TWI в sam7s |
Jan 29 2008, 17:11
Из: Красноярск
Пользователь №: 30 600
Впервые для себя запускаю TWI на sam7s. Использована атмеловская lib_twi Запись Код int AT91F_TWI_WriteSingle(const AT91PS_TWI pTwi, int SlaveAddr, char *data) { unsigned int end = 0, status, err=0;
/* Enable Master Mode */ // AT91C_BASE_TWI->TWI_CR = AT91C_TWI_MSEN;
/* Set the TWI Master Mode Register */ AT91C_BASE_TWI->TWI_MMR = (SlaveAddr<<16 ) & ~AT91C_TWI_MREAD;
/* Write the data to send into THR. Start conditionn DADDR and R/W bit are sent automatically */ AT91C_BASE_TWI->TWI_THR = *data; AT91C_BASE_TWI->TWI_CR = AT91C_TWI_START;
/* NACK errata handling */ /* Do not poll the TWI_SR */ /* Wait 3 x 9 TWCK pulse (max) 2 if IADRR not used, before reading TWI_SR */ /* From 400Khz down to 1Khz, the time to wait will be in µs range.*/ /* In this example the TWI period is 1/400KHz */ AT91F_TWI_WaitMicroSecond (40);
while (!end) { status = AT91C_BASE_TWI->TWI_SR; if ((status & AT91C_TWI_NACK) == AT91C_TWI_NACK) { err++; end=1; } /* Wait for the Transmit ready is set */ if ((status & AT91C_TWI_TXRDY) == AT91C_TWI_TXRDY) end=1; } AT91C_BASE_TWI->TWI_CR = AT91C_TWI_STOP; /* Wait for the Transmit complete is set */ status = AT91C_BASE_TWI->TWI_SR; while (!(status & AT91C_TWI_TXCOMP)) status = AT91C_BASE_TWI->TWI_SR;
return err; } Инициализация (вызывается для 100кГц) Код void AT91F_TWI_Open(int TwiClock) { /* Configure TWI PIOs */ AT91F_TWI_CfgPIO ();
/* Configure PMC by enabling TWI clock */ AT91F_TWI_CfgPMC ();
/* Reset the TWI */ AT91C_BASE_TWI->TWI_CR = AT91C_TWI_SWRST;
/* Configure TWI in master mode */ AT91F_TWI_Configure (AT91C_BASE_TWI);
/* Set TWI Clock Waveform Generator Register */ //AT91C_BASE_TWI->TWI_CWGR=0x047575; AT91F_SetTwiClock(TwiClock); } Расчёт делителей Код void AT91F_SetTwiClock(int TwiClock) { unsigned int cldiv,ckdiv=1;
/* CLDIV = ((Tlow x 2^CKDIV) -3) x Tmck */ /* CHDIV = ((THigh x 2^CKDIV) -3) x Tmck */ /* Only CLDIV is computed since CLDIV = CHDIV (50% duty cycle) */ cldiv = ( (MCK/(2*TwiClock))-3 ) / pow(2,ckdiv); while ( cldiv> 255 ) { ckdiv++; cldiv = ( (MCK/(2*TwiClock))-3 ) / pow(2,ckdiv);
} AT91C_BASE_TWI->TWI_CWGR =(ckdiv<<16)|((unsigned int)cldiv << 8)|(unsigned int)cldiv; } Проблема в том, что процедура передачи просто виснит, очевидно не получая из статус регистра TXRDY. TWI инициализирован приведённой выше процедурой. Я не ошибаюсь, считая, что "железные" проблемы никак не влияют на работу модуля внутри? Пока не идёт речи о корректности передачи, лишь о факте того, что статус регистр не ведёт себя должным образом. Есть ли вероятность что модуль битый напрочь?
Jan 30 2008, 13:16
Из: Свердловск
Пользователь №: 25 269
Я на TWI вешал 24LC256 подтягивал 2к Привожу свой код Кварц 16МГц работал на частоте квалца , без ФАПЧ Код //============================================================================== // Функция : AT91F_SetTwiClock // Описание : // входные параметры : // выходные параметры : //============================================================================== void AT91F_SetTwiClock(void) { int sclock;
/* Here, CKDIV = 1 and CHDIV=CLDIV ==> CLDIV = CHDIV = 1/4*((Fmclk/FTWI) -6)*/
sclock = (10*MCK /AT91C_TWI_CLOCK); if (sclock % 10 >= 5) sclock = (sclock /10) - 5; else sclock = (sclock /10)- 6; sclock = (sclock + (4 - sclock %4)) >> 2; // div 4
AT91C_BASE_TWI->TWI_CWGR = ( 1<<16 ) | (sclock << 8) | sclock; } //============================================================================== // Функция : AT91F_TWI_Open // Описание : // входные параметры : // выходные параметры : //============================================================================== void AT91F_TWI_Open(void) { AT91F_TWI_CfgPIO(); // configure TWI PIOs AT91F_TWI_CfgPMC(); // enable clock TWI AT91F_TWI_Configure (AT91C_BASE_TWI); // configure in MASTER mode AT91F_SetTwiClock(); } //============================================================================== // Функция : AT91F_TWI_WriteByte // Описание : // входные параметры : // выходные параметры : //============================================================================== int AT91F_TWI_WriteByte(const AT91PS_TWI pTwi ,int mode, int int_address, char *data2send, int nb) { unsigned int status,counter=0,error=0;
// Set TWI Internal Address Register if ((mode & AT91C_TWI_IADRSZ) != 0) pTwi->TWI_IADR = int_address;
// Set the TWI Master Mode Register pTwi->TWI_MMR = mode & ~AT91C_TWI_MREAD; if(nb <2) { pTwi->TWI_CR = AT91C_TWI_START | AT91C_TWI_MSEN | AT91C_TWI_STOP; pTwi->TWI_THR = *data2send; } else { // Set the TWI Master Mode Register for(counter=0;counter<nb;counter++) { pTwi->TWI_CR = AT91C_TWI_START | AT91C_TWI_MSEN; if (counter == (nb - 1)) pTwi->TWI_CR = AT91C_TWI_STOP; status = pTwi->TWI_SR; if ((status & ERROR) == ERROR) error++; while (!(status & AT91C_TWI_TXRDY)) { status = pTwi->TWI_SR; if ((status & ERROR) == ERROR) error++; } pTwi->TWI_THR = *(data2send+counter); } } status = pTwi->TWI_SR; if ((status & ERROR) == ERROR) error++; while (!(status & AT91C_TWI_TXCOMP)) { status = pTwi->TWI_SR; if ((status & ERROR) == ERROR) error++; } return error; } //============================================================================== // Функция : AT91F_TWI_ReadByte // Описание : // входные параметры : // выходные параметры : //============================================================================== int AT91F_TWI_ReadByte(const AT91PS_TWI pTwi ,int mode, int int_address, char *data, int nb) { unsigned int status,counter=0,error=0;
// Set the TWI Master Mode Register pTwi->TWI_MMR = mode | AT91C_TWI_MREAD;
// Start transfer if (nb == 1) { pTwi->TWI_CR = AT91C_TWI_START | AT91C_TWI_STOP; status = pTwi->TWI_SR; if ((status & ERROR) == ERROR) error++; while (!(status & AT91C_TWI_TXCOMP)) { status = pTwi->TWI_SR; if ((status & ERROR) == ERROR) error++; } *(data) = pTwi->TWI_RHR; } else { pTwi->TWI_CR = AT91C_TWI_START | AT91C_TWI_MSEN; status = pTwi->TWI_SR; if ((status & ERROR) == ERROR) error++;
// Wait transfer is finished while (!(status & AT91C_TWI_TXCOMP)) { status = pTwi->TWI_SR; if ((status & ERROR )== ERROR) error++; if(status & AT91C_TWI_RXRDY) { *(data+counter++) = pTwi->TWI_RHR; if (counter == (nb - 1)) pTwi->TWI_CR = AT91C_TWI_STOP; } } } return 0; } //============================================================================== // Функция : // Описание : // входные параметры : // выходные параметры : //============================================================================== void TWI_ReadByte(const AT91PS_TWI pTwi ,int mode, char *data, int nb) { unsigned int status,counter=0; // Set TWI Internal Address Register // without internal address ?????? //if ((mode & AT91C_TWI_IADRSZ) != 0) pTwi->TWI_IADR = int_address;
// Set the TWI Master Mode Register // Use MS 7 bits as mode ?????? pTwi->TWI_MMR = mode | AT91C_TWI_MREAD;
// Start transfer if (nb == 1) { pTwi->TWI_CR = AT91C_TWI_START | AT91C_TWI_STOP; status = pTwi->TWI_SR; //if ((status & ERROR) == ERROR) error++; while (!(status & AT91C_TWI_TXCOMP)); *(data) = pTwi->TWI_RHR; } else { pTwi->TWI_CR = AT91C_TWI_START | AT91C_TWI_MSEN; status = pTwi->TWI_SR; // Wait transfer is finished while (!(status & AT91C_TWI_TXCOMP)) { AT91F_DBGU_Printk("\n\rTEST_AT91F_TWI_ReadByte_1"); if(status & AT91C_TWI_RXRDY) { *(data+counter++) = pTwi->TWI_RHR; AT91F_DBGU_Printk("\n\rTEST_AT91F_TWI_ReadByte_2"); if (counter == (nb - 1)) pTwi->TWI_CR = AT91C_TWI_STOP; //AT91F_DBGU_Printk("\n\rTEST_AT91F_TWI_ReadByte_3"); } } } }
Сообщение отредактировал Хомяк - Jan 30 2008, 13:18
Feb 4 2008, 18:30
Из: Кишинев
Пользователь №: 15 025
Цитата(Goofy @ Feb 1 2008, 07:03)  Проблема решилась. При отсутствии устройства на шине по запрашиваемому адресу, цикл виснит. Буду вводить таймауты. Какое-то время назад тут уже подымалась тема TWI. Тема для меня больная, но повторяться не буду, только выводы: Хотите иметь надежное устройство- делайте софтовый TWI. Чтобы Ваше устройство работало так, как хотите Вы и не зависало от каждой иголки на шине. Подчеркну, это мой личный выстраданный опыт, никому свое мнение навязывать не буду. Причем это я на других АРМах грыз (AT91RM9200). Но "чуйствую", что уши у проблемы те же.
Goofy TWI в sam7s Jan 29 2008, 17:11 Хомяк Запускал TWI на AT91SAM7A3 проблем не было.
Но у м... Jan 30 2008, 04:06 Goofy Цитата(Хомяк @ Jan 30 2008, 11:06) Запуск... Jan 30 2008, 05:27  gladov Сразу бросается в глаза, что Вы делаете при переда... Jan 30 2008, 10:49   Goofy Цитата(gladov @ Jan 30 2008, 17:49) Сразу... Jan 30 2008, 11:20    gladov Цитата(Goofy @ Jan 30 2008, 14:20) Принуд... Jan 30 2008, 12:44     Goofy Цитата(gladov @ Jan 30 2008, 19:44) А 100... Jan 30 2008, 12:52   cebotor Цитата(gladov @ Jan 30 2008, 13:49) Влияе... Feb 7 2008, 11:58   Terrabyte всё будет хорошо господа! читайте документ:
h... Feb 7 2008, 11:09    singlskv Цитата(Terrabyte @ Feb 7 2008, 15:09) всё... Apr 6 2008, 21:27 pan_oleg вот у меня такая ситуация, на STM32 не может сгене... Apr 4 2008, 11:40 aaarrr ИМХО, TWI на SAM7 все же неработоспособен. У меня ... Apr 7 2008, 05:02 Goofy Цитата(aaarrr @ Apr 7 2008, 13:02) ИМХО, ... Apr 24 2008, 12:23  aaarrr Цитата(Goofy @ Apr 24 2008, 16:23) А могл... Apr 24 2008, 12:35   Goofy Цитата(aaarrr @ Apr 24 2008, 20:35) Что т... Apr 24 2008, 12:43    aaarrr Цитата(Goofy @ Apr 24 2008, 16:43) До как... Apr 24 2008, 12:49 defunct Цитата(aaarrr @ Apr 7 2008, 08:02) ИМХО, ... Jun 16 2008, 22:41 sonycman Цитата(aaarrr @ Apr 7 2008, 09:02) ИМХО, ... Jun 19 2008, 12:11  aaarrr Цитата(sonycman @ Jun 19 2008, 16:11) Да ... Jun 19 2008, 12:28 JeDay Работал с TWI в SAM7SE. Проблемы которые были в SA... Apr 8 2008, 10:06 aaarrr Да, исправляют потихоньку. Еще выпущен SAM9261S - ... Apr 8 2008, 10:31 aaarrr Плохо давили, значит. Не верю
С 24-ми и у меня р... Jun 16 2008, 23:01 singlskv Цитата(aaarrr @ Jun 17 2008, 02:01) Плохо... Jan 12 2010, 23:10  aaarrr Не вижу смысла программно реанимировать откровенно... Jan 12 2010, 23:50   singlskv Цитата(aaarrr @ Jan 13 2010, 02:50) Не ви... Jan 13 2010, 10:08    Terrabyte Цитата(singlskv @ Jan 13 2010, 13:08) Вся... Jan 6 2014, 11:07  EugenB2 Цитата(singlskv @ Jan 13 2010, 01:10) А в... Jan 16 2010, 08:10 defunct Да вроде нормально давил ;>
Попробовал фокус с ... Jun 17 2008, 01:54 sonycman Хм, что-же, приму к сведению, когда буду пробовать... Jun 19 2008, 14:34 ЕшТ И снова TWI в AT91SAM7S256. Это нормально, что ста... Jul 4 2008, 00:51  ЕшТ товарищи, у кого нибудь вообще тви аппаратный рабо... Sep 3 2008, 23:09   DmitryM Цитата(ЕшТ @ Sep 4 2008, 03:09) товарищи,... Sep 4 2008, 06:06 aaarrr Выше посмотреть не пробовали? Sep 4 2008, 05:51
