> STM32F107RCT6 + ADS1256
remixx
сообщение Apr 11 2018, 04:14
Пользователь №: 93 818
Пытаюсь подключить ADS1256 (АЦП) к 107-мому по SPI .
Схему подключения, настройки МК и SPI, даташит АЦП - приложил.
Ну и собственно сам код:
* @file : main.c
* @brief : Main program body
** This notice applies to any and all portions of this file
* that are not between comment pairs USER CODE BEGIN and
* USER CODE END. Other portions of this file, whether
* inserted by the user or by software development tools
* are owned by their respective copyright owners.
* COPYRIGHT© 2018 STMicroelectronics
* Redistribution and use in source and binary forms, with or without modification,
* are permitted provided that the following conditions are met:
* 1. Redistributions of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright notice,
* this list of conditions and the following disclaimer in the documentation
* and/or other materials provided with the distribution.
* 3. Neither the name of STMicroelectronics nor the names of its contributors
* may be used to endorse or promote products derived from this software
* without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
* CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "stm32f1xx_hal.h"
/* USER CODE BEGIN Includes */
#include "stdio.h"
#include "math.h"
#include <string.h>
#include <errno.h>
#define CS_ON() HAL_GPIO_WritePin(CS_GPIO_Port, CS_Pin, GPIO_PIN_RESET) // Vkluchenie ADC
#define CS_OFF() HAL_GPIO_WritePin(CS_GPIO_Port, CS_Pin, GPIO_PIN_SET) // Vikluchenie ADC
#define ADS_DRDY (HAL_GPIO_ReadPin(DRDY_GPIO_Port, DRDY_Pin)==GPIO_PIN_SET) // Proverka gotovnosti ADC
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
SPI_HandleTypeDef hspi3;
/* USER CODE BEGIN PV */
uint8_t aTxBuffer[1]={0}; // Buffer dlya otpravlyaemih dannih
uint8_t aRxBuffer[3]={0,0,0}; // Buffer dlya prinimaemih dannih
uint32_t result;
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_SPI3_Init(void);
/* USER CODE BEGIN PFP */
/* Funkciya inicializacii ADC */
void ADS1256_Init(void)
CS_ON(); // Aktiviruem ADC
HAL_Delay(100);
aTxBuffer[0]=0xFE; // Ukazivaem adres commandi RESET
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Posilaem komandy RESET (sbrasivaem ADC k defoltnim nastroykam)
HAL_Delay(100);
aTxBuffer[0]=0xFC;// Ukazivaem adres commandi SYNC
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Posilaem komandy SYNC (sinhronizaciya ADC s signalom na vivode SCLK)
aTxBuffer[0]=0x00; // Ukazivaem adres commandi WAKEUP
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Posilaem komandy WAKEUP (v sootvetstvii s datasheet)
aTxBuffer[0]=0x50 | 0x00; // Ukazivaem adress registra s kotorogo nachinaetsa zapis (STATUS)
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Peredaem adress pervogo registra
aTxBuffer[0]=3; // Ukazivaem kolichestvo registrov v kotorie budem zapisivat (zapisivaetsa 1 + TO KOLICHESTVO KOTOROE UKAZIVAEM, V DANOM SLUCHAE POLUCHAETSA 1+3=4)
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Peredaem kolichesto registrov
aTxBuffer[0]=0x04; // Ukazivaem dannie, kotorie neobhodimo zapisat v pervyi registr (STATUS) - ustanavlivaem poryadok chteniya so starshego bayta (MSB), vkluchaem avto-kalibrovky, vikluchaem analogovyi buffer, dubliruem vivod DRDY
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Peredaem dannie v registr STATUS
/* while(ADS_DRDY) {}; // Vozmojno nujno dlya ojidaniya zaversheniya avtokalibrovki */
aTxBuffer[0]=0x00 | 0x01; // Ukazivaem dannie, kotorie neobhodimo zapisat vo vtoroy registr (MUX) - vkluchaem vhod AIN0 kak POSITIVE, AIN1 kak NEGATIVE
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Peredaem dannie v registr MUX
aTxBuffer[0]=0x00; // Ukazivaem dannie, kotorie neobhodimo zapisat v tretyi registr (ADCON) - otkluchaem CLK0/CLK1, otkluchaem datchik opredeleniya istochnika toka, ustanavlivaem vnutrennyi usilitel v 64 raza
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Peredaem dannie v registr ADCON
aTxBuffer[0]=0x82; // Ukazivaem dannie, kotorie neobhodimo zapisat v chetvertyi registr (DRATE) - zadaem skorost raboti ADC (kolichestvo viborok v sekundu), v dannom sluchae 100 SPS
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Peredaem dannie v registr DRATE
HAL_Delay(100); //min=50*(1/fCLKIN)=50*(1/7.68MHZ)=6500ns;max=whatever
CS_OFF(); // Vikluchaem ADC
HAL_Delay(100);
/* Funkciya polucheniya rezultata ODNOGO preobrazovaniya */
uint32_t ADS1256ReadData(void)
uint32_t sum=0;
aTxBuffer[0]=0x01; // Ukazivaem adres commandi READ DATA
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Posilaem komandy READ DATA (chtenie rezultata ODNOGO preobrazovaniya)
HAL_SPI_Receive(&hspi3, (uint8_t*)aRxBuffer, 3, 50); // Schitivaem poluchennyi rezultat (3 bayta)
sum = aRxBuffer[0];
sum = sum << 8; // Poetomy, posle kajdogo poluchennogo bayta provodim smeshenie na 8
sum |= aRxBuffer[1];
sum = sum << 8;
sum |= aRxBuffer[2];
return sum; // Vozvrashaem znachenie poluchennogo rezultata
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* @brief The application entry point.
* @retval None
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration----------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_SPI3_Init();
/* USER CODE BEGIN 2 */
HAL_Delay(100);
ADS1256_Init();
HAL_Delay(100);
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
result = ADS1256ReadData();
while (ADS_DRDY) {}
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
RCC_OscInitTypeDef RCC_OscInitStruct;
RCC_ClkInitTypeDef RCC_ClkInitStruct;
/**Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV5;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.Prediv1Source = RCC_PREDIV1_SOURCE_PLL2;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
RCC_OscInitStruct.PLL2.PLL2State = RCC_PLL2_ON;
RCC_OscInitStruct.PLL2.PLL2MUL = RCC_PLL2_MUL8;
RCC_OscInitStruct.PLL2.HSEPrediv2Value = RCC_HSE_PREDIV2_DIV5;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
_Error_Handler(__FILE__, __LINE__);
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
/**Configure the Systick interrupt time
HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
__HAL_RCC_PLLI2S_ENABLE();
/* SysTick_IRQn interrupt configuration */
HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
/* SPI3 init function */
/* SPI3 parameter configuration*/
hspi3.Instance = SPI3;
hspi3.Init.Mode = SPI_MODE_MASTER;
hspi3.Init.Direction = SPI_DIRECTION_2LINES;
hspi3.Init.DataSize = SPI_DATASIZE_8BIT;
hspi3.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi3.Init.CLKPhase = SPI_PHASE_1EDGE;
hspi3.Init.NSS = SPI_NSS_SOFT;
hspi3.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_32;
hspi3.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi3.Init.TIMode = SPI_TIMODE_DISABLE;
hspi3.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi3.Init.CRCPolynomial = 7;
if (HAL_SPI_Init(&hspi3) != HAL_OK)
/** Configure pins as
* Analog
* Input
* Output
* EVENT_OUT
* EXTI
GPIO_InitTypeDef GPIO_InitStruct;
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOD_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(CS_GPIO_Port, CS_Pin, GPIO_PIN_SET);
/*Configure GPIO pin : DRDY_Pin */
GPIO_InitStruct.Pin = DRDY_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_IT_FALLING;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(DRDY_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pin : CS_Pin */
GPIO_InitStruct.Pin = CS_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
HAL_GPIO_Init(CS_GPIO_Port, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @param file: The file name as string.
* @param line: The line in file as a number.
* @retval None
void _Error_Handler(char *file, int line)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
while(1)
/* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ © COPYRIGHT STMicroelectronics *****END OF FILE****/
В итоге во входной буфер приходят только нулевые значения.
Если посылать команду RDATAC (т.е. выполнять не единичное преобразование, а сделать так, чтобы АЦП постоянно слал 24 бита один за другим), результат такой же.
Не понимаю в чем проблема, не правильная инициализация или схема?
Сообщение отредактировал remixx - Apr 11 2018, 04:16
remixx
сообщение May 7 2018, 08:43
Вернулся к работе, но после всех корректировок так ничего и не изменилось)
Может быть я неправильно настраиваю CPOL и CPHA?
Приложил картинку передачи сигналов из ДШ.
По-моему в настройках SPI нужно устанавливать CPOL - 0, CPHA - 1Edge.
Еще кстати заметил, что в настройках выводов SCK и MOSI заданы как AF, а MISO как Input. А разве MISO не должен тоже задаваться как AF?
Stanislav_S
сообщение May 7 2018, 10:19
извечный пессимист
Из: Днепропетровск
Пользователь №: 21 125
В общем случае надо смотреть такие вещи:
- правильно настроить SPI - режим 1
- очень внимательно прочитать ДШ на АЦП на предмет команд, работы SPI и особенно важно не упустить задержки, коих там много и без их соблюдения нормальной работы не будет!
- выбросить HAL и написать нормально - это самый лучший путь, АЦП достаточно сложный в плане работы (для новичка конечно).
А так могу сказать, что АЦП работает - у меня в текущем проекте их 3 штуки на плате и все прекрасно работает.
Slaves are those of this world
Given freedom to lay chains upon The Master
The wolf is no longer free
Release the chains and come for me
RSS Текстовая версия Сейчас: 21st August 2025 - 10:43
Страница сгенерированна за 0.01386 секунд с 7
