> Microblaze+Gigabit Ethernet+S3, EDK 9.2
Serg`
сообщение May 16 2008, 07:18
Пользователь №: 28 668
Доброе время суток!!
Сразу к делу! У меня есть плата с гигабитным Ethernet контроллером и спартаном 3 на 4 млн. вентилей! Так же есть EDK 9.2. При создании проэкта я выбрал себе в качестве Ethernet модуля - Hard_Ethernet_MAC так как Ethernetlight не потдерживает Gigabit Ethernet и протакол GMII, но ни что не дается даром и при имплементации выдался след лог
Checking expanded design ...
ERROR:NgdBuild:604 - logical block
   'Hard_Ethernet_MAC/Hard_Ethernet_MAC/I_RX0/I_RX_STATUS_FIFO' with type
   'hard_ethernet_mac_wrapper_sync_fifo_v5_0_3' could not be resolved. A pin
   name misspelling can cause this, a missing edif or ngc file, or the
   misspelling of a type name. Symbol
   'hard_ethernet_mac_wrapper_sync_fifo_v5_0_3' is not supported in target
   'spartan3'.
   'Hard_Ethernet_MAC/Hard_Ethernet_MAC/I_RX0/I_RX_FIFO' with type
   'hard_ethernet_mac_wrapper_sync_fifo_v5_0_4' could not be resolved. A pin
   'hard_ethernet_mac_wrapper_sync_fifo_v5_0_4' is not supported in target
   'spartan3'.
   'Hard_Ethernet_MAC/Hard_Ethernet_MAC/I_RX0/I_RX_TEMAC_IF/I_RX_CL_IF/I_RX_CLIE
   NT_FIFO' with type 'hard_ethernet_mac_wrapper_async_fifo_v6_1_2' could not be
   resolved. A pin name misspelling can cause this, a missing edif or ngc file,
   or the misspelling of a type name. Symbol
   'hard_ethernet_mac_wrapper_async_fifo_v6_1_2' is not supported in target
   'spartan3'.
   'Hard_Ethernet_MAC/Hard_Ethernet_MAC/I_TX0/I_TX_TEMAC_IF/I_TX_CL_IF/I_TX_CLIE
   NT_FIFO' with type 'hard_ethernet_mac_wrapper_async_fifo_v6_1_1' could not be
   'hard_ethernet_mac_wrapper_async_fifo_v6_1_1' is not supported in target
   'spartan3'.
   'Hard_Ethernet_MAC/Hard_Ethernet_MAC/I_TX0/I_TX_CSUM_FIFO' with type
   'hard_ethernet_mac_wrapper_sync_fifo_v5_0_1' could not be resolved. A pin
   'hard_ethernet_mac_wrapper_sync_fifo_v5_0_1' is not supported in target
   'spartan3'.
   'Hard_Ethernet_MAC/Hard_Ethernet_MAC/I_TX0/I_TX_FIFO' with type
   'hard_ethernet_mac_wrapper_sync_fifo_v5_0_2' could not be resolved. A pin
   'hard_ethernet_mac_wrapper_sync_fifo_v5_0_2' is not supported in target
   'spartan3'.
под is not supported in target 'spartan3' я понял не совместимость со spartan3. Так как же мне решить эту проблему подскажите!!!
Зарание спасибо!!
Serg`
сообщение May 16 2008, 10:18
Понятно тоесть остается либо менять плис (что почти не реально), либо ждать выхода нового варианта ядра, либо забыть про гигабитный канал - так наверное и придется сделать!! 05.gif
bms
сообщение May 16 2008, 20:11
Пользователь №: 7 545
Да вы чё, ребята! Спартан-3 достаточно мощный кристалл для гигабита!
Как раз сейчас именно на этом кристалле доделываю проект с гигабитным эзернетом. Гигабит уже вовсю работает! Мало того - он уже поучаствовал в "связьэкспоком"! Остались еще мелкие недоделки - но совсем ерундовые.
Проект собран на кристалле XC3S400-4FT256 - как видите довольно скромный кристалл и по ресурсам и по скорости (на самом деле хватило бы и 200-го).
Никакого микроблейза там конечно нет - слабоват он для гигабита НА ЛЮБОМ КРИСТАЛЛЕ. Если Вам обязательно нужен готовый контроллер для гигабитного эзернета - то нужен кристалл с аппаратным PowerPC, читайте внимательно соответствующие XAPP-ы, там все написано.
Я сделал гигабит исключительно на логике, реализовал протоколы IP, UDP, ARP, ICMP. Для этого совсем необязательно использовать готовые контроллеры типа микроблейза.
RSS Текстовая версия Сейчас: 11th August 2025 - 17:52
Страница сгенерированна за 0.02158 секунд с 7
