OpenAT |
Apr 25 2008, 07:20
Пользователь №: 31 837
#include "adl_global.h"
/***************************************************************************/ /* Mandatory variables */ /*-------------------------------------------------------------------------*/ /* wm_apmCustomStack */ /* wm_apmCustomStackSize */ /*-------------------------------------------------------------------------*/ /***************************************************************************/ const u16 wm_apmCustomStackSize = 1024;
/***************************************************************************/ /* Local variables */ /***************************************************************************/
/* String To Send List */ wm_lst_t StringList;
/* Flag for FCM State */ bool bFCMIsReady = TRUE; bool flag = FALSE;
/* AT command buffer */ ascii ATCommand[ 512 ]; /* Used flow */ #define USED_FLOW ADL_PORT_UART1
static s8 V24Handle,UARTHandle;
/***************************************************************************/ /* Function : V24CtrlHandler */ /*-------------------------------------------------------------------------*/ /* Objet : FCM Control Events Handler */ /* */ /* Return : return value is not relevant */ /* */ /*-------------------------------------------------------------------------*/ /* Variable Name |IN |OUT|GLB| Utilisation */ /*--------------------+---+---+---+----------------------------------------*/ /* Event | | | | Event from GPRS Service */ /*--------------------+---+---+---+----------------------------------------*/ /***************************************************************************/ bool V24CtrlHandler ( u8 Event ) { bool bReturn = TRUE; s32 sReturn; flag = FALSE; TRACE (( 1, "V24 event %d", Event )); adl_atSendResponse (ADL_AT_RSP, "\r\n Prishli v V24Ctrl handler\r\n"); // sReturn = adl_fcmSwitchV24State ( V24Handle, ADL_FCM_V24_STATE_DATA ); // Switch on event switch ( Event ) { case ADL_FCM_EVENT_FLOW_OPENNED : adl_atSendResponse (ADL_AT_RSP, "\r\n Open \r\n"); sReturn = adl_fcmSwitchV24State ( V24Handle, ADL_FCM_V24_STATE_DATA ); adl_atSendResponse (ADL_AT_RSP, "\r\n Switch to data\r\n"); TRACE (( 1, "Switch to data : %d", sReturn )); bFCMIsReady = TRUE; break; case ADL_FCM_EVENT_RESUME : adl_atSendResponse (ADL_AT_RSP, "\r\n Resume \r\n"); sReturn = adl_fcmSwitchV24State ( V24Handle, ADL_FCM_V24_STATE_DATA ); adl_atSendResponse (ADL_AT_RSP, "\r\n Switch to data\r\n"); bFCMIsReady = TRUE ; TRACE (( 1, "Resume Data Flow")); break; case ADL_FCM_EVENT_MEM_RELEASE : bFCMIsReady = TRUE ; TRACE (( 1, "Data are sent")); break; case ADL_FCM_EVENT_FLOW_CLOSED : adl_atSendResponse (ADL_AT_RSP, "\r\n Flow closed\r\n"); sReturn = adl_fcmSwitchV24State ( V24Handle, ADL_FCM_V24_STATE_AT );\ bFCMIsReady = TRUE ; TRACE (( 1, "Data are sent")); break; } return bReturn; }
void MyTimeout (u8 id)
adl_atSendResponse (ADL_AT_RSP, "\r\n Timer works!\r\n"); }
bool V24DataHandler ( u16 Length, u8 * Data ) { adl_atSendResponse (ADL_AT_RSP, "\r\n Prishli v V24DATA handler!\r\n"); /* Scan received string */ u16 i,j,ATLastLength = wm_strlen ( ATCommand ); ascii * RecString = adl_memGet ( ( u16 ) ( Length ) ); TRACE (( 1, "V24DataHandler begin")); wm_memcpy ( ( ascii * ) RecString, ( ascii * ) Data, Length ); adl_atSendResponse (ADL_AT_RSP, "\r\n Receive complete!\r\n");
for ( i = 0 ; i < Length ; i++ ) { /* If string is empty, search for 'a' */ if ( ( wm_strlen ( ATCommand ) == 0 ) && ( ( RecString [ i ] == 'a' ) || ( RecString [ i ] == 'A' ) ) ) { adl_fcmSwitchV24State ( V24Handle, ADL_FCM_V24_STATE_AT ); flag = TRUE; // adl_fcmUnsubscribe(V24Handle); // return TRUE; // continue; } } adl_fcmSendData (V24Handle, RecString, wm_strlen (RecString)); ATLastLength = 0; adl_memRelease ( RecString ); // release credit return TRUE;
void AtStartHandler (adl_atCmdPreParser_t *p)
{ adl_atSendResponse (ADL_AT_RSP, "\r\nHello, world!\r\n"); V24Handle=adl_fcmSubscribe (ADL_PORT_UART1, (adl_fcmCtrlHdlr_f)V24CtrlHandler, (adl_fcmDataHdlr_f)V24DataHandler); if(flag==TRUE) { adl_atSendResponse (ADL_AT_RSP, "\r\n flag==TRUE\r\n"); adl_fcmUnsubscribe(V24Handle); } };
void AtSwitchHandler (adl_atCmdPreParser_t *p)
{ adl_atSendResponse (ADL_AT_RSP, "\r\nSwitch\r\n"); adl_fcmSwitchV24State ( V24Handle, ADL_FCM_V24_STATE_DATA );
void adl_main ( adl_InitType_e InitType ) { adl_atSendResponse (ADL_AT_RSP, "\r\n Hi user, let's start our transfere!\r\n"); ascii * RecString1 = adl_memGet ( ( u16 ) ( 256) ); /* Initialize String To Send list */ StringList = wm_lstCreate ( WM_LIST_NONE, NULL );
/* Init AT command string */ ATCommand[ 0 ] = 0; /* Subscribe to call events */ adl_atCmdSubscribe ("at+start", (adl_atCmdHandler_t)AtStartHandler, ADL_CMD_TYPE_ACT); adl_atCmdSubscribe ("at+switch", (adl_atCmdHandler_t)AtSwitchHandler, ADL_CMD_TYPE_ACT);
} Вот весь файл...
Apr 25 2008, 10:07
Пользователь №: 36 045
Не понятно зачем вы переходите в ДАТА режим для отправки данных?
разве не достаточно просто послать adl_atSendResponse(ADL_PORT_UART1,bufUart1); или для текущего порта adl_atSendResponse(ADL_AT_RSP,bufUart1); или для вашего случая adl_atSendResponsePort(ADL_AT_RSP, p->Port, x)
Я как то написал универсальную функцию и забыл... Возможно кривовато #define MAX_LEN_BUF_UART1 512 //максимальная длина посылки за один раз unsigned char bufUart1[MAX_LEN_BUF_UART1+1]; //Буфер глобальный. Возможно так быстрее unsigned int SendUart1(unsigned char *str) { unsigned char *pBuf; unsigned int len, bufLen;
bufLen = len = (unsigned int)strlen(str);
if(!len) //Нулевую длину не обрабатываем return 0;
if(len<=MAX_LEN_BUF_UART1) {//Для буфера меньше допустимо возможного просто отправляем данные и выходим adl_atSendResponse(ADL_PORT_UART1,str); } else { //Массив большой - пошлём кусками pBuf = str; do{ memset(bufUart1, 0, MAX_LEN_BUF_UART1+1); strncpy(bufUart1, pBuf, MAX_LEN_BUF_UART1); //копируем кусок для отправки
len = (unsigned int)strlen(pBuf);
if(len<=MAX_LEN_BUF_UART1) break; else pBuf+=MAX_LEN_BUF_UART1; }while(1); } return bufLen; //Возвращаем количество посланных байт }
kban OpenAT Feb 20 2008, 07:37 sz36 Цитата(kban @ Feb 20 2008, 10:37) Всем кт... Feb 23 2008, 16:59 Velund QUOTE (sz36 @ Feb 23 2008, 22:59) Сделал ... Jan 10 2011, 21:21 KonstantinT Хранцузы - такие затейники :-). Но через пол года ... Feb 23 2008, 21:14 kban ЦитатаВручную переписываем свои *.h файлы в папку ... Feb 26 2008, 09:16 de__ Цитата(kban @ Feb 26 2008, 12:16) Вот и я... Mar 19 2008, 11:28 dezzer Банальная переустановка OpenAT зачастую излечивала... Mar 5 2008, 06:27 kban Спасибо всем за ответы. Установил - более-менее ра... Mar 20 2008, 10:12 alexQ вот это не очень понятно:
>не ту информацию, ко... Mar 20 2008, 10:26  kban Спасибо за ответ.
Цитата(alexQ @ Mar 20 2008,... Apr 2 2008, 07:54   kban Пересоздал буфер - вроде начал передавать.... Толь... Apr 4 2008, 05:27    de__ Цитата(kban @ Apr 4 2008, 08:27) А как мн... Apr 4 2008, 10:32     kban Цитата(de__ @ Apr 4 2008, 17:32) Как я по... Apr 8 2008, 05:35 de__ Цитата(kban @ Mar 20 2008, 13:12) Спасибо... Mar 20 2008, 10:41  alexQ а в 26-м четыре и все работает намного быстрее.
и ... Mar 20 2008, 13:12   de__ Цитата(alexQ @ Mar 20 2008, 16:12) а в 26... Mar 21 2008, 08:58    alexQ 26-е лучше конечно. а 24-е позиционируются как по... Mar 21 2008, 10:27 de__ Хм. На вопрос "а мне все здесь непонятно, рас... Apr 8 2008, 09:04 kban Прошу прощения, мож я чё не так написал...
Вопрос ... Apr 11 2008, 07:38 kban В интернете нашёл хорошую ссылочку - http://www.co... Apr 15 2008, 04:48 kban И снова здравствуйте. Сделал приложение, которое п... Apr 25 2008, 04:27 sobr По этому кусочку кода понять что то сложно, покажи... Apr 25 2008, 06:41 kban И ещё - в V24CtrlHandler на событие ADL_FCM_EVENT_... Apr 25 2008, 06:04 sobr Попробуйте так...
Кодvoid AtStartHandler (adl_... Apr 25 2008, 09:18 kban Спасибо большое за ответы! Буду работать дальш... Apr 28 2008, 05:36 sobr Цитата(kban @ Apr 28 2008, 12:36) Ещё воп... Apr 28 2008, 06:41 kban И снова здравствуйте, уважаемые форумчане. Вопрос ... Apr 30 2008, 06:04 kban И снова здраствуйте. Подскажите пожалуйста команду... May 8 2008, 04:41 sobr Цитата(kban @ May 8 2008, 11:41) И снова ... May 8 2008, 05:17  kban Цитата(sobr @ May 8 2008, 12:17) Кодadl_a... May 8 2008, 06:43   sobr Цитата(kban @ May 8 2008, 13:43) А другие... May 8 2008, 07:29    kban А тогда (извиняюсь, мож я чё не понял...) какой см... May 8 2008, 07:35     sobr Цитата(kban @ May 8 2008, 14:35) А тогда ... May 8 2008, 08:07 kban Спасибо) May 8 2008, 05:42 kban Пробовал разобраться с примерами GPS-приложений - ... May 14 2008, 05:34 kban Или хотя бы последовательность действий (команд) д... May 16 2008, 05:50 kban И снова здравствуйте! Кто-нибуль сталкивался с... Jun 17 2008, 06:03 sobr Не поделитесь этим примером? Jun 17 2008, 06:14 kban Вот пример вейвкома Jun 17 2008, 06:54 sobr Цитата(kban @ Jun 17 2008, 13:54) Вот при... Jun 17 2008, 07:28 kban Дайте мыло - вышлю... чтото не выкладывается файл.... Jun 17 2008, 08:00 sobr Цитата(kban @ Jun 17 2008, 15:00) Дайте м... Jun 18 2008, 07:57 kban Разобрался с перепрошивкой - всё заработало. Тепер... Jun 18 2008, 05:51 sobr Цитата(kban @ Jun 18 2008, 12:51) Разобра... Jun 19 2008, 06:58 ArtemTom Где можно скачать OpenAT?
У меня есть Open_AT_SDK_... Jun 24 2009, 04:43 bronepoezd OpenAT один) есть разный версии) после установки в... Jun 24 2009, 05:44 ArtemTom Ну понятно что один, а какая версия нужна мне для ... Jun 24 2009, 05:47 bronepoezd команда ati3 вообще z .pf. m2m studio для отладки ... Jun 24 2009, 05:51 ArtemTom Выдает на ATI3 WAVECOM MODEM MULTIBAND 900E 1800... Jun 24 2009, 06:02 bronepoezd это не версия прошивки) мб просто ati модема нет п... Jun 24 2009, 06:06 andrewlekar Согласен, дурная вещь. В свежих версиях многое поп... Jan 11 2011, 02:26
