000 //clock module
#define Def_APB0_Gating CCMBase + 0x68
//#define Def_APB0_Gating 0x01C20068
#define GPIOBase 0x01C20800
#define GPIOIncrement 0x24
#define ALLWINNER_GPIO_A GPIOBase
#define ALLWINNER_GPIO_B GPIOBase + (1*GPIOIncrement)
#define ALLWINNER_GPIO_C GPIOBase + (2*GPIOIncrement)
#define ALLWINNER_GPIO_D GPIOBase + (3*GPIOIncrement)
#define ALLWINNER_GPIO_E GPIOBase + (4*GPIOIncrement)
#define ALLWINNER_GPIO_F GPIOBase + (5*GPIOIncrement)
#define ALLWINNER_GPIO_G GPIOBase + (6*GPIOIncrement)
#define ALLWINNER_GPIO_H GPIOBase + (7*GPIOIncrement)
#define ALLWINNER_GPIO_I GPIOBase + (8*GPIOIncrement)
#define Port_CFG0 0x00 //pin direction and function 0 to 7
#define Port_CFG1 0x04 //pin direction and function 8 to 15
#define Port_CFG2 0x08 //pin direction and function 16 to 24
#define Port_CFG3 0x0C //pin direction and function 25 to 32
#define Port_DAT 0x10
#define Port_DRV0 0x14
#define Port_DRV1 0x18
#define Port_PUL0 0x1C
void main(void)
int i;
int j;
int foo;
uint32_t *portGConfig;
uint32_t *portGData;
uint32_t *APB0Gating;
//setup pointers for registers
portGConfig = (uint32_t *)(ALLWINNER_GPIO_G + Port_CFG1);
portGData = (uint32_t *)(ALLWINNER_GPIO_G + Port_DAT);
APB0Gating = (uint32_t *)(Def_APB0_Gating);
//enable clocking for GPIO
*APB0Gating |= 0x0020;
//configure port G pin 9 to output
*portGConfig |= 0x10;
//set output to on
*portGData |= 0x0200;
Loop:
foo = 0;
for (j = 0; j < 100; j++)
//toggle output
*portGData ^= 0x0200;
foo=j;
for (i = 0; i < 30000000; i++)
if(i>10)
foo++;
goto Loop;
Файл линковщика:
MEMORY
RAM (XRW) : ORIGIN = 0x00000000, LENGTH = 0x00004000 /* 16 KB */
SECTIONS
.start    : { *(.start)    } > RAM
.text     : { *(.text)     } > RAM
.bss      : { *(.bss)      } > RAM
.fill     :
  FILL(0x00);
  . = ORIGIN(RAM) + LENGTH(RAM) - 1;
  BYTE(0x00);
} > RAM
/DISCARD/ : { *(.dynstr*)  }
/DISCARD/ : { *(.dynamic*) }
/DISCARD/ : { *(.plt*)     }
/DISCARD/ : { *(.interp*)  }
/DISCARD/ : { *(.gnu*)     }
/DISCARD/ : { *(.note*)    }
ассемблерный листинг:
test.elf:     file format elf32-littlearm
Disassembly of section .text.startup:
00000000 <main>:
   0:    e59f3030     ldr    r3, [pc, #48]; 38 <main+0x38>
   4:    e5932068     ldr    r2, [r3, #104]; 0x68
   8:    e3822020     orr    r2, r2, #32
   c:    e5832068     str    r2, [r3, #104]; 0x68
  10:    e59328dc     ldr    r2, [r3, #2268]; 0x8dc
  14:    e3822010     orr    r2, r2, #16
  18:    e58328dc     str    r2, [r3, #2268]; 0x8dc
  1c:    e59328e8     ldr    r2, [r3, #2280]; 0x8e8
  20:    e3822c02     orr    r2, r2, #512; 0x200
  24:    e58328e8     str    r2, [r3, #2280]; 0x8e8
  28:    e59f300c     ldr    r3, [pc, #12]; 3c <main+0x3c>
  2c:    e2533001     subs    r3, r3, #1
  30:    1afffffd     bne    2c <main+0x2c>
  34:    eafffffb     b    28 <main+0x28>
мейк-скрипт:
arm-none-eabi-gcc     -Os -march=armv7-a -std=c99 -marm -fpic -Wall -fno-common -fno-builtin -ffreestanding -nostdinc -nostdlib -fno-strict-aliasing -mno-thumb-interwork -fno-stack-protector -fno-toplevel-reorder -Wstrict-prototypes -Wno-format-nonliteral -Wno-format-security -c test.c -o test.o
arm-none-eabi-ld      -T test.lds -M -o test.elf test.o
arm-none-eabi-objdump -D test.elf > test.asm
arm-none-eabi-objcopy -O binary test.elf test.bin
mksunxiboot.exe test.bin test-sd.bin
Для создания загрузочного образа использую программу с аргументами: mksunxiboot.exe test.bin test-sd.bin
С помощью дискового редактора копирую весь образ на 16-й сектор карты памяти (это смещение 8кБ от начала).
Карта памяти отформатирована в винде. Первые сектора - ДОСовский загрузчик-заглушка .
Из ассемблерного листинга видно что программа идет с адреса 0, как требуется в A13.
Хедер вроде тоже с верной контрольной суммой.
Стек инитится BROM-ом (при старте) SP=0x7FF8
Вставляю карту в одладочную плату, подаю питание (внешний БП 6V 2A) - и ничего не горит.
Пожалуйста, помогите разобраться, чего не хватает и что не так?
Весь проект прилагаю, мейк-файлы, скрипты и утилиты там же.
P.S.
Звонил светодиод и ножку контроллера - контакт есть, диод зажигается от тестера.
Объявил переменные volatile, не помогло:
CODE
void main(void)
volatile int i;
volatile int j;
volatile int foo;
volatile uint32_t *portGConfig;
volatile uint32_t *portGData;
volatile uint32_t *APB0Gating;
portGConfig = (volatile uint32_t *)(ALLWINNER_GPIO_G + Port_CFG1);
portGData = (volatile uint32_t *)(ALLWINNER_GPIO_G + Port_DAT);
APB0Gating = (volatile uint32_t *)(Def_APB0_Gating);
//set output to on
Loop:
foo = 0;
//toggle output
foo=j;
if(i>10)
foo++;
goto Loop;
00000000 <main>:
0: e59f3094 ldr r3, [pc, #148]; 9c <main+0x9c>
4: e24dd010 sub sp, sp, #16
8: e5932068 ldr r2, [r3, #104]; 0x68
c: e3822020 orr r2, r2, #32
10: e5832068 str r2, [r3, #104]; 0x68
14: e59328dc ldr r2, [r3, #2268]; 0x8dc
18: e3822010 orr r2, r2, #16
1c: e58328dc str r2, [r3, #2268]; 0x8dc
20: e59328e8 ldr r2, [r3, #2280]; 0x8e8
24: e3822c02 orr r2, r2, #512; 0x200
28: e58328e8 str r2, [r3, #2280]; 0x8e8
2c: e3a02000 mov r2, #0
30: e58d200c str r2, [sp, #12]
34: e58d2008 str r2, [sp, #8]
38: e59d2008 ldr r2, [sp, #8]
3c: e3520063 cmp r2, #99; 0x63
40: cafffff9 bgt 2c <main+0x2c>
44: e59328e8 ldr r2, [r3, #2280]; 0x8e8
48: e2222c02 eor r2, r2, #512; 0x200
4c: e58328e8 str r2, [r3, #2280]; 0x8e8
50: e59d2008 ldr r2, [sp, #8]
54: e58d200c str r2, [sp, #12]
58: e3a02000 mov r2, #0
5c: e58d2004 str r2, [sp, #4]
60: e59d1004 ldr r1, [sp, #4]
64: e59f2034 ldr r2, [pc, #52]; a0 <main+0xa0>
68: e1510002 cmp r1, r2
6c: ca000007 bgt 90 <main+0x90>
70: e59d2004 ldr r2, [sp, #4]
74: e352000a cmp r2, #10
78: c59d200c ldrgt r2, [sp, #12]
7c: c2822001 addgt r2, r2, #1
80: c58d200c strgt r2, [sp, #12]
84: e59d2004 ldr r2, [sp, #4]
88: e2822001 add r2, r2, #1
8c: eafffff2 b 5c <main+0x5c>
90: e59d2008 ldr r2, [sp, #8]
94: e2822001 add r2, r2, #1
98: eaffffe5 b 34 <main+0x34>
9c: 01c20000 biceq r0, r2, r0
a0: 01c9c37f biceq ip, r9, pc, ror r3
Сообщение отредактировал IgorKossak - Mar 30 2018, 14:33
Причина редактирования: [codebox] для длинного кода. [code]-для короткого!!!
__inline__
сообщение Apr 1 2018, 08:36
Было 2 ошибки.
Ошибка номер 1.
Начал с проверки COM-порта. Замкнул вывод 2 с выводом 3 на системном блоке компа, убедился как тут писали, что связь есть: получаю то же, что и отправляю.
Значит порт исправен и WinXP дает доступ к нему.
Дальше: подсоединил адаптер, запитал его от 3,3V от платы A13-Olinuxino. Выводы TX и RX адаптера соединил вместе. Вот тут и зарылась собака - в ответ летит не то, что отправляю!
Запитал адаптер отдельно от 5V, протестил: обмен исправен. Понизил питание до 3V - снова пошла лажа на скорости 115200 бит/c!.
Понизил скорость до 2400 бит/c - обмен при питании 3V нормальный.
Сделал вывод, что тот MAX3232, что стоит в адаптере не позволяет при питании 3,3V давать обмен на 115200 бит/c.
Порылся в закромах, нашёл в резерве одну MAX3232, выпаял ту что была на адаптере и впаял новую.
Проверил снова обмен при 5V и при 3.3V на скорости 115200 бит/c - работает исправно! Делаю вывод о бракованной партии микросхем MAX3232, которая попала мне в адаптере.
Фотка фуфела MAX3232, не работающего на 115200 бит/с при 3,3V:
Фотка нормальной микросхемы:
Ошибка номер 2.
Программа дискового редактора, которую я использовал: HxD Hex-редактор от Maёl Horz, неверно делала запись на 16-й сектор карты!
Позже, скачав win32-disk-imager-0-7-en-win.zip (эта не свежая версия, но идёт под WinXP, что для меня важно!) и записав образ sunxi-spl.bin из папки a13_olinuxino_hwpack, я получил наконец-то запуск программы на A13:
Действительно, для отладки используется порт UART1. Образ sunxi-spl.bin для A13 прилагаю:
ну и далее попробовал запустить Debian, тот самый, что якобы на карту с 4 ГБ влезает (на самом деле нет, олимексовцы по-мойму забыли, что 4 ГБ это не 4*1024^3 байт, а 4*1000^3 sm.gif ) всё пошло:
Качал вот этот архив: A13_debian_34_90_mainline_u-boot_release_11_3.7z, с торрента - файл прикладываю:
Прикрепленный файл  A13_debian_34_90_mainline_u_boot_release_11_3.zip ( 25.23 килобайт ) Кол-во скачиваний: 13
Естественно, перед заливкой образа, архив распаковать. Образ писал программой, что описана выше: win32-disk-imager-0-7-en-win.zip
Потом всё-же решил посмотреть, где же глючит HxD и почему она пишет 16-й сектор не туда, куда надо и не видит там ничего после записи win32-disk-imager-0-7-en-win.zip.
Для этого прочёл образ с карты (1% достаточно) и увидел, что сигнатура eGON.BT0 была на 145-м секторе! Делайте выводы, господа! Вот так софтина может подставить программиста!
Шаг 3.
После как разобрался в ошибках, попробовал закатать образ своей программы с мигающим светодиодом.
Так как HxD - оказался на поверку говном, а win32-disk-imager не может писать образы не с начала, пришлось 0x2000 байт с самого начала SD-карты скопировать в отдельный файл.
Затем бинарно клеить эти 0x2000 байт со своей программой (у которой уже есть хедер и посчитана контрольная сумма).
Тоесть алгоритм такой:
1) компилируем и линкуем свою программу (при этом моделируя набросок заголовка: прыжок на main(), заполняя оставшееся место нулями)
2) вычисляем контрольную сумму в получившемся бинарнике (я использую checksumm.exe собственноручно скомпилированную из сорцов Гитхаба)
3) склеиваем 2 файла: первые 0x2000 байт со своим бинарником (я использую свой конкатенатор concat.exe)
4) полученный файл *.img катаем на SD-карту win32-disk-imager-ом.
5) вставляем карту в A13-olinuxino, включаем питание и радуемся результату! sm.gif
Загрузка мгновенна, никаких кнопок Power и Home/U-boot жать не надо!
Прикрепляю рабочий проект целиком - оптимизация по скорости, максимальная. Проект перелопатил из олимексовского говнокода. (+ утилита для контрольной суммы):
Использую такие тулчейны:
gcc-arm-none-eabi-6-2017-q2-update-win32.exe
gcc-arm-none-eabi-4_8-2014q3-20140805-win32.exe
Без разницы какой, после инсталляции важно прописать переменные окружения в операционной системе , иначе не будет работать как надо.
Сорцы пишу в Блокноте (с синтаксической подсветкой типа "Bred"), для сборки батники или make-файлы.
По-мойму это лучше, чем искать проприетарное тяжеловесное дерьмо, за которое мудаки требуют деньги (в контексте последних ARM-ов).
И к тому же которое под WinXP идёт либо криво или вообще не пускается.
Ну и вспомогательные вещи: утилита склейки concat.exe и файл первых 0x2000 байт, которые должны быть до программы.
Утилита склеивает 2 файла : "0x2000.bin" и "spl.bin" в один "image.img" - его катать на карту win32-disk-imager-ом!
Прикрепленный файл  concat_util.zip ( 33.44 килобайт ) Кол-во скачиваний: 10
Если достать нормальный дисковый редактор, то можно сразу spl.bin катать на 16-й сектор. Без всяких склеек с 0x2000.bin.
Но пока такой программы не нашёл, все клянчат деньги и не дают работать на запись...
Надеюсь, что то что написал, поможет начинающим разобраться и не спотыкаться на те грабли, что мне пришлось испытать. smile3046.gif
to mantech:
регистры, порты ввода-вывода, переменные, менющиеся в обработчиках прерываний - должны быть объявлены как volatile, иначе компилятор оставляет за собой право выкинуть часть кода или закешировать эти переменные в регистры (особенно с максимальной оптимизацией, где не учитывается специфика работы с аппаратурой: допускается многократное присваивание в один и тот же регистр) sm.gif
Сообщение отредактировал __inline__ - Apr 1 2018, 09:37
Jury093
сообщение Apr 1 2018, 10:30
Пользователь №: 13 050
Цитата(__inline__ @ Apr 1 2018, 11:36) *
спасибо, что поделились результатами, кто-нить следующий придет, прочитает и обойдет подобные грабли..
по max3232 - у вас либо перемаркированная max232 или фейк от китайцев
ближайший пост:
https://www.eevblog.com/forum/reviews/fake-...tional-details/
там помимо олимексовцев, д.б. разозленные клиенты, которые заплатили деньги за плату, а "образ на карточку не лезет"
напишите им фидбек - "какого хрена 'ссылка' не лезет на 4ГБ", если это их косяк, то исправят
поищите winhex или какой-нить discedit, у того же олимекса были ссылки на дисковые редакторы
формально, можно загрузиться с uSD в дефолтный дебьян и пилить вторую карточку через usb ридер прямо на плате, но это уж как кому удобнее..
mantech
сообщение Apr 1 2018, 13:43
Из: Киров
Пользователь №: 73 143
Я предлагал ТСу программу cfimager от фриски. Пишет с на сд карту свой бинарь с первого сектора и ничего изобретать не нужно... Причем, что удобно, в ней нет гуя, работает с командной строки без установки драйверов или еще чего-либо.
Цитата(Obam @ Apr 1 2018, 13:44) *
В маркировке MAX-а смущает "+": вот не помню, это способность большого ESD (1.5кВ)?
А если перемаркированная 232, то можно было бы увеличить ёмкости конденсаторов накопительных. В прочем, на фиг (;
С успехом вас (:
Неа, тут это не поможет, проверял.
Т.е. ИДЕ не используете. А если ошибка в программе, как она отображается? В ИДЕ можно сразу на строчку с ошибкой кликнуть, ИМХО удобнее будет...
Сообщение отредактировал mantech - Apr 1 2018, 13:37
aaarrr
сообщение Apr 1 2018, 14:12
Пользователь №: 1 448
В консоли, естественно. Перейти на нужную строку в нужном файле можно и без ИДЕ - обычно все и так перед глазами.
mantech
сообщение Apr 1 2018, 14:49
Из: Киров
Не говорю, что нельзя, просто в иде удобнее, особенно, когда файлов больше сотни, а у ТСа, если он реально будет камень осваивать, будет и больше...
- __inline__   Alwinner A13 не стартует с SD-карты   Mar 30 2018, 13:15
- - aaarrr   Попробуйте сначала этот бинарник из-под u-boot...   Mar 30 2018, 13:40
- - __inline__   может быть проблема в этом: Кодsudo dd if=bin/rele...   Mar 30 2018, 14:24
|- - aaarrr   Цитата(__inline__ @ Mar 30 2018, 17:24) м...   Mar 30 2018, 14:31
|- - mantech   Цитата(aaarrr @ Mar 30 2018, 17:31) Содер...   Mar 30 2018, 20:11
|- - Jury093   Цитата(mantech @ Mar 30 2018, 23:11) Не д...   Mar 31 2018, 12:24
|- - aaarrr   Цитата(Jury093 @ Mar 31 2018, 15:24) кста...   Mar 31 2018, 12:32
|- - mantech   Цитата(Jury093 @ Mar 31 2018, 15:24) стра...   Mar 31 2018, 13:17
|- - aaarrr   Цитата(mantech @ Mar 31 2018, 16:17) На с...   Mar 31 2018, 13:23
|- - Jury093   Цитата(aaarrr @ Mar 31 2018, 16:23) Госп...   Mar 31 2018, 13:30
||- - aaarrr   Цитата(Jury093 @ Mar 31 2018, 16:30) ну в...   Mar 31 2018, 13:35
|- - mantech   Цитата(aaarrr @ Mar 31 2018, 16:23) Госп...   Mar 31 2018, 14:27
|- - aaarrr   Цитата(mantech @ Mar 31 2018, 17:27) я на...   Mar 31 2018, 15:26
- - __inline__   Ещё один момент: на отладочной плате A13-Olinuxin...   Mar 30 2018, 15:03
- - aaarrr   Allwinner'ы грузятся с нулевой SD карты при лю...   Mar 30 2018, 15:08
|- - __inline__   Цитата(aaarrr @ Mar 30 2018, 16:08) Allwi...   Mar 31 2018, 05:01
- - __inline__   Взял spl и u-boot отсюдова: http://dl.linux-sunxi....   Mar 31 2018, 06:50
|- - Jury093   Цитата(__inline__ @ Mar 31 2018, 09:50) С...   Mar 31 2018, 08:35
- - __inline__   Я много вариантов перепробовал: и с мигающим диодо...   Mar 31 2018, 11:06
|- - aaarrr   Цитата(__inline__ @ Mar 31 2018, 14:06) Н...   Mar 31 2018, 11:59
- - __inline__   На счёт соединения с ком-портом, адаптер вызвонил ...   Mar 31 2018, 14:09
|- - aaarrr   Цитата(__inline__ @ Mar 31 2018, 17:05) П...   Mar 31 2018, 14:10
|- - aaarrr   Цитата(__inline__ @ Mar 31 2018, 17:09) Е...   Mar 31 2018, 14:21
||- - __inline__   Цитата(aaarrr @ Mar 31 2018, 15:21) volat...   Mar 31 2018, 14:31
|- - Jury093   Цитата(__inline__ @ Mar 31 2018, 17:09) С...   Mar 31 2018, 15:14
|- - mantech   Цитата(Jury093 @ Mar 31 2018, 18:14) возь...   Mar 31 2018, 16:32
|- - aaarrr   Цитата(mantech @ Mar 31 2018, 19:32) Кста...   Mar 31 2018, 16:46
||- - mantech   Цитата(aaarrr @ Mar 31 2018, 19:46) Видим...   Mar 31 2018, 17:10
|- - Jury093   Цитата(mantech @ Mar 31 2018, 19:32) Кста...   Mar 31 2018, 17:29
- - __inline__   В общем что это http://radiokot.ru/articles/59/ чт...   Mar 31 2018, 14:14
- - __inline__   Вот такой адаптер (MAX3232 )   Mar 31 2018, 14:24
- - aaarrr   Цитата(__inline__ @ Mar 31 2018, 17:09) Д...   Mar 31 2018, 14:29
||- - aaarrr   Цитата(Jury093 @ Apr 1 2018, 13:30) там п...   Apr 1 2018, 11:08
|||- - Jury093   Цитата(aaarrr @ Apr 1 2018, 14:08) Просто...   Apr 1 2018, 15:39
|||- - aaarrr   Цитата(Jury093 @ Apr 1 2018, 18:39) карто...   Apr 1 2018, 15:51
|- - mantech   Цитата(__inline__ @ Apr 1 2018, 11:36) Ка...   Jul 23 2018, 11:55
- - Obam   В маркировке MAX-а смущает "+": вот не п...   Apr 1 2018, 10:44
- - __inline__   Всем спасибо за помощь! Цитата(mantech)Я пр...   Apr 1 2018, 16:22
- - aaarrr   Цитата(__inline__ @ Apr 1 2018, 19:22) Ка...   Apr 1 2018, 16:33
- - aaarrr   Цитата(__inline__ @ Apr 1 2018, 19:22) 2)...   Apr 1 2018, 17:34
RSS Текстовая версия Сейчас: 21st August 2025 - 01:22
Страница сгенерированна за 0.01583 секунд с 7
