> какие-то проблемы с mmc, при загрузки видно что ядро видит, но в /dev нету
_chaos_
сообщение Sep 12 2008, 09:48
Пользователь №: 37 653
День добрый!
столкнулся с проблемой. при загрузке ядра видно что определиась SD карточка
mmc0: host does not support reading read-only switch. Assuming write-enable.
mmc0: new SD card at address 0002
mmcblk0: mmc0:0002 00000 994816KiB
mmcblk0:<7>mmc0: starting CMD18 arg 00000000 flags 000000b5
но при просмотре /dev ничего похожего нет sad.gif
где собака зарыта?
Linux version 2.6.24 (chaos@penguin) (gcc version 4.2.4) #7 Fri Sep 12 15:25:12 YEKST 2008
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: Atmel AT91SAM9260-EK
Memory policy: ECC disabled, Data cache writeback
Clocks: CPU 198 MHz, master 99 MHz, main 18.432 MHz
CPU0: D VIVT write-back cache
CPU0: I cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets
CPU0: D cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: root=/dev/ram rw console=ttyS0,115200,mem=64M initrd=0x22500000,4M
AT91: 96 gpio irqs in 3 banks
PID hash table entries: 256 (order: 8, 1024 bytes)
console [ttyS0] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 58544KB available (1948K code, 171K data, 104K init)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 64 bytes
NET: Registered protocol family 16
SCSI subsystem initialized
NET: Registered protocol family 2
Time: pit clocksource has been installed.
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Freeing initrd memory: 4096K
io scheduler noop registered
io scheduler anticipatory registered (default)
atmel_usart.0: ttyS0 at MMIO 0xfefff200 (irq = 1) is a ATMEL_SERIAL
atmel_usart.1: ttyS1 at MMIO 0xfffb0000 (irq = 6) is a ATMEL_SERIAL
atmel_usart.2: ttyS2 at MMIO 0xfffb4000 (irq = 7) is a ATMEL_SERIAL
RAMDISK driver initialized: 16 RAM disks of 32768K size 1024 blocksize
ssc ssc.0: Atmel SSC device at 0xc4820000 (irq 14)
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
Driver 'sd' needs updating - please use bus_type methods
block2mtd: version $Revision: 1.30 $
i2c /dev entries driver
i2c-gpio i2c-gpio: using pins 55 (SDA) and 56 (SCL)
at91sam9_wdt: invalid timeout (must be between 1 and 16)
TCP cubic registered
NET: Registered protocol family 17
RAMDISK: Compressed image found at block 0
VFS: Mounted root (ext2 filesystem).
Freeing init memory: 104K
p1
Initializing random number generator... done.
_chaos_
сообщение Sep 12 2008, 11:17
Цитата(_chaos_ @ Sep 12 2008, 12:48) *
День добрый!
где собака зарыта?
проблемы исчезли - сделал udev -s
Тема закрыта!
RSS Текстовая версия Сейчас: 23rd August 2025 - 22:37
Страница сгенерированна за 0.01376 секунд с 7
