> П-И-регулятор
Sprite
сообщение Jun 11 2018, 08:25
Пользователь №: 37 414
Добрый день всем!
Пишу ПИ-регулятор, требуется профессиональная критика) Камень - cyclone III, использовано 4 аппаратных умножителя.
Код:
module pid
    input     clk,
    input     ena,
    input     signed [15:0] in_ustavka,
    input     signed [15:0] in_fakt,
    input     signed [15:0] Ki,
    input     signed [15:0] Kp,
    input     signed [15:0] out_min,
    input     signed [15:0] out_max,
    output     reg signed [31:0] out
    reg signed [31:0] I_reg;
    reg signed [31:0] F_reg;
    reg signed [31:0] I_prev_reg;
    reg [1:0] F_limits_reg;
    reg [1:0] I_limits_reg;
    reg    [1:0] ena_reg;
    reg    state;
    initial
    begin
        ena_reg = 2'b00;
        I_prev_reg = 31'd1000;
        out = 0;
        state = 1'b0;
    end
    wire ena_risingEdge;
    wire [1:0] w_F_limits;
    wire [1:0] w_I_limits;
    wire signed [31:0] w_F;
    wire signed [31:0] w_I;
    wire signed [31:0] w_P;
    wire signed [15:0] w_err;
    // Front detector
    always @(posedge clk)
    begin
        ena_reg <= {ena_reg[0], ena};
    end
    assign ena_risingEdge = (ena_reg == 2'b01);
    // PID-calculating
    assign w_err = in_ustavka - in_fakt;
    assign w_I = Ki*w_err + I_prev_reg;
    assign w_P = Kp*w_err;
    assign w_F = w_I + w_P;
    assign w_F_limits[0] = (w_F < out_min)? 1'b1 : 1'b0;
    assign w_F_limits[1] = (w_F > out_max)? 1'b1 : 1'b0;
    assign w_I_limits[0] = (w_I < out_min)? 1'b1 : 1'b0;
    assign w_I_limits[1] = (w_I > out_max)? 1'b1 : 1'b0;
    always @ (posedge clk)
    begin
        case (state)
        // Gets I and F values
        1'b0:
            if (ena_risingEdge)
                begin
                    I_reg <= w_I;
                    F_reg <= w_F;
                    I_limits_reg <= w_I_limits;
                    F_limits_reg <= w_F_limits;
                    state <= 1'b1;
                end
            else
                state <= 1'b0;
        // Integral and out limitation
        1'b1:
            begin
                case (F_limits_reg)
                    2'b01:        out <= out_min;
                    2'b10:         out <= out_max;
                    default:    out <= F_reg;
                endcase
                case (I_limits_reg)
                    2'b01:        I_prev_reg <= out_min;
                    2'b10:         I_prev_reg <= out_max;
                    default:    I_prev_reg <= I_reg;
                endcase
                state <= 1'b0;
            end
        default:
            state <= 1'b0;
        endcase
    end
Моделсим:
nice_vladi
сообщение Jun 12 2018, 05:40
Из: Томск
Пользователь №: 93 239
Цитата(Sprite @ Jun 11 2018, 09:25) *
Добрый день всем!
    assign w_I = Ki*w_err + I_prev_reg; // 32 бита = (16 бит * 16 бит) + 32 бита -- возможно переполнение
Всегда дико заморочно следить за разрядностями, но иногда из-за этого все ломается.
А вместо машины на два состояния, которая щелкает каждый такт (если я правильно понял) можно сделать простой однобитный счетчик, который будет по какому-то событию перекидываться 0-1-0-1... мне кажется и лаконичнее и писанины меньше (хотя, наверное, дело религии).
И вместо кейсов на 2-3 состояния красивше писать if-else. Опять же лаконичнее и писанины меньше (но, наверное, это тоже дела религиозные))).
Т.е. получаем вместо:
case (F_limits_reg)
endcase
Что-то вроде:
    if (F_limits_reg == 2'b01)         out <= out_min;
    else if (F_limits_reg == 2'b10)  out <= out_max;
      else                                     out <= F_reg;
Sprite
сообщение Jun 12 2018, 07:50
Спасибо за замечание! Но значение I_prev_reg, а значит и интегральная составляющая (w_I) у меня ограничивается максимальным и минимальным значениями (out_max и out_min), которые имеют разрядность 16 бит, так что криминала быть не должно.
Не совсем понял фразу "щелкает каждый такт", но мысль уловил. Переписал немного добавив регистр (flag):
    reg flag;
    begin
        if (ena_pulse)
            begin
                I_reg <= w_I;
                F_reg <= w_F;
                flag <= 1'b1;
            end
        else if (flag)
        begin
            case (F_limits_reg)
            endcase
            case (I_limits_reg)
            endcase
            flag <= 1'b0;
        end
    end
В чем вообще разница между стэйт-машиной и регистром в данном случае? Что предпочтительнее использовать? Результат симуляции в обоих случаях одинаковый.
RSS Текстовая версия Сейчас: 29th July 2025 - 14:17
Страница сгенерированна за 0.01445 секунд с 7
