> Описание DxD-Exp command line tools, где можно почитать?
cioma
сообщение May 20 2008, 07:15
Из: Беларусь
Пользователь №: 65
Подскажите, пожалуйста, есть ли где-нибудь список command line tools в DxD-Exp, с описанием для чего каждая из них предназначена?
Александр Карась
сообщение May 22 2008, 08:33
Из: Minsk, Belarus
Пользователь №: 37 626
Это???:
-A-
a0size -- Change the sheet size.
a1size -- Change the sheet size.
a2size -- Change the sheet size.
a3size -- Change the sheet size.
a4size-- Change the sheet size.
adistance-- Change the avoidance distance.
ainvis -- Make the attribute invisible.
Align – align selected components to a side of the window
annooff -- Turn off annotation.
annoon -- Turn on annotation.
anvis-- Make the attribute name visible.
aoff-- Turn off attribute visibility.
aon-- Turn on attribute visibility.
applynicknames
arc-- Draw and arc.
aroute-- Change to avoidance routing.
array-- Create an array.
arrowson -- Turn on pintype arrows
arrowsoff -- Turn off pintype arrows
asize-- Change the sheet size.
attr-- Add attribute text.
avis-- Make the attribute visible.
avvis-- Make the attribute value visible.
-B-
bannotate-- Change to annotation block.
bb -- Modify bounding box
bcomposite-- Change to composite block
bcopy-- Copy to the buffer.
bcut-- Cut to the buffer.
bmodule-- Change to module block.
boff -- Turn off the border
bon-- Turn on the border
box-- Draw a box
bpaste-- Paste from the buffer
bpin-- Change to a pin block.
bsize-- Change the sheet size.
bus-- Draw a bus.
-C-
cattribute-- Change properties for all attributes.
cb- change border.
ccomp-- Change component
chgattr-- Change properties for selected attribute
chglabel-- Change selected label.
chgtext-- Change selected text
cinst-- Update pin numbers
circle-- Draw a circle.
component -- Add a component.
color-- Change color
copy-- Copy object
csize-- Changes the sheet size.
ctoff-- Toggle text off
cton -- Toggle text on.
cuapply – Apply symbol updates to component(s).
cucheck – Check symbol and component for update compliance.
cuclear – Clear out-of-date highlights and mark as compliant.
cunumbers – Promote symbol numbers to component(s) from the symbol.
cureposattrs – Reposition component attribute(s) to match the relative position from the symbol.
cycle -- Automatically instantiate next specialized pin on the list.
-D-
dbevoff-- Turn off verbose error.
dbevon-- Turn on verbose error.
defshoff - Turn off default sheet borders.
defshon - Turn on default sheet borders.
defsh1off - Turn off use of Sheet 1 border for underlying schematics.
defsh1on - Turn on use of Sheet 1 border for underlying schematics.
defshfix - Toggle to non-configurable default sheet border.
defshcfg - Toggle to user-configurable default sheet border.
delete-- Delete object.
directory-- List schematics and symbols
dirsch-- List schematics
dirsym-- List symbols
doff-- Toggle continuous object display off
don-- Toggle continuous object display on.
dsize-- Change the sheet size.
-E-
esize-- Change the sheet size.
-F-
fcloseall – Close all open schematics and symbols
full-- Show full view.
-G-
global-- Change to global scope.
goff-- Toggle grid off.
gon-- Toggle grid on.
gspace-- Change grid spacing
-H-
hoff-- Toggle header off.
hon-- Toggle header on
-I-
ib - Insert border
in -- Zoom in.
-L-
label -- Add a label.
line -- Draw a line.
linvis-- Make label invisible
loff-- Turn off display of all labels.
local-- Change to local scope.
lon -- Turn on display of all labels.
longstrings -- Search for strings greater than 127 characters.
lsense-- Invert label sense.
lvis-- Make label visible.
-M-
move -- Move selected objects
-N-
nainv-- Make new attributes invisible
nanv-- Make new attribute names visible.
narray -- Automatically complete adding nets to a bus.
navis-- Make new attributes visible.
navvis-- Make new attribute values visible.
name-- Change the attribute name
net -- Draw a net.
noff-- Toggle display of internal names off.
non-- Toggle display of internal names on.
-O-
o1 -- Set the origin point for text.
o2 -- Set the origin point for text.
o3 -- Set the origin point for text.
o4 -- Set the origin point for text.
o5 -- Set the origin point for text.
o6 -- Set the origin point for text.
o7 -- Set the origin point for text.
o8 -- Set the origin point for text.
o9 -- Set the origin point for text.
oatsdetail -- Give information on OATs.
oattribute -- Add an occurrence attribute (OAT) to the selected object.
odetail-- Give information of objects.
oroute-- Change to orthagonal routing
out-- Zoom out.
-P-
pin -- Draw a pin.
poff-- Turn off pin numbers
pon -- Turn on pin numbers.
Pop -- Move up in the hierarchy.
promote-- Promote symbol attributes
psch -- Push to the underlying schematic.
Psh -- Push to the next sheet.
psense-- Toggle the sense of a pin.
psheet-- Push to a given sheet.
psym-- Push to the corresponding symbol for a schematic.
-R-
reflect-- Reflect an object around an axis.
refresh-- Refresh the screen.
read-- Refresh memory with the active block.
reread-- Reread all data in memory.
roff-- Turn off display of REFDES
ron-- Turn on display of REFDES
rotate-- Rotate an object.
run -- Run a script.
-S-
sattr-- Select attribute
save-- Write to disk
savepin-- Write PINORDER to file.
scale-- Change object size
schematic -- Open a schematic.
scomp-- Select component
sdistance-- Define selection distance
size-- Change size of textual data
slabel-- Select label
slot-- Change component slot.
sname-- Select object by name.
snap – Align schematic objects to grid
soff-- Turn off snap-to-pin
son-- Turn on snap-to-pin.
sortoff-- Turn off alphabetic name sorting.
sorton-- Turn on alphabetic name sorting.
sroute-- Change to straight routing
stext-- Select text string.
stretch-- Stretch object.
string-- Change string.
stub-- Add net stubs
svalue-- Select object by value
symbol-- Open a symbol
-T-
text-- Add text.
threshold-- Change text display threshhold.
toff-- Turn off text visibility.
ton-- Turn on text visibility.
-U-
ubat - Update border attributes
undo-- Undo change.
uoff-- Turn off unique labeling
uon-- Turn on unique labeling.
-V-
value-- Change attribute value.
voff-- Turn off simulation value visibility
von-- Turn on simulation value visibility.
-W-
wclose-- Close active drawing.
write-- Save and check drawing.
writinit -- Write to viewdraw.ini
wte--Open text editor.
-Z-
zoom-- Zoom in on specified section.
zselect-- Zoom in on selected section.
zsize-- Change the sheet size.
cioma
сообщение May 22 2008, 08:57
Из: Беларусь
Пользователь №: 65
нет, меня интересует описание утилит (программ) для манипуляции данными в составе пакета, а не команды внутри DxD. В общем то основное нашел сам:
http://electronix.ru/forum/index.php?showtopic=48016
fill
сообщение May 22 2008, 09:14
Из: КП Две Поляны
Пользователь №: 512
Под "списком задач" я понимал задачи разработки, под каждую задачу есть свой редактор и у каждого редактора есть свой набор внешних утилит - по указанной ссылке утилиты для топологического редактора, для схемного свой набор и т.д. Если поискать в хелпе на конкретный редактор, то можно встретить и ссылки на его утилиты.
А вообще, по нормальному, возмите функции Automation и напишите сразу свои утилиты, которые будут напрямую из базы выбирать нужную информацию и выдавать в нужном вам виде.
www.megratec.ru
cioma
сообщение May 22 2008, 09:26
Из: Беларусь
Пользователь №: 65
Цитата(fill @ May 22 2008, 13:14) *
...А вообще, по нормальному, возмите функции Automation и напишите сразу свои утилиты, которые будут напрямую из базы выбирать нужную информацию и выдавать в нужном вам виде.
Согласен, только для этого сначала надо найти программера, т.к. у самого просто нет времени изучать smile.gif .
RSS Текстовая версия Сейчас: 8th August 2025 - 21:41
Страница сгенерированна за 0.01396 секунд с 7
