> Описание стека на Verilog, подскажите что не так
Consigliere
сообщение Mar 13 2008, 07:27
Пользователь №: 35 869
Идея в том, чтоб описать 8-битный стек, запись и чтение производится с помощью управляющего сигнала "wr"
module stack(out_stack, in_stack);
    output [7:0] out_stack;
    input [7:0] in_stack;
    wire st0 [7:0],
    st1 [7:0],
    st2 [7:0],
    st3 [7:0],
    st4 [7:0],
    st5 [7:0],
    st6 [7:0],
    st7 [7:0];
    wire wr;
    always in_stack
    if (wr)
        st7 = st6;
        st6 = st5;
        st5 = st4;
        st4 = st3;
        st3 = st2;
        st2 = st1;
        st1 = st0;
        st0 = in_stack;
endmodule
при компиляции выдает данное сообщение
# Pass 1. Scanning modules hierarchy.
# Error: VCP2000 stack.v : (20, 8): Syntax error. Unexpected token: =. Expected tokens: '#' , '(' , ':' , 'delay' , ',' ... .
# Error: VCP2000 stack.v : (21, 8): Syntax error. Unexpected token: =. Expected tokens: '#' , '(' , ':' , 'delay' , ',' ... .
# Error: VCP2000 stack.v : (22, 8): Syntax error. Unexpected token: =. Expected tokens: '#' , '(' , ':' , 'delay' , ',' ... .
# Error: VCP2000 stack.v : (23, 8): Syntax error. Unexpected token: =. Expected tokens: '#' , '(' , ':' , 'delay' , ',' ... .
# Error: VCP2000 stack.v : (24, 8): Syntax error. Unexpected token: =. Expected tokens: '#' , '(' , ':' , 'delay' , ',' ... .
# Error: VCP2000 stack.v : (25, 8): Syntax error. Unexpected token: =. Expected tokens: '#' , '(' , ':' , 'delay' , ',' ... .
# Error: VCP2000 stack.v : (26, 8): Syntax error. Unexpected token: =. Expected tokens: '#' , '(' , ':' , 'delay' , ',' ... .
# Warning: VCP2515 stack.v : (21, 1): Undefined module: st4 was used. Port connection rules will not be checked at such instantiations.
# Warning: VCP2515 stack.v : (20, 1): Undefined module: st5 was used. Port connection rules will not be checked at such instantiations.
# Warning: VCP2515 stack.v : (23, 1): Undefined module: st2 was used. Port connection rules will not be checked at such instantiations.
# Warning: VCP2515 stack.v : (22, 1): Undefined module: st3 was used. Port connection rules will not be checked at such instantiations.
# Warning: VCP2515 stack.v : (26, 1): Undefined module: in_stack was used. Port connection rules will not be checked at such instantiations.
# Warning: VCP2515 stack.v : (25, 1): Undefined module: st0 was used. Port connection rules will not be checked at such instantiations.
# Warning: VCP2515 stack.v : (24, 1): Undefined module: st1 was used. Port connection rules will not be checked at such instantiations.
# Compile failure 7 Errors 7 Warnings Analysis time : 0[s].
# done
не могу понять что я делаю не так...
Заранее спасибо за помощь.)
если не туда разместил тему перенесите пожалуйста в нужный раздел форума
Consigliere
сообщение Mar 18 2008, 12:44
все только на поведенческом уровнеsmile.gif просто описаниеsmile.gif и временные диаграммыsmile.gif
- Consigliere   Описание стека на Verilog   Mar 13 2008, 07:27
- - yuri_d   1) при работе со стеком подразумевается, что есть ...   Mar 13 2008, 08:42
- - XVR   Цитата(Consigliere @ Mar 13 2008, 10:27) ...   Mar 13 2008, 08:47
- - iosifk   Цитата(Consigliere @ Mar 13 2008, 10:27) ...   Mar 13 2008, 09:00
- - Consigliere   спасибо, всем за помощь а можно еще один вопрос Ц...   Mar 13 2008, 10:07
|- - XVR   Цитата(Consigliere @ Mar 13 2008, 13:07) ...   Mar 13 2008, 17:12
- - Consigliere   Ну смотри, это не реальное задание, а так, просто ...   Mar 13 2008, 18:36
|- - CaPpuCcino   http://en.wikipedia.org/wiki/Stack_(data_structure...   Mar 13 2008, 18:58
|- - XVR   Цитата(Consigliere @ Mar 13 2008, 21:36) ...   Mar 13 2008, 20:12
|- - CaPpuCcino   для поведеньческой модели: Кодclass stack #(ty...   Mar 13 2008, 20:26
- - Consigliere   Цитата(CaPpuCcino @ Mar 13 2008, 21:58) h...   Mar 13 2008, 19:13
|- - CaPpuCcino   писал находу без верификации. так что могут быть и...   Mar 13 2008, 19:43
- - Consigliere   XVR, не то чтоб, совсем до лампочки, но рассматрив...   Mar 14 2008, 04:31
|- - XVR   Цитата(Consigliere @ Mar 14 2008, 07:31) ...   Mar 14 2008, 08:50
- - yuri_d   Цитата(CaPpuCcino @ Mar 13 2008, 22:43) п...   Mar 14 2008, 20:52
|- - CaPpuCcino   Цитата(yuri_d @ Mar 14 2008, 23:52) Всё з...   Mar 14 2008, 21:59
- - Consigliere   XVR, вобщем как выяснилось, смысл был не совсем то...   Mar 15 2008, 14:22
|- - XVR   Цитата(Consigliere @ Mar 15 2008, 17:22) ...   Mar 15 2008, 20:11
|- - CaPpuCcino   господа, не пора ли переместиться в соответствующи...   Mar 15 2008, 21:11
|- - Consigliere   Цитата(XVR @ Mar 15 2008, 23:11) Это устр...   Mar 16 2008, 08:35
|- - XVR   Цитата(Consigliere @ Mar 16 2008, 11:35) ...   Mar 17 2008, 08:46
|- - Consigliere   Цитата(XVR @ Mar 17 2008, 11:46) Т.е. пре...   Mar 17 2008, 10:25
|- - XVR   Цитата(Consigliere @ Mar 17 2008, 13:25) ...   Mar 17 2008, 17:05
|- - Consigliere   Цитата(XVR @ Mar 17 2008, 20:05) Предлага...   Mar 17 2008, 17:30
|- - XVR   Цитата(Consigliere @ Mar 17 2008, 20:30) ...   Mar 18 2008, 08:39
|- - XVR   Цитата(Consigliere @ Mar 18 2008, 15:44) ...   Mar 18 2008, 13:25
- - Consigliere   на счет этого не знаю, но предполагаю что абстракт...   Mar 18 2008, 14:26
|- - XVR   Цитата(Consigliere @ Mar 18 2008, 17:26) ...   Mar 18 2008, 17:03
- - Consigliere   я пока что заболел, лежу с температурой, как тольк...   Mar 20 2008, 07:03
- - Consigliere   вот и выздоровил так как на счет такой реализации...   Mar 27 2008, 08:24
|- - XVR   Цитата(Consigliere @ Mar 27 2008, 11:24) ...   Mar 27 2008, 16:50
- - Consigliere   там не 4 шины для обмена со стеком, 2 на стек и 2 ...   Mar 28 2008, 05:28
|- - XVR   Цитата(Consigliere @ Mar 28 2008, 08:28) ...   Mar 28 2008, 06:04
- - Consigliere   я не понимаю принцип действия контроллера какую ро...   Mar 31 2008, 07:12
|- - XVR   Цитата(Consigliere @ Mar 31 2008, 11:12) ...   Mar 31 2008, 07:22
- - Consigliere   а как его делать, вместе со стеком? и опять же он ...   Mar 31 2008, 17:31
- - XVR   Цитата(Consigliere @ Mar 31 2008, 21:31) ...   Apr 1 2008, 08:05
RSS Текстовая версия Сейчас: 2nd August 2025 - 23:51
Страница сгенерированна за 0.01422 секунд с 7
