> Cadence OrCAD 16.0, !!!!!
Stariy Alex
сообщение Jun 16 2007, 16:01
Из: Berlin
Пользователь №: 16 605
Текст представления программы, чаще всего используемая для производства PCB, ИМХО, не нуждается в переводе
All OrCAD 16.0 products are now supported in Windows Vista™ Enterprise.
New Cadence OrCAD and PSpice Bundle!
Cadence OrCAD EE Designer Plus
OrCAD EE Designer Plus provides powerful schematic entry and simulation in one premium package. This competitively priced, complete front-end design solution includes:
OrCAD Capture schematic entry, the world's leading schematic capture tool
PSpice A/D for analog and mixed-signal simulation
PSpice advanced analysis capabilities—sensitivity analysis, optimization, Smoke (stress analysis), and Monte Carlo (yield analysis)—to automatically maximize the performance of circuits
For more information contact us at info@ema-eda.com or call 800-813-7494.
Cadence OrCAD Capture
Improved support for complex hierarchical designs, including better support for occurrence properties and externally referenced designs.
Support for placing and moving text and drawing objects on fine grid independent of connectivity objects
Enhancements to archiving adds an option to include PSpice models in the archive libraries which improves the performance of archived simulation profiles
Improved error messages and DRC engine
Cadence Help Online Documentation System replaces CDSDoc, providing faster invocation time, advanced search capabilities, and built-in viewing window
Usability enhancements and implementation of over 100 CCRs for improved quality and performance
Cadence OrCAD Capture CIS Option
Support for including mechanical parts and assemblies in standard component information system (CIS) Bill of Materials (BOM)
Better support for Japanese characters in CIS
Better BOM generation for non-English operating systems
Cadence PSpice A/D
Improved speed for power electronics designs, especially those using ABM if-then expressions, which will simulate up to 50x faster
CheckPoint Restart feature allows you to save the state of a transient simulation at specific times as CheckPoints. Prior to restarting, you can change component values, so if you’re not getting the results you want, you can tune your circuit without having to restart from the beginning. This is particularly useful for circuits that have a long startup time like a switch mode power supply. You can simulate once to reach steady state, tune the circuit to get the final result you want, and then simulate from the beginning to verify the full simulation. In this situation, CheckPoint Restart can be a significant time saver
Autoconvergence feature allows PSpice to automatically modify convergence options as necessary. This reduces the need for user interaction for problem circuits
Improved transient convergence. Adaptive iteration, improvements in the step time algorithm, and an improved switch model allow PSpice to converge on certain types of problem circuits
Run in resume mode accessible from graphical user interface (GUI)
Minimum step size recalculation
Tasks such as adding a trace, adding a plot, zooming the view, or adding a text label are now available using the right mouse button to display a context-sensitive menu in the Probe window
Probe window cursors now display X and Y coordinates on the status bar of the Probe window
Improved simulation speed for E and G device-based circuits
PSpice libraries have 120 new power devices. Updated vendor libraries include 290 new LED models
Cadence PSpice AA
PSpice Advanced Analysis support for legacy PSpice models. Traditional tolerance specifications can now be used by the Monte Carlo and Sensitivity tools. This includes the use of PDF custom distributions and device and lot tolerances
Cadence OrCAD PCB Designer (including OrCAD PCB Editor)
OrCAD Layout translator user interface opens from within OrCAD PCB Editor
Usability enhancements made within the display canvas and to the command structure
Redesigned color / visibility GUI
Enhancements made to the underlying graphics system, based on OpenGL graphics engine
Physical and spacing constraints incorporated in the Allegro constraint management system
Interactive and automatic controls for component fanout (pin escaping)
Context-sensitive editing paradigm built on selecting database objects first, followed by action command
Cadence OrCAD Layout
Support for GerbTool Version 15.0
Implementation of numerous CCRs for improved quality and performance
PS. Солдаты грянули ура - полки увидели Петра...
Сообщение отредактировал Stariy Alex - Jun 16 2007, 16:07
nextsid
сообщение Dec 9 2008, 00:49
Пользователь №: 369
NOLIC.COM очень хорошо крякает, что OrCAD, что SPB, и разных версий, и будете иметь не усечёнки по лицензиям. OrCAD на сегодня - это некоторые куски из SPB, но с другими именами. При NOLIC файл лицензий можно занулить, сервер лицензий не нужен (устанавливать не надо), да и не будет перехлёстов с FlexLM других CADов. Кстати, сейчас уже "ходит" 16.2 или нет ещё?
Смысл с NOLIC - она не за раз пропатчивает. Сначала надо определить все каталоги где имеются файлы .exe и .dll. Откройте консоль и запускайте по несколько раз в одном и том же каталоге, и по её сообщениям увидите когда пора остановиться. Если проскакивают ошибки, ещё раз запускайте. Далее переходите в другой каталог и аналогично. Можно сделать .bat-ник (.cmd-шник).
LSV
сообщение Dec 10 2008, 15:50
Пользователь №: 2 668
Ставил SPB 16.2. Пропатчивал всё ноликом и в System32 и во всех каталогах SPB.
SPB 16.2 запускается, но Spice работает в режиме Basic.
Если не трудно явите миру avi, где это работает в полном обьёме и подробную инструкцию по установке.
Просто многие говорят, что всё в моделировании работает, но никnо не выложил avi c подтверждением.
AlexN
сообщение Dec 10 2008, 16:08
Пользователь №: 200
сдается мне, что товарищ nextsid не замечает разницы между basic режимом pspice и остальными, вот и утверждает, что типа у него все работат (ведь запускается и симулит..). А все остальные видимо не умеют кнопки жать.
Короче, после нолика только basic pspice. И всегда так было во всех предыдущих версиях. Так что надо ждать Shooters, для 16.0 они сделали как надо..
- Stariy Alex   Cadence OrCAD 16.0   Jun 16 2007, 16:01
- - Yuri Potapoff   ЦитатаТекст представления программы, чаще всего ис...   Jun 16 2007, 17:06
|- - Stariy Alex   Цитата(Yuri Potapoff @ Jun 16 2007, 21:06...   Jun 17 2007, 17:25
|- - Прохожий   Цитата(Stariy Alex @ Jun 17 2007, 21:25) ...   Jun 17 2007, 19:06
- - Vinnetu   ЦитатаСолдаты грянули ура - полки увидели Петра......   Jun 17 2007, 16:58
- - vin   Ех, коллеги! Знаю также, что 15 числа сего ме...   Jun 18 2007, 15:12
|- - 98   Цитата(vin @ Jun 18 2007, 18:12) Ех, колл...   Jun 19 2007, 00:27
|- - 98   Цитата(vin @ Jun 18 2007, 18:12) Ех, колл...   Jun 29 2007, 21:37
- - prototype   Есть предложение: давайте сообщение о выходе проду...   Jun 18 2007, 18:07
|- - ikar77   Цитата(prototype @ Jun 18 2007, 21:07) Ес...   Jun 19 2007, 06:17
|- - Прохожий   Цитата(ikar77 @ Jun 19 2007, 10:17) Со...   Jun 19 2007, 08:02
|- - LSV   Цитата(Прохожий @ Jun 19 2007, 12:02) PSp...   Jun 19 2007, 10:20
|- - Прохожий   Цитата(LSV @ Jun 19 2007, 14:20) Ну я бы ...   Jun 19 2007, 10:37
|- - Прохожий   Большое спасибо за письмо, но мне это, к сожалению...   Jun 19 2007, 14:43
- - Vinnetu   ЦитатаЗнаю также, что 15 числа сего месяца официал...   Jun 19 2007, 05:46
|- - 98   Цитата(Vinnetu @ Jun 19 2007, 08:46) Подо...   Jun 23 2007, 16:40
- - Dmitrij_80   вроде неплохо выглядит. А чем обосновано Ваше мнен...   Jun 30 2007, 14:18
- - falling_stone   Кстати, о лекарстве. Старое, вроде, подходит.   Jul 1 2007, 06:50
|- - [sER]   Цитата(falling_stone @ Jul 1 2007, 09:50)...   Jul 1 2007, 15:19
|- - uniservis   Цитата(falling_stone @ Jul 1 2007, 09:50)...   Aug 1 2007, 10:38
- - arttab   что протол начал напоминать. Интерфейс не привычно...   Jul 2 2007, 03:41
- - khach   Кстати, лайоут из 16 никуда не делся- ставится, ра...   Jul 5 2007, 23:46
- - KiV   Кто уже поработал с пакетом - поделитесь впечатле...   Jul 7 2007, 12:36
|- - prototype   Цитата(KiV @ Jul 7 2007, 15:36) Кто уже п...   Jul 18 2007, 04:34
- - bezobraznic   Кто может и хочет, выложите плиз сабж!!...   Jul 15 2007, 10:57
- - KiV   Так облом два Гига качать, чтобы убедиться, что ст...   Jul 18 2007, 11:35
- - prototype   Понял, скачаю - попальпирую сам. Впечатления обеща...   Jul 19 2007, 19:15
- - uniservis   ed2k links spb16.0: ed2k://|file|Base_SPB160_wint...   Jul 31 2007, 16:03
|- - Volonter   Цитата(uniservis @ Jul 31 2007, 19:03) ed...   Aug 14 2007, 13:59
|- - uniservis   Цитата(Volonter @ Aug 14 2007, 16:59) А к...   Aug 15 2007, 08:53
|- - Volonter   Цитата(uniservis @ Aug 15 2007, 11:53) Ис...   Aug 16 2007, 10:25
|- - uniservis   Цитата(Volonter @ Aug 16 2007, 13:25) Да....   Aug 17 2007, 17:22
|- - Volonter   Цитата(uniservis @ Aug 17 2007, 20:22) То...   Aug 19 2007, 09:15
|- - uniservis   Цитата(Volonter @ Aug 19 2007, 12:15) У м...   Aug 19 2007, 21:03
|- - Volonter   Цитата(uniservis @ Aug 20 2007, 00:03) Ес...   Aug 20 2007, 10:17
- - ElectroNick   ed2k ссылка дана на OrCad 16.0 (входит ли он в нее...   Aug 28 2007, 18:08
|- - uniservis   Цитата(ElectroNick @ Aug 28 2007, 21:08) ...   Aug 29 2007, 13:47
- - ElectroNick   Скачал, и внутри архива ALLEGRO® SPB RELEASE 1...   Aug 29 2007, 13:52
- - Uree   Попробуйте ставить, там при установке можно выбрат...   Aug 29 2007, 15:15
|- - ElectroNick   Цитата(Uree @ Aug 29 2007, 19:15) Попробу...   Aug 29 2007, 15:48
- - Uree   А "раскрывать" плюсики никак? И почитать...   Aug 29 2007, 15:59
- - ElectroNick   Не то все это!Даже на orcad.com сказано, что O...   Aug 29 2007, 16:14
- - Krys   Подскажите, где кроме местного фтп и ослика можно ...   Aug 31 2007, 08:40
|- - Volonter   Цитата(Krys @ Aug 31 2007, 11:40) Подскаж...   Aug 31 2007, 11:40
|- - backa   Цитата(Krys @ Aug 31 2007, 11:40) Подскаж...   Sep 14 2007, 06:48
|- - sup-sup   Скачал ослом в пяти частях spb16 - а это не OrCAD....   Nov 5 2007, 12:03
- - Uree   А может дать а потом, после скачивания, быстренько...   Aug 31 2007, 08:50
|- - ElectroNick   Установил Orcad v16 & SPB v16, но все вычислен...   Aug 31 2007, 08:54
- - sera_os   У меня 15.7 столит ли качать новый? И еще, 3D вид ...   Sep 10 2007, 22:21
- - Mentor   Скачал быстро, но в архиве не нашел лекарства. Как...   Sep 13 2007, 19:12
- - ElectroNick   Тем что есть ты ее не выличишь, а покоцаешь.Патч n...   Sep 13 2007, 19:16
- - Krys   Попробуйте заглянуть в эту тему: http://electronix...   Sep 14 2007, 04:37
- - Uree   Ну не ограничивайте себя - SPB16 это Аллегро. Орка...   Nov 5 2007, 13:10
|- - itcit   Подскажите в чем проблема скачал с рапиды установи...   Nov 7 2007, 09:50
|- - Uree   Цитата(itcit @ Nov 7 2007, 12:50) ...нод3...   Nov 7 2007, 10:53
|- - itcit   Цитата(Uree @ Nov 7 2007, 13:53) А он и е...   Nov 7 2007, 11:45
- - Uree   Ну как - скачал, и записал на винт в известное мес...   Nov 7 2007, 11:49
- - Victor®   Здравствуйте! Я так и не понял - есть в приро...   Nov 21 2007, 09:50
- - Axel   .../upload/EDA/_Cadence_/Orcad16/   Nov 21 2007, 11:09
|- - sup-sup   Цитата(Axel @ Nov 21 2007, 15:09) .../upl...   Dec 1 2007, 18:54
- - Victor®   Здравствуйте! Поставил 16.0 под XP SP2. При п...   Dec 6 2007, 07:50
- - VladimirZ   Вы наверное не заменили RWUXThemeS.dll в windows/s...   Dec 6 2007, 15:23
|- - Victor®   Цитата(VladimirZ @ Dec 6 2007, 19:23) Вы ...   Dec 7 2007, 08:23
- - ElectroNick   Господа, наконец-то появился полнофункциональный п...   Dec 6 2007, 20:15
- - Designer56   nod32 ругается   Dec 7 2007, 03:19
|- - AlexN   Цитата(Designer56 @ Dec 7 2007, 09:19) no...   Dec 7 2007, 03:40
|- - SergM   Цитата(AlexN @ Dec 7 2007, 07:40) у меня ...   Dec 7 2007, 12:23
- - Designer56   Да, у меня тоже так- проверил. Значит, на сайте ви...   Dec 7 2007, 04:19
- - ElectroNick   Ссылку правил не я, а модератор, после чего файл о...   Dec 7 2007, 08:19
|- - Victor®   Цитата(ElectroNick @ Dec 7 2007, 12:19) С...   Dec 7 2007, 11:10
- - Designer56   Спасибо!   Dec 7 2007, 08:23
- - ElectroNick   ЦитатаПричина - патч не видит папки tools, browse ...   Dec 7 2007, 12:46
|- - Victor®   Цитата(ElectroNick @ Dec 7 2007, 16:46) 1...   Dec 7 2007, 14:00
- - ElectroNick   ЦитатаА чем это решение отличается от NOLIC.COM? Т...   Dec 7 2007, 15:05
|- - LSV   Цитата(ElectroNick @ Dec 7 2007, 18:05) Н...   Dec 4 2008, 17:03
- - bezobraznic   Заработал но так и не появились 1. New Parts Simul...   Dec 9 2007, 09:22
- - ElectroNick   Из файла лицензий удалить парграфы лицензий типа ...   Dec 9 2007, 16:12
- - bezobraznic   Cпасибо всё ок!!!   Dec 9 2007, 21:48
- - Kostos   А можно где нить взять оркад 16й? Я слово волшебно...   Dec 10 2007, 12:50
|- - bezobraznic   Цитата(Kostos @ Dec 10 2007, 16:50) А мож...   Dec 10 2007, 20:48
|- - Kostos   Цитата(bezobraznic @ Dec 10 2007, 23:48) ...   Dec 11 2007, 04:22
- - Designer56   Я вчера с трудом поставил 16.0. С трудом- потому ч...   Dec 11 2007, 06:27
- - bezobraznic   Layout Plus не работает там с лицензией лажа   Dec 11 2007, 07:01
- - Designer56   ЦитатаLayout Plus не работает там с лицензией лажа...   Dec 11 2007, 07:45
|- - bezobraznic   Цитата(Designer56 @ Dec 11 2007, 11:45) П...   Dec 11 2007, 08:45
- - Designer56   Точно. Не обратил внимание сначалаю Запускается La...   Dec 11 2007, 09:53
- - Designer56   Кстати, в соседней ветке про Оркад 16 обсуждается ...   Dec 11 2007, 11:24
- - ElectroNick   ЦитатаКстати, в соседней ветке про Оркад 16 обсужд...   Dec 11 2007, 19:57
- - Designer56   Layout Plus запускается, но в виде LayoutEE   Dec 12 2007, 03:37
- - ElectroNick   Designer56, ты как "эксперементируешь"?М...   Dec 12 2007, 14:08
- - prototype   Буду дома - попытаюсь вспомнить как я победил эту ...   Dec 13 2007, 10:54
- - Designer56   Никто не пробовал с помощью Cadence Switch Release...   Dec 13 2007, 11:27
- - kleruoi   Большая ли разница, если использовать версию 15.7 ...   Sep 29 2008, 19:30
- - kleruoi   Касаемо самой темы. Установил версию ORCAD 16 с ле...   Oct 1 2008, 11:06
- - kleruoi   bin\dxf2a.exe -> Original file not existed...   Oct 1 2008, 13:07
- - kleruoi   Где можно скачать компонент NCVHDL для ORCAD 16?   Oct 18 2008, 11:45
- - kleruoi   Вопрос относительно данного компонента NCVHDL оста...   Nov 7 2008, 13:26
RSS Текстовая версия Сейчас: 28th July 2025 - 15:32
Страница сгенерированна за 0.01436 секунд с 7
