Цитата(-=A.N.G.E.R=- @ Jan 9 2007, 14:11)
Не судите строго, перехожу на IAR (по отзывам наибелее используемый) с AtmanAVR.
Подскажите, кто чем формирует стартовый код для проекта (на C, C++) в IAR, оччень надо.
Руками.
_EXTERN_C char __low_level_init() {
/* Add your custom setup here. */
PORTD = (0<<7)|(0<<6)|(0<<5)|(0<<4)|(0<<3)|(0<<2)|(1<<1)|(1<<0); //Tx = high, pull-ups on inputs
DDRD = (1<<7)|(1<<6)|(1<<5)|(1<<4)|(1<<3)|(1<<2)|(0<<1)|(0<<0);
PORTC = (0<<6)|(0<<5)|(0<<4)|(0<<3)|(0<<2)|(0<<1)|(0<<0);
DDRC = (1<<6)|(1<<5)|(1<<4)|(1<<3)|(1<<2)|(1<<1)|(1<<0);
PORTB = (0<<7)|(0<<6)|(1<<5)|(1<<4)|(1<<3)|(0<<2)|(0<<1)|(0<<0); // turn on pull-up on MANUAL_PROG
UBRRH = ((unsigned)(OSC / (8.0 * RS_BAUDRATE) - 0.5) >> 8) & 0x0F;
UBRRL = ((unsigned)(OSC / (8.0 * RS_BAUDRATE) - 0.5) >> 0) & 0xFF;
UCSRA = (1<<U2X);
// UCSRB = (1<<RXCIE)|(0<<TXCIE)|(0<<UDRIE)|(1<<RXEN)|(1<<TXEN)|(0<<UCSZ2);
UCSRC = (1<<URSEL)|(0<<UMSEL)|(0<<UPM1)|(0<<UPM0)|(0<<USBS)|(1<<UCSZ1)|(1<<UCSZ0);
TCCR0 = (1<<CS02)|(0<<CS01)|(0<<CS00); // OSC / 256
TCCR1A = (0<<COM1A1)|(0<<COM1A0)|(1<<COM1B1)|(0<<COM1B0)|(0<<WGM11)|(0<<WGM10);
TCCR1B = (0<<ICNC1)|(0<<ICES1)|(1<<WGM13)|(0<<WGM12)|(0<<CS12)|(0<<CS11)|(1<<CS10);
ICR1 = OSC / 64000UL / 2;
OCR1B = 0;//OSC / 64000UL / 2 * 3.2 / 5;
TIMSK = (0<<OCIE2)|(0<<TOIE2)|(0<<TICIE1)|(0<<OCIE1A)|(0<<OCIE1B)|(0<<TOIE1)|(1<<TOIE0);
SPCR = (0<<SPIE)|(0<<SPE)|(0<<DORD)|(0<<MSTR)|(0<<CPOL)|(0<<CPHA)|(0<<SPR1)|(0<<SPR0);
SPSR = (0<<SPI2X);
/* Return 1 to indicate that normal segment */
/* initialization should be performed. If */
/* normal segment initialization should not */
/* be performed, return 0. */
return 1;
_END_EXTERN_C
