FreeBSD на AT91RM9200 |
Feb 17 2008, 17:19
Пользователь №: 6 426
Доброго времени суток всем! Поискал по форуму о запуске FreeBSD на AT91RM9200 и ничего не нашел, поэтому решил открыть ветку. С недавних пор вожусь з запуском FreeBSD на RM9200. Код KB9202(www.kwikbyte.com) Auto boot.. 0x0 : m 42 53 44 0 0 1[E] 0x1 : ip 206 168 13 194[E] 0x2 : server_ip 206 168 13 207[E] 0x3 : tftp 0x20000000 kernel.bin[E] 0x4 : e 0x20000000[E] 0x5 : [E] 0x6 : [E] 0x7 : [E] 0x8 : [E] 0x9 : |?[E]
>m 42 53 44 0 0 1
>ip 206 168 13 194
>tftp 0x20000000 kernel.bin tftp: 2497948 byte
>e 0x20000000 KDB: debugger backends: ddb KDB: current backend: ddb Copyright (c) 1992-2008 The FreeBSD Project. Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 The Regents of the University of California. All rights reserved. FreeBSD is a registered trademark of The FreeBSD Foundation. FreeBSD 7.0-RC2 #2: Fri Feb 15 10:14:59 EET 2008 root@:/usr/obj/arm/usr/src/sys/KB920X CPU: ARM920T rev 0 (ARM9TDMI core) DC enabled IC enabled WB enabled LABT 16KB/32B 64-way Instruction cache 16KB/32B 64-way write-back-locking-A Data cache real memory = 33554432 (32 MB) avail memory = 29450240 (28 MB) atmelarm0: <AT91 device bus> on motherboard at91_st0: <ST> mem 0xdffffd00-0xdffffdff irq 1 on atmelarm0 at91_st0: watchdog registered, timeout intervall max. 64 sec at91_pio0: <PIOA> mem 0xdffff400-0xdffff5ff irq 1 on atmelarm0 at91_pio0: ABSR: 0x60 OSR: 0 PSR:0x138001f ODSR: 0 at91_pio0: [FILTER] at91_pio1: <PIOB> mem 0xdffff600-0xdffff7ff irq 1 on atmelarm0 at91_pio1: ABSR: 0xff300 OSR: 0 PSR:0x3fc00cff ODSR: 0 at91_pio1: [FILTER] at91_pio2: <PIOC> mem 0xdffff800-0xdffff9ff irq 1 on atmelarm0 at91_pio2: ABSR: 0 OSR: 0x1c0000 PSR:0xffffc07f ODSR: 0x180000 at91_pio2: [FILTER] at91_pio3: <PIOD> mem 0xdffffa00-0xdffffbff irq 1 on atmelarm: 0 PSR:0xfffffff ODSR: 0 at91_pio3: [FILTER] at91_pmc0: <PMC> mem 0xdffffc00-0xdffffcff irq 1 on atmelarm0 at91_pmc0: Primary: 10000000 Hz PLLA: 180 MHz CPU: 180 MHz MCK: 60 MHz at91_mci0: <MCI mmc/sd host bridge> mem 0xdffb4000-0xdffb7fff irq 10 on atmelarm0 at91_mci0: [ITHREAD] mmc0: <mmc/sd bus> on at91_mci0 at91_twi0: <TWI> mem 0xdffb8000-0xdffbbfff irq 12 on atmelarm0 at91_twi0: [ITHREAD] iicbus0: <Philips I2C bus> on at91_twi0 setting cwgr to 0x1a4a4 iicbus0: <unknown card> at addr 0 iic0: <I2C generic I/O> on iicbus0 icee0: <I2C EEPROM> at addr 0xa0 on iicbus0 ate0: <EMAC> mem 0xdffbc000-0xdffbffff irq 24 on atmelarm0 miibus0: <MII bus> on ate0 ukphy0: <Generic IEEE 802.3u media interface> PHY 0 on miibus0 ukphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto ate0: Ethernet address: 42:53:44:00:00:01 ate0: [ITHREAD] uart0: <DBGU> mem 0xdffff200-0xdffff3ff irq 1 on atmelarm0 uart0: console (115200,n,8,1) uart1: <USART0> mem 0xdffc0000-0xdffc3fff irq 6 on auart2: <USART1> mem 0xdffc 4000-0xdffc7fff irq 7 on atmelarm0 uart2: [FILTER] uart3: <USART2> mem 0xdffc8000-0xdffcbfff irq 8 on atmelarm0 uart3: [FILTER] uart4: <USART3> mem 0xdffcc000-0xdffcffff irq 9 on atmelarm0 uart4: [FILTER] at91_spi0: <SPI> mem 0xdffe0000-0xdffe3fff irq 13 on atmelarm0 at91_spi0: [ITHREAD] spibus0: <spibus bus> on at91_spi0 ohci0: <AT91 integrated ohci controller> mem 0xdfe00000-0xdfefffff irq 23 on atmelarm0 ohci0: [GIANT-LOCKED] ohci0: [ITHREAD] usb0: OHCI version 1.0 usb0 on ohci0 usb0: USB revision 1.0 uhub0: <Atmel OHCI root hub, class 9/0, rev 1.00/1.00, addr 1> on usb0 uhub0: 2 ports with 2 removable, self powered uhub0: device problem (IOERROR), disabling port 2 Cannot get 100 Hz clock; using 100Hz at91_st0: [FILTER] Timecounter "AT91RM9200 timer" frequency 32768 Hz quality 1000 Timecounters tick every 10.000 msec SD CARD: 998768640 bytes mmcsd0: <mmc or sd flash card> on mmc0 mmc0: setting transfer rate to 30.000MHz Trying to mount root from ufs:/dev/mmcsd0s1a warning: no time-of-day clock registered, system time will not be set accurately Loading configuration files. No suitable dump device was found. Entropy harvesting: interrupts ethernet point_to_point kickstart. swapon: adding /dev/mmcsd0s1b as swap device Starting file system checks: /dev/mmcsd0s1a: FILE SYSTEM CLEAN; SKIPPING CHECKS /dev/mmcsd0s1a: clean, 146347 free (1171 frags, 18147 blocks, 0.5% fragmentation) Setting hostuuid: 2db3ec31-dbc8-11dc-bc4d-425344000001. Setting hostid: 0x8098ae24. Mounting local file systems:. Setting hostname: borda.nik.net.ua. lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 inet 127.0.0.1 netmask 0xff000000 Additional routing options:. Starting devd. ate0: link state changed to UP Additional IP options:. Mounting NFS file systems:. ELF ldconfig path: /lib /usr/lib /usr/lib/compat /usr/local/lib Creating and/or trimming log files:. Starting syslogd. /etc/rc: WARNING: Dump device does not exist. Savecore not run. Initial arm initialization:. Additional ABI support:. NFS access cache time=60 Clearing /tmp (X related). Starting lighttpd. Starting local daemons:. Updating motd. Mounting late file systems:. Starting sshd. Starting cron. Local package initialization: msql3. Starting inetd. Starting background file system checks in 60 seconds.
Sat Feb 16 19:38:36 UTC 2008
FreeBSD/arm (borda.nik.net.ua) (ttyu0)
login: root Password: Feb 16 19:39:03 borda login: ROOT LOGIN (root) ON ttyu0 Last login: Sat Feb 16 19:22:59 on ttyu0 Copyright (c) 1992-2008 The FreeBSD Project. Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 The Regents of the University of California. All rights reserved.
FreeBSD 7.0-RC2 (KB920X) #2: Fri Feb 15 10:14:59 EET 2008
You have new mail. borda# pkg_info libtool-1.5.24 Generic shared library support script lighttpd-1.4.18_1 A secure, fast, compliant, and very flexible Web Server msql-3.8 Version 3 of the Mini SQL relational database system pcre-7.6 Perl Compatible Regular Expressions library rdb-2.6d A fast, portable, relational database management syste Лm borda# uname -a FreeBSD borda.nik.net.ua 7.0-RC2 FreeBSD 7.0-RC2 #2: Fri Feb 15 10:14:59 EET 2 008 root@:/usr/obj/arm/usr/src/sys/KB920X arm borda# Запускал на плате KwikiByte KB9202C. Загрузка длится около 2 мин и причиной тому медленная работа с SD-карточкой. В запуске очень помогла рассылка freebsd-arm на http://lists.freebsd.org/mailman/listinfo/freebsd-armВ данный момент ищу облегченную бесплатную базу данных с поддержкой SQL
Feb 25 2008, 21:53
Из: г. Москва
Пользователь №: 16 729
Тофарищи, а если у кого-нибудь ещё осталась рабочая плата Черкашина с рабочим USB: не могли бы Вы запустить образ фри и выложить dmesg? А то я никак с USB не разберусь что-то:-(
ST4096-RIPE
Feb 26 2008, 11:48
Цитата(Stanislav Sedov @ Feb 26 2008, 01:53)  Тофарищи, а если у кого-нибудь ещё осталась рабочая плата Черкашина с рабочим USB: не могли бы Вы запустить образ фри и выложить dmesg? А то я никак с USB не разберусь что-то:-( К сожелению платы уже нет. Но я вспомнил что Дмитрий говорил что-то об отличиях в разводке его платы в сравнении с Атмеловской касательно USB. Деталей не помню.
Feb 26 2008, 23:51
Из: г. Москва
Цитата(jack_avenger @ Feb 26 2008, 14:48)  К сожелению платы уже нет. Но я вспомнил что Дмитрий говорил что-то об отличиях в разводке его платы в сравнении с Атмеловской касательно USB. Деталей не помню. Жалко. По поводу USB Host - там отличий быть не может, по-другому не сделать. А USB Device у него, действительно, по-своему разведён, пины другие. Хотя это и не принципиально. Самое забавное, что пока мы не поменяли MMC слот на SD - всё работало...
ST4096-RIPE
Mar 1 2008, 10:05
Из: г. Москва
Цитата(dch @ Feb 29 2008, 17:49)  Не должно влиять - три пина которыми SD отличается от MMC - могут использоваться как линии передачи данных у SD или как пины SCC и поэтому выведены и на SCC разъем и на ММС/SD. Замена разъема не должна влиять на USB. На USB девайсе два джпио используются другие против атмеловского USB посему двайвер USB девайсе обычно правится. На USB хосте должен работать оригинальный драйвер. Да понятно, что не должно, однако... Возможно, мы что-то испортили. Не могли бы Вы, пожалуйста, запустить ядро на Вашей плате, пожалуйста, и выложить сюда dmesg (или послать мне по почте). Я Вам, кстати, письмо писал, может оно не дошло? Спасибо!
ST4096-RIPE
jack_avenger FreeBSD на AT91RM9200 Feb 17 2008, 17:19 doomer#gp Trying to mount root from ufs:/dev/mmcsd0s1a
UFS ... Feb 17 2008, 22:01 jack_avenger Цитата(doomer#gp @ Feb 18 2008, 01:01) Tr... Feb 18 2008, 07:45 PrSt Цитата(jack_avenger @ Feb 17 2008, 19:19)... Feb 20 2008, 07:49 Stanislav Sedov Собственно, на Черкашинской плате она тоже нормаль... Feb 21 2008, 12:09 jack_avenger Цитата(Stanislav Sedov @ Feb 21 2008, 16... Feb 21 2008, 13:39  Stanislav Sedov Цитата(jack_avenger @ Feb 21 2008, 16:39)... Feb 21 2008, 14:01   jack_avenger Цитата(Stanislav Sedov @ Feb 21 2008, 18... Feb 21 2008, 15:02    Stanislav Sedov Цитата(jack_avenger @ Feb 21 2008, 18:02)... Feb 21 2008, 15:09     jack_avenger Цитата(Stanislav Sedov @ Feb 21 2008, 19... Feb 21 2008, 15:21      Stanislav Sedov Цитата(jack_avenger @ Feb 21 2008, 18:21)... Feb 21 2008, 23:39
