программа упр. светодиодами, нужно небольшое изменение кода пр-ммы |
Feb 8 2007, 01:20
Пользователь №: 25 153
Братцы, звиняйте за длинный листинг это прога для 16ф84, который управляет мерцанием 8 светодиодов. треба понизить скорость мерцания. отблагодарю пивом или например денег на сотовый подброшу. надо для одного проекта. все работает, но надо помедленнее. CODE title "flash" ; Program title June 2002 W equ 00H ; Destination is W-Register F equ 01H ; Destination is F-Register ; Operational Register File INDF equ 00H ; indf Data addressing TMR0 equ 01H ; Real Time Clock/Counter Register PCL equ 02H ; Program counter STATUS equ 03H ; Status Word Register FSR equ 04H ; File Select Register PORTA equ 05H ;inputs PORTB equ 06H ;outputs PCLATH equ 0AH INTCON equ 0BH ;gp files from 0Ch (68 files) ; OPTION_REG equ 081H TRISA equ 085H TRISB equ 086H ; PERIOD equ 0CH HOLD equ 0DH SHIFT equ 0EH TEMP1 equ 0FH TEMP2 equ 010H STORE equ 011H TEMPLIM equ 012H MODFAC equ 013H ; STORE2 equ 014H WREG equ 020H ;8 working regs INDX equ 030H ;array index (8locs) ; INPUT equ PORTA OUTPUT equ PORTB ; ;=========================================================================== ;Subroutines ;=========================================================================== org 00H goto main_start ;start of main program ; getmark btfsc input,4 ;check which array goto otherone clrf pclath movf indf,W addwf PCL, F retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H ;10 retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H ;20 retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H ;30 retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 02H retlw 02H retlw 02H retlw 02H retlw 02H ;40 retlw 03H retlw 03H retlw 03H retlw 03H retlw 04H retlw 04H retlw 04H retlw 05H retlw 05H retlw 06H retlw 06H retlw 07H ;50 retlw 07H retlw 08H retlw 08H retlw 09H retlw 09H retlw 0AH retlw 0AH retlw 0BH retlw 0BH retlw 0CH ;60 retlw 0CH retlw 0DH retlw 0DH retlw 0EH retlw 0EH retlw 0FH retlw 0FH retlw 010H retlw 011H retlw 012H ;70 retlw 013H retlw 014H retlw 016H retlw 018H retlw 01AH retlw 01CH retlw 01EH retlw 020H retlw 024H retlw 028H ;80 retlw 02CH retlw 030H retlw 038H retlw 040H retlw 048H retlw 050H retlw 058H retlw 060H retlw 068H retlw 070H ;90 retlw 080H retlw 090H retlw 0A0H retlw 0B0H retlw 0C0H retlw 0D0H retlw 0F0H retlw 0FFH ;100 retlw 0F0H retlw 0D0H retlw 0C0H retlw 0B0H retlw 0A0H retlw 090H retlw 080H retlw 070H ;110 retlw 068H retlw 060H retlw 058H retlw 050H retlw 048H retlw 040H retlw 038H retlw 030H retlw 02CH retlw 028H ;120 retlw 024H retlw 020H retlw 01EH retlw 01CH retlw 01AH retlw 018H retlw 016H retlw 014H retlw 012H retlw 010H ;130 retlw 0FH retlw 0FH retlw 0EH retlw 0EH retlw 0DH retlw 0DH retlw 0CH retlw 0CH retlw 0BH retlw 0BH ;140 retlw 0AH retlw 0AH retlw 09H retlw 09H retlw 08H retlw 08H retlw 07H retlw 07H retlw 06H retlw 06H ;150 retlw 05H retlw 05H retlw 04H retlw 04H retlw 04H retlw 03H retlw 03H retlw 03H retlw 03H retlw 02H retlw 02H retlw 02H ;160 retlw 02H retlw 02H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H ;170 retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H ;180 retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H ;190 retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H ;200 retlw 01H retlw 01H ; getlim clrf pclath ;get index limit and modofy call lim ;accordong to modfac.This gives movwf store ;the number of /2's movf modfac,W ;div factor (+1) movwf store2 bcf status,0 ;clear carry rlf store,F ;limit *2 divlim rrf store,F ;index lim /2 decfsz store2,F ;this determines the no of div by 2's goto divlim movf store,W ;modified index limit movwf templim ;save for lower limit addlw D'100' return ; lim addwf PCL, F ;index limits retlw D'76' retlw D'80' retlw D'84' retlw D'88' retlw D'92' retlw D'96' retlw D'100' retlw D'72' ; resetlim movf templim,W sublw D'99' ;w = 100 - lim movwf indf return ;with start value in W ; speed clrf pclath addwf PCL,F retlw 01H ;for 00 switch setting, port a b0,b1 retlw 04H ; 10 retlw 02H ; 01 retlw 08H ; 11 ; getmod clrf pclath addwf PCL,F retlw 08H retlw 010H retlw 018H retlw 020H org 0100H ;================================================================= ;Main programme ;================================================================= main_start clrf output clrf input bsf status, 5 clrf TRISB ;set port b to o/p movlw 0FFH movwf TRISA ;set port a to i/p movlw 080H movwf option_reg bcf status, 5 ; movlw 08H ;set all array indexes to 0 movwf temp2 movlw indx movwf FSR clearindx clrf indf incf FSR,F decfsz temp2,F goto clearindx ; outer movlw 03H ;read speed switches andwf input,W ;mask off other switches call speed ;repititions of mark/space movwf hold ;for each array value btfsc input,4 incf hold,F ; movlw B'00001100' ;get modulation factor andwf input,W movwf modfac bcf status,0 ;clear carry rrf modfac,F rrf modfac,F ;shift mod to ls bits movf modfac,W addwf hold,F ;modify speed if <100% mod incf modfac,F ;1=/1div, 2=/2, etc ;-------------------------------------------------------------------------- ;Put array values into working regs opmark movlw 01H ;counter for 8 values movwf shift movlw wreg ;working reg movwf temp1 ;save address movlw indx ;index movwf temp2 ;save address loadmark movf temp2, W ;index addr movwf FSR call getmark ;get mark from array movwf store movf temp1, W ;addr for wreg movwf FSR movf store, W movwf indf incf temp1, F ;next working reg incf temp2, F ;next array index rlf shift, F ;b7 into carry ? btfss status, 0 ;temp1,2 set to 9th loc on exit goto loadmark ;but lost anyway ;exit with c=1 ;-------------------------------------------------------------------------- ;Output one mark/space for all 8 outputs movlw 0FFH ;inner loop. Mark is already movwf period ;loaded into work reg domark movlw wreg ;space is 255-mark movwf FSR ;base address movlw 01H ;keeps track of 8 working regs movwf shift ;and use to set/clear o/p bits bcf status,0 ;clear carry opbits decfsz indf, F ;decrement mark goto setbit ;if >0 comf shift, W ;space if 0 andwf output, F ;set output pin lo incf indf, F ;restore to 1 for next loop goto nextbit setbit movf shift, W iorwf output, F ;set pin hi nextbit incf FSR, F ;next working reg rlf shift, F ;working reg tracker btfss status, 0 ;all 8 wregs done if c=1 goto opbits ;care! 9th indirect reg has been ;incremented decfsz period, F goto domark ;exit with c=1 ;-------------------------------------------------------------------------- ;Repeat to control speed decfsz hold, F ;repeat mark/space o/p goto opmark ;to control speed ;-------------------------------------------------------------------------- ;Check the size of indexes movlw 01H ;check if indexes have reached movwf shift ;their limits clrf temp1 ;no. of index, 0-7 movlw indx ;index base address movwf FSR indlim movf temp1, W ;offset call getlim ;limit for this offset subwf indf, W ;W = indf-W btfsc status, 0 ;c=1 for 0 or +ve result call resetlim ;i.e. limit reached incf indf, F ;increment current index incf temp1, F ;o/s for next limit incf FSR, F ;next array index rlf shift, F ;8 indexes done ? btfss status,0 goto indlim ;exit with c=1 ;indx value set to 1 if cleared goto outer ;next mark/space ; ;----------------------------------------------------------------------------- org 0200H otherone movlw 02H movwf pclath movf indf,W addwf PCL, F retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H ;10 retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H ;20 retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H ;30 retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H ;40 retlw 01H retlw 01H retlw 01H retlw 02H retlw 02H retlw 01H retlw 01H retlw 03H retlw 03H retlw 01H retlw 01H retlw 04H ;50 retlw 06H retlw 01H retlw 01H retlw 08H retlw 0AH retlw 01H retlw 01H retlw 0EH retlw 010H retlw 01H ;60 retlw 01H retlw 012H retlw 014H retlw 01H retlw 01H retlw 016H retlw 018H retlw 01H retlw 01H retlw 01AH ;70 retlw 01CH retlw 01H retlw 01H retlw 020H retlw 024H retlw 01H retlw 01H retlw 028H retlw 030H retlw 01H ;80 retlw 01H retlw 038H retlw 040H retlw 01H retlw 01H retlw 060H retlw 080H retlw 01H retlw 01H retlw 0A0H ;90 ; retlw 0C0H retlw 01H retlw 01H retlw 0D0H retlw 0E0H retlw 01H ; retlw 01H retlw 0FFH ;100 retlw 0FFH ; retlw 01H retlw 01H retlw 0E0H retlw 0D0H retlw 01H retlw 01H ; retlw 0C0H ;110 retlw 0A0H retlw 01H retlw 01H retlw 080H retlw 060H retlw 01H retlw 01H retlw 040H retlw 038H retlw 01H ;120 retlw 01H retlw 030H retlw 028H retlw 01H retlw 01H retlw 024H retlw 020H retlw 01H retlw 01H retlw 01CH ;130 retlw 01AH retlw 01H retlw 01H retlw 018H retlw 014H retlw 01H retlw 01H retlw 012H retlw 010H retlw 01H ;140 retlw 01H retlw 0EH retlw 0CH retlw 01H retlw 01H retlw 0AH retlw 08H retlw 01H retlw 01H retlw 06H ;150 retlw 04H retlw 01H retlw 01H retlw 03H retlw 03H retlw 01H retlw 01H retlw 02H retlw 02H retlw 01H retlw 01H retlw 01H ;160 retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H ;170 retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H ;180 retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H ;190 retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H retlw 01H ;200 retlw 01H retlw 01H end
Сообщение отредактировал Doka - Feb 10 2007, 12:18
Feb 9 2007, 23:00
Пользователь №: 23 498
Цитата(poke @ Feb 8 2007, 02:20)  Братцы, звиняйте за длинный листинг это прога для 16ф84, который управляет мерцанием 8 светодиодов. треба понизить скорость мерцания. отблагодарю пивом или например денег на сотовый подброшу. надо для одного проекта. все работает, но надо помедленнее. млин, стока читать... проще написать по - новой на 628 .. смени кварц...
Feb 9 2007, 23:40
Цитата(urry1 @ Feb 9 2007, 23:00)  Цитата(poke @ Feb 8 2007, 02:20)  Братцы, звиняйте за длинный листинг это прога для 16ф84, который управляет мерцанием 8 светодиодов. треба понизить скорость мерцания. отблагодарю пивом или например денег на сотовый подброшу. надо для одного проекта. все работает, но надо помедленнее.
млин, стока читать... проще написать по - новой на 628 .. смени кварц...  censored... а че, на пониженной будет работать? там на 20мгц кварц стоит..
Сообщение отредактировал Doka - Feb 10 2007, 12:19
Feb 10 2007, 10:57
Цитата(poke @ Feb 10 2007, 00:40)  Цитата(urry1 @ Feb 9 2007, 23:00)  Цитата(poke @ Feb 8 2007, 02:20)  Братцы, звиняйте за длинный листинг это прога для 16ф84, который управляет мерцанием 8 светодиодов. треба понизить скорость мерцания. отблагодарю пивом или например денег на сотовый подброшу. надо для одного проекта. все работает, но надо помедленнее.
млин, стока читать... проще написать по - новой на 628 .. смени кварц...  хуивознаит... а че, на пониженной будет работать? там на 20мгц кварц стоит.. будет
poke программа упр. светодиодами Feb 8 2007, 01:20  DL36 Цитата(poke @ Feb 10 2007, 00:40) хуивозн... Feb 10 2007, 11:43  poke Цитата(poke @ Feb 9 2007, 23:40) Цитата(u... Feb 10 2007, 11:49 VXDRV Конфиг не забудте поменять с HS на XT при смене кв... Feb 10 2007, 12:08 Doka hint: для длинных листингов не забываем юзать таги... Feb 10 2007, 12:20 poke понял. спасибо. да, про хт забыл.
про 628 с 4мгц-... Feb 10 2007, 12:36 VXDRV Да в пять раз медленнее. Feb 10 2007, 14:54 usawal Есть способ с программной задержкой.
Из себя это п... Feb 20 2007, 02:07 poke С кварцем на десять мгц нормально работает, частот... Feb 20 2007, 10:33 urry1 Цитата(poke @ Feb 20 2007, 11:33) С кварц... Feb 20 2007, 10:36
