вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 008 |
May 3 2018, 12:23
Пользователь №: 88 095
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 038 Код Fixed CCRs: SPB 17.2 HF038 04-27-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1861616 ADW TDO-SHAREPOIN Team Design Option requires Allegro_ECAD_Collab_Workbench license feature 1784170 ALLEGRO_EDITOR 3D_CANVAS Allegro 3D Canvas does not show the flex zone thickness correctly 1801053 ALLEGRO_EDITOR 3D_CANVAS Moving component in 3D Canvas does not move the pads 1805038 ALLEGRO_EDITOR 3D_CANVAS Soldermask and drill not refreshed when component is moved in 3D Canvas, or on the board with Canvas open 1808579 ALLEGRO_EDITOR 3D_CANVAS 3D Canvas displays annular ring incorrectly 1816732 ALLEGRO_EDITOR 3D_CANVAS Mismatch in shape width between board and 3D Canvas 1822778 ALLEGRO_EDITOR 3D_CANVAS 3D Canvas does not display nets when selection is done through click drag 1838129 ALLEGRO_EDITOR 3D_CANVAS User is not able to create a pastemask layer that is visible in 3D Canvas 1842911 ALLEGRO_EDITOR 3D_CANVAS Etch shapes not visible in the 3D Canvas when invoked from a symbol drawing 1849380 ALLEGRO_EDITOR 3D_CANVAS Mirrored components placed in flex zones are not displayed in the 3D Canvas 1851898 ALLEGRO_EDITOR 3D_CANVAS STL export from 3D Viewer scales it up by 100 1853378 ALLEGRO_EDITOR 3D_CANVAS The new interactive 3D Canvas has a display issue with the off-centered drills. 1859713 ALLEGRO_EDITOR 3D_CANVAS PLACE_BOUND shape with package_height_max and package_height_min set displayed incorrectly in 3D Canvas 1880073 ALLEGRO_EDITOR 3D_CANVAS Design Outline is not displayed correctly in 3D Canvas 1880338 ALLEGRO_EDITOR 3D_CANVAS Step Model missing in interactive 3D canvas. 1881889 ALLEGRO_EDITOR 3D_CANVAS Changing the color of STEP model in STEP Mapping Window does not display this color in 3D Canvas. 1889861 ALLEGRO_EDITOR 3D_CANVAS 3D Canvas swaps padstack from Bottom to Top 1830749 ALLEGRO_EDITOR ARTWORK Gerber 4x and 6x output do not fill the shape 1848514 ALLEGRO_EDITOR COLOR axlVisibleDesign does not interact with wirebonds 1837388 ALLEGRO_EDITOR CROSS_SECTION Cannot add solder mask to the site layer mask file 1859797 ALLEGRO_EDITOR CROSS_SECTION The Report only option does not work when choosing Setup - Cross-section - Import - IPC2581 1877858 ALLEGRO_EDITOR CROSS_SECTION Dynamic Pads Suppression option is not working correctly 1880093 ALLEGRO_EDITOR CROSS_SECTION Unused Pad Suppression options are not working correctly and are reset on opening cross-section 1886283 ALLEGRO_EDITOR CROSS_SECTION Unable to turn on 'Dynamic Unused Pads Suppression' 1890959 ALLEGRO_EDITOR CROSS_SECTION Dynamic Pads Suppression option is not working correctly 1900397 ALLEGRO_EDITOR CROSS_SECTION Dynamic Unused Pad Suppression option in Cross-section not working at one go. 1905315 ALLEGRO_EDITOR CROSS_SECTION 'Dynamic Unused Pad Suppression' cannot be turned on. 1861406 ALLEGRO_EDITOR DATABASE Refresh symbol for flex zone not mapping padstack layers correctly 1877132 ALLEGRO_EDITOR DATABASE Fail to open #Taaaaed17598.tmp file and save database 1883747 ALLEGRO_EDITOR DATABASE PCB Editor crashes on stackup modification 1860238 ALLEGRO_EDITOR DFM Applying a DFF constraint set closes PCB Editor instantly 1872780 ALLEGRO_EDITOR DFM DFF false pin to via DRCs: Copper Spacing, SMD pin Pad to Thru Via pad 1823912 ALLEGRO_EDITOR DRC_CONSTR Thru pin to Thru pin DRC between Symbol Pin to Mechanical Hole (with NO regular pad) 1828168 ALLEGRO_EDITOR DRC_CONSTR Upgrading from release 16.3 to 17.2-2016: Differences in spacing constraints 1844780 ALLEGRO_EDITOR DRC_CONSTR Mechanical Pin to Shape Air Gap value is reduced when updating shape 1845011 ALLEGRO_EDITOR DRC_CONSTR When upgrading from 16.6 to 17.2, Spacing constraints for shape to mechanical pin not being resolved properly 1861548 ALLEGRO_EDITOR DRC_CONSTR Inconsistent Micro via to Micro via drill to drill overlap DRCs 1862281 ALLEGRO_EDITOR DRC_CONSTR Mechanical Pin/hole to Shape spacing too small 1887145 ALLEGRO_EDITOR DRC_CONSTR Mechanical pin to conductor spacing setting is overriding constraint region in release 17.2-2016 1893012 ALLEGRO_EDITOR DRC_CONSTR Shape voiding not taking the shape to hole spacing rules for NPTH 1906840 ALLEGRO_EDITOR GRAPHICS Context menu stays when PCB Editor is minimized. 1738624 ALLEGRO_EDITOR INTERACTIV 'Invalid Sector' error when saving psm file for symbol that has die pads, which are copied 1800741 ALLEGRO_EDITOR INTERACTIV Search in User Preferences Editor is giving incorrect results 1812530 ALLEGRO_EDITOR INTERACTIV PCB Editor crashes when opening a file that is in an unsupported format 1812570 ALLEGRO_EDITOR INTERACTIV PCB Editor hangs when an invalid pin number value is specified as the rotation point in the symbol preselect mode 1826819 ALLEGRO_EDITOR INTERACTIV 'Route - Resize/Respace - Align Vias' menu is not available 1842645 ALLEGRO_EDITOR INTERACTIV Via align command is missing from the menu path 1845748 ALLEGRO_EDITOR INTERACTIV With 'Shape - Change Shape Type' enabled, changing visibility reverts the Shape Fill selection to dynamic copper. 1849700 ALLEGRO_EDITOR INTERACTIV Add the reason for generating DBFIX_PAD, to the dbdoctor.log. 1860934 ALLEGRO_EDITOR INTERACTIV Auto-Paste environment variable is not working as it should 1861928 ALLEGRO_EDITOR INTERACTIV Provide a Persistent snap pick option for Display - Measure 1864238 ALLEGRO_EDITOR INTERACTIV Shape place rectangle issue: Dimension of placed rectangle changes on cancelling action 1877026 ALLEGRO_EDITOR INTERACTIV Filled rectangles on ETCH/TOP and ETCH/BOTTOM are not getting copied 1881637 ALLEGRO_EDITOR INTERACTIV Radius of Shape changes when trying to place circle using Place Circle mode. 1883032 ALLEGRO_EDITOR INTERACTIV Find by Query does not find all padstacks in a symbol drawing 1855248 ALLEGRO_EDITOR INTERFACES The Technology Dependent Footprint command returns an error 1885716 ALLEGRO_EDITOR INTERFACES Increase supported STEP model size to enable the use of models larger then 500MB 1860835 ALLEGRO_EDITOR MANUFACT Display a message when backdrill_max_pth_stub is defined for vias or pins only 1869528 ALLEGRO_EDITOR MANUFACT Backdrill out of date when deleting Teardrop and Sliding cline with Teardrop 1885672 ALLEGRO_EDITOR NC NC drill is creating false backdrills when repeat code is turned on in release 17.2-2016 1895084 ALLEGRO_EDITOR NC Padstacks with backdrill data trigger backdrill out-of-date even if the board is not set up for backdrilling 1837514 ALLEGRO_EDITOR PAD_EDITOR Offset is not consistent for keepout and mask layers in padstack editor. 1842902 ALLEGRO_EDITOR PAD_EDITOR Scrolling through the .pad files in the Library Padstack Browser displays Error(SPMHA1-161) 1846504 ALLEGRO_EDITOR PAD_EDITOR COVERLAY_TOP definition lost while opening and saving a 16.6 pad in 17.2 padstack editor 1879453 ALLEGRO_EDITOR PAD_EDITOR The 'Y' tolerance in the Padstack Editor does not update when changing the units of the padstack. 1805202 ALLEGRO_EDITOR PLACEMENT Place via array adds via on differential pairs incorrectly 1806675 ALLEGRO_EDITOR PLACEMENT Place - Manually - Quickview displays the Assembly Top details only 1835177 ALLEGRO_EDITOR PLACEMENT Can place symbol even after cancelling copy by choosing 'Oops' from pop-up 1846892 ALLEGRO_EDITOR PLOTTING PCB Editor Export PDF does not show lines correct for certain component 1006328 ALLEGRO_EDITOR SHAPE Static shapes should void around corners as dynamic shapes do 1033326 ALLEGRO_EDITOR SHAPE Cannot compose lines to shape 1045089 ALLEGRO_EDITOR SHAPE Dynamic shape voiding is inconsistent for solid and xhatch shape fill type 1069959 ALLEGRO_EDITOR SHAPE Compose shape crashes PCB Editor 1085907 ALLEGRO_EDITOR SHAPE Pad does not get thermal connections to shape if outside of the shape outline by more than DRC spacing. 1143563 ALLEGRO_EDITOR SHAPE The pin void inline clearance does not seem to dynamically update the shape and requires a 'force update'. 1243688 ALLEGRO_EDITOR SHAPE shape_rki_autoclip fails to clip shape to route keepin 1269069 ALLEGRO_EDITOR SHAPE Shape void not working properly in release 16.5 hotfix 054 1327755 ALLEGRO_EDITOR SHAPE Need the ability to nest dynamic shapes on different nets partially or entirely 1417394 ALLEGRO_EDITOR SHAPE Shape not updating correctly 1430742 ALLEGRO_EDITOR SHAPE When adding fillet to an irregular pad, the fillet might not be added or be strangely shaped 1750760 ALLEGRO_EDITOR SHAPE Shape to Route Keepout DRC for a void that meets route keepout 1793898 ALLEGRO_EDITOR SHAPE Add teardrops fails to add anything with different settings 1811662 ALLEGRO_EDITOR SHAPE 'show measure' gives incorrect air gap value between two pins 1820901 ALLEGRO_EDITOR SHAPE The pins on adjacent layers are voided as Rounded Rectangle instead of Rectangular as defined in padstacks 1829570 ALLEGRO_EDITOR SHAPE Display measure airgap value is very large 1858696 ALLEGRO_EDITOR SHAPE The via to the edge of the board is not connecting to shape even with the PAD_SHAPE_TOUCH_CONNECTION property added 1873384 ALLEGRO_EDITOR SHAPE Boolean AND operation returning nil 1873860 ALLEGRO_EDITOR SHAPE Copper shape does not respect route keepout 1889312 ALLEGRO_EDITOR SHAPE Shape voided for net vias on adding 'PAD_SHAPE_TOUCH_CONNECTIONS' when enabling via suppression 1890702 ALLEGRO_EDITOR SHAPE Not able to add teardrop in release 17.2-2016 1892692 ALLEGRO_EDITOR SHAPE Thermal relief connections being added to static shapes present in the void inside Dynamic Shapes 1893492 ALLEGRO_EDITOR SHAPE 'merge shapes' results in moved void 1896543 ALLEGRO_EDITOR SHAPE Same net pin will not add thermal connection to shape if it is a rotated slot in the symdef 1897645 ALLEGRO_EDITOR SKILL axlCNSGetSpacing() returns nil if active class is non-etch. 1822364 ALLEGRO_EDITOR UI_FORMS Design Parameters dialog disappears if prmed is called while show measure is active 1834395 ALLEGRO_EDITOR UI_FORMS Setup menu of OrCAD PCB Editor is missing the Anchor 3D View command 1838941 ALLEGRO_EDITOR UI_FORMS Anchor 3D View command is not available in OrCAD PCB Editor Setup menu 1716433 ALLEGRO_EDITOR UI_GENERAL Alias keys do not work until mouse scroll key is activated 1721761 ALLEGRO_EDITOR UI_GENERAL During manual placement of symbols, hovering over symbols does not highlight them 1732915 ALLEGRO_EDITOR UI_GENERAL Alias does not work in release 17.2-2016 when switching windows 1770723 ALLEGRO_EDITOR UI_GENERAL Funckey does not work if focus is not on canvas in release 17.2-2016 1793839 ALLEGRO_EDITOR UI_GENERAL Function Key does not work if a form is opened by a previous command 1813961 ALLEGRO_EDITOR UI_GENERAL Inconsistent file formats available when saving reports 1816716 ALLEGRO_EDITOR UI_GENERAL Shortcut not working when using working layer with 'add connect' 1864321 ALLEGRO_EDITOR UI_GENERAL Funckeys not being registered after focus has moved to other window and back again in PCB Editor 1865010 ALLEGRO_EDITOR UI_GENERAL PCB Editor does not get focus when clicking shortcut after switching from any other program or application 1868708 ALLEGRO_EDITOR UI_GENERAL Allegro PCB Editor, funckeys stop working intermittently in release 17.2-2016, hotfix 032 1869745 ALLEGRO_EDITOR UI_GENERAL Allegro 3D Canvas window becomes active on pointing at minimized icon on taskbar 1869860 ALLEGRO_EDITOR UI_GENERAL Hotkeys no longer functional on switching from PCB Editor to another application and then back again 1870744 ALLEGRO_EDITOR UI_GENERAL Need html extension added to Save pull down menu. 1870996 ALLEGRO_EDITOR UI_GENERAL If you switch from one active window to other, hotkeys stop working 1883507 ALLEGRO_EDITOR UI_GENERAL Hotkeys stop working after Allegro PCB Editor UI window is opened 1886981 ALLEGRO_EDITOR UI_GENERAL Focus lost from layout when switching between PCB Editor and Capture 1887519 ALLEGRO_EDITOR UI_GENERAL Release 17.2-2016, hotfix 034: Shortcuts defined using funckeys not working correctly 1887660 ALLEGRO_EDITOR UI_GENERAL Alias does not work in release 17.2-2016 when switching windows. 1891204 ALLEGRO_EDITOR UI_GENERAL PCB Editor crashes if SKILL form is closed using the Close icon ('X') 1898059 ALLEGRO_EDITOR UI_GENERAL Funckey commands are not working consistently in release 17.2-2016 1902322 ALLEGRO_EDITOR UI_GENERAL Cannot use funckey commands when cross-probing 1905906 ALLEGRO_EDITOR UI_GENERAL Issue with keys and focus when navigating between windows 1913768 ALLEGRO_EDITOR UI_GENERAL Uppercase funckey shortcuts do not work 1751586 APD OTHER axlGetMetalUsageForLayer() for etch returns value including pins and vias 1863241 APD SHAPE Fillet is left on the T-Point without Cline(center) connection. 1894438 APD STREAM_IF APD/SiP Layout: Export rounded features as circumscribed and not inscribed polygon in GDS 1812699 ASDA AUTOMATION Enhance the performance when extracting data from SDA, using TCL functions 1863436 ASDA CANVAS_EDIT alignment guides are not displayed when placing or copy a part, only when moving. They are most needed during placement 1863445 ASDA CANVAS_EDIT dark theme blue text in docked CM needs to be a different color. difficult to read 1802111 ASDA DARK_THEME Dark theme in SDA should also change the border line color and text color of grid references: they are still black 1869951 ASDA EXPORT_PCB File browser button in Export to PCB Layout flashes graphics of the window behind the form 1845831 ASDA FORMAT_OBJECT Width of the twisted pair of wire should automatically be set to 6, otherwise it is not drawn correctly 1879914 ASDA INTERNATIONAL Using French Keyboard cannot use the . (point) delimiter to set VOLTAGE property value 1865753 ASDA MISCELLANEOUS Inconsistent and non-ideal behavior in SDA product choice dialog, small box, hard to check unlike the bottom box 1863457 ASDA PACKAGER globaly unset all user assigned references 1889301 ASDA TDO SDA TDO Crashes when switching to/from Offline mode 1823203 ASDA VARIANT_MANAG Variant setting part to not present does not do anything 1823992 ASDA VARIANT_MANAG Variant Editor fails to read netlist if a net is named NC 1863451 ASDA VARIANT_MANAG variant mode can select multiple parts to add to variant but can't select multiple parts to hit reset 1863455 ASDA VARIANT_MANAG Cant resize any panales in variant view mode 1874952 ASDA VARIANT_MANAG Letter I in the alternate part icons in variant spreadsheet should be white for readability 1878401 ASDA VARIANT_MANAG SDA Variant Display - DNI marker color switches between black and red 1877239 ASDA WORKSPACE SDA DRC window is hidden if undocked and minimized 1809605 CAPTURE LIBRARY Part has pins in the incorrect order in the Connectors library 1638693 CAPTURE OTHER Capture Footprint Viewer not showing footprint. 1873612 CONCEPT_HDL COPY_PROJECT Copy project causes nets to be added to net groups and ports - fails to package due to mismatch 1779289 CONCEPT_HDL CORE Adding a component and wire and saving the design results in a 'Connectivity save failed' error 1878719 CONCEPT_HDL CORE Cannot enable or apply block variants at the top-level in a hierarchical design. 1865480 CONCEPT_HDL OTHER 'partmgr -ptfMode shoppingCart' cannot output cell name with project ptf file into shoppingCart.xml 1829966 CONSTRAINT_MGR CONCEPT_HDL DML independent flow: Export Physical audits missing signal models in release 17.2 1904458 CONSTRAINT_MGR ECS_APPLY 'Audit - ECSets' crashes DE-HDL in release 17.2-2016, Hotfix 037 1798269 CONSTRAINT_MGR OTHER Script changes '-' in layer name to '_' 1835520 CONSTRAINT_MGR OTHER Cannot add members to netclass name with parenthesis 1896638 CONSTRAINT_MGR OTHER Constraint Manager worksheets jump abruptly 1801938 CONSTRAINT_MGR UI_FORMS Add To Netclass window: Focus not on ClassSelection 1854060 CONSTRAINT_MGR UI_FORMS Using the tab key in the Manufacturing workbook jumps a cell 1881832 ECW ROLES_PERMISS Adding Users in SSO environment using PS is error prone 1864870 F2B BOM Incomplete BOM report generated 1846578 PCB_LIBRARIAN GRAPHICAL_EDI radio buttons and clickable buttons are hidden in the UI for verify rules 1854080 PCB_LIBRARIAN METADATA con2con needs to support special characters in Primitive Name 1796377 PCB_LIBRARIAN SYMBOL_EDITOR Unable to move pins using arrows when symbol is opened in Symbol Editor 1839692 PCB_LIBRARIAN SYMBOL_EDITOR Properties tab grayed out in Symbol preview window 1865657 PCB_LIBRARIAN SYMBOL_EDITOR Cannot change symbol properties using the General tab 1906888 PCB_LIBRARIAN SYMBOL_EDITOR Properties button in Symbol Pins tab of the Symbols section is inactive. 1891248 PCB_LIBRARIAN SYMBOL_EDITOR Copy and mirror arc drawing object in the new Symbol Editor results in wrong arc on opening symbol in DE-HDL 1908381 PDN_ANALYSIS PCB_STATICIRD Allegro PCB PDN Analysis crashes after performing analysis and saving result in release 17.2-2016 1825087 PSPICE AA_OPT Graph view menu does not appear when we use 'Curve Fit' in Optimizer. 1808091 PSPICE ENVIRONMENT 'orSimSetup' crashes when 'Restart Simulation' is selected 1811782 PSPICE ENVIRONMENT Setup Simulation Profile no longer enables Advanced Markers when appropriate 1834147 PSPICE ENVIRONMENT PSpice Part Search library icons not displayed if product is installed in the Program Files folder in release 17.2-2016 1841992 PSPICE FRONTENDPLUGI Getting a blank Error dialog while adding a marker 1858574 PSPICE NETLISTER PSpice simulation: Some models cannot be used after upgrading to release 17.2-2016 1865022 PSPICE NETLISTER The division operator is not recognized by PSpice in DEV expressions in release 17.2-2016 1677119 PSPICE PROBE PSpice crashes when plotting simulation message summary 1837046 PSPICE PROBE On Windows 10, PSpice crashes on clicking Yes to see message 1879387 PSPICE PROBE PSpice crashes when we choose to plot simulation message summary 1842231 PSPICE SIMULATOR Wrong results in PSpice Advanced Analysis for DC Sweep Analysis 1843446 PSPICE SIMULATOR Distribution type is not showing under Assign Tolerance window for transistor 1872630 RF_PCB ROUTING Transition taper length does not work in route- Add RF trace 1872636 RF_PCB ROUTING Inherit Width parameter in Route -RF trace only uses width of one side 1872644 RF_PCB ROUTING Regression RF trace: change in trace width not retained while routing 1901201 SIP_LAYOUT EXTRACT extracta is not retaining custom layer names 1813380 SIP_LAYOUT OTHER Layer Compare is not adding the required shapes 1852762 SIP_LAYOUT OTHER Error generated in Package Design Integrity Check when adding soldermask to my design 1886847 SIP_LAYOUT REPORTS Incorrect metal area in metal usage report 1491315 SIP_LAYOUT SHAPE Dynamic shape filling exceeds the shape boundary on running 'create bounding shape' command 1853989 SIP_LAYOUT SHAPE 'Shape - Select' and then' Move' from pop-up with ix 500 iy 0 moves shape diagonally 1868509 SPECCTRA PARSER Autorouter takes long time to invoke 1869317 SYSTEMSI ENG_PBA SystemSI PBA does not align correlation waveforms correctly on Linux platform
rom67 вышел хотфикс OrCAD/Allegro 17.2 Nov 2 2016, 21:05 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Dec 13 2016, 20:18 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Jan 9 2017, 13:17 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Jan 23 2017, 17:27 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Feb 13 2017, 18:33 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Feb 19 2017, 18:31 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Mar 5 2017, 19:29 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Mar 27 2017, 18:54 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Apr 10 2017, 19:03 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Apr 12 2017, 21:29 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... May 9 2017, 00:32 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... May 14 2017, 15:16 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... May 22 2017, 21:40 rom67 . May 22 2017, 21:40 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Jun 6 2017, 17:04 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Jun 19 2017, 15:37 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Aug 11 2017, 22:41 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Aug 28 2017, 17:39 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Sep 20 2017, 18:53 alver Кто-нибудь знает, что за новая опция появилась в A... Sep 26 2017, 12:41 Карлсон Может что-то тут есть?
Sep 26 2017, 17:09 alver нет, и официальные партнеры затрудняются сказать. Sep 26 2017, 17:26 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Oct 9 2017, 17:30 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Oct 16 2017, 20:36 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Nov 8 2017, 17:41 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Nov 20 2017, 18:30 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Dec 11 2017, 15:35 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Jan 15 2018, 20:45 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Jan 30 2018, 17:53 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Feb 14 2018, 19:02 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Mar 5 2018, 19:55 rom67 КодFixed CCRs: SPB 17.2 HF035
02-30-2018
=====... Mar 7 2018, 17:11 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Mar 19 2018, 17:17 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Apr 3 2018, 14:46 copov Очень мощное обновление Cadence Allegro Editor и ... May 7 2018, 10:51 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... May 15 2018, 15:36 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... May 29 2018, 21:01 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Jun 19 2018, 07:33 copov Подскажите пожалуйста. После установки OrCAD/Alleg... Jun 22 2018, 08:08 copov Спасибо, сам отвечу. Косяки в символьном редактор... Jun 26 2018, 06:03 PCBtech Цитата(copov @ Jun 26 2018, 09:03) Спасиб... Jul 18 2018, 19:59 copov del Jun 27 2018, 09:23 En_Serg А в известном месте можно взять Hotfix 42.
Такая ж... Jul 18 2018, 07:54 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Jul 18 2018, 21:40 rloc Sigrity 2018 Whats New
https://www.cadence.com/co... Jul 26 2018, 09:01 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Aug 3 2018, 16:27 kudor ВРоде много пишут о фиксах Symbol Editor, а как на... Aug 6 2018, 22:22 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Aug 11 2018, 22:51 Flood Пекут как горячие пирожки
Спасибо! Aug 13 2018, 16:09 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Aug 26 2018, 16:24 rom67 вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: ... Sep 13 2018, 19:54 copov Есть ли смысл выкладывать на FTP?
Hotfix_SPB16.60.... Sep 20 2018, 07:25 Aner QUOTE (copov @ Sep 20 2018, 10:25) Есть л... Sep 20 2018, 07:33 copov Hotfix_SPB16.60.112_wint
upload\PCB\_Cad... Sep 20 2018, 12:01
