itoa на asm, из темы "51 vs AVR"... |
Nov 13 2007, 23:19
дятел
Из: Питер
Пользователь №: 17 065
Цитата(mse @ Nov 3 2007, 23:51)  itoa от =AVR= ;О) Кто быстрее? CODE ;-------------------------------------------------------------------- ; Converts an unsigned integer r5:r4 to a 5-character ASCII string [x] ; 58 program words, 73 clocks + ret itoa: .equ rev10k= 429497; ~= 2^32/10000
clr r2
ldi r16,low(rev10k) ldi r17,high(rev10k) ldi r18,byte3(rev10k)
mul r4,r16 mov r6,r1 mul r4,r17 add r6,r0 adc r1,r2 mov r7,r1 mul r4,r18 add r7,r0 adc r1,r2 mov r8,r1; r8r7r6 ~= Xlsb*429497/256, 06872B max
mul r5,r16 add r6,r0 adc r7,r1 adc r8,r2 mul r5,r17 add r7,r0 adc r8,r1 mul r5,r18 add r8,r0; r8r7 ~= int2fract(X%10000) ldi r17,'0' adc r1,r17; r1 = ASCII(X/10000)
st x+,r1; Tens of thousands ;-------------------------------------------------------------------- ; Converts fractional 16-bit value in r5:r4 (0..9999) range ; to a 4-character ASCII string [x] ; by sequential multiplication by 10 fractoa: ldi r16,10; Constant for multiplication by 10
sec ; Correct int2fract result to fit in 16-bit word adc r7,r2; by incrementing it adc r8,r2;
mul r7,r16; Multiply a 16-bit value by 10 movw r2,r0; mul r8,r16; add r3,r0; r3r2 ~= int2fract(X%1000) adc r1,r17; r1 = ASCII(X/1000) st x+,r1; Thousands
mul r2,r16; Same as above for hundreds movw r4,r0 mul r3,r16 add r5,r0 adc r1,r17 st x+,r1
mul r4,r16; Same as above for tens movw r2,r0 mul r5,r16 add r3,r0 adc r1,r17 st x+,r1
mul r2,r16; Same as above for units movw r4,r0 mul r3,r16 add r5,r0 adc r1,r17 st x+,r1
ret
Ну я быстрее...  Чиста редактируем код многоуважаемого =AVR=  CODE ;-------------------------------------------------------------------- ; Converts an unsigned integer r5:r4 to a 5-character ASCII string [x] ; 56 program words, 71 clocks + ret itoa: .equ rev10k= 429497; ~= 2^32/10000
clr r3
mul r4,r16 mov r6,r1 mul r4,r17 add r6,r0 adc r1,r3 mov r7,r1 mul r4,r18 add r7,r0 adc r1,r3 mov r8,r1; r8r7r6 ~= Xlsb*429497/256, 06872B max
mul r5,r16 add r6,r0 adc r7,r1 adc r8,r3 mul r5,r17 add r7,r0 adc r8,r1 mul r5,r18 add r8,r0; r8r7 ~= int2fract(X%10000) ldi r17,'0' adc r1,r17; r1 = ASCII(X/10000)
mul r7,r16; Multiply a 16-bit value by 10 movw r2,r0 mul r8,r16 add r2,r16 adc r3,r0 adc r1,r17 st x+,r1
mul r2,r16 movw r4,r0 mul r3,r16 add r5,r0 adc r1,r17 st x+,r1
mul r4,r16 movw r2,r0 mul r5,r16 add r3,r0 adc r1,r17 st x+,r1
ret
Итого: - 2слова, -2такта Кстати, думаю что еще пару-тройку слов/тактов можно еще скушать... Но это в следующий раз, когда мозк потребует деятельности... P.S. Просьба не флеймить и высказываться только по существу...
Nov 14 2007, 17:52
Ambidexter
Из: Oxford, UK
Пользователь №: 18 282
Цитата(singlskv @ Nov 13 2007, 23:19)  Ну я быстрее...  Чиста редактируем код многоуважаемого =AVR=  Итого: - 2слова, -2такта Кстати, думаю что еще пару-тройку слов/тактов можно еще скушать... Но это в следующий раз, когда мозк потребует деятельности... P.S. Просьба не флеймить и высказываться только по существу... Если заменить фрагмент кода =AVR=, который вычисляет количество десятков тысяч, на нижеприведённый код (до метки fractoa), а остальное оставить, то можно уменьшить время выполнения, по крайней мере на 4 такта, в среднем ещё больше. Код, тупо вычитающий десятки тысяч (макс.29, мин.10, в среднем 20) Код bin1: subi res0,0x10 ; sbci res1,0x27 ; brpl bin2 ; ldi temp,0x30 ;digit 0 subi res0,0xF0 ; sbci res1,0xD8 ; rjmp eo1e4 ; bin2: subi res0,0x10 ; sbci res1,0x27 ; brpl bin3 ; ldi temp,0x31 ;digit 1 subi res0,0xF0 ; sbci res1,0xD8 ; rjmp eo1e4 ; bin3: subi res0,0x10 ; sbci res1,0x27 ; brpl bin4 ; ldi temp,0x32 ;digit 2 subi res0,0xF0 ; sbci res1,0xD8 ; rjmp eo1e4 ; bin4: subi res0,0x10 ; sbci res1,0x27 ; brpl bin5 ; ldi temp,0x33 ;digit 3 subi res0,0xF0 ; sbci res1,0xD8 ; rjmp eo1e4 ; bin5: sbci res0,0x10 ; sbci res1,0x27 ; brpl bin6 ; ldi temp,0x34 ;digit 4 subi res0,0xF0 ; sbci res1,0xD8 ; rjmp eo1e4 ; bin6: subi res0,0x10 ; sbci res1,0x27 ; brpl bin7 ; ldi temp,0x35 ;digit 5 subi res0,0xF0 ; sbci res1,0xD8 ; rjmp eo1e4 ; bin7: ldi temp,0x36 ;digit 6 eo1e4: st x+,temp ;
Nov 15 2007, 01:41
дятел
Из: Питер
Цитата(=GM= @ Nov 14 2007, 20:52)  Если заменить фрагмент кода =AVR=, который вычисляет количество десятков тысяч, на нижеприведённый код (до метки fractoa), а остальное оставить, то можно уменьшить время выполнения, по крайней мере на 4 такта, в среднем ещё больше. Код, тупо вычитающий десятки тысяч (макс.29, мин.10, в среднем 20) Код ................ brpl bin2 ; ............... brpl bin3 ; ................ Наверное все-таки нужно brsh а не brpl ? Ну и тактов по максимуму там 30 а не 29  Ну а если уже заниматься вычитаниями, то тогда так: Код bin1_1: subi res0,0x40 ;-40000 sbci res1,0x9C brsh bin1_3 subi res0,0xE0 ;+20000 sbci res1,0xB1 brsh bin1_2 ldi temp,0x30 subi res0,0xF0 ;+10000 sbci res1,0xD8 brlo bin1_5 ldi temp,0x31 rjmp bin1_6 bin1_2: ldi temp,0x32 subi res0,0x10 ;-10000 sbci res1,0x27 brlo bin1_5 ldi temp,0x33 rjmp bin1_6 bin1_3: subi res0,0x20 ;-20000 sbci res1,0x4E brsh bin1_4 ldi temp,0x34 subi res0,0xF0 ;+10000 sbci res1,0xD8 brlo bin1_5 ldi temp,0x35 rjmp bin1_6 bin1_4: ldi temp,0x36 rjmp bin1_6 bin1_5: subi res0,0xF0 ;+10000 sbci res1,0xD8 bin1_6: st x+,temp Такты: min 13, max 16, среднее типа 15
Nov 15 2007, 11:22
Ambidexter
Из: Oxford, UK
Цитата(singlskv @ Nov 15 2007, 01:41)  Наверное все-таки нужно brsh а не brpl? Ну а если уже заниматься вычитаниями, то тогда так:Такты: min 13, max 16, среднее типа 15  Удивительно, как это разным людям приходят в голову одинаковые мысли(:-). GM version singlskv versionКод grant1: subi res0,0x40 grant1: subi res0,0x40 ;-40000 sbci res1,0x9C sbci res1,0x9C brsh grant3 brsh grant3 subi res0,0xE0 subi res0,0xE0 ;+20000 sbci res1,0xB1 sbci res1,0xB1 brsh grant2 brsh grant2 ldi temp,0x30 ldi temp,0x30 subi res0,0xF0 subi res0,0xF0 ;+10000 sbci res1,0xD8 sbci res1,0xD8 brlo grant5 brlo grant5 ldi temp,0x31 rjmp grant4 rjmp grant6 grant2: ldi temp,0x32 grant2: ldi temp,0x32 subi res0,0x10 subi res0,0x10 ;-10000 sbci res1,0x27 sbci res1,0x27 brlo grant5 brlo grant5 ldi temp,0x33 rjmp grant4 rjmp grant6 grant3: ldi temp,0x36 subi res0,0x20 grant3: subi res0,0x20 ;-20000 sbci res1,0x4E sbci res1,0x4E brsh grant6 brsh grant4 ldi temp,0x34 ldi temp,0x34 subi res0,0xF0 subi res0,0xF0 ;+10000 sbci res1,0xD8 sbci res1,0xD8 brlo grant5 brlo grant5 grant4: inc temp ldi temp,0x35 rjmp grant6 rjmp grant6 grant4: ldi temp,0x36 rjmp grant6 grant5: subi res0,0xF0 grant5: subi res0,0xF0 ;+10000 sbci res1,0xD8 sbci res1,0xD8 grant6: st x+,temp grant6: st x+,temp Примерно такая штука стоит у меня в конвертере 24 бита в азки. Разница только в размере кода, у меня короче на 3 слова. Да, удивительно, и подозрительно...Вас на какой фабрике программировали(:-)?
Nov 15 2007, 16:50
дятел
Из: Питер
Цитата(=GM= @ Nov 15 2007, 14:22)  GM version singlskv versionКод ........................................ Примерно такая штука стоит у меня в конвертере 24 бита в азки. Разница только в размере кода, у меня короче на 3 слова. Все правильно, у меня был точно такой же код как и у Вас, а потом я стал уранивать длительности выполнения по разным веткам чтобы уменьшить максимум, ну и заодно среднее чуть уменьшилось. Такты по разным веткам GM version singlskv versionКод 15 15 17 15 16 16 18 16 17 16 17 16 11 13 правда код конечно вырос. Цитата Да, удивительно, и подозрительно...Вас на какой фабрике программировали(:-)?
Nov 16 2007, 18:09
дятел
Из: Питер
Цитата(=GM= @ Nov 16 2007, 02:39)  mse, время исполнения исходного кода =АВР= улучшено на 17+2=19 тактов, или на 26%. =GM= , здесь Вы слегка поспешили, в коде =AVR=, промежуточный результат получается как значение 0-9999 нормализованное до 0-0xFFFF, и после этого можно выполнять домножение на 10 и на каждом шаге получать новый разряд. Для того чтобы нормализовать диапозон 0-9999 в 0-0xFFFF нужно 10-13тактов, так что реальная экономия всего 6-8 тактов, те ~10%. Цитата(=GM= @ Nov 16 2007, 14:13)  To singlskv Вот ещё свёрнутый фрагмент кода. По-своему тоже красиво. Код binasc: ldi temp,0x2F ; binas1: inc temp ;10000 stage subi res0,0x10 ; sbci res1,0x27 ; brsh binas1 ; subi res0,0xF0 ; sbci res1,0xD8 ; st x+,temp ; У меня так: Код binasc: ldi temp,0x36 subi res0,0x60 sbci res1,0xEA brsh binasc2 binasc1: dec temp subi res0,0xF0 sbci res1,0xD8 brlo binasc2 binasc2: st x+,temp все по тем же причинам...
singlskv itoa на asm Nov 13 2007, 23:19 =AVR= ЦитатаКстати, думаю что еще пару-тройку слов/такто... Nov 13 2007, 23:50 singlskv Цитата(=AVR= @ Nov 14 2007, 02:50) А вот ... Nov 14 2007, 00:05  Прохожий Цитата(singlskv @ Nov 14 2007, 03:05) Дык... Nov 14 2007, 00:18 =AVR= А пожалуйста:
Код;-------------------------------... Nov 14 2007, 00:20 singlskv Цитата(=AVR= @ Nov 14 2007, 03:20) А пожа... Nov 14 2007, 00:35     mse Цитата(=GM= @ Nov 16 2007, 02:39) Чёта =m... Nov 16 2007, 07:30      =GM= Цитата(mse @ Nov 16 2007, 07:30) И то, вс... Nov 16 2007, 11:13       mse Цитата(=GM= @ Nov 16 2007, 14:13) To mse
... Nov 16 2007, 12:20        =GM= Цитата(mse @ Nov 16 2007, 12:20) Не, щас ... Nov 16 2007, 17:20      singlskv Цитата(mse @ Nov 16 2007, 10:30) И то, вс... Nov 16 2007, 22:04 SasaVitebsk А если пофлеймить, то это выглядит так. Данная про... Nov 14 2007, 20:20 =AVR= Данная процедура в моих изделиях (и в тысячах и ты... Nov 14 2007, 20:49 SasaVitebsk Тогда извиняюсь. Но "в сотни раз" это уж... Nov 14 2007, 21:57 =AVR= Кажется, такой вариант приводил ник AD(?) на Телес... Nov 15 2007, 08:52 singlskv Цитата(=AVR= @ Nov 15 2007, 11:52) Кажетс... Nov 15 2007, 09:08 =AVR= Внесу ясность. Как я уже отметил выше, мой код был... Nov 16 2007, 05:56 ae_ Цитата(singlskv @ Nov 17 2007, 03:09) ...... Nov 17 2007, 01:57
