Aug 23 2018, 05:55
Пользователь №: 92 691
Вот что написано у меня в файле xc2s300e.bsd: entity generated_xc2s300e is
generic (PHYSICAL_PIN_MAP : string := "X_PACKAGE");
port (TCK: in bit; TDI: in bit; TDO: out bit; TMS: in bit);
use STD_1149_1_2001.all; attribute Component_Conformance of xc2s300e : entity is "STD_1149_1_2001";
attribute PIN_MAP of xc2s300e : entity is PHYSICAL_PIN_MAP;
constant X_PACKAGE:PIN_MAP_STRING := "TCK : 1," & "TDI : 2," & "TDO : 3," & "TMS : 4"; attribute Tap_Scan_In of TDI: signal is true; attribute Tap_Scan_Mode of TMS: signal is true; attribute Tap_Scan_Out of TDO: signal is true; attribute Tap_Scan_Clock of TCK: signal is (1.0e06, BOTH);
attribute Instruction_Length of xc2s300e: entity is 2; attribute Instruction_Opcode of xc2s300e: entity is "BYPASS (11)"; attribute Instruction_Capture of xc2s300e: entity is "01"; attribute Boundary_Length of xc2s300e: entity is 1; attribute Boundary_Register of xc2s300e: entity is "0 (BC_1, *, control, 0)";
end xc2s300e;
Не пойму где тут указан ID? В файл .svf у меня вообще ничего не пишется, он пуст.
Прошу прощения .svf не пустой...
// Created using Xilinx iMPACT Software [ISE - 9.2i] TRST OFF; ENDIR IDLE; ENDDR IDLE; STATE RESET; STATE IDLE; FREQUENCY 1E6 HZ; TIR 0 ; HIR 0 ; TDR 0 ; HDR 0 ; TIR 0 ; HIR 0 ; HDR 0 ; TDR 0 ; TIR 0 ; HIR 0 ; TDR 0 ; HDR 0 ; TIR 0 ; HIR 0 ; TDR 0 ; HDR 0 ; TIR 0 ; HIR 0 ; HDR 0 ; TDR 0 ;
MPetrovich Не шьётся Spartan2 Aug 20 2018, 14:25 MegaVolt Цитата(MPetrovich @ Aug 20 2018, 17:25) В... Aug 20 2018, 14:34 MPetrovich Цитата(MegaVolt @ Aug 20 2018, 14:34) Нап... Aug 21 2018, 05:25  serj1979 Цитата(MPetrovich @ Aug 21 2018, 08:25) i... Aug 21 2018, 06:44   MPetrovich Цитата(serj1979 @ Aug 21 2018, 06:44) Мож... Aug 21 2018, 07:05    serj1979 Цитата(MPetrovich @ Aug 21 2018, 10:05) Н... Aug 21 2018, 07:22     MPetrovich Цитата(serj1979 @ Aug 21 2018, 07:22) Кон... Aug 21 2018, 07:44    makc Цитата(MPetrovich @ Aug 21 2018, 10:05) С... Aug 21 2018, 10:44     MPetrovich Цитата(makc @ Aug 21 2018, 10:44) У Вас е... Aug 21 2018, 11:54      makc Цитата(MPetrovich @ Aug 21 2018, 14:54) Р... Aug 21 2018, 12:02      _4afc_ Цитата(MPetrovich @ Aug 21 2018, 15:54) А... Aug 21 2018, 12:24    _4afc_ Цитата(MPetrovich @ Aug 21 2018, 11:05) Н... Aug 21 2018, 11:28  Jury093 Цитата(MPetrovich @ Aug 21 2018, 08:25) П... Aug 21 2018, 06:55 iosifk Цитата(MPetrovich @ Aug 20 2018, 17:25) п... Aug 20 2018, 14:40 MPetrovich Цитатав XAPP058 есть фраза:
Есть))) Специально про... Aug 21 2018, 12:34 serj1979 Цитата(MPetrovich @ Aug 21 2018, 15:34) П... Aug 21 2018, 12:55 makc Цитата(MPetrovich @ Aug 21 2018, 15:34) Е... Aug 22 2018, 04:11  MPetrovich
Прикрепил фото сигналов JTAG на осциллографе. Све... Aug 22 2018, 13:16   iosifk Цитата(MPetrovich @ Aug 22 2018, 16:16) П... Aug 22 2018, 13:22   makc Цитата(MPetrovich @ Aug 22 2018, 16:16) П... Aug 23 2018, 06:20 MPetrovich Шью Impactом. Программатор до этой ПЛИСины (пару н... Aug 21 2018, 14:12 iosifk Цитата(MPetrovich @ Aug 21 2018, 17:12) Ш... Aug 22 2018, 07:33 vladec В моей практике раньше случались такие проблемы пр... Aug 22 2018, 06:16 Yuri124 Можно попробовать сигналы TCK, TDI, TDO от програм... Aug 22 2018, 07:25 MPetrovich ЦитатаПопробуйте найти в программе программатора т... Aug 22 2018, 13:42 iosifk Цитата(MPetrovich @ Aug 22 2018, 16:42) Э... Aug 22 2018, 14:11 MPetrovich В моем случае: Operation -> Initialize Chain
Оп... Aug 22 2018, 14:21 iosifk Цитата(MPetrovich @ Aug 22 2018, 17:21) А... Aug 22 2018, 15:06 MPetrovich ЦитатаБанк 2 тоже запитан от 3,3 В?
Да
ЦитатаНе зн... Aug 23 2018, 06:28 makc Цитата(MPetrovich @ Aug 23 2018, 09:28) А... Aug 23 2018, 07:05 MPetrovich Пересобрал по схеме Slave Serial - всё шьётся влё... Aug 23 2018, 08:32
