> П-И-регулятор
Sprite
сообщение Jun 11 2018, 08:25
Пользователь №: 37 414
Добрый день всем!
Пишу ПИ-регулятор, требуется профессиональная критика) Камень - cyclone III, использовано 4 аппаратных умножителя.
Код:
module pid
    input     clk,
    input     ena,
    input     signed [15:0] in_ustavka,
    input     signed [15:0] in_fakt,
    input     signed [15:0] Ki,
    input     signed [15:0] Kp,
    input     signed [15:0] out_min,
    input     signed [15:0] out_max,
    output     reg signed [31:0] out
    reg signed [31:0] I_reg;
    reg signed [31:0] F_reg;
    reg signed [31:0] I_prev_reg;
    reg [1:0] F_limits_reg;
    reg [1:0] I_limits_reg;
    reg    [1:0] ena_reg;
    reg    state;
    initial
    begin
        ena_reg = 2'b00;
        I_prev_reg = 31'd1000;
        out = 0;
        state = 1'b0;
    end
    wire ena_risingEdge;
    wire [1:0] w_F_limits;
    wire [1:0] w_I_limits;
    wire signed [31:0] w_F;
    wire signed [31:0] w_I;
    wire signed [31:0] w_P;
    wire signed [15:0] w_err;
    // Front detector
    always @(posedge clk)
    begin
        ena_reg <= {ena_reg[0], ena};
    end
    assign ena_risingEdge = (ena_reg == 2'b01);
    // PID-calculating
    assign w_err = in_ustavka - in_fakt;
    assign w_I = Ki*w_err + I_prev_reg;
    assign w_P = Kp*w_err;
    assign w_F = w_I + w_P;
    assign w_F_limits[0] = (w_F < out_min)? 1'b1 : 1'b0;
    assign w_F_limits[1] = (w_F > out_max)? 1'b1 : 1'b0;
    assign w_I_limits[0] = (w_I < out_min)? 1'b1 : 1'b0;
    assign w_I_limits[1] = (w_I > out_max)? 1'b1 : 1'b0;
    always @ (posedge clk)
    begin
        case (state)
        // Gets I and F values
        1'b0:
            if (ena_risingEdge)
                begin
                    I_reg <= w_I;
                    F_reg <= w_F;
                    I_limits_reg <= w_I_limits;
                    F_limits_reg <= w_F_limits;
                    state <= 1'b1;
                end
            else
                state <= 1'b0;
        // Integral and out limitation
        1'b1:
            begin
                case (F_limits_reg)
                    2'b01:        out <= out_min;
                    2'b10:         out <= out_max;
                    default:    out <= F_reg;
                endcase
                case (I_limits_reg)
                    2'b01:        I_prev_reg <= out_min;
                    2'b10:         I_prev_reg <= out_max;
                    default:    I_prev_reg <= I_reg;
                endcase
                state <= 1'b0;
            end
        default:
            state <= 1'b0;
        endcase
    end
Моделсим:
nice_vladi
сообщение Jun 12 2018, 05:40
Из: Томск
Пользователь №: 93 239
Цитата(Sprite @ Jun 11 2018, 09:25) *
Добрый день всем!
    assign w_I = Ki*w_err + I_prev_reg; // 32 бита = (16 бит * 16 бит) + 32 бита -- возможно переполнение
Всегда дико заморочно следить за разрядностями, но иногда из-за этого все ломается.
А вместо машины на два состояния, которая щелкает каждый такт (если я правильно понял) можно сделать простой однобитный счетчик, который будет по какому-то событию перекидываться 0-1-0-1... мне кажется и лаконичнее и писанины меньше (хотя, наверное, дело религии).
И вместо кейсов на 2-3 состояния красивше писать if-else. Опять же лаконичнее и писанины меньше (но, наверное, это тоже дела религиозные))).
Т.е. получаем вместо:
case (F_limits_reg)
endcase
Что-то вроде:
    if (F_limits_reg == 2'b01)         out <= out_min;
    else if (F_limits_reg == 2'b10)  out <= out_max;
      else                                     out <= F_reg;
Flip-fl0p
сообщение Jun 12 2018, 05:53
В поисках себя...
Пользователь №: 77 140
case (F_limits_reg)
endcase
Что-то вроде:
      else                                     out <= F_reg;
Тут Вы сильно заблуждаетесь.
Во втором случае у вас будет совершенно другая схема синтезироваться, в отличии от case.
Вот тут немного написано про это: https://electronics.stackexchange.com/quest...=google_rich_qa
andrew_b
сообщение Jun 12 2018, 11:00
Из: Воронеж
Пользователь №: 1 757
Сами читали, на что сослались? Всё одно сведётся к логической функции нескольких переменных и ляжет в LUT. Результат будет тот же самый. Соревноваться с оптимизирующим компилятором бессмысленно.
Flip-fl0p
сообщение Jun 12 2018, 18:40
В поисках себя...
Тут Вы правы это я немного поспешил. Тут же не приоритетный шифратор. Эх...
Хотя всё-равно считаю, что описывать через case правильнее, с точки зрения стиля написания. Читается проще.
gin
сообщение Jun 14 2018, 07:56
Пользователь №: 61 682
По поводу описания есть еще один не совсем очевидный момент. Не всегда описание, которое принимается синтезатор, может понять симулятор. Иногда при написании кода приходится помнить, что ModelSim понимает не все конструкции (по крайней мере для VHDL так, не знаю как для Verilog).
andrew_b
сообщение Jun 14 2018, 08:08
Из: Воронеж
Я уверен, что вас не затруднит подтвердить слова кодом.
RSS Текстовая версия Сейчас: 19th August 2025 - 06:39
Страница сгенерированна за 0.01433 секунд с 7
