П-И-регулятор |
Jun 11 2018, 08:25
Пользователь №: 37 414
Добрый день всем! Пишу ПИ-регулятор, требуется профессиональная критика) Камень - cyclone III, использовано 4 аппаратных умножителя. Код: Код module pid ( input clk, input ena, input signed [15:0] in_ustavka, input signed [15:0] in_fakt, input signed [15:0] Ki, input signed [15:0] Kp, input signed [15:0] out_min, input signed [15:0] out_max, output reg signed [31:0] out ); reg signed [31:0] I_reg; reg signed [31:0] F_reg; reg signed [31:0] I_prev_reg; reg [1:0] F_limits_reg; reg [1:0] I_limits_reg; reg [1:0] ena_reg;
reg state; initial begin ena_reg = 2'b00; I_prev_reg = 31'd1000; out = 0; state = 1'b0; end wire ena_risingEdge; wire [1:0] w_F_limits; wire [1:0] w_I_limits; wire signed [31:0] w_F; wire signed [31:0] w_I; wire signed [31:0] w_P; wire signed [15:0] w_err;
//--------------------------------- // Front detector //--------------------------------- always @(posedge clk) begin ena_reg <= {ena_reg[0], ena}; end assign ena_risingEdge = (ena_reg == 2'b01);
//--------------------------------- // PID-calculating //--------------------------------- assign w_err = in_ustavka - in_fakt; assign w_I = Ki*w_err + I_prev_reg; assign w_P = Kp*w_err; assign w_F = w_I + w_P; assign w_F_limits[0] = (w_F < out_min)? 1'b1 : 1'b0; assign w_F_limits[1] = (w_F > out_max)? 1'b1 : 1'b0; assign w_I_limits[0] = (w_I < out_min)? 1'b1 : 1'b0; assign w_I_limits[1] = (w_I > out_max)? 1'b1 : 1'b0; always @ (posedge clk) begin case (state) //-------------------------------- // Gets I and F values //-------------------------------- 1'b0: if (ena_risingEdge) begin I_reg <= w_I; F_reg <= w_F; I_limits_reg <= w_I_limits; F_limits_reg <= w_F_limits; state <= 1'b1; end else state <= 1'b0; //-------------------------------- // Integral and out limitation //-------------------------------- 1'b1: begin case (F_limits_reg) 2'b01: out <= out_min; 2'b10: out <= out_max; default: out <= F_reg; endcase case (I_limits_reg) 2'b01: I_prev_reg <= out_min; 2'b10: I_prev_reg <= out_max; default: I_prev_reg <= I_reg; endcase
state <= 1'b0; end //-------------------------------- default: state <= 1'b0; endcase //-------------------------------- end Моделсим:
Jun 12 2018, 05:40
Из: Томск
Пользователь №: 93 239
Цитата(Sprite @ Jun 11 2018, 09:25)  Добрый день всем! Пишу ПИ-регулятор, требуется профессиональная критика) Камень - cyclone III, использовано 4 аппаратных умножителя. На профессионала не потяну, НО Код assign w_I = Ki*w_err + I_prev_reg; // 32 бита = (16 бит * 16 бит) + 32 бита -- возможно переполнение Всегда дико заморочно следить за разрядностями, но иногда из-за этого все ломается. А вместо машины на два состояния, которая щелкает каждый такт (если я правильно понял) можно сделать простой однобитный счетчик, который будет по какому-то событию перекидываться 0-1-0-1... мне кажется и лаконичнее и писанины меньше (хотя, наверное, дело религии). И вместо кейсов на 2-3 состояния красивше писать if-else. Опять же лаконичнее и писанины меньше (но, наверное, это тоже дела религиозные))). Т.е. получаем вместо: Код case (F_limits_reg) 2'b01: out <= out_min; 2'b10: out <= out_max; default: out <= F_reg; endcase Что-то вроде: Код if (F_limits_reg == 2'b01) out <= out_min; else if (F_limits_reg == 2'b10) out <= out_max; else out <= F_reg;
Jun 12 2018, 05:53
В поисках себя...
Пользователь №: 77 140
Цитата(nice_vladi @ Jun 12 2018, 08:40)  И вместо кейсов на 2-3 состояния красивше писать if-else. Опять же лаконичнее и писанины меньше (но, наверное, это тоже дела религиозные))). Т.е. получаем вместо: Код case (F_limits_reg) 2'b01: out <= out_min; 2'b10: out <= out_max; default: out <= F_reg; endcase Что-то вроде: Код if (F_limits_reg == 2'b01) out <= out_min; else if (F_limits_reg == 2'b10) out <= out_max; else out <= F_reg; Тут Вы сильно заблуждаетесь. Во втором случае у вас будет совершенно другая схема синтезироваться, в отличии от case. Вот тут немного написано про это: https://electronics.stackexchange.com/quest...=google_rich_qa
Jun 12 2018, 11:00
Из: Воронеж
Пользователь №: 1 757
Цитата(Flip-fl0p @ Jun 12 2018, 08:53)  Тут Вы сильно заблуждаетесь. Во втором случае у вас будет совершенно другая схема синтезироваться, в отличии от case. Вот тут немного написано про это: https://electronics.stackexchange.com/quest...=google_rich_qaСами читали, на что сослались? Всё одно сведётся к логической функции нескольких переменных и ляжет в LUT. Результат будет тот же самый. Соревноваться с оптимизирующим компилятором бессмысленно.
Jun 12 2018, 18:40
В поисках себя...
Цитата(andrew_b @ Jun 12 2018, 14:00)  Сами читали, на что сослались? Основной смысл - в картинках Цитата Результат будет тот же самый. Соревноваться с оптимизирующим компилятором бессмысленно. Тут Вы правы это я немного поспешил. Тут же не приоритетный шифратор. Эх... Хотя всё-равно считаю, что описывать через case правильнее, с точки зрения стиля написания. Читается проще.
Jun 14 2018, 07:56
Пользователь №: 61 682
Цитата(Flip-fl0p @ Jun 12 2018, 21:40)  Основной смысл - в картинках Тут Вы правы это я немного поспешил. Тут же не приоритетный шифратор. Эх... Хотя всё-равно считаю, что описывать через case правильнее, с точки зрения стиля написания. Читается проще. По поводу описания есть еще один не совсем очевидный момент. Не всегда описание, которое принимается синтезатор, может понять симулятор. Иногда при написании кода приходится помнить, что ModelSim понимает не все конструкции (по крайней мере для VHDL так, не знаю как для Verilog).
Jun 14 2018, 08:22
Цитата(andrew_b @ Jun 14 2018, 11:08)  Я уверен, что вас не затруднит подтвердить слова кодом. На память могу ошибиться. но вот как щас помню объявляем сигнал: Код signal cnt : natural range 0 to 5 затем его используем в каком-нить процессе: Код if (cnt = cnt'high) then Квартус это проглатывал, а вот Modelsim ругался. Версию моделсима щас уже не вспомню Так же моделсим вот на такую контсрукцию ругается Код case? <expression> is when <constant_expression> => -- Sequential Statement(s) when <constant_expression> => -- Sequential Statement(s) when others => -- Sequential Statement(s) end case?;
Jun 14 2018, 09:32
Из: Воронеж
Цитата(gin @ Jun 14 2018, 11:22)  На память могу ошибиться. но вот как щас помню объявляем сигнал: Код signal cnt : natural range 0 to 5 затем его используем в каком-нить процессе: Код if (cnt = cnt'high) then Квартус это проглатывал, а вот Modelsim ругался. Я тоже на такое натыкался, но лень было выяснять, Моделсим тут прав или нет. Я просто ввёл новый тип. Цитата Так же моделсим вот на такую контсрукцию ругается Код case? <expression> is when <constant_expression> => -- Sequential Statement(s) when <constant_expression> => -- Sequential Statement(s) when others => -- Sequential Statement(s) end case?; Про vhdl'2008 почти ничего не знаю.
Jun 14 2018, 13:19
Цитата(andrew_b @ Jun 14 2018, 12:32)  Я тоже на такое натыкался, но лень было выяснять, Моделсим тут прав или нет. Я просто ввёл новый тип.
Про vhdl'2008 почти ничего не знаю. Моделсим его частично поддерживает, по крайней мере в версии 10.2 Там даже отдельный technote есть с описанием того, что и как поддерживается для vhdl2008 Цитата(andrew_b @ Jun 14 2018, 15:09)  Во-первых, я не вижe там какого-то особого профита. А кто виноват? Вот-вот, синтезатор или не полностью его поддерживает. Или может совсем не поддерживать (в случае, если вы пишете код для АСИКа). А '93 поддерживают все. В 2008 стандарте есть удобные фишки, тот же список чувствительности процесса можно задать как Код process(all) И case удобно применять для описания приоритетного шифратора. Жизнь упрощает, хотя конечно же и без всего этого можно
Sprite П-И-регулятор Jun 11 2018, 08:25 Flip-fl0p Цитата(Sprite @ Jun 11 2018, 11:25)
Пони... Jun 11 2018, 17:28        Flip-fl0p Цитата(andrew_b @ Jun 14 2018, 12:32) Про... Jun 14 2018, 10:23         andrew_b Цитата(Flip-fl0p @ Jun 14 2018, 13:2... Jun 14 2018, 12:09         andrew_b Цитата(gin @ Jun 14 2018, 16:19) В 2008 с... Jun 14 2018, 13:54 Sprite Цитата(nice_vladi @ Jun 12 2018, 12:40) К... Jun 12 2018, 07:50 Nieve Использование "case" предпочтительнее (к... Jun 12 2018, 07:02
