> AT91RM9200 + Angstron linux, консоль?
Dron_Gus
сообщение Oct 18 2008, 11:43
Пользователь №: 1 861
Собрал сабжевый линух. Собрал ядро. Залил rootfs на внешний винт. Подключил его к rainbow. Ядро загружается, монтирует корневой раздел и останавливается на Freeing init memory: 100K. Явно не зватает записи в inittab для запуска консоли. Может кто добрый подкинет свой inittab?
Собственно лог:
io scheduler noop registered
io scheduler anticipatory registered (default)
atmel_usart.0: ttyS0 at MMIO 0xfefff200 (irq = 1) is a ATMEL_SERIAL
atmel_usart.1: ttyS1 at MMIO 0xfffc4000 (irq = 7) is a ATMEL_SERIAL
usbcore: registered new interface driver ub
eth0: Link now 100-FullDuplex
eth0: AT91 ethernet at 0xfefbc000 int=24 100-FullDuplex (12:23:34:45:56:67)
eth0: Micrel KS8721 PHY
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
Driver 'sd' needs updating - please use bus_type methods
SCSI Media Changer driver v0.25
Driver 'ch' needs updating - please use bus_type methods
physmap platform flash device: 00200000 at 10000000
physmap-flash physmap-flash.0: map_probe failed
at91_cf: irqs det #64, io #0
usbmon: debugfs is not available
at91_ohci at91_ohci: AT91 OHCI
at91_ohci at91_ohci: new USB bus registered, assigned bus number 1
at91_ohci at91_ohci: irq 23, io mem 0x00300000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usb usb1: Product: AT91 OHCI
usb usb1: Manufacturer: Linux 2.6.24-gentoo-r4 ohci_hcd
usb usb1: SerialNumber: at91
Initializing USB Mass Storage driver...
usb 1-1: new full speed USB device using at91_ohci and address 2
usb 1-1: configuration #1 chosen from 1 choice
usb 1-1: Product: USB to ATA/ATAPI Bridge
usb 1-1: Manufacturer: JMicron
usb 1-1: SerialNumber: 222222222222
usb 1-2: new low speed USB device using at91_ohci and address 3
usb 1-2: device descriptor read/64, error -62
usb 1-2: new low speed USB device using at91_ohci and address 4
usb 1-2: new low speed USB device using at91_ohci and address 5
usb 1-2: device not accepting address 5, error -62
usb 1-2: new low speed USB device using at91_ohci and address 6
usb 1-2: device not accepting address 6, error -62
scsi0 : SCSI emulation for USB Mass Storage devices
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver libusual
udc: at91_udc version 3 May 2006
mice: PS/2 mouse device common for all mice
at91_rtc at91_rtc: rtc core: registered at91_rtc as rtc0
AT91 Real Time Clock driver.
i2c /dev entries driver
AT91 Watchdog Timer enabled (5 seconds, nowayout)
TCP cubic registered
NET: Registered protocol family 1
NET: Registered protocol family 17
at91_rtc at91_rtc: setting system clock to 1998-01-01 00:00:17 UTC (883612817)
Waiting 20sec before mounting root device...
scsi 0:0:0:0: Direct-Access     Maxtor 2 X3JE             1PB0 PQ: 0 ANSI: 2 CCS
sd 0:0:0:0: [sda] 39102336 512-byte hardware sectors (20020 MB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Assuming drive cache: write through
sda: sda1
sd 0:0:0:0: [sda] Attached SCSI disk
sd 0:0:0:0: Attached scsi generic sg0 type 0
EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
VFS: Mounted root (ext2 filesystem).
А вот мой inittab:
# /etc/inittab: init(8) configuration.
# $Id: inittab,v 1.91 2002/01/25 13:35:21 miquels Exp $
# The default runlevel.
# Boot-time system configuration/initialization script.
# This is run first except when booting in emergency (- B) mode.
si::sysinit:/etc/init.d/rcS
# What to do in single-user mode.
~~:S:wait:/sbin/sulogin
# /etc/init.d executes the S and K scripts upon change
# of runlevel.
# Runlevel 0 is halt.
# Runlevel 1 is single-user.
# Runlevels 2-5 are multi-user.
# Runlevel 6 is reboot.
l0:0:wait:/etc/init.d/rc 0
l1:1:wait:/etc/init.d/rc 1
l2:2:wait:/etc/init.d/rc 2
l3:3:wait:/etc/init.d/rc 3
l4:4:wait:/etc/init.d/rc 4
l5:5:wait:/etc/init.d/rc 5
l6:6:wait:/etc/init.d/rc 6
# Normally not reached, but fallthrough in case of emergency.
z6:6:respawn:/sbin/sulogin
S:2345:respawn:/sbin/getty 115200 ttyS0
Если сверху смотреть, то сбоку кажется, что снизу ничего не видно.
Dron_Gus
сообщение Dec 9 2008, 14:47
Подебажил немного ядро через jtag. Бэктрейсом удалось выяснить что ядро никуда не проваливается и крутиться в idle цикле. Init запускается нормально. Но толи сразу выходит, то ли никогда не получает управление. Как дальше дебажить не знаю.
- Dron_Gus   AT91RM9200 + Angstron linux   Oct 18 2008, 11:43
- - dch   вообщето, она помоему сначала пишет что запускает ...   Oct 19 2008, 19:50
- - MTh   Так вот строчка которая вешает прогу для работы с ...   Oct 20 2008, 00:40
- - Dron_Gus   2 dch, спасибо, гляну. Как я не догадался. 2 MTh...   Oct 20 2008, 10:19
|- - Alex03   Может не в тему, но иногда очень полезна опция ядр...   Oct 24 2008, 09:59
- - amw   Цитата(Dron_Gus @ Oct 18 2008, 14:43) Соб...   Oct 24 2008, 14:11
- - Dron_Gus   Спасибо за комментарии. Попытаюсь разобраться. Пок...   Oct 25 2008, 10:15
- - Dron_Gus   Поковырялся тут. init=/bin/bash не особо помогает....   Oct 29 2008, 20:58
- - Dron_Gus   Одну из проблемм выявил и решил. Angstrom собирает...   Nov 1 2008, 14:29
|- - dch   Цитата(Dron_Gus @ Nov 1 2008, 17:29) Опят...   Nov 1 2008, 22:56
- - Dron_Gus   Нет. Через некоторое время после Freeing init memo...   Nov 2 2008, 09:41
|- - amw   Цитата(Dron_Gus @ Nov 2 2008, 11:41) Нет....   Nov 3 2008, 15:02
- - Dron_Gus   Вообще фигня какая-то. У меня на плате стоит 64 ме...   Nov 2 2008, 12:43
- - Dron_Gus   Извиняюсь, если я не так выразился. Сам только осв...   Nov 3 2008, 16:15
|- - dch   а где вы этот дистрибутив ? Чтото захотелось посм...   Nov 3 2008, 17:24
- - Dron_Gus   http://www.angstrom-distribution.org/ описалово вс...   Nov 3 2008, 17:30
- - Dron_Gus   Цитата(amw @ Nov 3 2008, 18:02) Если все ...   Nov 3 2008, 22:46
|- - AVR   Цитата(Dron_Gus @ Nov 4 2008, 02:46) Посм...   Nov 3 2008, 23:47
|- - amw   Цитата(Dron_Gus @ Nov 4 2008, 00:46) Ском...   Nov 4 2008, 08:52
- - Dron_Gus   2 AVR, фишка данного дистра в простоте установки (...   Nov 4 2008, 11:34
|- - amw   Цитата(Dron_Gus @ Nov 4 2008, 13:34) 1. +...   Nov 4 2008, 13:32
- - Dron_Gus   Цитата(amw @ Nov 4 2008, 16:32) А что так...   Nov 4 2008, 23:31
|- - amw   Цитата(Dron_Gus @ Nov 5 2008, 01:31) Само...   Nov 5 2008, 09:14
- - Dron_Gus   Спасибо. Вечером дома попробую. Пока читал про за...   Nov 6 2008, 14:15
- - Dron_Gus   1. да 2. да 3. ничего не изменилось. 4. отдельный...   Nov 7 2008, 20:13
- - AVR   Удалось запустить? Я вот тоже с этим Angstrom бью...   Dec 27 2008, 23:59
|- - dch   Цитата(AVR @ Dec 28 2008, 02:59) беда... ...   Dec 28 2008, 01:32
- - Dron_Gus   Удалось собрать, запустить и работает на 9260. На ...   Dec 28 2008, 21:08
|- - AVR   Цитата(Dron_Gus @ Dec 29 2008, 00:08) Выл...   Dec 28 2008, 21:27
||- - AVR   Нашел немного времени, попробовал собрать этот Ang...   Feb 18 2009, 17:25
|- - sasamy   1 если есть рабочий linux на этой плате - загрузит...   Dec 29 2008, 23:48
|- - sasamy   Цитата(sasamy @ Dec 30 2008, 02:48) #cat ...   Dec 30 2008, 02:12
- - Dron_Gus   Вроде как, с ключами -jxvf   Dec 29 2008, 21:52
- - Dron_Gus   А остальное заработало? На какой железке испытывал...   Feb 18 2009, 22:43
- - AVR   Цитата(Dron_Gus @ Feb 19 2009, 01:43) А о...   Feb 19 2009, 08:23
RSS Текстовая версия Сейчас: 28th July 2025 - 02:43
