> вектор прерывания
swagger
сообщение Apr 9 2008, 16:42
Из: Moscow
Пользователь №: 34 201
Добрый день!
Сейчас изучаю модуль mssp, хочу сделать обмен по I2C c внешней памятью. Скачал архив AN734 (http://www.microchip.com), переделал линкер под 16F876a(закомментированые строчки от предыдущего файла)
// File: 16f876a.lkr
// Linker Script file, modified
// Date: 06/07/2000
// Modified 7/18/2000 -.RLF
LIBPATH  .
CODEPAGE   NAME=vectors  START=0x0000   END=0x0004   PROTECTED
CODEPAGE   NAME=page0    START=0x0005   END=0x07FF
CODEPAGE   NAME=page1    START=0x0800   END=0x0FFF
CODEPAGE   NAME=page2    START=0x1000   END=0x17FF
CODEPAGE   NAME=page3    START=0x1800   END=0x1FFF
CODEPAGE   NAME=.idlocs  START=0x2000   END=0x2003   PROTECTED
CODEPAGE   NAME=.config  START=0x2007   END=0x2007   PROTECTED
CODEPAGE   NAME=eedata   START=0x2100   END=0x21FF   PROTECTED
//CODEPAGE   NAME=vectors  START=0x0      END=0x70    PROTECTED
//CODEPAGE   NAME=page0    START=0x71     END=0x7FF
//CODEPAGE   NAME=page1    START=0x800    END=0xFFF    PROTECTED
//CODEPAGE   NAME=.idlocs  START=0x2000   END=0x2003   PROTECTED
//CODEPAGE   NAME=.config  START=0x2007   END=0x2007   PROTECTED
//Special Function Registers in Banks 0-3
DATABANK   NAME=sfr0     START=0x0      END=0x1F     PROTECTED
DATABANK   NAME=sfr1     START=0x80     END=0x9F     PROTECTED
DATABANK   NAME=sfr2     START=0x100    END=0x10F    PROTECTED
DATABANK   NAME=sfr3     START=0x180    END=0x18F    PROTECTED
//General Purpose RAM in Banks 0-3
DATABANK   NAME=gpr0     START=0x20     END=0x6F
DATABANK   NAME=gpr1     START=0xA0     END=0xEF
DATABANK   NAME=gpr2     START=0x110    END=0x16F
DATABANK   NAME=gpr3     START=0x190    END=0x1EF
//General Purpose RAM - available in all banks
SHAREBANK  NAME=gprnobnk START=0x70     END=0x7F
SHAREBANK  NAME=gprnobnk START=0xF0     END=0xFF
SHAREBANK  NAME=gprnobnk START=0x170    END=0x17F
SHAREBANK  NAME=gprnobnk START=0x1F0    END=0x1FF
//DATABANK   NAME=sfr0     START=0x0      END=0x1F     PROTECTED
//DATABANK   NAME=sfr1     START=0x80     END=0x9F     PROTECTED
//DATABANK   NAME=sfr2     START=0x100    END=0x10F    PROTECTED
//DATABANK   NAME=sfr3     START=0x180    END=0x18F    PROTECTED
//DATABANK   NAME=gpr0     START=0x20     END=0x7F
//DATABANK   NAME=gpr1     START=0xA0     END=0xFF
SECTION    NAME=STARTUP  ROM=vectors    // Reset and interrupt vectors
SECTION    NAME=PROG1    ROM=page0      // ROM code space - page0
SECTION    NAME=PROG2    ROM=page1      // ROM code space - page1
SECTION       NAME=IDLOCS   ROM=.idlocs    // ID locations
SECTION    NAME=CONFIG   ROM=.config    // Configuration bits location
и пытаюсь запустить, но МПЛАБ пишет ошибку:
MPLINK 4.11, Linker
Copyright © 2007 Microchip Technology Inc.
Error - section 'INT_VECTOR' can not fit the absolute section. Section 'INT_VECTOR' start=0x00000004, length=0x000001a4
Errors : 1
Как я понимаю, чтото с вектором прерывания. В чем ошибка? Что надо подправить?
Может вообще надо както делать обмен по другому?
Сообщение отредактировал swagger - Apr 9 2008, 16:55
blackbit
сообщение Apr 10 2008, 11:06
Пользователь №: 25 892
Вы неправильно отредактировали скрипт - практически не оставили памяти под размещение обработчика прерываний:
Вот линкер вам и говорит, что не может разместить код обработчика в пределах памяти, выделенной вами под эту секцию. Увеличивайте значение параметра END в этой строке, а следущей сделайте адрес хотя бы на 1 больше в параметре START, поскольку секции vectors и page0 не должны перекрываться.
У вас:
Не забудьде, что длину секции линкер приводит в байтах, но адресация идет в словах. Значит у вас конечный адрес под секцию обработчика: (0x04+0x1A4/2-1)=0xD5. А начальный адрес следующей секции кода: 0xD6
CODEPAGE NAME=vectors START=0x0000 END=0x00D5 PROTECTED
CODEPAGE NAME=page0 START=0x00D6 END=0x07FF
Это если слово в слово, но если вставите в обработчик прерываний хотя бы еще одну команду, получите ту же ошибку. Поэтому лучше для отладки лучше устанавите размер секции с запасом. Потом подрежете.
RSS Текстовая версия Сейчас: 22nd July 2025 - 15:10
