> SCAN-CHAINS
-=Vitaly=-
сообщение Jan 14 2008, 07:25
Пользователь №: 19 991
Здравствуйте!
Хочу сгенерировать скан-цепочки типа multiplexed_flip_flip в DC.
Есть 2 вопросика.
1. У меня в дизайне есть клок CLK, он же будет использоваться для скан-цепочки.
это опция -clock_mixing no_mux?
2. На что влияет опция -methodology например full_scan?
Спасибо!
grigorik
сообщение Jan 14 2008, 10:04
Из: ARM
Пользователь №: 10 424
Цитата(-=Vitaly=- @ Jan 14 2008, 11:25) *
Здравствуйте!
Есть 2 вопросика.
Спасибо!
-clock_mixing don't have option "no_mux" the right is no_mix.
no_mix is the default: and it means that all cells must be clocked by the same edge of the same clock. You have one clock if all triggers are working with the same egdes you have no problem.
Otherwies if you want both types of triggers (rise edge and fall edge) to be included in scan chain use "-clock_mixing mix_edges".
This is from user guide:
In the full-scan methodology, DFT Compiler replaces all sequential cells in your design with their scannable equivalents during scan insertion.
If a sequential cell cannot be made scannable because of test design rule violations or because you have explicitly excluded the cell from the scan chain, DFT Compiler classifies the cell as a black box sequential cell during test design rule checking. Black box sequential cells lower fault coverage results. See “Scan Design Techniques” for more information on sequential cell classifications.
Because it is a more predictable methodology, full scan typically provides higher fault coverage in a shorter period of time than partial scan. Full scan also provides improved diagnostic capabilities compared to partial scan.
Because full scan substitutes scannable equivalents for all sequential cells, however, it increases design area and decreases design performance. Integration with synthesis minimizes the area and performance impact of full scan. In most cases, performance can be maintained in a full-scan design, but at the cost of additional area.
Maybe it will help you.
G.
- -=Vitaly=-   SCAN-CHAINS   Jan 14 2008, 07:25
|- - -=Vitaly=-   Спасибо, помогло. А если в исходном верилоге зало...   Jan 14 2008, 10:35
|- - -=Vitaly=-   Делюсь простеньким скриптом, может кому надо: Ко...   Jan 14 2008, 12:06
|- - grigorik   Цитата(-=Vitaly=- @ Jan 14 2008, 14...   Jan 15 2008, 09:31
|- - -=Vitaly=-   Цитата(grigorik @ Jan 15 2008, 11:31) да,...   Jan 15 2008, 14:15
|- - grigorik   Цитата(-=Vitaly=- @ Jan 15 2008, 18...   Jan 15 2008, 15:02
|- - -=Vitaly=-   Цитата(grigorik @ Jan 15 2008, 17:02) пос...   Jan 15 2008, 16:12
|- - -=Vitaly=-   Может кто-то может выложить в закрома толковые док...   Jan 16 2008, 07:54
||- - -=Vitaly=-   Мини вопрос по Formality. Когда он проверяет гейт...   Jan 16 2008, 09:05
||- - -=Vitaly=-   Все вроде разобрался для дизайна который выше я сд...   Jan 16 2008, 14:16
||- - grigorik   Огромное спасибо grigorik . Единственное что та...   Jan 16 2008, 19:58
||- - yes   Цитата(-=Vitaly=- @ Jan 16 2008, 17...   Jan 21 2008, 12:33
||- - -=Vitaly=-   Цитата(yes @ Jan 21 2008, 15:33) может я ...   Jan 21 2008, 20:45
||- - yes   Цитата(-=Vitaly=- @ Jan 21 2008, 23...   Jan 23 2008, 12:19
||- - -=Vitaly=-   Цитата(yes @ Jan 23 2008, 14:19) не предс...   Jan 24 2008, 07:12
||- - yes   Цитата(-=Vitaly=- @ Jan 24 2008, 10...   Jan 24 2008, 16:42
||- - -=Vitaly=-   Цитата(yes @ Jan 24 2008, 18:42) бэкендов...   Jan 24 2008, 20:24
||- - grigorik   Цитата(-=Vitaly=- @ Jan 25 2008, 00...   Jan 29 2008, 07:51
||- - -=Vitaly=-   Делюсь скриптом для автоматической генерации скан-...   Jan 31 2008, 08:58
|- - grigorik   думаю из-за этой части casex(SCAN_EN) 1'b...   Jan 16 2008, 09:35
|- - -=Vitaly=-   Цитата(grigorik @ Jan 16 2008, 11:35) дум...   Jan 16 2008, 09:41
|- - -=Vitaly=-   Цитата(-=Vitaly=- @ Jan 16 2008, 11...   Jan 16 2008, 11:00
- - KMC   ЦитатаМожет кто-то может выложить в закрома толков...   Jan 18 2008, 09:36
RSS Текстовая версия Сейчас: 3rd August 2025 - 12:08
