Редакторы HDL, альтернатива |
Mar 17 2008, 08:52
Adept
Из: Novosibirsk
Пользователь №: 1 343
Цитата(Vadim @ Mar 17 2008, 12:56)  Вопрос к тем, кто работает с сликом. Как перенести личные настройки с одного компьютера на другой? Попробуйте так (это фрагмент из старой доки, в новой почему-то этот FAQ убрали): Цитата Q: How do I transfer my configuration?
A: Each user's configuration is automatically transferred to a newly installed version of Visual SlickEdit when they run the new version. Some configuration changes will not be transferred such as changes to our menus, and changes to our dialog boxes. Changes to our toolbars are preserved only if you are upgrading from 3.0b or after.
non-UNIX platforms: For single user configurations you need to install the new version of Visual SlickEdit on top of the previous version in order for your configuration to be transferred to the new version.
SINGLE USER NON-UNIX PLATFORMS:
To manually transfer your configuration changes from the previous version of Visual SlickEdit, perform these steps:
· If you are currently running the new version of Visual SlickEdit, close the editor now.
· If you have made color coding changes, copy your "vslick\user.vlx" file into the "vslick" directory of the new version.
· If you have recorded macros, copy your "vslick\macros\vusrmacs.e" into the "vslick\macros" directory of the new version.
· To tranfer other configuration changes, bring up the previous version of Visual SlickEdit. Activate the Visual SlickEdit command line at the bottom of the editor (ESC for most emulations) and type "list-source" and press ENTER. This will create the macro file "vusrdefs.e", and possible another macro file called "vusrobjs.e" in your "vslick\macros" directory. Copy " vusrdefs.e" and (optionally) "vusrobjs.e", into the vslick\macros directory of the new version.
· Run the new version of Visual SlickEdit.
· If you ran the "list-source" command, type "vusrmods" and press ENTER on the Visual SlickEdit command line. This will switch emulations if necessary, and run "vusrdefs.e" and " vusrobjs.e" (if present).
· If you copied your recorded macros file ("vslick\macros\vusrmacs.e"), load this macro now with the Load Module dialog box ("Macro...", "Load Module...").
MULTI-USER NON-UNIX PLATFORMS:
· If you have made color coding changes, copy your "user.vlx" file located in the directory specified by your VSLICKCONFIG environment variable into the your VSLICKCONFIG directory of the new version.
· If you have recorded macros, copy your "vusrmacs.e" file located in the directory specified by your VSLICKCONFIG environment variable into the VSLICKCONFIG directory of the new version.
· To tranfer other configuration changes, bring up the previous version of Visual SlickEdit. Activate the Visual SlickEdit command line at the bottom of the editor (ESC for most emulations) and type "list-source" and press ENTER. This will create the macro file "vusrdefs.e", and possible another macro file called "vusrobjs.e" in the directory specified by your VSLICKCONFIG environment variable. Copy "vusrdefs.e" and (optionally) "vusrobjs.e", into the VSLICKCONFIG directory of the new version.
· If you copied your recorded macros file ("vusrmacs.e"), load this macro now with the Load Module dialog box ("Macro...", "Load Module...").
UNIX PLATFORMS:
· If you have made color coding changes, copy your "user.vlx" file located in your $HOME/.vslick directory into the your $HOME/.vslick directory of the new version.
· If you have recorded macros, copy your "vusrmacs.e" file located in your $HOME/.vslick directory into the your $HOME/.vslick directory of the new version.
· To tranfer other configuration changes, bring up the previous version of Visual SlickEdit. Activate the Visual SlickEdit command line at the bottom of the editor (ESC for most emulations) and type "list-source" and press ENTER. This will create the macro file "vusrdefs.e", and possible another macro file called "vusrobjs.e" in your $HOME/.vslick directory. Copy " vusrdefs.e" and (optionally) "vusrobjs.e", into the $HOME/.vslick directory of the new version.
zorromen Редакторы HDL Mar 24 2007, 13:38 Doka ну а что такое "писать" ?
"просто ... Mar 24 2007, 16:54 iosifk Цитата(Doka @ Mar 24 2007, 16:54) "п... Mar 27 2007, 09:11 Adlex В квартусе делаетcz File-New-HDL Verilog Fileпосле... Mar 24 2007, 19:28 vetal Очень интересный и хороший текстовый редактор Prog... Mar 24 2007, 20:55 makc (g)vim - http://www.vim.org/
Мощный и легко расши... Mar 24 2007, 21:29 std-logic IMHO, лучше ActiveHDL-а от ALDEC (www.aldec.com) п... Mar 26 2007, 06:35 Uuftc Цитата(std-logic @ Mar 26 2007, 07:3... Mar 27 2007, 08:51 SM Цитата(zorromen @ Mar 24 2007, 14:38) Так... Mar 27 2007, 10:59 Victor® Цитата(zorromen @ Mar 24 2007, 13:38) При... Mar 27 2007, 12:01 druzhin Цитата(Victor® @ Mar 27 2007, 13:01) Cont... Mar 28 2007, 13:13  NiOS Цитата(druzhin @ Mar 28 2007, 14:13) Я дл... Mar 28 2007, 13:53   druzhin Цитата(NiOS @ Mar 28 2007, 14:53) Замечу,... Mar 28 2007, 14:48 zorromen А как сделать силумуляцию в ActiveHDL проекта из к... Mar 27 2007, 14:52 SM Цитата(zorromen @ Mar 27 2007, 15:52) А к... Mar 27 2007, 15:10 glock17 Цитата(zorromen @ Mar 24 2007, 19:38) При... Mar 27 2007, 15:54 MobyDick Для VHDL и Verilog - посмотрите в сторону Notepad+... Mar 27 2007, 19:56 NiOS Цитата(MobyDick @ Mar 27 2007, 20:56) Для... Mar 28 2007, 11:26 zorromen Чесно меня заинтересовала симуляция в левых пакета... Mar 28 2007, 09:10 SM Будут задержки, если симуляция будет после разводк... Mar 28 2007, 10:29 Postoroniy_V Цитата(SM @ Mar 28 2007, 11:29) Будут зад... Mar 28 2007, 14:44 dxp Цитата(SM @ Mar 28 2007, 14:29) Будут зад... Mar 28 2007, 16:00 zorromen А мультисим? ... Кстати а шо такое просто мультиси... Mar 28 2007, 10:55 SM Цитата(zorromen @ Mar 28 2007, 11:55) А м... Mar 28 2007, 19:43 rv3dll(lex) попеременно desview и редактор от ISE Mar 28 2007, 20:41 zorromen Извеняюсь ... конечно modelsim ... У меня неполуча... Mar 28 2007, 20:46 SM Вот там описано шаг за шагом => http://www.alte... Mar 28 2007, 20:49 zorromen У меня пишет когда пускаешь симуляцию из кваки6.0 ... Mar 29 2007, 11:50 dxp Цитата(zorromen @ Mar 29 2007, 15:50) У м... Mar 29 2007, 12:58 zorromen Люди помогите ... меня уже это все достало ... как... Mar 29 2007, 15:37 sazh Quartus нормально поддерживает языки описания. Нор... Mar 29 2007, 16:27 Malder Для написнания кода на Verilog'e и VHDL'e ... May 11 2007, 20:49 dxp Цитата(Malder @ May 12 2007, 03:49) НО... May 13 2007, 12:54 zltigo Цитата(Malder @ May 11 2007, 23:49) Кто-н... May 13 2007, 15:47  Malder Цитата(zltigo @ May 13 2007, 19:47) Прико... May 28 2007, 06:15   zltigo Цитата(Malder @ May 28 2007, 09:15) Зажим... Jul 15 2007, 21:59 BSV В UltraEdit и UEStudio имеется такой режим - назыв... May 28 2007, 17:31 sumerik Цитата(BSV @ May 28 2007, 21:31) В UltraE... May 29 2007, 19:51  RHnd А подскажите, умеет ли кто-нить из перечисленных р... Jul 15 2007, 19:23   Doka Цитата(RHnd @ Jul 15 2007, 23:23) работат... Jul 15 2007, 22:21   makc Цитата(RHnd @ Jul 15 2007, 23:23) А подск... Jul 16 2007, 05:52 RHnd Поставил себе notepad++. Нравится. Однако, возникл... Feb 9 2008, 13:46 Саша Z Цитата(RHnd @ Feb 9 2008, 17:46) Поставил... Feb 9 2008, 14:45 cyclop Цитата(RHnd @ Feb 9 2008, 17:46) Поставил... Jun 4 2008, 09:25  cyclop Для notepad++ создал verilog.api. Ключевые слова -... Jun 5 2008, 15:26 Doka RHnd
сейчас поставил себе эту штуку - посмотреть х... Feb 10 2008, 12:14 RHnd Цитата(Doka @ Feb 10 2008, 15:14) при выб... Feb 10 2008, 16:09  CaPpuCcino подсветка систаксиса СистемВерилог для УльтраЕдит ... Feb 18 2008, 10:01   CaPpuCcino Цитата(CaPpuCcino @ Feb 18 2008, 13:01) п... Mar 5 2008, 11:41 LeonY Господа! Еще один вопрос о "редакторах HD... Mar 6 2008, 13:08 Vadim Цитата(LeonY @ Mar 6 2008, 17:08) Господа... Mar 6 2008, 14:02 makc Цитата(LeonY @ Mar 6 2008, 16:08) Господа... Mar 6 2008, 19:36 id_gene Цитата(LeonY @ Mar 6 2008, 16:08) редакто... Mar 12 2008, 09:27  des00 Цитата(id_gene @ Mar 12 2008, 04:27) У em... Mar 12 2008, 10:20   Intekus Цитата(des00 @ Mar 12 2008, 14:20) Неболь... Mar 12 2008, 11:27 Evil Archer Подсветка синтаксиса SV для notepad++ 4.8.1. Прост... Mar 6 2008, 19:46 Evil Archer Цитата(Evil Archer @ Mar 6 2008, 22:46) П... Mar 13 2008, 18:19 des00 Цитата(Vadim @ Mar 17 2008, 01:56) Вопрос... Mar 18 2008, 04:17  dxp Цитата(des00 @ Mar 18 2008, 10:17) Вы не ... Mar 18 2008, 04:51   des00 Цитата(dxp @ Mar 17 2008, 23:51) Что вы п... Mar 18 2008, 05:13    dxp Цитата(des00 @ Mar 18 2008, 11:13) Ну у м... Mar 18 2008, 07:17     des00 Цитата(dxp @ Mar 18 2008, 02:17) Вы про s... Mar 18 2008, 10:07      dxp Цитата(des00 @ Mar 18 2008, 16:07) Нет я ... Mar 18 2008, 13:38 Vadim dxp, des00, спасибо. Mar 18 2008, 07:52 Escorial Поставил Eclipse IDE, а для SystemVerilog подключи... Apr 8 2008, 21:37 Evil Archer Цитата(Escorial @ Apr 9 2008, 00:37) Пост... Jan 22 2009, 15:49  CaPpuCcino Цитата(Evil Archer @ Jan 22 2009, 19:49) ... Jan 22 2009, 22:00   Evil Archer Цитата(CaPpuCcino @ Jan 23 2009, 01:00) а... Jan 23 2009, 00:54 Vadim Можно ли сликовское окошко Build заставить отображ... Jun 10 2008, 07:24 dxp Цитата(Vadim @ Jun 10 2008, 14:24) Можно ... Jun 10 2008, 11:56  Vadim Цитата(dxp @ Jun 10 2008, 14:56) А почему... Jun 10 2008, 12:08   dxp Цитата(Vadim @ Jun 10 2008, 19:08) Как? T... Jun 10 2008, 13:07    Vadim Цитата(dxp @ Jun 10 2008, 16:07) У вас с ... Jun 10 2008, 13:24 andrew_b VIM plugin: Automatic generator for Verilog HDL
S... Sep 11 2008, 10:18 CaPpuCcino долго мучился пытаясь выбрать из предложенных вари... Nov 18 2008, 05:08 Vadim Хорошая вещь, однако. Спасибо за наводку. Давно уж... Nov 19 2008, 19:13 CaPpuCcino Цитата(Vadim @ Nov 19 2008, 23:13)
мне о... Nov 19 2008, 20:18  CaPpuCcino сделал настройки для SystemVerilog под SciTe:
изме... Nov 21 2008, 16:39 Vadim Про слик и sv. Сохраните свои sv-файлы с расширени... Nov 28 2008, 12:22 cms Добавил новые кейворды и функции в verilog-колорер... Dec 10 2008, 16:44 Vadim С нетерпением ждем появления SlickEdit 2009
Цитат... Feb 8 2009, 15:21 Vadim Бесплатный достойный внимания текстовый редактор:
... Mar 13 2009, 10:35 CaPpuCcino Цитата(Vadim @ Mar 13 2009, 14:35) Беспла... Mar 16 2009, 05:02 des00 Цитата(Vadim @ Mar 13 2009, 04:35) Беспла... Mar 20 2009, 04:43 Vadim Подружить его с SUSE 11 мне не удалось. Глючит, ок... Mar 16 2009, 07:04 CaPpuCcino Цитата(Vadim @ Mar 16 2009, 10:04)
что-т... Mar 20 2009, 01:51  Vadim Цитата(CaPpuCcino @ Mar 20 2009, 04:51) В... Mar 20 2009, 08:12   CaPpuCcino Цитата(Vadim @ Mar 20 2009, 12:12) Вид-... Mar 20 2009, 15:02 yes прикольно, что про emacs/xemacs с verilog-mode (ve... Mar 23 2009, 12:00 Vadim И не мудрено. Где-то вычитал, что emacs имеет два ... Mar 25 2009, 11:41 yes Цитата(Vadim @ Mar 25 2009, 14:41) И не м... Mar 27 2009, 11:05 des00 посмотрел новый слик, блин все равно с косяками р... Mar 29 2009, 16:51 Vadim И Editra подтянулась Уже пару дней как обрелизила... Mar 30 2009, 07:00 Vadim Надо признать, едитра кривовата. Под линуксом слом... Mar 31 2009, 05:58 Victor® Здравствуйте!
Раньше использовал Context.
Но п... Apr 28 2009, 18:25 glock17 Цитата(Victor® @ Apr 29 2009, 03:25) Здра... Apr 29 2009, 04:49  Victor® Цитата(glock17 @ Apr 29 2009, 07:49) Инте... Apr 29 2009, 05:54   glock17 Цитата(Victor® @ Apr 29 2009, 14:54) 1) П... Apr 29 2009, 07:10
3 страниц
1 2 3 >
