MEMMAP = 2; на LPC2146 |
Jan 15 2008, 11:38
Пользователь №: 32 484
Здравствуйте, код ниже работает с MEMMAP = 1 и не работает с MEMMAP = 2 (переключается препроцессором). Может, я какую мелочь упустил? Спасибо. Код #include <iolpc2146.h> #include <intrinsics.h>
#define BIT_(x) (1 << (x))
namespace { unsigned const DBG_PIN = 24; }
enum vec_id_t { VEC_RESET = 0, VEC_UNDEF = 1, VEC_SWI = 2, VEC_PREFETCH = 3, VEC_DATA_ABORT = 4, VEC_RESERVED__ = 5, VEC_IRQ = 6, VEC_FIQ = 7, VEC_TOTAL_NUM = 8 };
#define MEMMAP_OPTION (1)
#if 1 == MEMMAP_OPTION #define VIC_ISR __irq __arm #else #pragma location=0x40000000 __no_init unsigned intvec[VEC_TOTAL_NUM * 2]; #define VIC_ISR #endif
VIC_ISR void irq_timer(void); VIC_ISR void non_vectored_handler(void);
extern "C" __irq __arm void reset_handler(void) {} extern "C" __irq __arm void undef_handler(void) {} extern "C" __irq __arm void swi_handler(void) {} extern "C" __irq __arm void prefetch_handler(void) {} extern "C" __irq __arm void data_handler(void) {} extern "C" __irq __arm void fiq_handler(void) {}
#if 2 == MEMMAP_OPTION __irq __arm void irq_handler(void) { typedef void (VIC_ISR * handler_t)(void); handler_t h = reinterpret_cast<handler_t>(VICVectAddr); (*h)(); } #endif
void hw_init(void) { PCON = 0; PCONP = BIT_(1);
VPBDIV = 1; MAMCR = 0; MAMTIM = 2; MAMCR = 2; MEMMAP = MEMMAP_OPTION; #if 2 == MEMMAP_OPTION for (unsigned i = 0; i < VEC_TOTAL_NUM; ++i) { intvec[i] = 0x18F09FE5; // ldr pc, [pc, #24]; } intvec[VEC_TOTAL_NUM + VEC_RESET] = reinterpret_cast<unsigned>(&reset_handler); intvec[VEC_TOTAL_NUM + VEC_UNDEF] = reinterpret_cast<unsigned>(&undef_handler); intvec[VEC_TOTAL_NUM + VEC_SWI] = reinterpret_cast<unsigned>(&swi_handler); intvec[VEC_TOTAL_NUM + VEC_PREFETCH] = reinterpret_cast<unsigned>(&prefetch_handler); intvec[VEC_TOTAL_NUM + VEC_DATA_ABORT] = reinterpret_cast<unsigned>(&data_handler); intvec[VEC_TOTAL_NUM + VEC_IRQ] = reinterpret_cast<unsigned>(&irq_handler); intvec[VEC_TOTAL_NUM + VEC_FIQ] = reinterpret_cast<unsigned>(&fiq_handler); #endif
VICSoftIntClear = ~0; VICIntEnClear = ~0; VICIntSelect = 0;
VICVectAddr0 = reinterpret_cast<unsigned long>(&irq_timer); VICVectCntl0 = 4 + BIT_(5); VICIntSelect &= ~BIT_(4); VICDefVectAddr = reinterpret_cast<unsigned long>(&non_vectored_handler);
VICIntEnable = BIT_(4);
VICProtection = 1; VICVectAddr = 0;
T0IR = 0xFF; T0TCR = BIT_(0) + BIT_(1); T0CTCR = 0; T0PR = 0; T0PC = 0; T0MCR = 0; T0CCR = 0; T0EMR = 0; T0TCR = BIT_(0); SCS = BIT_(1); PINSEL2 &= ~BIT_(3); FIO1DIR |= BIT_(DBG_PIN); }
namespace { unsigned const TIMER_TICK = 20000000 / 1000; }
void start(void) { T0MR0 = T0TC + TIMER_TICK; T0MCR_bit.MR0INT = 1; __enable_interrupt(); }
int main(void) { hw_init(); start(); while (true) {} }
VIC_ISR void irq_timer(void) { T0MR0 += TIMER_TICK; FIO1PIN ^= BIT_(DBG_PIN); T0IR = T0IR; VICVectAddr = 0; }
VIC_ISR void non_vectored_handler(void) { VICVectAddr = 0; }
Jan 15 2008, 11:58
Цитата(alexander55 @ Jan 15 2008, 14:53)  Для отладки в RAM кроме MEMMAP=2, нужно перестроить распределение памяти для линкера. Идей кроме как сдвинуть нижнюю границу RAM - нет. -DRAMSTART=40000040 -DRAMEND=40007FFF Не работает. Да и не используются у меня в этом фрагменте нижние адреса RAM.
Сообщение отредактировал meister - Jan 15 2008, 12:12
Jan 15 2008, 13:03
Цитата(alexander55 @ Jan 15 2008, 15:48)  А что с ROM ? -DROMSTART=00000040 -DROMEND=0003FFFF -Z(CODE)INTVEC=00-3F -Z(CODE)ICODE,DIFUNCT=ROMSTART-ROMEND -Z(CODE)SWITAB=ROMSTART-ROMEND -Z(CODE)CODE=ROMSTART-ROMEND -Z(CONST)CODE_ID=ROMSTART-ROMEND -Z(CONST)INITTAB,DATA_ID,DATA_C=ROMSTART-ROMEND -Z(CONST)CHECKSUM=ROMSTART-ROMEND Но это же должно быть абсолютно без разницы, раз уж работает с MEMMAP = 1 - только место, откуда будут браться вектора прерываний изменится. Вот это у меня точно правильно? Код intvec[i] = 0x18F09FE5; // ldr pc, [pc, #24];
Jan 15 2008, 13:40
Бывалый
Пользователь №: 29 615
Цитата(meister @ Jan 15 2008, 16:03)  -DROMSTART=00000040 -DROMEND=0003FFFF Сделайте так. -DROMSTART=0 -DROMEND=0
Jan 15 2008, 13:53
Цитата(alexander55 @ Jan 15 2008, 16:40)  Сделайте так. -DROMSTART=0 -DROMEND=0 В общем-то ожидаемо: Building configuration: memmap2 - Debug Updating build tree... entry.cpp Linking Error[e16]: Segment ICODE (size: 0xec align: 0x2) is too long for segment definition. At least 0xec more bytes needed. The problem occurred while processing the segment placement command "-Z(CODE)ICODE,DIFUNCT=ROMSTART-ROMEND", where at the moment of placement the available memory ranges were "-none-" Reserved ranges relevant to this placement: 0-1f INTVEC Total number of errors: 1 Total number of warnings: 0
Jan 15 2008, 14:16
Бывалый
Цитата(meister @ Jan 15 2008, 16:53)  У Вас жалуется линкер на ICODE. Рекомендую посмотреть примерчик для размещения в RAM и сделать по аналогии. М.б. -Z(CODE)INTVEC=40000000-4000003f
Jan 15 2008, 18:56
Из: Рига, Латвия
Пользователь №: 17 095
Цитата(meister @ Jan 15 2008, 18:25)  Вся разница этих двух режимов - откуда процессор будет вынимать байты. На самом деле разницы никакой - он во обоих случаях берет байты из нулевых адресов. Отражен туда кусочек ОЗУ или нет - для него не важно. Посмотрите вот этот проект - мне удалось сделать выбор флеш/ОЗУ выбором скрипта линкера и скрипта отладчика (.mac). Исходники идентичны для обоих случаев.
На любой вопрос даю любой ответ"Write code that is guaranteed to work, not code that doesn’t seem to break" ( C++ FAQ)
